<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Trouble programming Thingy 53 via USB Bootloader method</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/101771/trouble-programming-thingy-53-via-usb-bootloader-method</link><description>Two developers at our site are having the same issue trying to flash one of the Nordic pre-compiled examples to two new Thingy:53&amp;#39;s. We are following the Getting Started directions for Updating through USB. We are both using Programmer V3.0.9 under Windows</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Thu, 13 Jul 2023 14:30:11 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/101771/trouble-programming-thingy-53-via-usb-bootloader-method" /><item><title>RE: Trouble programming Thingy 53 via USB Bootloader method</title><link>https://devzone.nordicsemi.com/thread/436293?ContentTypeID=1</link><pubDate>Thu, 13 Jul 2023 14:30:11 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:81971be7-1b25-4b34-bab1-2b1e62008d82</guid><dc:creator>Dale R</dc:creator><description>&lt;p&gt;Great, thank you for confirming that it was not a problem on our end. We will proceed with the DK approach for now...&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Trouble programming Thingy 53 via USB Bootloader method</title><link>https://devzone.nordicsemi.com/thread/436291?ContentTypeID=1</link><pubDate>Thu, 13 Jul 2023 14:27:17 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8a298f8e-49a0-49b6-9b7e-049a273607d4</guid><dc:creator>Kenneth</dc:creator><description>&lt;p&gt;I can see the same here and have reported it now. Due to summer holiday&amp;#39;s etc it may take some time to fix. Please order yourself an nRF5340-DK so you can use for programming and debugging.&lt;/p&gt;
&lt;p&gt;Kenneth&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Trouble programming Thingy 53 via USB Bootloader method</title><link>https://devzone.nordicsemi.com/thread/436065?ContentTypeID=1</link><pubDate>Wed, 12 Jul 2023 16:27:59 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:012c2b21-f381-44dd-a30f-f7289d846f90</guid><dc:creator>Dale R</dc:creator><description>&lt;p&gt;... sorry, I should have mentioned that we just downloaded and used the latest nrfutil v7.5.0.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Trouble programming Thingy 53 via USB Bootloader method</title><link>https://devzone.nordicsemi.com/thread/436063?ContentTypeID=1</link><pubDate>Wed, 12 Jul 2023 16:20:16 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:eb95ec9b-ff68-48d0-a5bf-27aede2ee46b</guid><dc:creator>Dale R</dc:creator><description>&lt;p&gt;Thank you for the reply! We installed and tried nrfutil, both with the ZIP file mentioned above, and also with the app_signed.hex from a Zephyr Blinky binary that we built with VS Code. They each had a different problem.&lt;/p&gt;
&lt;p&gt;With the pre-compiled ZIP file, the console first shows &amp;quot;Erase Image&amp;quot; for about 20 seconds, then it overwrites that, and shows the error shown below. This seems to &amp;quot;feel&amp;quot; similar to what happened when using the Programmer GUI with the ZIP file.&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;nrfutil device program --firmware 2023-06-09-precompiled-application-firmware\Peripheral_LBS\pe
ripheral_lbs\peripheral_lbs_2.4.0_thingy53_nrf5340.zip  --traits mcuBoot
[00:00:20] ###### 100% [5/6 AB1EBC906921406F] Failed, [mcuBoot] Error when programming through MCUBoot: Unable to progra
Error: One or more program tasks failed&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;With the Blinky HEX file, it seems to program and show &amp;quot;Upload image&amp;quot; to &amp;quot;about&amp;quot; 80%, then overwrites that, and shows an error:&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;nrfutil device program --firmware app_signed.hex  --traits mcuBoot
[00:00:24] ###### 100% [5/6 AB1EBC906921406F] Failed, [mcuBoot] Error when programming through MCUBoot: Unable to progra
&lt;p&gt;The reason I say &amp;quot;about&amp;quot; 80% is that that number is slightly different on each run. The second time I tried it was 76%, another time it was 79%, and another it was 89%, so it seems like more of a timing thing than a specific point in the binary upload.&lt;/p&gt;
&lt;p&gt;Of course, this is my first time using nrfutil, so I may just be making some mistake on the command line, or maybe the project that created the Blinky app_signed.hex was not set up correctly.&lt;/p&gt;
&lt;p&gt;Thank you!&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Trouble programming Thingy 53 via USB Bootloader method</title><link>https://devzone.nordicsemi.com/thread/436028?ContentTypeID=1</link><pubDate>Wed, 12 Jul 2023 14:28:27 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b75137e5-8e17-4af8-850f-01caaeea18e9</guid><dc:creator>Kenneth</dc:creator><description>&lt;p&gt;Do you see the same if using nrfutil from command line?&lt;br /&gt;&lt;a href="https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/nrf-util-unified-command-line-utility"&gt;One tool to rule them all: nRF Util becomes a unified command line utility&lt;/a&gt;&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Trouble programming Thingy 53 via USB Bootloader method</title><link>https://devzone.nordicsemi.com/thread/435976?ContentTypeID=1</link><pubDate>Wed, 12 Jul 2023 12:35:03 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:9fcee495-58d6-4bed-8a69-60ad8051e603</guid><dc:creator>Kenneth</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;I don&amp;#39;t have access to a thingy at the moment, but I will try to replicate this later.&lt;/p&gt;
&lt;p&gt;For development I strongly recommend to get a nRF5340-DK for proper development environment (e.g. programming and debugging). Using the nRF5340-DK you can also program and debug the thingy 53:&lt;br /&gt;&lt;a href="https://infocenter.nordicsemi.com/topic/ug_thingy53/UG/thingy53/hw_description/program_debug_if.html"&gt;https://infocenter.nordicsemi.com/topic/ug_thingy53/UG/thingy53/hw_description/program_debug_if.html&lt;/a&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Kenneth&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
