<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>NCS 2.3.0 FOTA issue when flashing from NCS 1.9.1</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/102452/ncs-2-3-0-fota-issue-when-flashing-from-ncs-1-9-1</link><description>Hi,
 I am working on a custom code based on the sample peripheral_uart for the thingy53. I am using NCS version 2.3.0. Previously, I was working with NCS version 1.9.1.
 I am able to flash the custom code with NCS version 1.9.1 using VS Code without</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 11 Aug 2023 16:27:55 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/102452/ncs-2-3-0-fota-issue-when-flashing-from-ncs-1-9-1" /><item><title>RE: NCS 2.3.0 FOTA issue when flashing from NCS 1.9.1</title><link>https://devzone.nordicsemi.com/thread/441011?ContentTypeID=1</link><pubDate>Fri, 11 Aug 2023 16:27:55 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:56caf5f4-5d3f-4af6-acc8-ab1b7b5ade3a</guid><dc:creator>Hieu</dc:creator><description>[quote user="vthieu"]My guess is that the DFU metadata that the v2.3.0 application wrote on flash is not compatible with the v1.9.1 bootloader.[/quote]
&lt;p&gt;I am second doubting myself&amp;nbsp;regarding this point. I think maybe rather than the metadata being incompatible, it might be that the partitioning is different between your two builds.&lt;/p&gt;
&lt;p&gt;Could you please run a Memory Report on both your v1.9.1 and v2.3.0 applications and send me the result?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NCS 2.3.0 FOTA issue when flashing from NCS 1.9.1</title><link>https://devzone.nordicsemi.com/thread/440853?ContentTypeID=1</link><pubDate>Fri, 11 Aug 2023 03:58:55 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:c7a04168-0d81-4ea1-85e1-c1981aa5a688</guid><dc:creator>Sachin Rawat</dc:creator><description>[quote userid="9456" url="~/f/nordic-q-a/102452/ncs-2-3-0-fota-issue-when-flashing-from-ncs-1-9-1/440774"]Does this issue only happen when you try to further update&amp;nbsp;a device that was initially flashed with v1.9.1 bootloader and application?[/quote]
&lt;p&gt;Yes, if initially flashed with v1.9.1 and then further flashed with v2.3.0 it is not flashing after one time.&lt;/p&gt;
[quote userid="9456" url="~/f/nordic-q-a/102452/ncs-2-3-0-fota-issue-when-flashing-from-ncs-1-9-1/440774"]My guess is that the DFU metadata that the v2.3.0 application wrote on flash is not compatible with the v1.9.1 bootloader.[/quote]
&lt;p&gt;Ohh&lt;/p&gt;
[quote userid="9456" url="~/f/nordic-q-a/102452/ncs-2-3-0-fota-issue-when-flashing-from-ncs-1-9-1/440774"]Or do you really need the v1.9.1 bootloader to continue to work with multiple future v2.3.0 application versions?[/quote]
&lt;p&gt;I am having the number of Thingy53, and as you know their is pre-flashed firmware of EDGE IMPULSE&amp;nbsp; on it.&amp;nbsp;&lt;br /&gt;So can I DFU OTA update that Thingy53 with my latest v2.3.0 SDK firmware code?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NCS 2.3.0 FOTA issue when flashing from NCS 1.9.1</title><link>https://devzone.nordicsemi.com/thread/440774?ContentTypeID=1</link><pubDate>Thu, 10 Aug 2023 13:53:32 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:95dfb232-646d-43f0-8b53-a39deb017811</guid><dc:creator>Hieu</dc:creator><description>[quote user="sachinrawat"]At first I flash the ncs v1.9.1 code using VS code, after successful flash, I connect the board with nrf connect for mobile and try to DFU OTA with the .zip that is created after build for ncs 2.3.0 code. The update looks well. But after this when I again tried to DFU OTA through nrf connect for mobile app with the .zip file of ncs 2.3.0, It won&amp;#39;t update to new firmware(I checked logs).[/quote]
&lt;p&gt;Does this issue only happen when you try to further update&amp;nbsp;a device that was initially flashed with v1.9.1 bootloader and application?&lt;/p&gt;
&lt;p&gt;I looked at your Kconfig and there is nothing that stands out. My guess is that the DFU metadata that the v2.3.0 application wrote on flash is not compatible with the v1.9.1 bootloader.&lt;/p&gt;
&lt;p&gt;If this is the case, when you flash the device with a v2.3.0 bootloader and application, you should be able to update it any numbers of times.&amp;nbsp;Is this possible for you? Or do you really need the v1.9.1 bootloader to continue to work with multiple future v2.3.0 application versions?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NCS 2.3.0 FOTA issue when flashing from NCS 1.9.1</title><link>https://devzone.nordicsemi.com/thread/440214?ContentTypeID=1</link><pubDate>Tue, 08 Aug 2023 05:18:47 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:91a38a70-3bab-4506-8dbe-421a2c759faf</guid><dc:creator>Sachin Rawat</dc:creator><description>&lt;p&gt;Yeah sure, below is the MCUboot child image file .config&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="c_cpp"&gt;
# MCUboot-specific configuration options
# CONFIG_BOOT_USE_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_MCUBOOT_SCRATCH=0x1e000
CONFIG_PM_PARTITION_SIZE_MCUBOOT_PAD=0x200
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
CONFIG_MCUBOOT_NRF_CLEANUP_PERIPHERAL=y
CONFIG_MCUBOOT_NRF_CLEANUP_NONSECURE_RAM=y
CONFIG_BOOT_SIGNATURE_KEY_FILE=&amp;quot;root-rsa-2048.pem&amp;quot;
CONFIG_BOOT_ERASE_PROGRESSIVELY=y
CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
CONFIG_BOOT_IMAGE_ACCESS_HOOK_NRF5340=y
CONFIG_NRF53_MULTI_IMAGE_UPDATE=y
CONFIG_NRF53_MCUBOOT_PRIMARY_1_RAM_FLASH=y
CONFIG_NRF53_RAM_FLASH_SIZE=0x40000
CONFIG_MCUBOOT=y
CONFIG_BOOT_USE_MBEDTLS=y
CONFIG_NRFXLIB_CRYPTO=y
# CONFIG_NRF_CC310_BL is not set
# MCUBoot settings
# CONFIG_SINGLE_APPLICATION_SLOT is not set
# CONFIG_BOOT_SIGNATURE_TYPE_NONE is not set
CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
CONFIG_BOOT_SIGNATURE_TYPE_RSA_LEN=2048
# CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256 is not set
# CONFIG_BOOT_SIGNATURE_TYPE_ED25519 is not set
CONFIG_MCUBOOT_CLEANUP_ARM_CORE=y
CONFIG_MBEDTLS_CFG_FILE=&amp;quot;mcuboot-mbedtls-cfg.h&amp;quot;
# CONFIG_BOOT_HW_KEY is not set
CONFIG_BOOT_VALIDATE_SLOT0=y
CONFIG_BOOT_PREFER_SWAP_MOVE=y
# CONFIG_BOOT_SWAP_USING_SCRATCH is not set
CONFIG_BOOT_UPGRADE_ONLY=y
# CONFIG_BOOT_SWAP_USING_MOVE is not set
# CONFIG_BOOT_DIRECT_XIP is not set
# CONFIG_BOOT_RAM_LOAD is not set
# CONFIG_BOOT_BOOTSTRAP is not set
# CONFIG_BOOT_SWAP_SAVE_ENCTLV is not set
# CONFIG_BOOT_ENCRYPT_RSA is not set
# CONFIG_BOOT_ENCRYPT_EC256 is not set
# CONFIG_BOOT_ENCRYPT_X25519 is not set
CONFIG_BOOT_MAX_IMG_SECTORS=2048
