nrf5340 SDK 1.9.1 idle mode consumption and power management
Problem: I see a constant 1.4-1.5mA power consumption that I am unable to explain, can;t reduce despite trying a few things and need help debugging further
SDK: 1.9.1
MCU: nrf5340 running at 128MHz (not the default 64MHz)
Board: custom with multiple external components (PMIC, Accel, and few other things)
Environment: SES
Build: secure build
We have BLE enabled (few 100 bytes being sent exactly every second), MCUBoot, and DFU.. everything works as expected with zero issues (functionally and timing wise).. except for this current consumption we can not explain
What I have done
1. Basic stuff
Turned off serial/uart/log in prj.conf (for application core AND network core (hci_rpmsg).. we use MCUboot and turned off UART there too
CONFIG_ASSERT=n
CONFIG_LOG=n
CONFIG_CONSOLE=n
CONFIG_SERIAL=n
// UART debug port
&uart0 {
status = "okay";
//status = "disabled";
/delete-property/ rts-pin;
/delete-property/ cts-pin;
tx-pin = < 0x19 >;
rx-pin = < 0x1a >;
current-speed = <460800>;
#power management
CONFIG_PM=y
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
and i have added  the following too
#include <pm/pm.h>
#include <device.h>
I have added
/* Prevent deep sleep (system off) from being entered */
pm_constraint_set(PM_STATE_SOFT_OFF);
Questions:
1a. FPU is ON.. does it make any difference (we need it and hence can't turn it off)..
1b: shutting UART off should reduce power by 500uA right ? or is it more ?
2. I have a few GPIOs configured as interrupt pins.. most are edge triggered GPIO_INT_EDGE_FALLING or GPIO_INT_EDGE_RISING (won;t work otherwise so, i cant go for level triggered at this time)..Only button is GPIO_INT_LEVEL_INACTIVE..  Looks like in 1.9.1 we need to add an entry in overlay to take care of masking for sense-edge and i did..
&gpio0 {
status = "okay";
sense-edge-mask = < 0xffffffff >;
&gpio1 {
status = "okay";
Will making interrupts edge triggered add 100s of uA like it is mentioned in some older tickets ? is there a way around that I am missing ?
3. do we have to add CONFIG_PM=y  and CONFIG_PM_DEVICE=y to mcuboot and hci_rpmsg conf files too ? I haven't tried it yet
4. looks like idle thread runs.. (i even added a dummy idle with low priority to see if CPU is always busy doing stuff.. and i see that my dummy thread gets called ample times too..
just for testing, I enabled UART and added a print  (
if (pm_system_suspend(_kernel.idle) == false) {
printk("\n suspend failed");
k_cpu_idle();
and I see that print suspend failed ALL the time which is worrying.. but wasn't sure if it's the print that's making it fail or is it really failing.. hence asking you guys if this is something worth worrying  and investigating
5. using my PMIC , I cut off power for all external components and I still see suspend failed and still this additional power consumption.  I disconnect the JTAG and reset the board after flashing .. just to avoid answering "is JTAG somehow enabled.. have you reset the board"
6. I do have I2c2 and 3 turned on  configured at I2C_BITRATE_STANDARD (not doing transactions at the time of measurement).. according to datasheet, this should not add 100s of uAs  but may be 10of uA..  I also have one SPI port configured (but NOT doing any transactions).. Is this ok  or should I shut down everything except when i am using (makes the application design a bit more complex :-) )
7. I use QSPI (single wire) to talk to a Display controller and when display is not in use, QSPI is shutdown and pins are disconnected.
8. Eventually, I shutdown all peripherals and I still see no evidence of CPU going to idle and power consumption is close to 1 mA which really kind of shocked me.so I am questioning what else do i have to do .. base don what i have read, CONFIG_PM=y will ensure idle thread will run (and i verified that it does) and will ALSO push the cores to a lower power mode (which I don't see)..
