<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>nrf52833 output power control</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/100240/nrf52833-output-power-control</link><description>Hi All
 Hope you all are doing well!
 I am using nrf52833DK, NCS version 2.0.2/2.3.0, and VSCODE studio as an IDE.Peripherial_uart example and coded phy as multi peripheral.
 Above all working fine. Now the issue is that I want to set the output</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Sat, 10 Jun 2023 09:35:21 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/100240/nrf52833-output-power-control" /><item><title>RE: nrf52833 output power control</title><link>https://devzone.nordicsemi.com/thread/430305?ContentTypeID=1</link><pubDate>Sat, 10 Jun 2023 09:35:21 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:fe06cc8b-edaf-4f66-a1ca-0f603010e2ee</guid><dc:creator>Muhammad Usman</dc:creator><description>&lt;p&gt;Hi Naeem!&lt;/p&gt;
&lt;p&gt;Thank you for the response and help! Problem solved by&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;div&gt;
&lt;div&gt;&lt;span&gt;static&lt;/span&gt;&lt;span&gt; &lt;/span&gt;&lt;span&gt;int&lt;/span&gt;&lt;span&gt; &lt;/span&gt;&lt;span&gt;create_advertising_coded&lt;/span&gt;&lt;span&gt;(&lt;/span&gt;&lt;span&gt;void&lt;/span&gt;&lt;span&gt;)&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;{&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&amp;nbsp; &amp;nbsp; &lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&amp;nbsp; &amp;nbsp; &lt;/span&gt;&lt;span&gt;int&lt;/span&gt;&lt;span&gt; &lt;/span&gt;&lt;span&gt;err&lt;/span&gt;&lt;span&gt;;&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&amp;nbsp; &amp;nbsp; &lt;/span&gt;&lt;span&gt;struct&lt;/span&gt;&lt;span&gt; &lt;/span&gt;&lt;span&gt;bt_le_adv_param&lt;/span&gt;&lt;span&gt; &lt;/span&gt;&lt;span&gt;param&lt;/span&gt;&lt;span&gt; &lt;/span&gt;&lt;span&gt;=&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &lt;/span&gt;&lt;span&gt;BT_LE_ADV_PARAM_INIT&lt;/span&gt;&lt;span&gt;(&lt;/span&gt;&lt;span&gt;BT_LE_ADV_OPT_CONNECTABLE&lt;/span&gt;&lt;span&gt; &lt;/span&gt;&lt;span&gt;|&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;&lt;/span&gt;&lt;span&gt;BT_LE_ADV_OPT_EXT_ADV&lt;/span&gt;&lt;span&gt; &lt;/span&gt;&lt;span&gt;|&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &lt;strong&gt;&amp;nbsp;&lt;/strong&gt;&lt;/span&gt;&lt;strong&gt;BT_LE_ADV_OPT_USE_TX_POWER |&lt;/strong&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;&lt;/span&gt;&lt;span&gt;BT_LE_ADV_OPT_CODED&lt;/span&gt;&lt;span&gt;,&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;&lt;/span&gt;&lt;span&gt;BT_GAP_ADV_FAST_INT_MIN_2&lt;/span&gt;&lt;span&gt;,&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;&lt;/span&gt;&lt;span&gt;BT_GAP_ADV_FAST_INT_MAX_2&lt;/span&gt;&lt;span&gt;,&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;&lt;/span&gt;&lt;span&gt;NULL&lt;/span&gt;&lt;span&gt;);&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;by adding the&amp;nbsp;&lt;strong&gt;&amp;nbsp;&lt;/strong&gt;&lt;strong&gt;BT_LE_ADV_OPT_USE_TX_POWER ,&amp;nbsp;&lt;/strong&gt;it shows me at the receiver side the Tx power.&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;Again thank you for the help!&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;Thanks &amp;amp; regards,&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;Muhammad Usman&lt;/span&gt;&lt;/div&gt;