# CONFIG_MEASURED_BOOT is not set
# CONFIG_BOOT_SHARE_DATA is not set
CONFIG_BOOT_FIH_PROFILE_OFF=y
# CONFIG_BOOT_FIH_PROFILE_LOW is not set
# CONFIG_BOOT_FIH_PROFILE_MEDIUM is not set
# CONFIG_BOOT_FIH_PROFILE_HIGH is not set
CONFIG_BOOT_USB_DFU_NO=y
# CONFIG_BOOT_USB_DFU_WAIT is not set
# CONFIG_BOOT_USB_DFU_GPIO is not set
CONFIG_ZEPHYR_TRY_MASS_ERASE=y
# CONFIG_BOOT_USE_BENCH is not set
# CONFIG_MCUBOOT_INDICATION_LED is not set
CONFIG_MCUBOOT_SERIAL=y
# CONFIG_BOOT_SERIAL_UART is not set
CONFIG_BOOT_SERIAL_CDC_ACM=y
CONFIG_MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD=y
CONFIG_BOOT_SERIAL_UNALIGNED_BUFFER_SIZE=64
CONFIG_BOOT_MAX_LINE_INPUT_LEN=512
CONFIG_BOOT_SERIAL_MAX_RECEIVE_SIZE=1024
CONFIG_BOOT_SERIAL_DETECT_PORT=&amp;quot;GPIO_0&amp;quot;
CONFIG_BOOT_SERIAL_DETECT_PIN=-1
CONFIG_BOOT_SERIAL_DETECT_PIN_VAL=0
CONFIG_BOOT_SERIAL_DETECT_DELAY=0
# CONFIG_BOOT_MGMT_ECHO is not set
CONFIG_ENABLE_MGMT_PERUSER=y
CONFIG_BOOT_MGMT_CUSTOM_STORAGE_ERASE=y
# CONFIG_BOOT_MGMT_CUSTOM_IMG_LIST is not set
# CONFIG_BOOT_SERIAL_ENCRYPT_EC256 is not set
# CONFIG_BOOT_INTR_VEC_RELOC is not set
CONFIG_UPDATEABLE_IMAGE_NUMBER=2
CONFIG_BOOT_WATCHDOG_FEED=y
# CONFIG_MCUBOOT_ACTION_HOOKS is not set
# end of MCUBoot settings
CONFIG_MCUBOOT_DEVICE_SETTINGS=y
# Zephyr configuration options
CONFIG_MULTITHREADING=y
CONFIG_USB_DEVICE_PRODUCT=&amp;quot;Bootloader Thingy:53&amp;quot;
CONFIG_MCUBOOT_VERIFY_IMG_ADDRESS=y
CONFIG_GPIO=y
# CONFIG_KSCAN is not set
# CONFIG_WIFI is not set
# CONFIG_SPI is not set
CONFIG_GPIO_INIT_PRIORITY=40
# CONFIG_WATCHDOG is not set
# CONFIG_MODEM is not set
# CONFIG_I2C is not set
# CONFIG_SENSOR is not set
CONFIG_BOARD=&amp;quot;thingy53_nrf5340_cpuapp&amp;quot;
# CONFIG_BOARD_ENABLE_CPUNET is not set
CONFIG_FLASH_LOAD_SIZE=0x10000
CONFIG_SRAM_SIZE=448
CONFIG_FLASH_LOAD_OFFSET=0x0
CONFIG_HEAP_MEM_POOL_SIZE=0
CONFIG_USB_NRFX_ATTACHED_EVENT_DELAY=700
CONFIG_REGULATOR=y
CONFIG_USB_DEVICE_VID=0x1915
CONFIG_USB_DEVICE_PID=0x5300
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_CDC_ACM=y
# CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT is not set
# CONFIG_USB_DEVICE_REMOTE_WAKEUP is not set
CONFIG_SOC=&amp;quot;nRF5340_CPUAPP_QKAA&amp;quot;
CONFIG_SOC_SERIES=&amp;quot;nrf53&amp;quot;
CONFIG_NUM_IRQS=69
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_ROM_START_OFFSET=0
CONFIG_PINCTRL=y
# CONFIG_RESET is not set
CONFIG_CLOCK_CONTROL=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
# CONFIG_PM is not set
# CONFIG_PM_DEVICE is not set
CONFIG_NRF_RTC_TIMER=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_SERIAL_INIT_PRIORITY=55
# CONFIG_FPU is not set
CONFIG_MBEDTLS=y
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_TINYCRYPT is not set
CONFIG_SERIAL=y
CONFIG_MAIN_STACK_SIZE=10240
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_HAS_DTS=y
# Devicetree Info
CONFIG_DT_HAS_ADI_ADXL362_ENABLED=y
CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y
CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
CONFIG_DT_HAS_BOSCH_BME680_ENABLED=y
CONFIG_DT_HAS_BOSCH_BMM150_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CC312_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_FORWARDER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RTC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED=y
CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
CONFIG_DT_HAS_REGULATOR_FIXED_ENABLED=y
CONFIG_DT_HAS_ROHM_BH1749_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_VOLTAGE_DIVIDER_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_CDC_ACM_UART_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_SIM_FLASH_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# nrf (D:/v2.3.0/nrf)
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
# CONFIG_INIT_STACKS is not set
# Nordic nRF Connect
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_MCUMGR_BUF_SIZE=1024
CONFIG_BT_BUF_CMD_TX_COUNT=10
# CONFIG_ENTROPY_GENERATOR is not set
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# Image build variants
CONFIG_NCS_MCUBOOT_IN_BUILD=y
# end of Image build variants
CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=16
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_SECURE_BOOT_CRYPTO is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# end of Bootloader
# Bluetooth Low Energy
# BLE over nRF RPC
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# CONFIG_EMDS is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
CONFIG_PCD_APP=y
# CONFIG_PCD_NET is not set
# CONFIG_PCD_USE_CONSTANTS is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
CONFIG_NRF_CLOUD_CLIENT_ID=&amp;quot;my-client-id&amp;quot;
# end of Client ID (nRF Cloud Device ID)
# CONFIG_NRF_CLOUD_MQTT is not set
# CONFIG_NRF_CLOUD_FOTA is not set
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_REST is not set
# CONFIG_NRF_CLOUD_ALERTS is not set
# CONFIG_NRF_CLOUD_GATEWAY is not set
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# CONFIG_WIFI_CREDENTIALS_STATIC is not set
# CONFIG_MQTT_HELPER is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
# CONFIG_FW_INFO is not set
# Debug
# CONFIG_PPI_TRACE is not set
# CONFIG_CPU_LOAD is not set
# end of Debug
# CONFIG_MPSL_FEM_ONLY is not set
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_WORK_STACK_SIZE=1024
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_BASE_ADDRESS=0x20000000
# Zephyr subsystem configurations
# end of Zephyr subsystem configurations
# NCS subsystem configurations
# CONFIG_PM_SINGLE_IMAGE is not set
CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x80000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# CONFIG_ZIGBEE is not set
# Full Modem Firmware Update Management(FMFU)
# end of Full Modem Firmware Update Management(FMFU)
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
# Libraries
# Binary libraries
# end of Binary libraries
# CONFIG_ADP536X is not set
# CONFIG_AT_MONITOR is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
CONFIG_FPROTECT_BLOCK_SIZE=0x4000
CONFIG_FPROTECT=y
# CONFIG_FPROTECT_APP is not set
# CONFIG_AT_CUSTOM_CMD is not set
# CONFIG_DK_LIBRARY is not set
# CONFIG_MODEM_INFO is not set
# CONFIG_RESET_ON_FATAL_ERROR is not set
# CONFIG_SMS is not set
# CONFIG_SUPL_CLIENT_LIB is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
# CONFIG_MODEM_JWT is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
CONFIG_HW_CC3XX=y
# CONFIG_ETH_RTT is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (D:/v2.3.0/nrf)
# hostap (D:/v2.3.0/modules/lib/hostap)
CONFIG_POSIX_MAX_FDS=4
CONFIG_ZEPHYR_HOSTAP_MODULE=y