CONFIG_PM_DEVICE=y will need explicit power management api calls and implementations from individual drivers.. i have done that for my display driver (and have verified that it shuts down)
CONFIG_PM_DEVICE_RUNTIME=y --> I am not sure if this needed or should I removed it
I am close to the point of factory production of our device and this issue has become critical given this extra current consumption has reduced the battery life to half of what we would need it to be
  • Before looking into all your questions, try the following:
    • Run nrfjprog --recover --coprocessor CP_NETWORK && nrfjprog --recover
    • Run nrfjprog --program app_core_image.hex --chiperase
      • I have attached app_core_image.hex
      • If --coprocessor is not specificed it will program to app core by default
    • Run nrfjprog --pinreset
    After I completed these steps I saw a current of 2.5uA on the nRF5340 DK
    7180.app_core_image.hex
    Simon
  • Thank you for getting back quickly.. I flashed the images you attached.. I see a current consumption of 540-580uA  on my board.. I can look at that and see what's consuming this (assuming your image put the system to sleep)..
    but would appreciate your responses to my questions/concerns
  • If your goal is to find the cause of the high current consumption I would recommend you to start with a really simple sample. For example the hello_world sample with CONFIG_SERIAL=n in prj.conf. Erase both of the cores and program the sample. Then you should se a current of around 2-3 uA. Using this approach you can easily figure out if the high current consumption is due to the firmware or the custom board
    The hex file in the initial reply was copied from an older ticket I handled, and I think it was ahello world sample with CONFIG_SERIAL=n. I re-test this tomorrow and upload a new hex file to be certain.
    So if you still see a high current consumption with this ample, you know the custom hardware is the cause.
    Questions
    I have some knowledge about current consumption, but I'm not an expert. But I will answer the questions I know the answer to and ask some colleagues about the rest tomorrow.
    Will get back to you about this
    Yes, that is correct, it will consume around 500uA. Remember to disable it (set CONFIG_SERIAL=n) in all child images. In addition to the ones you mentioned, it may be b0n (netboot, which is a bootloader for netcore) or b0 (secure bootloader for appcore).
    As far as I'm aware, it should not be necessary to set these for the child images. I will test this tomorrow and get back to you.
    In the main application, CONFIG_PM should be enabled by default, and I don't think you necessarily need to set CONFIG_PM_DEVICE=y to decrease the current consumption, unless you want to use the pm_device_action_run() function (with this function you can enable UART in prj.conf, and disable it in the application when it's not used).
    Actually Zephyr will handle almost everything regarding current consumption, and you don't need to do too much. The most important thing is to disabe UART. When the CPU is not doing any work, the idle thread will run and the chip will go into System ON sleep (2-3uA).  All the peripherals, except UART I think, will release the HFCLK when they're idle (even if CONFIG_PM_DEVICE=n). Also, between Bluetooth events the chip goes into System ON sleep. What is your floor current? Could you check if it enters System ON sleep (2-3 uA) between peripheral and Bluetooth events/interrupts?
    I will get back to you about the rest of the questions tomorrow.
  • Also, between Bluetooth events the chip goes into System ON sleep. What is your floor current? Could you check if it enters System ON sleep (2-3 uA) between peripheral and Bluetooth events/interrupts?
    I was around 1.4mA.. Last night, I did find an issue with our touch controller power saving mode fixing which saved me about 200uA.. my floor is close to 1.2mA right now.. One strange thing is this floor remains the same when UART is enabled or not which i fid a bit suspect..
    I am not expecting anywhere near 2-3uA given all my components and their quiescent currents.. In fact, at least two of my components are always on.. I am trying to understand why i see suspend failed print (when i enable prints) a and make sure no matter what cpu goes to sleep when it is supposed to..
    I will also try a few things with one of the examples like you mentioned and see .. hello world as is with no changes except CONFIG_SERIAL=n should consume less than 3 uA on nordic 5340 DK right ?
    Yes, that is correct, program the hello world sample (with CONFIG_SERIAL=n) to the application core. However, if stuff is running on the netcore, that may consume current. Try erasing both of the cores before programming the hello world sample: nrfjprog --recover --coprocessor CP_NETWORK && nrfjprog --recover
    However, if you have added a custom board folder, you might have enabled Kconfigs there that causes a high current consumption, so I can't say for certain that hello world with uart disabled will be sufficient. I will do some testing tomorrow and upload a new hex file.