&lt;/div&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nrf52833 output power control</title><link>https://devzone.nordicsemi.com/thread/429054?ContentTypeID=1</link><pubDate>Fri, 02 Jun 2023 15:28:24 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:f8530b49-b414-4546-b16c-4895f3570288</guid><dc:creator>Naeem Maroof</dc:creator><description>&lt;p&gt;Hello Usman,&lt;/p&gt;
[quote user="Muhammad Usman"]&lt;p&gt;Can you please help me where is the issue in the above code? Should I have to use &lt;strong&gt;HCI&lt;/strong&gt; libraries or it will work with the prj. conf file configuration.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;[/quote]
&lt;p&gt;I did not get your question. Is this code based on some nordic example.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;As in your ticket, you have the problem that the output power was not getting updated.&lt;/p&gt;
&lt;p&gt;As for 2.0.2 is concerned, there was the issue and the workaround is provided (see previous response)&lt;/p&gt;
&lt;p&gt;As for 2.0.3 is concerned, power updating configurations are working.&lt;/p&gt;
&lt;p&gt;You can do a following experiment (with certain DK) in 2.0.3:&lt;/p&gt;
&lt;p&gt;Take any nordic sample sample, build and flash on the DK, and then using the nrfjprog (nrf command line tool), read the TXPOWER register of radio&lt;/p&gt;
&lt;p&gt;Repeat it by changing the configurations.&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1685719545019v1.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1685719690738v3.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;Regards,&lt;/p&gt;
&lt;p&gt;Naeem&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nrf52833 output power control</title><link>https://devzone.nordicsemi.com/thread/428408?ContentTypeID=1</link><pubDate>Wed, 31 May 2023 10:37:32 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:fffd8a7c-15f3-4ff1-989e-5f2f6863465f</guid><dc:creator>Muhammad Usman</dc:creator><description>&lt;p&gt;Hi Naeem!&lt;/p&gt;
&lt;p&gt;Thank you so much for the response!&lt;/p&gt;
&lt;p&gt;I tried it via nrf52833DK by loading the following code and on the receiver side I connected nrf52840 USB dongle + Wireshark. And also tested with nrf connect for desktop BLE standalone + dongle.&lt;/p&gt;
&lt;p&gt;I set a distance of 1 meter and changed the values in prj. conf file but it always showed me -60 to - 63dbm. although, I changed the range from -20 to 8dbm.&lt;/p&gt;
&lt;p&gt;I also tried &lt;strong&gt;NCS 2.3.0&lt;/strong&gt; but the same behavior.&lt;/p&gt;
&lt;p&gt;After that I set&amp;nbsp; &lt;strong&gt;BT_LE_ADV_OPT_USE_TX_POWER&lt;/strong&gt;&lt;/p&gt;
&lt;div&gt;
&lt;div&gt;&amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; in&amp;nbsp;&lt;br /&gt;&lt;span&gt;&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&lt;span&gt;&lt;/span&gt;&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;strong&gt;&amp;nbsp;static int create_advertising_coded(void)&lt;/strong&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;I am able to see the &lt;strong&gt;0dbm&lt;/strong&gt; in the coded phy packet that is set by default.&amp;nbsp;&lt;/span&gt;&lt;/div&gt;