# end of hostap (D:/v2.3.0/modules/lib/hostap)
# mcuboot (D:/v2.3.0/bootloader/mcuboot)
# MCUboot
CONFIG_SIGN_IMAGES=y
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM=y
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (D:/v2.3.0/bootloader/mcuboot)
# mbedtls (D:/v2.3.0/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
CONFIG_MBEDTLS_BUILTIN=y
# CONFIG_MBEDTLS_LIBRARY is not set
# CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=1500
# CONFIG_MBEDTLS_DEBUG is not set
# CONFIG_MBEDTLS_MEMORY_DEBUG is not set
# CONFIG_MBEDTLS_TEST is not set
# CONFIG_MBEDTLS_ENABLE_HEAP is not set
# CONFIG_MBEDTLS_ZEPHYR_ENTROPY is not set
CONFIG_APP_LINK_WITH_MBEDTLS=y
# PSA RNG support
# CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
# CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
# end of PSA RNG support
CONFIG_PSA_HAS_KEY_SUPPORT=y
CONFIG_PSA_WANT_KEY_TYPE_DERIVE=y
CONFIG_PSA_WANT_KEY_TYPE_HMAC=y
CONFIG_PSA_WANT_KEY_TYPE_AES=y
CONFIG_PSA_WANT_KEY_TYPE_CHACHA20=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY=y
# PSA AEAD support
CONFIG_PSA_HAS_AEAD_SUPPORT=y
CONFIG_PSA_WANT_ALG_CCM=y
CONFIG_PSA_WANT_ALG_GCM=y
CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305=y
# end of PSA AEAD support
# PSA MAC support
CONFIG_PSA_HAS_MAC_SUPPORT=y
CONFIG_PSA_WANT_ALG_CMAC=y
CONFIG_PSA_WANT_ALG_HMAC=y
# end of PSA MAC support
# PSA Hash support
CONFIG_PSA_HAS_HASH_SUPPORT=y
CONFIG_PSA_WANT_ALG_SHA_1=y
CONFIG_PSA_WANT_ALG_SHA_224=y
CONFIG_PSA_WANT_ALG_SHA_256=y
CONFIG_PSA_WANT_ALG_SHA_384=y
CONFIG_PSA_WANT_ALG_SHA_512=y
CONFIG_PSA_WANT_ALG_RIPEMD160=y
CONFIG_PSA_WANT_ALG_MD5=y
# end of PSA Hash support
# PSA Cipher support
CONFIG_PSA_HAS_CIPHER_SUPPORT=y
CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y
CONFIG_PSA_WANT_ALG_CBC_NO_PADDING=y
CONFIG_PSA_WANT_ALG_CBC_PKCS7=y
CONFIG_PSA_WANT_ALG_CFB=y
CONFIG_PSA_WANT_ALG_CTR=y
CONFIG_PSA_WANT_ALG_OFB=y
# end of PSA Cipher support
# PSA Key derivation support
CONFIG_PSA_HAS_KEY_DERIVATION=y
CONFIG_PSA_WANT_ALG_HKDF=y
# CONFIG_PSA_WANT_ALG_TLS12_PRF is not set
# CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS is not set
# end of PSA Key derivation support
# PSA Asymmetric support
CONFIG_PSA_HAS_ASYM_SIGN_SUPPORT=y
CONFIG_PSA_HAS_ECC_SUPPORT=y
CONFIG_PSA_WANT_ALG_ECDH=y
CONFIG_PSA_WANT_ALG_ECDSA=y
CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA=y
# Elliptic Curve type support
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
# CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
# CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
CONFIG_PSA_WANT_ECC_SECP_R1_256=y
# CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
# end of Elliptic Curve type support
# CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS is not set
# end of PSA Asymmetric support
CONFIG_PSA_WANT_ALG_STREAM_CIPHER=y
# end of mbedtls (D:/v2.3.0/modules/crypto/mbedtls)
# trusted-firmware-m (D:/v2.3.0/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (D:/v2.3.0/modules/tee/tf-m/trusted-firmware-m)
# cjson (D:/v2.3.0/modules/lib/cjson)
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (D:/v2.3.0/modules/lib/cjson)
# azure-sdk-for-c (D:/v2.3.0/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (D:/v2.3.0/modules/lib/azure-sdk-for-c)
# memfault-firmware-sdk (D:/v2.3.0/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (D:/v2.3.0/modules/lib/memfault-firmware-sdk)
# cirrus-logic (D:/v2.3.0/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (D:/v2.3.0/modules/hal/cirrus-logic)
# openthread (D:/v2.3.0/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (D:/v2.3.0/modules/lib/openthread)
# canopennode (D:/v2.3.0/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (D:/v2.3.0/modules/lib/canopennode)
# chre (D:/v2.3.0/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (D:/v2.3.0/modules/lib/chre)
# fatfs (D:/v2.3.0/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (D:/v2.3.0/modules/fs/fatfs)
# hal_nordic (D:/v2.3.0/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_SER_HOST is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
# CONFIG_NRFX_COMP is not set
# CONFIG_NRFX_DPPI is not set
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
# CONFIG_NRFX_I2S is not set
# CONFIG_NRFX_IPC is not set
# CONFIG_NRFX_NFCT is not set
CONFIG_NRFX_NVMC=y
# CONFIG_NRFX_PDM is not set
CONFIG_NRFX_POWER=y
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC is not set
CONFIG_NRFX_QSPI=y
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_SAADC is not set
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SPIM1 is not set
# CONFIG_NRFX_SPIM2 is not set
# CONFIG_NRFX_SPIM3 is not set
# CONFIG_NRFX_SPIM4 is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TWIM0 is not set
# CONFIG_NRFX_TWIM1 is not set
# CONFIG_NRFX_TWIM2 is not set
# CONFIG_NRFX_TWIM3 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_UARTE2 is not set
# CONFIG_NRFX_UARTE3 is not set
CONFIG_NRFX_USBD=y
CONFIG_NRFX_USBREG=y
CONFIG_NRFX_WDT=y
CONFIG_NRFX_WDT0=y
CONFIG_NRFX_WDT1=y
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
# end of nrfx drivers
# end of hal_nordic (D:/v2.3.0/modules/hal/nordic)
# liblc3 (D:/v2.3.0/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (D:/v2.3.0/modules/lib/liblc3)
# littlefs (D:/v2.3.0/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (D:/v2.3.0/modules/fs/littlefs)
# loramac-node (D:/v2.3.0/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (D:/v2.3.0/modules/lib/loramac-node)
# lvgl (D:/v2.3.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (D:/v2.3.0/modules/lib/gui/lvgl)
# lz4 (D:/v2.3.0/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (D:/v2.3.0/modules/lib/lz4)
# nanopb (D:/v2.3.0/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (D:/v2.3.0/modules/lib/nanopb)
# picolibc (D:/v2.3.0/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (D:/v2.3.0/modules/lib/picolibc)
# TraceRecorder (D:/v2.3.0/modules/debug/TraceRecorder)
CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
# end of TraceRecorder (D:/v2.3.0/modules/debug/TraceRecorder)
# uoscore-uedhoc (D:/v2.3.0/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (D:/v2.3.0/modules/lib/uoscore-uedhoc)
# zcbor (D:/v2.3.0/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# CONFIG_ZCBOR is not set
# end of zcbor (D:/v2.3.0/modules/lib/zcbor)
# zscilib (D:/v2.3.0/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (D:/v2.3.0/modules/lib/zscilib)
# nrfxlib (D:/v2.3.0/nrfxlib)
# Nordic nrfxlib
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# Crypto libraries for nRF5x SOCs.
