How to reduce the code size of TF-M
After porting the application to sdk v2.4.0, I get the following error after compiling the code:
"opt/zephyr-sdk/arm-zephyr-eabi/bin/... /lib/gcc/arm-zephyr-eabi/12.2.0/... /... /... /... /arm-zephyr-eabi/bin/ld.bfd.exe: region `FLASH' overflow 47368 bytes"
The partitions I use are as follows:
flash_primary (0x100000 - 1024kB):
| 0x0: mcuboot (0xc000 - 48kB) |
| 0xc000: EMPTY_0 (0x4000 - 16kB) |
+---0x10000: mcuboot_primary (0x68000 - 416kB)-----+
+---0x10000: tfm_secure (0x40000 - 256kB)----------+
| 0x10000: mcuboot_pad (0x200 - 512B) |
+---0x10200: mcuboot_primary_app (0x67e00 - 415kB)-+
| 0x10200: tfm (0x3fe00 - 255kB) |
+---0x50000: tfm_nonsecure (0x28000 - 160kB)-------+
| 0x50000: app (0x28000 - 160kB) |
| 0x78000: mcuboot_secondary (0x68000 - 416kB) |
| 0xe0000: EMPTY_3 (0x8000 - 32kB) |
+---0xe8000: nonsecure_storage (0x6000 - 24kB)-----+
| 0xe8000: nvs_storage (0x6000 - 24kB) |
| 0xee000: EMPTY_2 (0x6000 - 24kB) |
+---0xf4000: tfm_storage (0x8000 - 32kB)-----------+
| 0xf4000: tfm_its (0x2000 - 8kB) |
| 0xf6000: tfm_otp_nv_counters (0x2000 - 8kB) |
| 0xf8000: tfm_ps (0x4000 - 16kB) |
| 0xfc000: EMPTY_1 (0x4000 - 16kB) |
otp (0x2f4 - 756B):
| 0xff8108: otp (0x2f4 - 756B) |
sram_primary (0x40000 - 256kB):
+---0x20000000: mcuboot_sram (0x16000 - 88kB)------+
+---0x20000000: sram_secure (0x16000 - 88kB)-------+
| 0x20000000: tfm_sram (0x16000 - 88kB) |
+---0x20016000: sram_nonsecure (0x2a000 - 168kB)---+
+---0x20016000: nrf_modem_lib_sram (0x7ce8 - 31kB)-+
| 0x20016000: nrf_modem_lib_ctrl (0x4e8 - 1kB) |
| 0x200164e8: nrf_modem_lib_tx (0x5800 - 22kB) |
| 0x2001bce8: nrf_modem_lib_rx (0x2000 - 8kB) |
| 0x2001dce8: sram_primary (0x22318 - 136kB) |
Only 160K bytes are reserved for app, TF-M uses 255K bytes of flash.  I only use secp256k1 crypto in my application, how do I configure TF-M to reduce the TF-M code size ?
  • Thank you very much, I will test it and get back to you as soon as possible.
    I set prj.conf::CONFIG_TFM_PROFILE_TYPE_MEDIUM=y, just like the example you shared above, but my TF-M code size did not decrease. This is the dynamic partition generation in my project:
    otp (0x2f4 - 756B):
    And i still get the message that the app code size is not enough.
    "arm-zephyr-eabi/bin/ld.bfd.exe: region `FLASH' overflowed by 47424 bytes"
  • Could you try setting this instead?
    CONFIG_PM_PARTITION_SIZE_TFM=0x2FE00
    Remember to regenerate your build (ie. delete the build folder) after making such a change.
    Håkon
  • Thanks, it worked and now TF-M only takes up 191KB!
    +---0x10000: tfm_secure (0x30000 - 192kB)----------+
    | 0x10200: tfm (0x2fe00 - 191kB) |
    +---0x40000: tfm_nonsecure (0x38000 - 224kB)-------+
    | 0x40000: app (0x38000 - 224kB) |
    otp (0x2f4 - 756B):
  • Happy to help out, glad to hear that it worked!
    Håkon