&lt;/div&gt;
&lt;p&gt;main.c&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;/*
 * Copyright (c) 2018 Nordic Semiconductor ASA
/** @file
 *  @brief Nordic UART Bridge Service (NUS) sample
#include &amp;quot;uart_async_adapter.h&amp;quot;
#include &amp;lt;zephyr/types.h&amp;gt;
#include &amp;lt;zephyr/kernel.h&amp;gt;
#include &amp;lt;zephyr/drivers/uart.h&amp;gt;
#include &amp;lt;zephyr/usb/usb_device.h&amp;gt;
#include &amp;lt;zephyr/device.h&amp;gt;
#include &amp;lt;zephyr/devicetree.h&amp;gt;
#include &amp;lt;soc.h&amp;gt;
#include &amp;lt;zephyr/bluetooth/bluetooth.h&amp;gt;
#include &amp;lt;zephyr/bluetooth/uuid.h&amp;gt;
#include &amp;lt;zephyr/bluetooth/gatt.h&amp;gt;
#include &amp;lt;zephyr/bluetooth/hci.h&amp;gt;
#include &amp;lt;zephyr/bluetooth/hci_vs.h&amp;gt;
#include &amp;lt;bluetooth/services/nus.h&amp;gt;
#include &amp;lt;dk_buttons_and_leds.h&amp;gt;
#include &amp;lt;zephyr/settings/settings.h&amp;gt;
#include &amp;lt;stdio.h&amp;gt;
#include &amp;lt;zephyr/logging/log.h&amp;gt;
#define LOG_MODULE_NAME peripheral_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
#define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
#define PRIORITY 7
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN	(sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED DK_LED1
#define RUN_LED_BLINK_INTERVAL 1000
#define CON_STATUS_LED DK_LED2
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
static struct k_work start_advertising_worker;
static struct bt_le_ext_adv *adv;
static K_SEM_DEFINE(ble_init_ok, 0, 1);
static struct bt_conn *current_conn;
static struct bt_conn *auth_conn;
static const struct device *uart = DEVICE_DT_GET(DT_CHOSEN(nordic_nus_uart));
static struct k_work_delayable uart_work;
struct uart_data_t {
	void *fifo_reserved;
	uint8_t data[UART_BUF_SIZE];
	uint16_t len;
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
#if CONFIG_BT_NUS_UART_ASYNC_ADAPTER
UART_ASYNC_ADAPTER_INST_DEFINE(async_adapter);
#else
static const struct device *const async_adapter;
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	ARG_UNUSED(dev);
	static size_t aborted_len;
	struct uart_data_t *buf;
	static uint8_t *aborted_buf;
	static bool disable_req;
	switch (evt-&amp;gt;type) {
	case UART_TX_DONE:
		LOG_DBG(&amp;quot;UART_TX_DONE&amp;quot;);
		if ((evt-&amp;gt;data.tx.len == 0) ||
		    (!evt-&amp;gt;data.tx.buf)) {
			return;
		if (aborted_buf) {
			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
					   data);
			aborted_buf = NULL;
			aborted_len = 0;
		} else {
			buf = CONTAINER_OF(evt-&amp;gt;data.tx.buf, struct uart_data_t,
					   data);
		k_free(buf);
		buf = k_fifo_get(&amp;amp;fifo_uart_tx_data, K_NO_WAIT);
		if (!buf) {
			return;
		if (uart_tx(uart, buf-&amp;gt;data, buf-&amp;gt;len, SYS_FOREVER_MS)) {
			LOG_WRN(&amp;quot;Failed to send data over UART&amp;quot;);
	case UART_RX_RDY:
		LOG_DBG(&amp;quot;UART_RX_RDY&amp;quot;);
		buf = CONTAINER_OF(evt-&amp;gt;data.rx.buf, struct uart_data_t, data);
