<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Configuration CODED-PHY - Warnings KConfig [NRF5340DK &amp;amp; Thingy:53]</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/102303/configuration-coded-phy---warnings-kconfig-nrf5340dk-thingy-53</link><description>Hi all,
 I&amp;#39;m trying do some experiments with BLE5 and the long range feature, to see if it fits our purpose. For this I am using:
 NRF5340DK as the central, which is running the Bluetooth Central Heart Rate Monitor with Coded PHY
 Thingy:53 as the</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Mon, 31 Jul 2023 11:55:05 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/102303/configuration-coded-phy---warnings-kconfig-nrf5340dk-thingy-53" /><item><title>RE: Configuration CODED-PHY - Warnings KConfig [NRF5340DK &amp; Thingy:53]</title><link>https://devzone.nordicsemi.com/thread/439002?ContentTypeID=1</link><pubDate>Mon, 31 Jul 2023 11:55:05 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:30d50e2a-37ec-4642-9216-687d2b1edf92</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Thanks. Yes, the first screenshot&amp;nbsp;shows what I was looking for. However, I don&amp;#39;t see anything wrong.&amp;nbsp;&lt;/p&gt;
[quote user="benna"]Maybe I&amp;nbsp;should try a clean install?[/quote]
&lt;p&gt;You could try to reset the SDK the changes made to the SDK repos (if any) and open the peripheral_hr_coded sample in a new workspace.&lt;/p&gt;
&lt;p&gt;Step 1: Open the command prompt from the Toolchain manager&lt;/p&gt;
&lt;p&gt;Step 2: In the terminal, run the following commands:&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;# Warning: this command will discard all local changes
$ west forall -c &amp;quot;git reset --hard&amp;quot;
# Open VS code from the current directory
$ code .&lt;/pre&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Configuration CODED-PHY - Warnings KConfig [NRF5340DK &amp; Thingy:53]</title><link>https://devzone.nordicsemi.com/thread/438819?ContentTypeID=1</link><pubDate>Fri, 28 Jul 2023 18:25:10 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:e307a9ac-c329-4efe-a204-0754bbe5f513</guid><dc:creator>benna</dc:creator><description>&lt;p&gt;Not sure what you mean, I&amp;#39;m guessing one of following two screenshots :-)&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1690568653054v1.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1690568674198v2.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;Maybe I&amp;nbsp;should try a clean install?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Configuration CODED-PHY - Warnings KConfig [NRF5340DK &amp; Thingy:53]</title><link>https://devzone.nordicsemi.com/thread/438807?ContentTypeID=1</link><pubDate>Fri, 28 Jul 2023 16:12:55 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:9c20cb39-aced-4de0-be6d-4c345d936b48</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;I&amp;#39;m not sure what the problem could be. Would you mind posting a picture of the &amp;#39;APPLICATION&amp;#39; view where the build folder is shown as well?&amp;nbsp;&lt;/p&gt;
[quote user=""]Anyhow, in the .config file of the build files I see that&amp;nbsp; &lt;strong&gt;CONFIG_BT_CTLR_PHY_CODED=y&lt;/strong&gt; and&amp;nbsp;&lt;strong&gt;CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y,&amp;nbsp;&lt;/strong&gt;so I assume that everything is working fine.&amp;nbsp;[/quote]
&lt;p&gt;Yes, this&amp;nbsp;indicates that&amp;nbsp;the symbols are included in the build, so the issue seems to be with the Kconfig GUI viewer.&amp;nbsp;&lt;/p&gt;
[quote user="benna"]Another thing that comes to mind, I have a workspace with multiple examples in, could it have something to do with that?[/quote]
&lt;p&gt;This should not be a problem.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Configuration CODED-PHY - Warnings KConfig [NRF5340DK &amp; Thingy:53]</title><link>https://devzone.nordicsemi.com/thread/438499?ContentTypeID=1</link><pubDate>Thu, 27 Jul 2023 11:29:43 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:caafab16-cac5-4181-9e14-044d1f7b140a</guid><dc:creator>benna</dc:creator><description>&lt;p&gt;The hci_rpsmg.conf looks fine, I didn&amp;#39;t change this:&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;CONFIG_BT_EXT_ADV=y
CONFIG_BT_CTLR_ADV_EXT=y
CONFIG_BT_CTLR_PHY_CODED=y&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;Full build done without errors:&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1690457260538v1.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;Note: My application is called&amp;nbsp;&lt;span&gt;peripheral_hr_coded&lt;strong&gt;_fresh&lt;/strong&gt; because I started from scratch after making something brake in the KConfig and it refused to build. The&amp;nbsp;peripheral_hr_coded is removed from the samples directorty.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Another thing that comes to mind, I have a workspace with multiple examples in, could it have something to do with that?&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1690457381139v2.png" alt=" " /&gt;&lt;/span&gt;&lt;/p&gt;
&lt;div&gt;
&lt;div&gt;&lt;span&gt;&lt;/span&gt;&lt;/div&gt;
&lt;/div&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Configuration CODED-PHY - Warnings KConfig [NRF5340DK &amp; Thingy:53]</title><link>https://devzone.nordicsemi.com/thread/438497?ContentTypeID=1</link><pubDate>Thu, 27 Jul 2023 11:19:11 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:55365f6e-e9db-4996-9de8-fd12d4e9445a</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Hello,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;No problem. Just to confirm, are you still building the peripheral_hr_coded sample and do you have&amp;nbsp;CONFIG_BT_CTLR_PHY_CODED=y set in your child_image/hci_rpmsg.conf file?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Configuration CODED-PHY - Warnings KConfig [NRF5340DK &amp; Thingy:53]</title><link>https://devzone.nordicsemi.com/thread/438492?ContentTypeID=1</link><pubDate>Thu, 27 Jul 2023 11:14:40 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:9fafa308-0c1e-41dd-944c-3514ed41e84a</guid><dc:creator>benna</dc:creator><description>&lt;p&gt;Hello Vidar,&lt;/p&gt;
&lt;p&gt;Thanks for the tip. I&amp;#39;m very new to the environment so I was doing this wrong (I made a seperate build for the network core).&lt;/p&gt;
&lt;p&gt;Although the issue remains the same:&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-2023_2D00_07_2D00_27-131244.png" alt=" " /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Configuration CODED-PHY - Warnings KConfig [NRF5340DK &amp; Thingy:53]</title><link>https://devzone.nordicsemi.com/thread/438489?ContentTypeID=1</link><pubDate>Thu, 27 Jul 2023 11:05:58 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d7d8c061-fc4e-497a-9312-16fd3354dbb9</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;The BT_CTRL_* symbols are defined here &lt;a href="https://github.com/nrfconnect/sdk-zephyr/blob/cccfea24c1a56c75b3f0980dcd9e74783d6bca5f/subsys/bluetooth/controller/Kconfig"&gt;link&lt;/a&gt; and here &lt;a href="https://github.com/nrfconnect/sdk-nrf/blob/main/subsys/bluetooth/controller/Kconfig"&gt;link&lt;/a&gt;&amp;nbsp;apply to the BT controller which reside on the network core in the &amp;#39;hci_rpmsg&amp;#39; child image. Therefore, the&amp;nbsp;&lt;strong&gt;BT_CTLR_PHY_CODED_SUPPORT&amp;nbsp;&lt;/strong&gt;symbol will not be set for the app core image. Did you make sure to select the hci_rpmsg child image before you opened the kconfig GUI?&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1690455945577v1.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Vidar&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
