<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Zephyr VS Code RTT Terminal Problem</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/100920/zephyr-vs-code-rtt-terminal-problem</link><description>In the Zephyr project, the code works correctly when the RTT terminal is open, but it behaves incorrectly when it is closed. I am controlling a motor with the shell_bt_nus project using data obtained from the nrf toolbox. When the RTT terminal is open</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Wed, 21 Jun 2023 09:23:57 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/100920/zephyr-vs-code-rtt-terminal-problem" /><item><title>RE: Zephyr VS Code RTT Terminal Problem</title><link>https://devzone.nordicsemi.com/thread/432244?ContentTypeID=1</link><pubDate>Wed, 21 Jun 2023 09:23:57 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b3a3e1ca-c1b8-4655-bf59-9138a1131de4</guid><dc:creator>Basri Kilic</dc:creator><description>&lt;p&gt;Thank you. I edited the file you said and the error went away. thank you very much i have been dealing with this error for 1 week&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Zephyr VS Code RTT Terminal Problem</title><link>https://devzone.nordicsemi.com/thread/432238?ContentTypeID=1</link><pubDate>Wed, 21 Jun 2023 09:09:23 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:f92d4b35-5a86-4a7f-a45c-6261064f65ee</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;And you are both using the same SDK and toolchain version? Either way, I suggest you compare the .config file in &amp;lt;build folder&amp;gt;/zephyr/ from both builds to check if the configuration settings are the same.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Zephyr VS Code RTT Terminal Problem</title><link>https://devzone.nordicsemi.com/thread/432169?ContentTypeID=1</link><pubDate>Wed, 21 Jun 2023 05:29:14 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:6c8502d7-3dc3-4421-aa64-5d888af494c4</guid><dc:creator>Basri Kilic</dc:creator><description>&lt;p&gt;&lt;span&gt;I encountered this error while trying to open a project that was actually written by my friend. The project runs without any errors on my friend&amp;#39;s computer. However, when I try to run the project on my own computer, the library paths and config paths remain the same as those on my friend&amp;#39;s computer. How can I fix these paths.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Zephyr VS Code RTT Terminal Problem</title><link>https://devzone.nordicsemi.com/thread/431696?ContentTypeID=1</link><pubDate>Mon, 19 Jun 2023 09:56:54 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:ac6c3eef-f487-48dc-9685-7a59965799c4</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;When you connect the RTT terminal, the chip will be put into&amp;nbsp;&lt;a title="Debug Interface mode" href="https://infocenter.nordicsemi.com/topic/ps_nrf52840/dif.html?cp=5_0_0_3_7_3#debuginterfacemode"&gt;Debug Interface mode&lt;/a&gt;, which will slightly improve your wake-up time from sleep. However, this difference is usually not noticeable, and I&amp;#39;m not sure how it could be affecting your motor control.&lt;/p&gt;
&lt;p&gt;Could you try to test this with nRF Connect SDK v2.4.0 to see if it has the same problem?&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Vidar&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