		buf-&amp;gt;len += evt-&amp;gt;data.rx.len;
		if (disable_req) {
			return;
		if ((evt-&amp;gt;data.rx.buf[buf-&amp;gt;len - 1] == &amp;#39;\n&amp;#39;) ||
		    (evt-&amp;gt;data.rx.buf[buf-&amp;gt;len - 1] == &amp;#39;\r&amp;#39;)) {
			disable_req = true;
			uart_rx_disable(uart);
	case UART_RX_DISABLED:
		LOG_DBG(&amp;quot;UART_RX_DISABLED&amp;quot;);
		disable_req = false;
		buf = k_malloc(sizeof(*buf));
		if (buf) {
			buf-&amp;gt;len = 0;
		} else {
			LOG_WRN(&amp;quot;Not able to allocate UART receive buffer&amp;quot;);
			k_work_reschedule(&amp;amp;uart_work, UART_WAIT_FOR_BUF_DELAY);
			return;
		uart_rx_enable(uart, buf-&amp;gt;data, sizeof(buf-&amp;gt;data),
			       UART_WAIT_FOR_RX);
	case UART_RX_BUF_REQUEST:
		LOG_DBG(&amp;quot;UART_RX_BUF_REQUEST&amp;quot;);
		if (buf) {
			uart_rx_buf_rsp(uart, buf-&amp;gt;data, sizeof(buf-&amp;gt;data));
		} else {
	case UART_RX_BUF_RELEASED:
		LOG_DBG(&amp;quot;UART_RX_BUF_RELEASED&amp;quot;);
		buf = CONTAINER_OF(evt-&amp;gt;data.rx_buf.buf, struct uart_data_t,
				   data);
		if (buf-&amp;gt;len &amp;gt; 0) {
			k_fifo_put(&amp;amp;fifo_uart_rx_data, buf);
		} else {
			k_free(buf);
	case UART_TX_ABORTED:
		LOG_DBG(&amp;quot;UART_TX_ABORTED&amp;quot;);
		if (!aborted_buf) {
			aborted_buf = (uint8_t *)evt-&amp;gt;data.tx.buf;
		aborted_len += evt-&amp;gt;data.tx.len;
				   data);
		uart_tx(uart, &amp;amp;buf-&amp;gt;data[aborted_len],
			buf-&amp;gt;len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
	if (buf) {
	} else {
		return;
	uart_rx_enable(uart, buf-&amp;gt;data, sizeof(buf-&amp;gt;data), UART_WAIT_FOR_RX);
static bool uart_test_async_api(const struct device *dev)
	const struct uart_driver_api *api =
			(const struct uart_driver_api *)dev-&amp;gt;api;
	return (api-&amp;gt;callback_set != NULL);
static int uart_init(void)
	int err;
	int pos;
	struct uart_data_t *rx;
	struct uart_data_t *tx;
	if (!device_is_ready(uart)) {
		return -ENODEV;
	if (IS_ENABLED(CONFIG_USB_DEVICE_STACK)) {
		err = usb_enable(NULL);
		if (err) {
			LOG_ERR(&amp;quot;Failed to enable USB&amp;quot;);
			return err;
	rx = k_malloc(sizeof(*rx));
	if (rx) {
		rx-&amp;gt;len = 0;
	} else {
		return -ENOMEM;
	k_work_init_delayable(&amp;amp;uart_work, uart_work_handler);
	if (IS_ENABLED(CONFIG_BT_NUS_UART_ASYNC_ADAPTER) &amp;amp;&amp;amp; !uart_test_async_api(uart)) {
		/* Implement API adapter */
		uart_async_adapter_init(async_adapter, uart);
		uart = async_adapter;
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err) {
		LOG_ERR(&amp;quot;Cannot initialize UART callback&amp;quot;);
		return err;
	if (IS_ENABLED(CONFIG_UART_LINE_CTRL)) {
		LOG_INF(&amp;quot;Wait for DTR&amp;quot;);
		while (true) {
			uint32_t dtr = 0;
			uart_line_ctrl_get(uart, UART_LINE_CTRL_DTR, &amp;amp;dtr);
			if (dtr) {
			/* Give CPU resources to low priority threads. */
			k_sleep(K_MSEC(100));
		LOG_INF(&amp;quot;DTR set&amp;quot;);
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DCD, 1);
		if (err) {
			LOG_WRN(&amp;quot;Failed to set DCD, ret code %d&amp;quot;, err);
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DSR, 1);
		if (err) {
			LOG_WRN(&amp;quot;Failed to set DSR, ret code %d&amp;quot;, err);
	tx = k_malloc(sizeof(*tx));
