<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>NRF SDK supported TLS/SSL algorithms</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/100994/nrf-sdk-supported-tls-ssl-algorithms</link><description>I have a 9160 application that was successfully working using TLS to connect to my server using TLS wrapped sockets. I am moving to a new customer server, and they provided the ca, cert, and key. I loaded the certs on my device but keep receiving socket</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 20 Jun 2023 07:24:56 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/100994/nrf-sdk-supported-tls-ssl-algorithms" /><item><title>RE: NRF SDK supported TLS/SSL algorithms</title><link>https://devzone.nordicsemi.com/thread/431886?ContentTypeID=1</link><pubDate>Tue, 20 Jun 2023 07:24:56 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:0c0b604d-6d62-4cf9-adfb-d2286bd7034a</guid><dc:creator>&amp;#216;yvind</dc:creator><description>&lt;p&gt;Hello,&amp;nbsp;&lt;br /&gt;&lt;br /&gt;Are you able to share some information on what modem FW and SDK version you are running? Assuming it is the same as in case 305164.&lt;/p&gt;
&lt;p&gt;Here are the limitations of modem FW v1.3.1&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="powershell"&gt;*** Limitations
- TLS/DTLS
    - Up to three simultaneous TLS/DTLS connections are possible.
    - Maximum server certificate chain size has a limit of 4kB.
    - Server certificate expiry time is not verified.
    - pkcs#8 is not supported.
    - Absolute maximum number of supported credentials is 32. The actual amount depends on size of
      credentials as memory area reserved for credentials may be a limiting factor as well.
    - DTLS supports PSK authentication only.
    - 2kB secure socket buffer size.
- Maximum number of raw sockets is 4.
- It is recommended to free the modem resources by closing unused network sockets.
- User plane data is supported in Cat M1 mode only.
- TLS is not supported when socket is configured to TCP server mode.
- Support for Non-IP Data Delivery (NIDD). Feature is verified only for NB-IoT and LTE-M is not
  supported.
- The amount of ownership keys is restricted to one. Multiple instances are not allowed. Starting
  from mfw_nrf9160_1.3.1, it is not allowed to write ownership key with AT%CMNG AT command. As this
  change introduces incompatibility between older modem firmware versions, it is recommended to pay
  special attention to this change.
- Downgrading to older modem firmware
    - Keys and certificates written with credential storage management AT commands might get erased
      if older than mfw_nrf9160_1.3.0 modem firmware version is downgraded to a device. If
      downgrading, it is compulsory to check existence of keys and possibly re-write erased keys and
      certificates.
    - AT command configurations written and stored to a non-volatile memory will get erased from the
      memory if old modem firmware is downgraded to a device and that old version does not support
      the AT commands.&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;The&amp;nbsp;issue might be the certs length. If the certificates are from a web server these are often larger than what our device support.&amp;nbsp;&lt;br /&gt;&lt;br /&gt;&lt;br /&gt;The error 104 could be&amp;nbsp;&lt;/p&gt;
&lt;div&gt;
&lt;div&gt;&lt;span style="font-family:&amp;#39;courier new&amp;#39;, courier;"&gt;#define ECONNRESET 104 &amp;nbsp; /**&amp;lt; Connection reset by peer */&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&lt;br /&gt;But I will need more logs and a modem trace in order to know what exactly is the issue here.&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;&lt;span&gt;Kind regards,&lt;br /&gt;Øyvind&lt;/span&gt;&lt;/div&gt;
&lt;/div&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