CONFIG_CRYPTOCELL_CC312_USABLE=y
CONFIG_CRYPTOCELL_USABLE=y
# CONFIG_NRF_OBERON is not set
CONFIG_NRF_CC3XX_PLATFORM=y
# CONFIG_HW_CC3XX_INTERRUPT is not set
CONFIG_CC3XX_MUTEX_LOCK=y
# CONFIG_CC3XX_ATOMIC_LOCK is not set
# CONFIG_CC3XX_HW_MUTEX_LOCK is not set
# end of Crypto libraries for nRF5x SOCs.
# nrf_security module
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# end of nrf_security module
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_LC3_PLC_DISABLED is not set
CONFIG_LC3_ENC_CHAN_MAX=1
CONFIG_LC3_DEC_CHAN_MAX=1
# Encoder sample rates
CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
# end of Encoder sample rates
# Decoder sample rates
CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
# end of Decoder sample rates
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (D:/v2.3.0/nrfxlib)
# connectedhomeip (D:/v2.3.0/modules/lib/matter)
# CONFIG_CHIP is not set
# CONFIG_CHIP_LOG_SIZE_OPTIMIZATION is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (D:/v2.3.0/modules/lib/matter)
# Optional modules. Make sure they&amp;#39;re installed, via the project manifest.
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_NN is not set
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_SOF is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_TINYCBOR is not set
CONFIG_MCUBOOT_BOOTUTIL_LIB=y
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# end of Modules
CONFIG_BOARD_REVISION=&amp;quot;$BOARD_REVISION&amp;quot;
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_THINGY53_NRF5340_CPUAPP=y
# CONFIG_BOARD_THINGY53_NRF5340_CPUAPP_NS is not set
# Board Options
CONFIG_THINGY53_INIT_PRIORITY=79
CONFIG_BOARD_ENABLE_DCDC_APP=y
CONFIG_BOARD_ENABLE_DCDC_NET=y
CONFIG_BOARD_ENABLE_DCDC_HV=y
# CONFIG_BOARD_SERIAL_BACKEND_CDC_ACM is not set
# end of Board Options
# CONFIG_SOC_SERIES_BEETLE is not set
# CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
# CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
# CONFIG_SOC_SERIES_MPS2 is not set
# CONFIG_SOC_SERIES_MPS3 is not set
# CONFIG_SOC_SERIES_MUSCA_B1 is not set
# CONFIG_SOC_SERIES_MUSCA_S1 is not set
# CONFIG_SOC_SERIES_AST10X0 is not set
# CONFIG_SOC_SERIES_SAMC20 is not set
# CONFIG_SOC_SERIES_SAMC21 is not set
# CONFIG_SOC_SERIES_SAMD20 is not set
# CONFIG_SOC_SERIES_SAMD21 is not set
# CONFIG_SOC_SERIES_SAMD51 is not set
# CONFIG_SOC_SERIES_SAME51 is not set
# CONFIG_SOC_SERIES_SAME53 is not set
# CONFIG_SOC_SERIES_SAME54 is not set
# CONFIG_SOC_SERIES_SAML21 is not set
# CONFIG_SOC_SERIES_SAMR21 is not set
# CONFIG_SOC_SERIES_SAMR34 is not set
# CONFIG_SOC_SERIES_SAMR35 is not set
# CONFIG_SOC_SERIES_SAM3X is not set
# CONFIG_SOC_SERIES_SAM4E is not set
# CONFIG_SOC_SERIES_SAM4L is not set
# CONFIG_SOC_SERIES_SAM4S is not set
# CONFIG_SOC_SERIES_SAME70 is not set
# CONFIG_SOC_SERIES_SAMV71 is not set
# CONFIG_SOC_SERIES_VALKYRIE is not set
# CONFIG_SOC_SERIES_VIPER is not set
# CONFIG_SOC_SERIES_PSOC62 is not set
# CONFIG_SOC_SERIES_PSOC63 is not set
# CONFIG_SOC_SERIES_GD32E10X is not set
# CONFIG_SOC_SERIES_GD32E50X is not set
# CONFIG_SOC_SERIES_GD32F3X0 is not set
# CONFIG_SOC_SERIES_GD32F403 is not set
# CONFIG_SOC_SERIES_GD32F4XX is not set
# CONFIG_SOC_SERIES_XMC_4XXX is not set
# CONFIG_SOC_SERIES_CYCLONE5 is not set
# CONFIG_SOC_SERIES_MEC1501X is not set
# CONFIG_SOC_SERIES_MEC1701X is not set
# CONFIG_SOC_SERIES_MEC172X is not set
# CONFIG_SOC_SERIES_NRF51X is not set
# CONFIG_SOC_SERIES_NRF52X is not set
CONFIG_SOC_SERIES_NRF53X=y
# CONFIG_SOC_SERIES_NRF91X is not set
# CONFIG_SOC_SERIES_NPCX7 is not set
# CONFIG_SOC_SERIES_NPCX9 is not set
# CONFIG_SOC_SERIES_M48X is not set
# CONFIG_SOC_SERIES_IMX_6X_M4 is not set
# CONFIG_SOC_SERIES_IMX7_M4 is not set
# CONFIG_SOC_SERIES_IMX8ML_M7 is not set
# CONFIG_SOC_SERIES_IMX8MM_M4 is not set
# CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
# CONFIG_SOC_SERIES_IMX_RT5XX is not set
# CONFIG_SOC_SERIES_IMX_RT6XX is not set
# CONFIG_SOC_SERIES_IMX_RT is not set
# CONFIG_SOC_SERIES_KINETIS_K2X is not set
# CONFIG_SOC_SERIES_KINETIS_K6X is not set
# CONFIG_SOC_SERIES_KINETIS_K8X is not set
# CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
# CONFIG_SOC_SERIES_KINETIS_KL2X is not set
# CONFIG_SOC_SERIES_KINETIS_KV5X is not set
# CONFIG_SOC_SERIES_KINETIS_KWX is not set
# CONFIG_SOC_SERIES_LPC11U6X is not set
# CONFIG_SOC_SERIES_LPC51U68 is not set
# CONFIG_SOC_SERIES_LPC54XXX is not set
# CONFIG_SOC_SERIES_LPC55XXX is not set
# CONFIG_SOC_SERIES_S32ZE_R52 is not set
# CONFIG_SOC_EOS_S3 is not set
# CONFIG_SOC_SERIES_RCAR_GEN3 is not set
# CONFIG_SOC_SERIES_DA1469X is not set
# CONFIG_SOC_SERIES_RP2XXX is not set
# CONFIG_SOC_SERIES_EFM32GG11B is not set
# CONFIG_SOC_SERIES_EFM32HG is not set
# CONFIG_SOC_SERIES_EFM32JG12B is not set
# CONFIG_SOC_SERIES_EFM32PG12B is not set
# CONFIG_SOC_SERIES_EFM32PG1B is not set
# CONFIG_SOC_SERIES_EFM32WG is not set
# CONFIG_SOC_SERIES_EFR32BG13P is not set
# CONFIG_SOC_SERIES_EFR32FG13P is not set
# CONFIG_SOC_SERIES_EFR32FG1P is not set
# CONFIG_SOC_SERIES_EFR32MG12P is not set
# CONFIG_SOC_SERIES_EFR32MG21 is not set
# CONFIG_SOC_SERIES_STM32F0X is not set
# CONFIG_SOC_SERIES_STM32F1X is not set