	if (tx) {
		pos = snprintf(tx-&amp;gt;data, sizeof(tx-&amp;gt;data),
			       &amp;quot;Starting Nordic UART service example\r\n&amp;quot;);
		if ((pos &amp;lt; 0) || (pos &amp;gt;= sizeof(tx-&amp;gt;data))) {
			k_free(tx);
			LOG_ERR(&amp;quot;snprintf returned %d&amp;quot;, pos);
			return -ENOMEM;
		tx-&amp;gt;len = pos;
	} else {
		return -ENOMEM;
	err = uart_tx(uart, tx-&amp;gt;data, tx-&amp;gt;len, SYS_FOREVER_MS);
	if (err) {
		LOG_ERR(&amp;quot;Cannot display welcome message (err: %d)&amp;quot;, err);
		return err;
	return uart_rx_enable(uart, rx-&amp;gt;data, sizeof(rx-&amp;gt;data), 50);
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		LOG_ERR(&amp;quot;Connection failed (err %u)&amp;quot;, err);
		return;
	//LOG_INF(&amp;quot;Connected %s&amp;quot;, log_strdup(addr));
	current_conn = bt_conn_ref(conn);
	dk_set_led_on(CON_STATUS_LED);
	//LOG_INF(&amp;quot;Disconnected: %s (reason %u)&amp;quot;, log_strdup(addr), reason);
	if (auth_conn) {
		bt_conn_unref(auth_conn);
		auth_conn = NULL;
	if (current_conn) {
		bt_conn_unref(current_conn);
		current_conn = NULL;
		dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_NUS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
/*	if (!err) {
		LOG_INF(&amp;quot;Security changed: %s level %u&amp;quot;, log_strdup(addr),
			level);
	} else {
		LOG_WRN(&amp;quot;Security failed: %s level %u err %d&amp;quot;, log_strdup(addr),
			level, err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected    = connected,
	.disconnected = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
//	LOG_INF(&amp;quot;Passkey for %s: %06u&amp;quot;, log_strdup(addr), passkey);
static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey)
	auth_conn = bt_conn_ref(conn);
	LOG_INF(&amp;quot;Press Button 1 to confirm, Button 2 to reject.&amp;quot;);
static void auth_cancel(struct bt_conn *conn)
//	LOG_INF(&amp;quot;Pairing cancelled: %s&amp;quot;, log_strdup(addr));
static void pairing_complete(struct bt_conn *conn, bool bonded)
//	LOG_INF(&amp;quot;Pairing completed: %s, bonded: %d&amp;quot;, log_strdup(addr),
//		bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
//	LOG_INF(&amp;quot;Pairing failed conn: %s, reason %d&amp;quot;, log_strdup(addr),
//		reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.passkey_confirm = auth_passkey_confirm,
	.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data,
			  uint16_t len)
	int err;
	char addr[BT_ADDR_LE_STR_LEN] = {0};
	bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
//	LOG_INF(&amp;quot;Received data from: %s&amp;quot;, log_strdup(addr));
	for (uint16_t pos = 0; pos != len;) {
		struct uart_data_t *tx = k_malloc(sizeof(*tx));
		if (!tx) {
			LOG_WRN(&amp;quot;Not able to allocate UART send data buffer&amp;quot;);
			return;
		/* Keep the last byte of TX buffer for potential LF char. */
		size_t tx_data_size = sizeof(tx-&amp;gt;data) - 1;
		if ((len - pos) &amp;gt; tx_data_size) {
			tx-&amp;gt;len = tx_data_size;
		} else {
			tx-&amp;gt;len = (len - pos);
		memcpy(tx-&amp;gt;data, &amp;amp;data[pos], tx-&amp;gt;len);
		pos += tx-&amp;gt;len;
		/* Append the LF character when the CR character triggered
		 * transmission from the peer.
