Handle factory reset from API
I am trying a network joiner session from the API. First I do a factory reset to clear any previous network data in memory. However when I run the following code, it seems like the program reset
as well, which prevents the rest of my code from being executed.
// this is a custom cli command
otError cli_prov_joiner (void *aContext, uint8_t aArgsLength, char *aArgs[]) {
	otError error;
	otJoinerDiscerner discerner;
	#define pskd "J01NME"
	memset(&discerner, 0, sizeof(discerner));
	discerner.mValue = 0x1234;	// this will be replaced by aArgs[1]
	discerner.mLength = 16;
	otInstance *instance = openthread_get_default_instance();
	if (instance == NULL) {
		otCliOutputFormat ("get instantace  error");
		return OT_ERROR_FAILED;
	otCliOutputFormat ("\n\r factory reset ");
	otInstanceFactoryReset(instance);
    // following  doesnt get a chance to execute
	otCliOutputFormat ("done factory reset");
	error = otJoinerSetDiscerner (instance,  &discerner);
	if (error != OT_ERROR_NONE) {
		otCliOutputFormat ("joiner descerner set error");
		return (error);
	otCliOutputFormat ("\n\r ifconfig up ");
	error = otIp6SetEnabled(instance, true);	// ifconfig up
		otCliOutputFormat ("ifconfig up error");
		return (error);
	error = otJoinerStart(instance,
							pskd,
							NULL,
							NULL,
							NULL,
							NULL,
							NULL,
							joiner_callback,
							NULL);
		otCliOutputFormat ("joiner start error");
		return (error);
	return (OT_ERROR_NONE);
I have tried following instead of factory reset, but the joining fails.
1. ifconfig down
2. thread stop
3. panid set to 0xffff
4. set joiner discerner to 1234/16
4. ifconfig up
5. joiner start "J01NME"
What can I do?
Cheers,
Kaushalya