# CONFIG_SOC_SERIES_STM32F2X is not set
# CONFIG_SOC_SERIES_STM32F3X is not set
# CONFIG_SOC_SERIES_STM32F4X is not set
# CONFIG_SOC_SERIES_STM32F7X is not set
# CONFIG_SOC_SERIES_STM32G0X is not set
# CONFIG_SOC_SERIES_STM32G4X is not set
# CONFIG_SOC_SERIES_STM32H7X is not set
# CONFIG_SOC_SERIES_STM32L0X is not set
# CONFIG_SOC_SERIES_STM32L1X is not set
# CONFIG_SOC_SERIES_STM32L4X is not set
# CONFIG_SOC_SERIES_STM32L5X is not set
# CONFIG_SOC_SERIES_STM32MP1X is not set
# CONFIG_SOC_SERIES_STM32U5X is not set
# CONFIG_SOC_SERIES_STM32WBX is not set
# CONFIG_SOC_SERIES_STM32WLX is not set
# CONFIG_SOC_TI_LM3S6965 is not set
# CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
# CONFIG_SOC_SERIES_CC32XX is not set
# CONFIG_SOC_SERIES_MSP432P4XX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
# CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
# Hardware Configuration
CONFIG_CPU_HAS_ARM_MPU=y
CONFIG_CPU_HAS_NRF_IDAU=y
CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
CONFIG_HAS_SWO=y
CONFIG_SOC_FAMILY=&amp;quot;nordic_nrf&amp;quot;
CONFIG_SOC_FAMILY_NRF=y
CONFIG_HAS_HW_NRF_CC312=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_CTRLAP=y
CONFIG_HAS_HW_NRF_DCNF=y
CONFIG_HAS_HW_NRF_DPPIC=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE=y
CONFIG_HAS_HW_NRF_IPC=y
CONFIG_HAS_HW_NRF_KMU=y
CONFIG_HAS_HW_NRF_MUTEX=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_OSCILLATORS=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_PWM1=y
CONFIG_HAS_HW_NRF_QSPI=y
CONFIG_HAS_HW_NRF_REGULATORS=y
CONFIG_HAS_HW_NRF_RESET=y
CONFIG_HAS_HW_NRF_RTC0=y
CONFIG_HAS_HW_NRF_RTC1=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPIM3=y
CONFIG_HAS_HW_NRF_SPU=y
CONFIG_HAS_HW_NRF_TIMER0=y
CONFIG_HAS_HW_NRF_TIMER1=y
CONFIG_HAS_HW_NRF_TIMER2=y
CONFIG_HAS_HW_NRF_TWIM1=y
CONFIG_HAS_HW_NRF_USBD=y
CONFIG_HAS_HW_NRF_USBREG=y
CONFIG_HAS_HW_NRF_VMC=y
CONFIG_HAS_HW_NRF_WDT0=y
CONFIG_NRF_HW_RTC1_RESERVED=y
CONFIG_SOC_NRF5340_CPUAPP=y
CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
# CONFIG_SOC_NRF5340_CPUNET_QKAA is not set
CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
CONFIG_SOC_DCDC_NRF53X_APP=y
CONFIG_SOC_DCDC_NRF53X_NET=y
CONFIG_SOC_DCDC_NRF53X_HV=y
CONFIG_SOC_ENABLE_LFXO=y
# CONFIG_SOC_LFXO_CAP_EXTERNAL is not set
# CONFIG_SOC_LFXO_CAP_INT_6PF is not set
CONFIG_SOC_LFXO_CAP_INT_7PF=y
# CONFIG_SOC_LFXO_CAP_INT_9PF is not set
CONFIG_SOC_HFXO_CAP_DEFAULT=y
# CONFIG_SOC_HFXO_CAP_EXTERNAL is not set
# CONFIG_SOC_HFXO_CAP_INTERNAL is not set
CONFIG_NRF_ENABLE_CACHE=y
# CONFIG_NRF53_SYNC_RTC is not set
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
# CONFIG_NFCT_PINS_AS_GPIOS is not set
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_APPROTECT_USER_HANDLING is not set
CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
# CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
# CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
# CONFIG_NRF_TRACE_PORT is not set
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
# ARM Options
CONFIG_ARCH=&amp;quot;arm&amp;quot;
CONFIG_CPU_CORTEX=y
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
CONFIG_CPU_CORTEX_M=y
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_FAULT_DUMP=2
CONFIG_BUILTIN_STACK_GUARD=y
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M33=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_CPU_CORTEX_M_HAS_CMSE=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_SE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
CONFIG_ARMV8_M_DSP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_GEN_ISR_TABLES=y
# CONFIG_ZERO_LATENCY_IRQS is not set
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_ARM_TRUSTZONE_M=y
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_STACK_GUARD is not set
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
CONFIG_LITTLE_ENDIAN=y
# CONFIG_TRUSTED_EXECUTION_SECURE is not set
# CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_GEN_IRQ_START_VECTOR=0
# CONFIG_EXTRA_EXCEPTION_INFO is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_TEE=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
CONFIG_MPU_GAP_FILLING=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
# General Kernel Options
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_IDLE_STACK_SIZE=320
CONFIG_ISR_STACK_SIZE=2048
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
# CONFIG_ERRNO is not set
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Kernel Debugging and Metrics
# CONFIG_BOOT_BANNER is not set
CONFIG_BOOT_DELAY=0
# CONFIG_THREAD_MONITOR is not set
# CONFIG_THREAD_NAME is not set
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# Work Queue Options
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of Work Queue Options
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
# CONFIG_TIMESLICING is not set
# CONFIG_POLL is not set
# end of Timer API Options
# Other Kernel Object Options
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_PIPES is not set
CONFIG_KERNEL_MEM_POOL=y
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
CONFIG_XIP=y
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Security Options
# end of Security Options
# SMP Options
CONFIG_MP_NUM_CPUS=1