		if ((pos == len) &amp;amp;&amp;amp; (data[len - 1] == &amp;#39;\r&amp;#39;)) {
			tx-&amp;gt;data[tx-&amp;gt;len] = &amp;#39;\n&amp;#39;;
			tx-&amp;gt;len++;
		if (err) {
			k_fifo_put(&amp;amp;fifo_uart_tx_data, tx);
static struct bt_nus_cb nus_cb = {
	.received = bt_receive_cb,
void error(void)
	dk_set_leds_state(DK_ALL_LEDS_MSK, DK_NO_LEDS_MSK);
	while (true) {
		/* Spin for ever */
		k_sleep(K_MSEC(1000));
static void num_comp_reply(bool accept)
	if (accept) {
		bt_conn_auth_passkey_confirm(auth_conn);
		LOG_INF(&amp;quot;Numeric Match, conn %p&amp;quot;, (void *)auth_conn);
	} else {
		bt_conn_auth_cancel(auth_conn);
		LOG_INF(&amp;quot;Numeric Reject, conn %p&amp;quot;, (void *)auth_conn);
	auth_conn = NULL;
void button_changed(uint32_t button_state, uint32_t has_changed)
	uint32_t buttons = button_state &amp;amp; has_changed;
	if (auth_conn) {
		if (buttons &amp;amp; KEY_PASSKEY_ACCEPT) {
			num_comp_reply(true);
		if (buttons &amp;amp; KEY_PASSKEY_REJECT) {
			num_comp_reply(false);
#endif /* CONFIG_BT_NUS_SECURITY_ENABLED */
static void configure_gpio(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		LOG_ERR(&amp;quot;Cannot init buttons (err: %d)&amp;quot;, err);
	err = dk_leds_init();
	if (err) {
		LOG_ERR(&amp;quot;Cannot init LEDs (err: %d)&amp;quot;, err);
static void start_advertising_coded(struct k_work *item)
	int err;
	err = bt_le_ext_adv_start(adv, NULL);
	if (err) {
		printk(&amp;quot;Failed to start advertising set (%d)\n&amp;quot;, err);
		return;
	printk(&amp;quot;Advertiser %p set started\n&amp;quot;, adv);
	int err;
	struct bt_le_adv_param param =
		BT_LE_ADV_PARAM_INIT(BT_LE_ADV_OPT_CONNECTABLE |
				     BT_LE_ADV_OPT_EXT_ADV |
				     BT_LE_ADV_OPT_CODED,
				     BT_GAP_ADV_FAST_INT_MIN_2,
				     BT_GAP_ADV_FAST_INT_MAX_2,
				     NULL);
	err = bt_le_ext_adv_create(&amp;amp;param, NULL, &amp;amp;adv);
	if (err) {
		printk(&amp;quot;Failed to create advertiser set (%d)\n&amp;quot;, err);
		return err;
	printk(&amp;quot;Created adv: %p\n&amp;quot;, adv);
	err = bt_le_ext_adv_set_data(adv, ad, ARRAY_SIZE(ad), NULL, 0);
	if (err) {
		printk(&amp;quot;Failed to set advertising data (%d)\n&amp;quot;, err);
		return err;
	return 0;
static void bt_ready(void)
	int err = 0;
	printk(&amp;quot;Bluetooth initialized\n&amp;quot;);
	k_work_init(&amp;amp;start_advertising_worker, start_advertising_coded);
	err = create_advertising_coded();
	if (err) {
		printk(&amp;quot;Advertising failed to create (err %d)\n&amp;quot;, err);
		return;
	k_work_submit(&amp;amp;start_advertising_worker);
void main(void)
	int blink_status = 0;
	int err = 0;
	configure_gpio();
	err = uart_init();
	if (err) {
		error();
	if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
		err = bt_conn_auth_cb_register(&amp;amp;conn_auth_callbacks);
		if (err) {
			printk(&amp;quot;Failed to register authorization callbacks.\n&amp;quot;);
			return;
		err = bt_conn_auth_info_cb_register(&amp;amp;conn_auth_info_callbacks);
		if (err) {
			printk(&amp;quot;Failed to register authorization info callbacks.\n&amp;quot;);
			return;
	err = bt_enable(NULL);
	if (err) {
		error();
	LOG_INF(&amp;quot;Bluetooth initialized&amp;quot;);
	k_sem_give(&amp;amp;ble_init_ok);
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
   bt_ready();
	err = bt_nus_init(&amp;amp;nus_cb);
	if (err) {
		LOG_ERR(&amp;quot;Failed to initialize UART service (err: %d)&amp;quot;, err);
