<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>AT%XRFTEST TX Test setup B17</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/101034/at-xrftest-tx-test-setup-b17</link><description>Dear DevZone Support
 We plan to perform LTE antenna tests with an external partner. In preparation to this tests I currently setup modem TX-Text configurations in our software.
 I successfully managed to run several configurations: Using Nordics reference</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 27 Jun 2023 13:13:04 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/101034/at-xrftest-tx-test-setup-b17" /><item><title>RE: AT%XRFTEST TX Test setup B17</title><link>https://devzone.nordicsemi.com/thread/433258?ContentTypeID=1</link><pubDate>Tue, 27 Jun 2023 13:13:04 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:69a58536-f131-41f2-a2e4-b646b9ecb631</guid><dc:creator>StefanL</dc:creator><description>&lt;p&gt;Great! That did the trick :-)&lt;/p&gt;
&lt;p&gt;Thanks a lot for your help.&lt;/p&gt;
&lt;p&gt;BR, Stefan&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: AT%XRFTEST TX Test setup B17</title><link>https://devzone.nordicsemi.com/thread/433234?ContentTypeID=1</link><pubDate>Tue, 27 Jun 2023 12:25:53 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:4669aaac-4c63-42ff-812e-18da38729e43</guid><dc:creator>ketiljo</dc:creator><description>&lt;p&gt;Hi Stefan&lt;/p&gt;
&lt;p&gt;If you lock the system mode to NB-IoT, it should work.&lt;/p&gt;
&lt;p&gt;Do AT%XSYSTEMMODE=0,1,0,0&lt;/p&gt;
&lt;p&gt;Then the AT%XRFTEST command.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;As this is a NB-IoT band only, you need to specify the band in system mode.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Regards,&lt;/p&gt;
&lt;p&gt;Ketil&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: AT%XRFTEST TX Test setup B17</title><link>https://devzone.nordicsemi.com/thread/433081?ContentTypeID=1</link><pubDate>Tue, 27 Jun 2023 05:42:19 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:01f0d669-decd-4764-9467-fd7e2afdf683</guid><dc:creator>StefanL</dc:creator><description>&lt;p&gt;Hi Swathy&lt;/p&gt;
&lt;p&gt;The get systemmode command returns the following:&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;%XSYSTEMMODE: 1,1,0,0&lt;/strong&gt;&lt;/p&gt;
&lt;p&gt;That matches my expectations, since I configured &lt;strong&gt;CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT=y &lt;/strong&gt;in the prj.conf file.&lt;/p&gt;
&lt;p&gt;BR, Stefan&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: AT%XRFTEST TX Test setup B17</title><link>https://devzone.nordicsemi.com/thread/432715?ContentTypeID=1</link><pubDate>Fri, 23 Jun 2023 13:41:13 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8f58d590-bea9-4fc2-bf43-7618bcf69826</guid><dc:creator>SwRa</dc:creator><description>&lt;p&gt;Hi Stefan,&lt;/p&gt;
&lt;p&gt;I have asked about this to experts who works in the RF side and will get back to you as soon as I get updates.. Since&amp;nbsp;the band is only supported in NB-IoT mode, just to verify, have you configured the modem correctly with&amp;nbsp;%XSYSTEMMODE ?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Swathy&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: AT%XRFTEST TX Test setup B17</title><link>https://devzone.nordicsemi.com/thread/432062?ContentTypeID=1</link><pubDate>Tue, 20 Jun 2023 14:12:11 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:177ab340-1f7c-486c-83f2-bc6fdc7a9765</guid><dc:creator>StefanL</dc:creator><description>&lt;p&gt;Hi Swathy&lt;/p&gt;
&lt;p&gt;Thanks for taking up my support request.&lt;/p&gt;
&lt;p&gt;I followed your link, and read through it. &lt;span class="HwtZe" lang="en"&gt;&lt;span class="jCAhz ChMk0b"&gt;&lt;span class="ryNqvb"&gt;We plan to run two types of tests (in order to optimize our antenna circuit).&lt;/span&gt;&lt;/span&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span class="HwtZe" lang="en"&gt;&lt;span class="jCAhz ChMk0b"&gt;&lt;span class="ryNqvb"&gt;The first will be a passive test, where we feed in an RF signal via Signal Generator and where we&amp;#39;ll sweep through the interesting frequency spectrum.&lt;/span&gt;&lt;/span&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span class="HwtZe" lang="en"&gt;&lt;span class="jCAhz ChMk0b"&gt;&lt;span class="ryNqvb"&gt;The second will be&amp;nbsp; an &amp;quot;active&amp;quot; Test, where we use the modem TX-Test function to generate a carrier signal on selected frequencies.&lt;/span&gt;&lt;/span&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span class="HwtZe" lang="en"&gt;&lt;span class="jCAhz ChMk0b"&gt;&lt;span class="ryNqvb"&gt;For this second test we aim to generate a carrier signal just above 700 MHz (where B17 lies in). That&amp;#39;s why I want to launch the AT%XRFTEST command with a B17 parameter set.&lt;/span&gt;&lt;/span&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span class="HwtZe" lang="en"&gt;&lt;span class="jCAhz ChMk0b"&gt;&lt;span class="ryNqvb"&gt;BR, Stefan&lt;/span&gt;&lt;/span&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span class="HwtZe" lang="en"&gt;&lt;span class="jCAhz ChMk0b"&gt;&lt;span class="ryNqvb"&gt;*PS: Didn&amp;#39;t find further detail concerning the&amp;nbsp;AT%XRFTEST command on your linked page (it&amp;#39;s rather an overview about possible circuit options for RF testing)&lt;/span&gt;&lt;/span&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: AT%XRFTEST TX Test setup B17</title><link>https://devzone.nordicsemi.com/thread/432038?ContentTypeID=1</link><pubDate>Tue, 20 Jun 2023 13:33:28 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:67010790-99ea-4d43-8d85-b3b5456e27af</guid><dc:creator>SwRa</dc:creator><description>&lt;p&gt;Hi Stefan,&lt;/p&gt;
&lt;p&gt;Could you also take a look at this&amp;nbsp;document and and see if it helps?&amp;nbsp;&lt;a href="https://infocenter.nordicsemi.com/topic/nwp_034/WP/nwp_034/nwp_034_modem_rf.html?cp=2_0_6_4_3_5"&gt;https://infocenter.nordicsemi.com/topic/nwp_034/WP/nwp_034/nwp_034_modem_rf.html?cp=2_0_6_4_3_5&lt;/a&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Swathy&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