# end of SMP Options
CONFIG_TICKLESS_KERNEL=y
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
# CONFIG_THREAD_LOCAL_STORAGE is not set
# end of General Kernel Options
# Device Options
# end of Device Options
# Virtual Memory Support
# end of Virtual Memory Support
# Device Drivers
# CONFIG_LORA is not set
# CONFIG_CONSOLE is not set
CONFIG_HAS_SEGGER_RTT=y
# CONFIG_USE_SEGGER_RTT is not set
CONFIG_ETH_INIT_PRIORITY=80
# CONFIG_MDIO is not set
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
CONFIG_UART_USE_RUNTIME_CONFIGURE=y
CONFIG_UART_LINE_CTRL=y
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# CONFIG_UART_PIPE is not set
# Serial Drivers
# Interrupt Controllers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# CONFIG_INTC_ESP32 is not set
# end of Interrupt Controllers
# Timer Drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
CONFIG_SYSTEM_CLOCK_NO_WAIT=y
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY is not set
# end of Timer Drivers
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
CONFIG_GPIO_NRFX=y
# CONFIG_SDHC is not set
# CONFIG_I3C is not set
# CONFIG_I2S is not set
# CONFIG_DAI is not set
# CONFIG_PWM is not set
# CONFIG_PINMUX is not set
# CONFIG_ADC is not set
# CONFIG_DAC is not set
# CONFIG_W1 is not set
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_PTP_CLOCK is not set
# CONFIG_IPM is not set
CONFIG_FLASH_HAS_DRIVER_ENABLED=y
CONFIG_FLASH_HAS_PAGE_LAYOUT=y
CONFIG_FLASH_JESD216=y
CONFIG_FLASH=y
# CONFIG_FLASH_JESD216_API is not set
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_INIT_PRIORITY=50
CONFIG_SOC_FLASH_NRF=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
# CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
# CONFIG_SOC_FLASH_NRF_UICR is not set
CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y
CONFIG_FLASH_SIMULATOR=y
CONFIG_FLASH_SIMULATOR_UNALIGNED_READ=y
CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
# CONFIG_FLASH_SIMULATOR_SIMULATE_TIMING is not set
# CONFIG_FLASH_SIMULATOR_STATS is not set
CONFIG_NORDIC_QSPI_NOR_INIT_PRIORITY=80
# CONFIG_COUNTER is not set
# CONFIG_DMA is not set
# CONFIG_UDC_DRIVER is not set
CONFIG_USB_DEVICE_DRIVER=y
# CONFIG_USB_DC_HAS_HS_SUPPORT is not set
CONFIG_USB_NRFX=y
CONFIG_USB_NRFX_EVT_QUEUE_SIZE=32
CONFIG_USB_NRFX_WORK_QUEUE_STACK_SIZE=1024
# CONFIG_USB_NATIVE_POSIX is not set
# CONFIG_CRYPTO is not set
# CONFIG_DISPLAY is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LED is not set
# CONFIG_CAN is not set
# CONFIG_AUDIO is not set
# CONFIG_NEURAL_NET_ACCEL is not set
CONFIG_HWINFO=y
CONFIG_HWINFO_NRF=y
# CONFIG_ESPI is not set
# CONFIG_PS2 is not set
# CONFIG_VIDEO is not set
# CONFIG_EEPROM is not set
# CONFIG_PECI is not set
# CONFIG_PECI_INTERRUPT_DRIVEN is not set
CONFIG_REGULATOR_FIXED=y
CONFIG_REGULATOR_FIXED_INIT_PRIORITY=75
# CONFIG_MEMC is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_EDAC is not set
# CONFIG_PM_CPU_OPS is not set
# Miscellaneous Drivers
# CONFIG_GROVE_LCD_RGB is not set
# end of Miscellaneous Drivers
# CONFIG_DISK_DRIVERS is not set
# CONFIG_CACHE is not set
# CONFIG_SYSCON is not set
# CONFIG_BBRAM is not set
# CONFIG_FPGA is not set
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_MBOX is not set
# CONFIG_MM_DRV is not set
# CONFIG_POWER_DOMAIN is not set
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_MIPI_DSI is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_FUEL_GAUGE is not set
# C Library
CONFIG_SUPPORT_MINIMAL_LIBC=y
CONFIG_PICOLIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC=y
# CONFIG_PICOLIBC is not set
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_MINIMAL_LIBC_NON_REENTRANT_FUNCTIONS=y
CONFIG_MINIMAL_LIBC_MALLOC=y
CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=0
CONFIG_MINIMAL_LIBC_CALLOC=y
CONFIG_MINIMAL_LIBC_REALLOCARRAY=y
# CONFIG_MINIMAL_LIBC_LL_PRINTF is not set
CONFIG_MINIMAL_LIBC_OPTIMIZE_STRING_FOR_SIZE=y
# CONFIG_MINIMAL_LIBC_RAND is not set
CONFIG_MINIMAL_LIBC_TIME=y
# CONFIG_MINIMAL_LIBC_STRING_ERROR_TABLE is not set
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# Additional libraries
# OS Support Library
# CONFIG_JSON_LIBRARY is not set
CONFIG_RING_BUFFER=y
CONFIG_NOTIFY=y
CONFIG_BASE64=y
CONFIG_CRC=y
# CONFIG_PRINTK_SYNC is not set
# CONFIG_MPSC_PBUF is not set
CONFIG_ONOFF=y
# CONFIG_SPSC_PBUF is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# CONFIG_WINSTREAM is not set
CONFIG_REBOOT=y
# CONFIG_UTF8 is not set
# CONFIG_CBPRINTF_COMPLETE is not set
CONFIG_CBPRINTF_NANO=y
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_FP_ALWAYS_A is not set
CONFIG_CBPRINTF_LIBC_SUBSTS=y
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_VALIDATE is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
# CONFIG_SYS_HEAP_SMALL_ONLY is not set
# CONFIG_SYS_HEAP_BIG_ONLY is not set
CONFIG_SYS_HEAP_AUTO=y
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Heap and Memory Allocation
# end of OS Support Library
# CONFIG_GETOPT is not set
# CONFIG_POSIX_API is not set
# CONFIG_POSIX_CLOCK is not set
CONFIG_MAX_TIMER_COUNT=5
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_EVENTFD is not set
