nRF5340 Audio applications run error in NCS v2.7.0
I'm using nRF5340 audio application with nRF Connect SDK v2.7.0 on nrf5340 Audio DK.I didn't change anything in the sample code.
I build by this cmd:python buildprog.py -c both -b debug -d both -p
When I burned "merged_domains.hex"
When I burned the code, the error always occurred.
Here is the error log.
*** Booting nRF Connect SDK v2.7.0-ad602496b6a8 ***
*** Using Zephyr OS v3.6.99-100befc70c74 ***
GW [00:00:00.396,148] <inf> board_version: Compatible board/HW version found: 1.0.0
GW [00:00:00.420,989] <inf> fw_info:
	 nRF5340 Audio nRF5340 Audio DK cpuapp
	 NCS base version: 2.7.0
	 Cmake run : Thu Sep 12 18:12:37 2024
GW [00:00:00.421,020] <inf> fw_info: ------- DEBUG BUILD -------
GW [00:00:00.421,020] <inf> fw_info: Compiled for GATEWAY device
GW [00:00:00.490,722] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 5.4 (0x0d), Revision 8699
GW [00:00:00.490,936] <inf> bt_mgmt: Local identity addr: E7:E0:45:53:D5:28 (random)
GW [00:00:00.491,058] <inf> audio_usb: Ready for USB host to send/receive.
GW [00:00:00.491,973] <err> bt_bap_unicast_client: bt_iso_cig_create failed: -134
GW [00:00:00.491,973] <err> unicast_client: Failed to create unicast group: -134
GW [00:00:00.491,973] <err> main: ERR_CHK Err_code: [-134] @ line: 569
GW [00:00:00.492,004] <err> os: r0/a1:  0x00000003  r1/a2:  0x0000000c  r2/a3:  0x0000000b
GW [00:00:00.492,004] <err> os: r3/a4:  0x00000003 r12/ip:  0x20003530 r14/lr:  0x00060d11
GW [00:00:00.492,004] <err> os:  xpsr:  0x29100000
GW [00:00:00.492,004] <err> os: s[ 0]:  0x20001bac  s[ 1]:  0x00060ee5  s[ 2]:  0x20011db4  s[ 3]:  0x00000004
GW [00:00:00.492,034] <err> os: s[ 4]:  0x20011ecc  s[ 5]:  0x00040a69  s[ 6]:  0x00000000  s[ 7]:  0x2001fd70
GW [00:00:00.492,034] <err> os: s[ 8]:  0x2001fd40  s[ 9]:  0xffffffff  s[10]:  0xffffffff  s[11]:  0x00060f29
GW [00:00:00.492,034] <err> os: s[12]:  0x00007b5d  s[13]:  0x000726cc  s[14]:  0xffffff7a  s[15]:  0x00000239
GW [00:00:00.492,034] <err> os: fpscr:  0x2001fd40
GW [00:00:00.492,065] <err> os: Faulting instruction address (r15/pc): 0x00003cc2
GW [00:00:00.492,065] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
GW [00:00:00.492,095] <err> os: Current thread: 0x20006478 (main)
GW [00:00:00.492,095] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
I have tested NCS 2.4.0 last year,it worked will.
