[Zigbee] ZBOSS Fatal Error at init
Setup:
nrf52840DK (Zigbee Cordinator based on Zigbee Coordinator sample)
nrf52840DK (ZR)
NCS v2.4.1
I have encountered dangerous problem during development.
Device constantly reboots after calling zigbee_enable(). I was able to get the backtrace when that happens.
 Backtrace:
#0  zb_osif_abort () at ncs_v2.4.1/nrf/subsys/zigbee/osif/zb_nrf_platform.c:578
#1  0x000a6624 in zb_error_raise ()
#2  0x00096524 in zb_nvram_load ()
#3  0x00099602 in zb_zdo_dev_init ()
#4  0x00099c12 in zb_zdo_start_no_autostart ()
#5  0x0006bd42 in zboss_thread at ncs_v2.4.1/nrf/subsys/zigbee/osif/zb_nrf_platform.c:347
It seems that there was a problem with reading the data from zboss_nvram partition.
To reproduce that you should turn off the DK during joining process exactly when device gets its credentials/reporting configuration etc.
The goal is to interrupt device by turning it off when it processes data which must be stored in the device zboss_nvram flash partition.
It seems like ZBOSS does not have any recovery mechanism or implemented one is not sufficient to deal with invalid data in zboss_nvram partition.
On my end I have implemented a ZBOSS safe startup mechanism which simply checks if ZBOSS initialize successfully, otherwise zboss_nvram is erased recovering the device. Maybe do you have any ideas how can I protect device from such scenario ? like cutting of the power/rebooting during processing critical data.
If it matters my device uses POF(Power-on failure) feature.
Thanks in advance,
Pawel
