I see that this is your first case so I will give you some input as to what we would like to see w.r.t information in a general Devzone ticket.
For us to be able to help you it is important to get enough information about your issues/inquiry so that we can properly understand your issues. This is among
In addition there are a couple of getting started resources I would recommend that you go through, among them are our NCS Fundamentals and Intermediate courses on https://academy.nordicsemi.com/. In the intermediate course there is also a course about debugging, which might be helpful for you to isolate the issue further before you raise an inquiry with a too general issue for us to be able to help.
Moving on to your issue:
hen exporting the data collected, specifically the digital outputs, they are exporting incorrectly, but in the Data Logger tab they are presented correctly
This is where an image or other attachment would be great to have. What do you mean with "incorrectly"? To us this could mean anything. Do you see the values in decimal in one place but in hex in the other place? Do you see different ascii values in the two places? Please expand upon this if possible
Andreas
This is the log window.
2024-06-19T13:10:08.962Z INFO Initialising nrfutil module: device 2024-06-19T13:10:08.975Z DEBUG Application data folder: C:\Users\andyd\AppData\Roaming\nrfconnect\pc-nrfconnect-ppk 2024-06-19T13:10:09.043Z DEBUG Sending event "ppk: running nrfutil device" 2024-06-19T13:10:09.043Z DEBUG App pc-nrfconnect-ppk v4.1.1 (official) 2024-06-19T13:10:09.043Z DEBUG App path: C:\Users\andyd\.nrfconnect-apps\node_modules\pc-nrfconnect-ppk 2024-06-19T13:10:09.044Z DEBUG nRFConnect 5.0.0, required by the app is (>=4.4.1) 2024-06-19T13:10:09.044Z DEBUG nRFConnect path: C:\Users\andyd\AppData\Local\Programs\nrfconnect\resources\app.asar 2024-06-19T13:10:09.044Z DEBUG HomeDir: C:\Users\andyd 2024-06-19T13:10:09.044Z DEBUG TmpDir: C:\Users\andyd\AppData\Local\Temp 2024-06-19T13:10:10.393Z DEBUG Sending event "ppk: running nrfutil device" 2024-06-19T13:10:12.600Z DEBUG Sending event "ppk: running nrfutil device" 2024-06-19T13:10:12.600Z DEBUG Sending event "ppk: running nrfutil device" 2024-06-19T13:10:12.605Z DEBUG Sending event "ppk: running nrfutil device" 2024-06-19T13:10:12.927Z INFO Using nrfutil-device core version: 7.12.0 2024-06-19T13:10:13.511Z INFO Using nrfutil-device version: 2.1.1 2024-06-19T13:10:13.511Z INFO Using nrf-device-lib version: 0.17.5 2024-06-19T13:10:13.511Z INFO Using nrfjprog DLL version: 10.24.0 2024-06-19T13:10:13.511Z INFO Using JLink version: JLink_V7.94e 2024-06-19T13:10:14.228Z INFO Restoring state from D:\WORK\PROJECT\ESP-IDF_PROJECTS\SHM-SENSOR-NODE\Current-Measurement-CR-2.ppk2 2024-06-19T13:10:14.733Z INFO Decompression session information to C:\Users\andyd\AppData\Local\Temp\88691e41-bbb0-46bc-94d7-74bd748eaf7c 2024-06-19T13:10:14.734Z DEBUG Loading temporary ppk session file sessionFile C:\Users\andyd\AppData\Local\Temp\88691e41-bbb0-46bc-94d7-74bd748eaf7c 2024-06-19T13:12:26.338Z INFO Exported CSV to: D:\WORK\PROJECT\ESP-IDF_PROJECTS\SHM-SENSOR-NODE\Current-Measurement-CR-2.csv 2024-06-19T13:12:26.340Z DEBUG Sending event "ppk: Export data"
With SDK I guess you mean what I show in this first image.
Sorry I didn't explain myself in a good way. These images show what I meant, "incorrectly" means that the digital outputs don't have the values I see in the graph in the software.
The digital outputs are organized as D0 D1 D2 D3 D4 D5 D6 D7.
In the following image below, at timestamp 30286ms, digital outputs should be 1,0,0,1,0,0,0,0, but the file shows different values, like if they were inverted.
In the following bellow, timestamp 36262ms, digital outputs should be 0,0,0,0,0,1,0,0, but the exported file shows different values
n the following bellow, timestamp 36291ms, digital outputs should be 00000100, although there's a falling edge at that exact timestamp, but the exported file shows different values, and those 'X' which I don't know what they mean.
Thank you for expanding
andyduarte0192 said:With SDK I guess you mean what I show in this first image.
Typically with SDK (Software development Kit), we refer to nRF Connect SDK and the version is corresponding to for instance v2.6.1. But no worries, I see that this part is not relevant for this question
andyduarte0192 said:Sorry I didn't explain myself in a good way. These images show what I meant, "incorrectly" means that the digital outputs don't have the values I see in the graph in the software.
Aha, this makes things more clear, and what you see is correct. Bit 0 is furthest to the right (often referred as least significant bit) and bit 7 is furthest to the left (most significant bit)
andyduarte0192 said:and those 'X' which I don't know what they mean.
The X's mean that its not able to determine if it is 0 or 1 (if the voltage is somewhere in between, it could typically be anything). You don't want to assume that something that is 3.3V is logic high in a 5V device, when it is in theory closer to 5V than it is to 0V.
Andreas
I also thought that MSB to the left and LSB to the right, but that's not what the header of the csv file says.
And also, how to explain the behavior of the timestamp 36262ms (the second image I sent in my previous reply), even assuming the digital outputs are inverted in the csv file?
andyduarte0192 said:And also, how to explain the behavior of the timestamp 36262ms (the second image I sent in my previous reply), even assuming the digital outputs are inverted in the csv file?
Good point, I fixated too much on the first image, which were insufficient as evidence
I will look closer into this and see if I can find a better explanation. I'll check in here with a status tomorrow (Friday)
Anderas
