Question about NCS DTM and BLE stack option.
I would like to develop DTM and normal BLE stack operation in single firmware by NCS. Basically i will check a GPIO, go DTM test mode if GPIO short to High, go normal BLE stack if GPIO short to GND.
However, it seems no way to achieve that.
If i set CONFIG_BT=y, then start DTM, it get crash or HARDWARE FAULT.
If i set CONFIG_BT=n, then ok for DTM, but no way to initialixe the BLE Stack manually in code.
Am i correct?
So is it possible to enable CONFIG_BT=y manually in codes? Or disable BLE Stack completely so that i can switch to DTM mode properly?
Already search but still seems no feasible solution.
Thanks.
