<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Debugging/Programming Access</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/100030/debugging-programming-access</link><description>Hi,
 I have a dubt: The two cores of nRF5340 are both available, tfor the debugging and programming, by SWCLK/DIO iface?
 or I need to access to the P0.08 &amp;amp; P0.11 (SCK &amp;amp; SWO of the TRACEPORT) pins to access to the Apllication Core?
 in the PS I found</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Wed, 24 May 2023 16:25:09 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/100030/debugging-programming-access" /><item><title>RE: Debugging/Programming Access</title><link>https://devzone.nordicsemi.com/thread/427309?ContentTypeID=1</link><pubDate>Wed, 24 May 2023 16:25:09 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:f47f27c2-2c4c-45e7-a2b0-961e5a341ae6</guid><dc:creator>Naeem Maroof</dc:creator><description>&lt;p&gt;The SWO (and other) trace pins are used for tracing that collects data from ETM and ITM through TPIU.&lt;/p&gt;
&lt;p&gt;For debugging, you use SWDCLK and SWDIO.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Debugging/Programming Access</title><link>https://devzone.nordicsemi.com/thread/427236?ContentTypeID=1</link><pubDate>Wed, 24 May 2023 12:38:38 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:db21cd01-ae86-434a-ba40-cded43b7e13b</guid><dc:creator>0x00</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;therefore the SWO, in canonical case in which we have as pgrammer/debugger a JLINK for example,&amp;nbsp; is an &amp;quot;optional&amp;quot; line. Correct? ... i need to double check!&lt;/p&gt;
&lt;p&gt;Many Thanks&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Debugging/Programming Access</title><link>https://devzone.nordicsemi.com/thread/427181?ContentTypeID=1</link><pubDate>Wed, 24 May 2023 10:45:56 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:22bc755d-9b37-42cc-b7ed-f083c177c8de</guid><dc:creator>Naeem Maroof</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;Thank you for contacting DevZone at NordicSemi.&lt;/p&gt;
&lt;p&gt;As per the product specification of nrf5340:&lt;/p&gt;
&lt;p&gt;External debugger is connected to SW-DP through SWDCLK and SWDIO ports.&lt;br /&gt;This SW-DP is connected to the DAP bus interconnect, and you can see that both cores (app core and the net core) are connected to the DAP bus through their respective AHB-AP.&lt;br /&gt;This means that both of the core could be accessed through the debugger.&lt;/p&gt;
&lt;p&gt;The TPIU (Trace Port Interface Unit) could be used to trace data from the ETM and ITM of the app core. It could use 4-bit wide parallel trace (TRACEDATA[0:3]) or serial trace (via SWO protocol).&amp;nbsp;The dedicated trace pins (P0.08 to P0.12) are multiplexed with GPIOs and must use specified drive configurations.&lt;/p&gt;
&lt;p&gt;Regards,&lt;/p&gt;
&lt;p&gt;Naeem&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Debugging/Programming Access</title><link>https://devzone.nordicsemi.com/thread/426970?ContentTypeID=1</link><pubDate>Tue, 23 May 2023 13:31:15 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:4124a7d2-fcda-422a-99f3-dfca0cf2bfb7</guid><dc:creator>0x00</dc:creator><description>&lt;p&gt;Probably the TRAVCE port is optional... since the AppCore is connected also to the DAP.&lt;/p&gt;
&lt;p&gt;But a confirmation will be appreciated! :)!&lt;/p&gt;
&lt;p&gt;Thanks again&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
