<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Why the NRF52840 device run abnormally when APP_ ADV_ INTERVAL =640 or stopped ?</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/100112/why-the-nrf52840-device-run-abnormally-when-app_-adv_-interval-640-or-stopped</link><description>During the testing of the application board we designed, we found that the board A run normally ; When APP_ ADV_ INTERVAL=640, Board B and C always resets , and once Bluetooth is connected, it does not reset, but when enter DEBUG mode,they run normally;</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 30 May 2023 06:30:23 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/100112/why-the-nrf52840-device-run-abnormally-when-app_-adv_-interval-640-or-stopped" /><item><title>RE: Why the NRF52840 device run abnormally when APP_ ADV_ INTERVAL =640 or stopped ?</title><link>https://devzone.nordicsemi.com/thread/428043?ContentTypeID=1</link><pubDate>Tue, 30 May 2023 06:30:23 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:394323b9-c84d-473a-9587-12de74f40c34</guid><dc:creator>Simonr</dc:creator><description>&lt;p&gt;Hi&lt;/p&gt;
&lt;p&gt;Since the antennas are different on the okay and not okay designs are different that would be the most likely is the reason these doesn&amp;#39;t work correctly, but can you confirm whether your design use both the HF and LF crystals? If you&amp;#39;d like we can do a HW review of your design(s) . If you don&amp;#39;t want to upload it here in a public ticket you can create a private one instead and upload schematic/PCB layout signs.&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Simon&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Why the NRF52840 device run abnormally when APP_ ADV_ INTERVAL =640 or stopped ?</title><link>https://devzone.nordicsemi.com/thread/427711?ContentTypeID=1</link><pubDate>Fri, 26 May 2023 09:13:22 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:292ed4b1-5ae0-4972-830c-a419cf587989</guid><dc:creator>joyboss2005@126.com</dc:creator><description>&lt;p&gt;Hi Simon&lt;/p&gt;
&lt;p&gt;The antenna shape of boards A and B/C&amp;nbsp;is a little different;These are all custom boards based on the same design and run the exact same application code;&lt;/p&gt;
&lt;p&gt;We have Some experiments with these custom boards ,find the problem concern with SDK version and example .&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;&lt;b&gt;Experiment 1:&lt;/b&gt;&lt;/strong&gt;&lt;/p&gt;
&lt;p&gt;nRF5_SDK_15.2.0_9412b96\examples\ble_central_and_peripheral\experimental\ble_app_hrs_rscs_relay\pca10056\s140\arm5_no_packs&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;&lt;b&gt;R&lt;/b&gt;&lt;/strong&gt;&lt;strong&gt;&lt;b&gt;esult:all board A\B\C run normally.&lt;/b&gt;&lt;/strong&gt;&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;&lt;b&gt;Experiment 2:&lt;/b&gt;&lt;/strong&gt;&lt;/p&gt;
&lt;p&gt;.nRF5_SDK_17.1.0_ddde560\examples\ble_central_and_peripheral\experimental\ble_app_hrs_rscs_relay\pca10056\s140\arm5_no_packs&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;&lt;b&gt;Result:RELEASE abnormally(always reset)，DEBUG run normally。&lt;/b&gt;&lt;/strong&gt;&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;&lt;b&gt;Experiment 3:&lt;/b&gt;&lt;/strong&gt;&lt;/p&gt;
&lt;p&gt;.\nRF5_SDK_17.1.0_ddde560\examples\ble_peripheral\ble_app_uart&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;&lt;b&gt;Experiment 4:&lt;/b&gt;&lt;/strong&gt;&lt;/p&gt;
&lt;p&gt;&amp;nbsp;&amp;nbsp;With 10 boards of other product&amp;nbsp;to test same application code,only modified led gpio definition&amp;nbsp;,&lt;strong&gt;&lt;b&gt;they all &lt;/b&gt;&lt;/strong&gt;&lt;strong&gt;&lt;b&gt;run normally.&lt;/b&gt;&lt;/strong&gt;&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;&lt;b&gt;&amp;nbsp;&amp;nbsp;&lt;/b&gt;&lt;/strong&gt;We don&amp;#39;t understand the true cause of the problem, both the external crystal oscillator and DCDC are normal.&lt;/p&gt;
&lt;p&gt;Best regards&lt;/p&gt;
&lt;p&gt;Junwei&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Why the NRF52840 device run abnormally when APP_ ADV_ INTERVAL =640 or stopped ?</title><link>https://devzone.nordicsemi.com/thread/427653?ContentTypeID=1</link><pubDate>Fri, 26 May 2023 06:24:25 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d7034d89-d943-4535-bb24-3d004f7a8517</guid><dc:creator>Simonr</dc:creator><description>&lt;p&gt;Hi&lt;/p&gt;
&lt;p&gt;Is there any difference between boards A and B/C? I assume these are all custom boards based on the same design and run the exact same application code, correct? The reason for custom boards to have issues in release mode and not debug mode is often that either the external crystals aren&amp;#39;t mounted or loaded properly, or if the DCDC converter components aren&amp;#39;t mounted correctly on the devices.&lt;/p&gt;
&lt;p&gt;Simon&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
