<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Noisy Interrupt using CC Channel at 81-83 Hz and 241 - 243 Hz.</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/101087/noisy-interrupt-using-cc-channel-at-81-83-hz-and-241---243-hz</link><description>I have a GPIOTE programmed to stop Timer2 and record the current value of timer 2. This value is used in some data processing to find either RPM or MPH depending on set up. It runs smoothly and records the current timer value when adjusting input freq</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 07 Jul 2023 16:24:56 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/101087/noisy-interrupt-using-cc-channel-at-81-83-hz-and-241---243-hz" /><item><title>RE: Noisy Interrupt using CC Channel at 81-83 Hz and 241 - 243 Hz.</title><link>https://devzone.nordicsemi.com/thread/435319?ContentTypeID=1</link><pubDate>Fri, 07 Jul 2023 16:24:56 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:1a6a5a36-e1be-4ddb-93af-069fdaf25175</guid><dc:creator>inspiringdev123</dc:creator><description>&lt;p&gt;Timer was being stopped right on the overflow value with these frequencies causing it to be one whole timer period higher at times. Just needed to pause and clear the timer on the interrupt to avoid this anomaly.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Noisy Interrupt using CC Channel at 81-83 Hz and 241 - 243 Hz.</title><link>https://devzone.nordicsemi.com/thread/435318?ContentTypeID=1</link><pubDate>Fri, 07 Jul 2023 16:20:03 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:5e0e2663-26db-46be-a8de-6666a661a34f</guid><dc:creator>Sigurd</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;I haven&amp;#39;t tested your &lt;span&gt;implementation&lt;/span&gt;, but you might want to have a look at the examples posted in this post here:&amp;nbsp;&amp;nbsp;&lt;a href="https://devzone.nordicsemi.com/f/nordic-q-a/34547/ppi-configuration-to-count-pulses/133136"&gt;RE: PPI Configuration to Count Pulses&lt;/a&gt;&amp;nbsp;, and compare that to your own implementation.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Noisy Interrupt using CC Channel at 81-83 Hz and 241 - 243 Hz.</title><link>https://devzone.nordicsemi.com/thread/433280?ContentTypeID=1</link><pubDate>Tue, 27 Jun 2023 13:51:52 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:f1ea2267-b6f6-48a5-8661-91b514f54b11</guid><dc:creator>inspiringdev123</dc:creator><description>&lt;p&gt;It goes through a low pass filter and is going into the nrf in the range from 0-3.3 V DC. Sorry, thought you were referring to the source&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Noisy Interrupt using CC Channel at 81-83 Hz and 241 - 243 Hz.</title><link>https://devzone.nordicsemi.com/thread/433274?ContentTypeID=1</link><pubDate>Tue, 27 Jun 2023 13:48:02 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:75cc4f72-e6c2-4b1e-9164-56d5ac0c7c49</guid><dc:creator>Sigurd</dc:creator><description>&lt;p&gt;&lt;span&gt;You are inputting this square wave to the nRF52832, right?&amp;nbsp;&lt;/span&gt;Are you using some logic level switches? You can&amp;#39;t use these voltages directly on the nRF52832. See&amp;nbsp;I/O pin voltage:&amp;nbsp;&lt;a href="https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52832.ps.v1.1/abs_max_ratings.html?cp=5_2_0_4#abs_max_ratings"&gt;https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52832.ps.v1.1/abs_max_ratings.html?cp=5_2_0_4#abs_max_ratings&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Noisy Interrupt using CC Channel at 81-83 Hz and 241 - 243 Hz.</title><link>https://devzone.nordicsemi.com/thread/433267?ContentTypeID=1</link><pubDate>Tue, 27 Jun 2023 13:36:29 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:81dab75f-aea1-42f1-8444-905c770bb549</guid><dc:creator>inspiringdev123</dc:creator><description>&lt;p&gt;High is 7.5. Low is -2.5.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Noisy Interrupt using CC Channel at 81-83 Hz and 241 - 243 Hz.</title><link>https://devzone.nordicsemi.com/thread/433157?ContentTypeID=1</link><pubDate>Tue, 27 Jun 2023 09:23:03 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:71ca34ea-bd03-46d2-952f-371ad5680124</guid><dc:creator>Sigurd</dc:creator><description>[quote user="inspiringdev123"]VDD of the wave is 10 Vpp with a 2.5 V offset.[/quote]
&lt;p&gt;So high= 3.5V , and low is 1.5V?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Noisy Interrupt using CC Channel at 81-83 Hz and 241 - 243 Hz.</title><link>https://devzone.nordicsemi.com/thread/432741?ContentTypeID=1</link><pubDate>Fri, 23 Jun 2023 15:12:10 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b10ae541-a120-4b13-a026-288e1866b286</guid><dc:creator>inspiringdev123</dc:creator><description>&lt;p&gt;VDD is at 3.58 V. I scoped it and the square wave signal is consistent with what it should be. No anomalies detected. VDD of the wave is 10 Vpp with a 2.5 V offset.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Noisy Interrupt using CC Channel at 81-83 Hz and 241 - 243 Hz.</title><link>https://devzone.nordicsemi.com/thread/432645?ContentTypeID=1</link><pubDate>Fri, 23 Jun 2023 09:30:52 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:02b05ddb-a437-4319-a905-70e5689c1122</guid><dc:creator>Sigurd</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;That sounds strange. What is VDD(supply voltage) used on the nRF52832 device? Do you have a scope image of the&amp;nbsp;&lt;span&gt;square wave signal for when this is happens? What is VDD of the&amp;nbsp;square wave signal?&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Noisy Interrupt using CC Channel at 81-83 Hz and 241 - 243 Hz.</title><link>https://devzone.nordicsemi.com/thread/432545?ContentTypeID=1</link><pubDate>Thu, 22 Jun 2023 13:37:22 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:871fe4bf-5adb-4dcf-9072-29b354d4c7e2</guid><dc:creator>inspiringdev123</dc:creator><description>&lt;p&gt;Yeah so I am sending a square wave from a function generator to a GPIO pin to cause an interrupt to stop the timer count and convert it to MPH or RPM depending on certain attributes. It works smoothly with all frequencies except the ones posted. It seems like the interrupt does not trigger as expected during those frequencies.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Noisy Interrupt using CC Channel at 81-83 Hz and 241 - 243 Hz.</title><link>https://devzone.nordicsemi.com/thread/432521?ContentTypeID=1</link><pubDate>Thu, 22 Jun 2023 12:31:59 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d5e3be5c-8c40-4f6a-9f86-9bda46a49c41</guid><dc:creator>Sigurd</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;Could you explain a bit more what you mean by &amp;quot;Noisy Interrupt&amp;quot; ?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
