<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Question about SoftDevice behavior at first startup</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/101776/question-about-softdevice-behavior-at-first-startup</link><description>After programming the firmware with nrfjprog, only the first boot seems to take a long time. Is there some special process running in SoftDevice during the first boot?</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Wed, 19 Jul 2023 01:21:19 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/101776/question-about-softdevice-behavior-at-first-startup" /><item><title>RE: Question about SoftDevice behavior at first startup</title><link>https://devzone.nordicsemi.com/thread/437105?ContentTypeID=1</link><pubDate>Wed, 19 Jul 2023 01:21:19 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:f2db23bc-06f7-495d-9f3a-2e95c0df8ca0</guid><dc:creator>kohiro</dc:creator><description>&lt;p&gt;Thanks for the reply.&lt;/p&gt;
&lt;p&gt;I found a simple bug in the application.&lt;/p&gt;
&lt;p&gt;Thanks for the advice.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Question about SoftDevice behavior at first startup</title><link>https://devzone.nordicsemi.com/thread/436681?ContentTypeID=1</link><pubDate>Mon, 17 Jul 2023 09:42:05 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:23f79eb0-0450-4fa9-a85b-cfce045a58ed</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Using the &amp;quot;nrfjprog --readregs&amp;quot; command may help you figure out what state your device is in when it fails to establish communication with your other device. It will read out the CPU registers from a running device without resetting it.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Question about SoftDevice behavior at first startup</title><link>https://devzone.nordicsemi.com/thread/436657?ContentTypeID=1</link><pubDate>Mon, 17 Jul 2023 08:06:14 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:f548ae4f-ff1e-48dc-a770-613f288cbcb6</guid><dc:creator>kohiro</dc:creator><description>&lt;p&gt;Thank you for sharing the documentation.&lt;/p&gt;
&lt;p&gt;Yes, I too am beginning to think it is an application issue.&lt;/p&gt;
&lt;p&gt;After startup, it appears to be working fine without resetting, but there may be a problem with the initialization process at startup, etc.&lt;/p&gt;
&lt;p&gt;I would like to review the process a bit more.&lt;/p&gt;
&lt;p&gt;Thank you very much.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Question about SoftDevice behavior at first startup</title><link>https://devzone.nordicsemi.com/thread/436642?ContentTypeID=1</link><pubDate>Mon, 17 Jul 2023 07:16:09 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:45482b81-366a-4a29-8552-da6478287589</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Yes, the &amp;#39;&lt;a title="Master boot record and SoftDevice reset procedure" href="https://infocenter.nordicsemi.com/topic/sds_s132/SDS/s1xx/mbr_bootloader/mbr_sd_reset_behavior.html?cp=5_7_3_0_11_2"&gt;Master boot record and SoftDevice reset procedure&lt;/a&gt;&amp;#39; section of the Softdevice specification document explains the boot sequence.&amp;nbsp;However,&amp;nbsp;the issue you experience sounds more like an issue with the application. Do you have to reset the device to recover from this?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Question about SoftDevice behavior at first startup</title><link>https://devzone.nordicsemi.com/thread/436605?ContentTypeID=1</link><pubDate>Sun, 16 Jul 2023 23:35:15 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:6c4792d2-d904-4972-a615-025e12c9102d</guid><dc:creator>kohiro</dc:creator><description>&lt;p&gt;Thank you for your reply.&lt;/p&gt;
&lt;p&gt;I have not measured the specific time, but I assumed that the startup process is slow because it sometimes fails to communicate with external devices only at the first startup.&lt;/p&gt;
&lt;p&gt;Is there any documentation somewhere that shows the startup process for soft devices?&lt;/p&gt;
&lt;p&gt;Thanks.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Question about SoftDevice behavior at first startup</title><link>https://devzone.nordicsemi.com/thread/435924?ContentTypeID=1</link><pubDate>Wed, 12 Jul 2023 10:07:15 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:0f481fbc-90e7-4e49-837e-b869209615bb</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;The startup sequence inside the Softdevice remains the same, regardless of whether it is the first boot or not. How much longer is the first boot compared to the second one?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Thanks,&lt;/p&gt;
&lt;p&gt;Vidar&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
