<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>ncs-example-application not compatible with Windows NCS installation</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/102130/ncs-example-application-not-compatible-with-windows-ncs-installation</link><description>Hello,
 I have problems to setup my application when a custom board is used.
 I performed the following steps:
 install NCS 2.4.0 trough Toolchain Manager in Windows 10 at c:\ncs\ according to https://developer.nordicsemi.com/nRF_Connect_SDK</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Mon, 24 Jul 2023 13:44:15 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/102130/ncs-example-application-not-compatible-with-windows-ncs-installation" /><item><title>RE: ncs-example-application not compatible with Windows NCS installation</title><link>https://devzone.nordicsemi.com/thread/437897?ContentTypeID=1</link><pubDate>Mon, 24 Jul 2023 13:44:15 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:494573aa-8918-4e47-ac38-316abbcb7ebb</guid><dc:creator>Mathias Storck</dc:creator><description>&lt;p&gt;I try to understand how to set up projects right using the west.yml.&lt;/p&gt;
&lt;p&gt;We were not using this file before, just set up the workspace by git clone, loaded zephyr via git and builded the project. This worked, but as I learned this is no a good way to do so.&lt;/p&gt;
&lt;p&gt;My goal is to set up a workspace where I can:&lt;/p&gt;
&lt;ul&gt;
&lt;li&gt;develop in Windows on VS Code easily (which means for me an central SDK at a certain place, not to get it every time via &amp;#39;west init&amp;#39;)&lt;/li&gt;
&lt;li&gt;integrate this into CI&lt;/li&gt;
&lt;li&gt;Custom boards&lt;/li&gt;
&lt;li&gt;Custom devicetree bindings&lt;/li&gt;
&lt;li&gt;Out-of-tree drivers&lt;/li&gt;
&lt;li&gt;Out-of-tree libraries&lt;/li&gt;
&lt;/ul&gt;
&lt;p&gt;I&amp;#39;ll have a look at the course, thanks.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: ncs-example-application not compatible with Windows NCS installation</title><link>https://devzone.nordicsemi.com/thread/437874?ContentTypeID=1</link><pubDate>Mon, 24 Jul 2023 12:52:20 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:22717763-e243-483a-9f6b-bcfad17d257d</guid><dc:creator>&amp;#216;yvind</dc:creator><description>&lt;p&gt;Hello Mathias,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Is there a reason for why you want to use this particular application?&lt;/p&gt;
[quote user=""]try to install example application&amp;nbsp;&amp;nbsp;github.com/.../quote]
&lt;p&gt;Looking at the documentation of this sample, this is a stand-alone example which will clone the main branch of the nRF Connect SDK (NCS). You run this command to install NCS manually, as per &lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.4.0/nrf/getting_started/installing.html#get-the-ncs-code"&gt;Get the nRF Connect SDK code&lt;/a&gt;&amp;nbsp;documentation. You will need to initialize in a folder that does not already have NCS initialized e.g. C:\nRFConnectSDK. Note that you need to have all tools correctly installed, as per the statement: &amp;quot;&lt;span&gt;&lt;em&gt;Before getting started, make sure you have a proper nRF Connect SDK &lt;strong&gt;development environment&lt;/strong&gt;&lt;/em&gt;.&amp;quot;. Please see the &lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.4.0/nrf/getting_started/installing.html#installing-manually"&gt;Installing Manually section&lt;/a&gt;.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;This automatically handled for you when installing via Toolchain Manager, which includes everything except VS Code.&lt;/p&gt;
&lt;p&gt;If you are new to NCS I suggest having a look at our Developer Academy which includes a nRF Connect SDK Fundamentals course.&lt;/p&gt;
&lt;p&gt;Kind regards,&lt;br /&gt;Øyvind&lt;/p&gt;[/quote]&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
