Bootloader DFU transport - transfer of init packet
I'm implementing flashing modul, which will be running on external mcu. Therefore for the very 1st step, I have captured traffic while performing dfu on PCA10040 via nrf util from PC. Now I'm wondering of the meaning of transferred bytes, since it's not matching to decription in sdk.
First captured packet is: 0x09 0x01 0xc0; according to dfu transport shall be 0x02 0x00 0x01..
After response 0x60 0x09 0x01 0x01 0xc0, similar packet is sent 0x02 0x00 0x00 0xc0 and finally get response set prn success 0x60 0x02 0x01
Then Get MTU is following... and then I get a bit different response 0x60, 0x07, 0x01, 0x83, 0x00, 0xc0 --->how many bytes are use to represent MTU?
Now I'm wondering if there is any document/manual with detailed description of transfered bytes (somehow I didn't find it), or is there any existing code/library for performing dfu, that could be used for implementing flashing procedure on external mcu via uart.
Thank you in advance.
Matej
  • Hello Vidar,
    This is the case why I was wondering for protocol documentation and request sequence...
    As mentioned I'm implementing dfu flashing on external MCU via UART. Therefore I'm interested in packets description at least a list of min required requests.
    I have checked about following commands; ping, get mtu, and set receipt notification and I think its everything clear...
    Now I'm wondering of usage of select, create, write and execute... Could you please provide me a bit info how app/SD is selected, is there option to define also start address?
    Thank you for support.
    Matej
  • Hello Matej,
    The content of the update is transparent to the sender. It is the bootloader that know where to place the image in flash based on the update type specified in the transferred init command (the *.dat file). The DFU controller cannot instruct the DFU target to place the image at a specific address.
    Vidar
  • Hello Vidar,
    I have managed to transfer image and it boots up if I have flashed only bootloader and softdevice. If I have also application, then always old application boots up.
    If I refer to picture above - I'm at the state in the middle column... Is there any command that needs to be sent over to actually switch/replace old application with the new one?
    Thank you and best regards,
    Matej
  • Hello Matej,
    The new app should be activated automatically after the last Execute request. I recommend you enable logging over RTT from the target bootloader to see if there are any errors reported during the pre- or post-validation step.
    Vidar
  • Hi Vidar,
    I was a bit to fast with reseting and didn't check for execute response; and then i noticed that there is hash error... now I have reworked quite some things... and when I'm sending 64 byte long chunks, now I'm getting an error that allocating buffer has failed.
    Any idea? I'm attaching bootloader log:
    <info> nrf_dfu_serial_uart: Allocated buffer 20000530
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0004EFC0, src=0x2000063C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0004EFC0, pending 0
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <info> nrf_dfu_serial_uart: Allocated buffer 20000638
    <error> nrf_dfu_req_handler: Write request too long
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x3
    <warning> nrf_dfu_serial: DFU request completed with result: 0x3
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:8192, CRC:0x9C7914AB
    <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    <debug> app: timer_stop (0x20000028)
    <debug> app: timer_activate (0x20000028)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (data)
    <debug> nrf_dfu_req_handler: crc = 0x9C7914AB, offset = 0x2000, max_size = 0x1000
    <debug> nrf_dfu_serial: Sending Response: [0x6, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0004F000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0004F000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00002000, CRC: 0x9C7914AB
    <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    <error> nrf_dfu_serial_uart: Failed to allocate buffer
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0004F000, src=0x2000063C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0004F000, pending 0
    <info> nrf_dfu_serial_uart: Allocated buffer 20001DF0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0004F040, src=0x2000063C, len=129 bytes), queue usage: 1
    <error> app: Received a fault! id: 0x00004002, pc: 0x00000000, info: 0x2003FF48
    Thank you in advance!
    BR,
    Matej