		return;
	/*err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd,
			      ARRAY_SIZE(sd));
	if (err) {
		LOG_ERR(&amp;quot;Advertising failed to start (err %d)&amp;quot;, err);
		printk(&amp;quot;Advertising failed to start (err %d)&amp;quot;, err);
		return;
//	for (;;) {
//		//dk_set_led(led0, (++blink_status) % 2);
//		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
void ble_write_thread(void)
	/* Don&amp;#39;t go any further until BLE is initialized */
	k_sem_take(&amp;amp;ble_init_ok, K_FOREVER);
	for (;;) {
		/* Wait indefinitely for data to be sent over bluetooth */
		struct uart_data_t *buf = k_fifo_get(&amp;amp;fifo_uart_rx_data,
						     K_FOREVER);
        for(int i=0; i&amp;lt;buf-&amp;gt;len; i++){
		printk(&amp;quot;%c&amp;quot;,buf-&amp;gt;data[i]);
		if (bt_nus_send(NULL, buf-&amp;gt;data, buf-&amp;gt;len)) {
			LOG_WRN(&amp;quot;Failed to send data over BLE connection&amp;quot;);
		k_free(buf);
K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
		NULL, PRIORITY, 0, 0);&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;prj.conf&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;#
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME=&amp;quot;Nordic_UART_Service&amp;quot;
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_ASSERT=y
# i added these 3 lines from child image of coded phy uart pheripheral
CONFIG_BT_EXT_ADV=y
CONFIG_BT_CTLR_ADV_EXT=y
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_LL_SW_SPLIT=y
CONFIG_BT_CTLR_ADVANCED_FEATURES=y
CONFIG_BT_CTLR_CONN_RSSI=y
CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
#CONFIG_BT_USER_PHY_UPDATE=y
#CONFIG_BT_CTLR_TX_PWR_MINUS_20=y
CONFIG_BT_CTLR_TX_PWR_PLUS_8=y
#CONFIG_BT_CTLR_TX_PWR_0=y
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;One more observation, As I was getting the same RSSI value with 2.0.2 and 2.3.0 in the above-coded phy multilink project.so I created a new project peripheral_uart example. It gave me the expected values with -20dbm, 0 &amp;amp; 8dbm with values -83,-63, and -53dbm.With both NCS 2.0.2 &amp;amp; 2.3.0&lt;/p&gt;
&lt;p&gt;Thanks &amp;amp; Regards,&lt;/p&gt;
&lt;p&gt;Muhammad Usman&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nrf52833 output power control</title><link>https://devzone.nordicsemi.com/thread/428171?ContentTypeID=1</link><pubDate>Tue, 30 May 2023 12:56:58 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:946b25d8-a0fc-4191-9856-ca6c3d5f169b</guid><dc:creator>Naeem Maroof</dc:creator><description>&lt;p&gt;Hi Usman,&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Thank you for contacting DevZone at NordicSemi.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;How are you confirming that the configurations are not taking effect?&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Moreover, it is listed in &lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/known_issues.html"&gt;Known issues&lt;/a&gt; (SDK v2.0.2) that this configuration is not working, and a workaround is suggested:&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1685450826647v2.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1685450815176v1.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;Configurations are working in V2.3.0. I have confirmed with a 52840DK.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Regards,&lt;br /&gt;Naeem&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