# CONFIG_OPENAMP_RSC_TABLE is not set
# Util libraries
# CONFIG_FNMATCH is not set
# end of Util libraries
# CONFIG_SMF is not set
# end of Additional libraries
# Sub Systems and OS Services
# CONFIG_BT is not set
# Controller Area Network (CAN) bus subsystem
# CONFIG_ISOTP is not set
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# CONFIG_CPLUSPLUS is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
# CONFIG_PRINTK is not set
# CONFIG_EARLY_CONSOLE is not set
# CONFIG_ASSERT is not set
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# end of Debugging Options
# CONFIG_DISK_ACCESS is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
# CONFIG_FCB is not set
# CONFIG_NVS is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# Logging
# CONFIG_LOG is not set
# CONFIG_LOG_OUTPUT is not set
# end of Logging
# CONFIG_DSP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_MCUMGR is not set
# CONFIG_HAWKBIT is not set
# CONFIG_UPDATEHUB is not set
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# Networking
# CONFIG_NET_BUF is not set
# CONFIG_NETWORKING is not set
# end of Networking
# Portability
# end of Portability
# Power Management
# end of Power Management
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
CONFIG_USB_DEVICE_MANUFACTURER=&amp;quot;Nordic Semiconductor ASA&amp;quot;
CONFIG_USB_DEVICE_SN=&amp;quot;0123456789ABCDEF&amp;quot;
# CONFIG_USB_COMPOSITE_DEVICE is not set
CONFIG_USB_MAX_NUM_TRANSFERS=4
CONFIG_USB_REQUEST_BUFFER_SIZE=128
CONFIG_USB_MAX_ALT_SETTING=8
CONFIG_USB_NUMOF_EP_WRITE_RETRIES=3
# CONFIG_USB_DEVICE_SOF is not set
# CONFIG_USB_DEVICE_BOS is not set
# CONFIG_USB_DEVICE_OS_DESC is not set
CONFIG_USB_SELF_POWERED=y
CONFIG_USB_MAX_POWER=50
CONFIG_USB_WORKQUEUE=y
CONFIG_USB_WORKQUEUE_STACK_SIZE=1024
CONFIG_USB_WORKQUEUE_PRIORITY=-1
# USB CDC ACM Class support
CONFIG_USB_CDC_ACM_RINGBUF_SIZE=1024
CONFIG_CDC_ACM_INTERRUPT_EP_MPS=16
CONFIG_CDC_ACM_BULK_EP_MPS=64
CONFIG_CDC_ACM_IAD=y
# CONFIG_CDC_ACM_DTE_RATE_CALLBACK_SUPPORT is not set
# end of USB CDC ACM Class support
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_DEVICE_BLUETOOTH is not set
# CONFIG_USB_DEVICE_BT_H4 is not set
# CONFIG_USB_DEVICE_LOOPBACK is not set
# USB Device Networking support
# CONFIG_USB_DEVICE_NETWORK_ECM is not set
# CONFIG_USB_DEVICE_NETWORK_EEM is not set
# CONFIG_USB_DEVICE_NETWORK_RNDIS is not set
# end of USB Device Networking support
# CONFIG_USB_DEVICE_HID is not set
# CONFIG_USB_DEVICE_AUDIO is not set
# CONFIG_USBC_STACK is not set
# CONFIG_SD_STACK is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_IMG_MANAGER is not set
# Random Number Generators
# CONFIG_TEST_RANDOM_GENERATOR is not set
# end of Random Number Generators
# Storage
CONFIG_FLASH_MAP=y
# CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_SETTINGS is not set
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# CONFIG_RTIO is not set
# CONFIG_ZBUS is not set
# end of Sub Systems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_15=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_HAS_FLASH_LOAD_OFFSET=y
CONFIG_USE_DT_CODE_PARTITION=y
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_KERNEL_ENTRY=&amp;quot;__start&amp;quot;
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
CONFIG_SRAM_OFFSET=0
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
# end of Linker Sections
# end of Linker Options
# Compiler Options
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_NATIVE_APPLICATION is not set
CONFIG_SIZE_OPTIMIZATIONS=y
# CONFIG_SPEED_OPTIMIZATIONS is not set
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# CONFIG_NO_OPTIMIZATIONS is not set
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
CONFIG_FORTIFY_SOURCE_NONE=y
# CONFIG_FORTIFY_SOURCE_COMPILE_TIME is not set
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=&amp;quot;&amp;quot;
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME=&amp;quot;zephyr&amp;quot;
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
CONFIG_OUTPUT_DISASSEMBLY=y
# CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_OUTPUT_UF2 is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
CONFIG_BUILD_OUTPUT_META=y
# CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set
# end of Build Options
CONFIG_WARN_DEPRECATED=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
# Compatibility
CONFIG_COMPAT_INCLUDES=y
# end of Compatibility
# CONFIG_LEGACY_INCLUDE_PATH is not set
&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Below is the main application .config&lt;/p&gt;
# DFU service control
CONFIG_DFU_UPDATE_OPTION=y
CONFIG_DFU_UPDATE_ENABLE=y
# Device Drivers
CONFIG_SENSOR=y
CONFIG_BME688=y
# end of DFU service control
# Zephyr Kernel
CONFIG_GPIO=y
CONFIG_SPI=y
CONFIG_I2C=y
CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
CONFIG_BT_HCI_VS_EXT=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_BOARD_ENABLE_CPUNET=y
CONFIG_FLASH_LOAD_SIZE=0x40000
CONFIG_FLASH_LOAD_OFFSET=0x10000
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_BT_HAS_HCI_VS=y
CONFIG_REGULATOR=y
CONFIG_USB_DEVICE_PRODUCT=&amp;quot;Thingy:53 Nordic UART Service sample&amp;quot;
CONFIG_USB_DEVICE_PID=0x530E
CONFIG_UART_CONSOLE=y
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=y
CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=4000
# CONFIG_BT_CTLR is not set
CONFIG_BT_ECC=y
CONFIG_NUM_IRQS=69
CONFIG_PINCTRL=y
CONFIG_PM=y
CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET=y
CONFIG_LOG_DOMAIN_NAME=&amp;quot;&amp;quot;
CONFIG_FPU=y
# CONFIG_MBEDTLS is not set
CONFIG_TINYCRYPT=y
CONFIG_SERIAL=y
CONFIG_MAIN_STACK_SIZE=8192
# CONFIG_BT_USER_PHY_UPDATE is not set
CONFIG_HAS_DTS=y
# Devicetree Info
CONFIG_DT_HAS_BOSCH_BMI270_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
# Modules
CONFIG_NEWLIB_LIBC_NANO=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_MCUMGR_BUF_SIZE=2475
CONFIG_NCS_INCLUDE_RPMSG_CHILD_IMAGE=y
CONFIG_NCS_SAMPLE_HCI_RPMSG_CHILD_IMAGE=y
CONFIG_LOG_DEFAULT_LEVEL=3
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
# CONFIG_MCUMGR_SMP_BT_AUTHEN is not set
CONFIG_IMG_ERASE_PROGRESSIVELY=y
CONFIG_OS_MGMT_MCUMGR_PARAMS=y
CONFIG_MCUMGR_GRP_ZEPHYR_BASIC=y
CONFIG_MCUMGR_GRP_BASIC_CMD_STORAGE_ERASE=y
CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
CONFIG_BT_L2CAP_TX_MTU=700
CONFIG_BT_BUF_ACL_TX_SIZE=550
CONFIG_BT_BUF_ACL_RX_SIZE=550
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_VALIDATION=y
# Bootloader
# CONFIG_NRF53_ENFORCE_IMAGE_VERSION_EQUALITY is not set
# end of Bootloader
CONFIG_BT_MAX_CONN=2
CONFIG_BT_HCI_TX_STACK_SIZE=1024
CONFIG_BT_RX_STACK_SIZE=8192
# BLE Libraries
# CONFIG_BT_GATT_POOL is not set
CONFIG_BT_GATT_DM=y
CONFIG_BT_GATT_DM_MAX_ATTRS=35
# CONFIG_BT_GATT_DM_DATA_PRINT is not set
# CONFIG_BT_GATT_DM_LOG_LEVEL_OFF is not set
# CONFIG_BT_GATT_DM_LOG_LEVEL_ERR is not set
# CONFIG_BT_GATT_DM_LOG_LEVEL_WRN is not set
CONFIG_BT_GATT_DM_LOG_LEVEL_INF=y
# CONFIG_BT_GATT_DM_LOG_LEVEL_DBG is not set
CONFIG_BT_GATT_DM_LOG_LEVEL=3
# CONFIG_BT_ADV_PROV is not set
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_NAME_MAX_LEN=32
CONFIG_BT_SCAN_SHORT_NAME_MAX_LEN=32
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_MANUFACTURER_DATA_MAX_LEN=32
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_SCAN_NAME_CNT=0
CONFIG_BT_SCAN_SHORT_NAME_CNT=0
CONFIG_BT_SCAN_ADDRESS_CNT=0
CONFIG_BT_SCAN_APPEARANCE_CNT=0
CONFIG_BT_SCAN_MANUFACTURER_DATA_CNT=0
# CONFIG_BT_SCAN_CONN_ATTEMPTS_FILTER is not set
# CONFIG_BT_SCAN_BLOCKLIST is not set
# CONFIG_BT_SCAN_LOG_LEVEL_OFF is not set
# CONFIG_BT_SCAN_LOG_LEVEL_ERR is not set
# CONFIG_BT_SCAN_LOG_LEVEL_WRN is not set
# CONFIG_BT_SCAN_LOG_LEVEL_INF is not set
CONFIG_BT_SCAN_LOG_LEVEL_DBG=y
CONFIG_BT_SCAN_LOG_LEVEL=4
# CONFIG_BT_CONN_CTX is not set
# Bluetooth Services
CONFIG_BT_NRF_SERVICES=y
# CONFIG_BT_AMS_CLIENT is not set
# CONFIG_BT_ANCS_CLIENT is not set
# CONFIG_BT_BAS_CLIENT is not set
CONFIG_BT_CTS_CLIENT=y
# CONFIG_BT_CTS_CLIENT_LOG_LEVEL_OFF is not set
# CONFIG_BT_CTS_CLIENT_LOG_LEVEL_ERR is not set
# CONFIG_BT_CTS_CLIENT_LOG_LEVEL_WRN is not set
CONFIG_BT_CTS_CLIENT_LOG_LEVEL_INF=y
# CONFIG_BT_CTS_CLIENT_LOG_LEVEL_DBG is not set
CONFIG_BT_CTS_CLIENT_LOG_LEVEL=3
# CONFIG_BT_DFU_SMP is not set
# CONFIG_BT_GATTP is not set
# CONFIG_BT_HIDS is not set
# CONFIG_BT_HOGP is not set
# CONFIG_BT_LBS is not set
# CONFIG_BT_NSMS is not set
CONFIG_BT_NUS=y
# CONFIG_BT_NUS_AUTHEN is not set
# CONFIG_BT_NUS_LOG_LEVEL_OFF is not set
# CONFIG_BT_NUS_LOG_LEVEL_ERR is not set
# CONFIG_BT_NUS_LOG_LEVEL_WRN is not set
CONFIG_BT_NUS_LOG_LEVEL_INF=y
# CONFIG_BT_NUS_LOG_LEVEL_DBG is not set
CONFIG_BT_NUS_LOG_LEVEL=3
CONFIG_BT_NUS_CLIENT=y
# CONFIG_BT_NUS_CLIENT_LOG_LEVEL_OFF is not set
# CONFIG_BT_NUS_CLIENT_LOG_LEVEL_ERR is not set
# CONFIG_BT_NUS_CLIENT_LOG_LEVEL_WRN is not set
CONFIG_BT_NUS_CLIENT_LOG_LEVEL_INF=y
# CONFIG_BT_NUS_CLIENT_LOG_LEVEL_DBG is not set
CONFIG_BT_NUS_CLIENT_LOG_LEVEL=3
# CONFIG_BT_RSCS is not set
# CONFIG_BT_THROUGHPUT is not set
# CONFIG_BT_LATENCY is not set
# CONFIG_BT_LATENCY_CLIENT is not set
# CONFIG_BT_HRS_CLIENT is not set
# CONFIG_BT_DDFS is not set
# CONFIG_BT_MDS is not set
# CONFIG_BT_CGMS is not set
# CONFIG_BT_FAST_PAIR is not set
# CONFIG_BT_DIS is not set
CONFIG_BT_GATT_AUTO_SEC_REQ=y
# end of Bluetooth Services
# BLE over nRF RPC
# CONFIG_BT_RPC is not set
CONFIG_BT_DRIVERS=y
# CONFIG_BT_RPC_STACK is not set
CONFIG_BT_CENTRAL=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_CONN=y
# CONFIG_BT_REMOTE_VERSION is not set
CONFIG_BT_PHY_UPDATE=y
CONFIG_BT_DATA_LEN_UPDATE=y
# CONFIG_BT_EXT_ADV is not set
# CONFIG_BT_BAS is not set
# CONFIG_BT_HRS is not set
# CONFIG_BT_TPS is not set
# CONFIG_BT_IAS is not set
# CONFIG_BT_IAS_CLIENT is not set
CONFIG_BT_IAS_CLIENT_LOG_LEVEL=1
CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INHERIT=y
# CONFIG_BT_IAS_CLIENT_LOG_LEVEL_OFF is not set
# CONFIG_BT_IAS_CLIENT_LOG_LEVEL_ERR is not set
# CONFIG_BT_IAS_CLIENT_LOG_LEVEL_WRN is not set
# CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INF is not set
# CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DBG is not set
# CONFIG_BT_IAS_LOG_LEVEL_OFF is not set
# CONFIG_BT_IAS_LOG_LEVEL_ERR is not set
# CONFIG_BT_IAS_LOG_LEVEL_WRN is not set
CONFIG_BT_IAS_LOG_LEVEL_INF=y
# CONFIG_BT_IAS_LOG_LEVEL_DBG is not set
CONFIG_BT_IAS_LOG_LEVEL=3
# CONFIG_BT_OTS is not set
# CONFIG_BT_OTS_CLIENT is not set
CONFIG_BT_BUF_ACL_TX_COUNT=3
CONFIG_BT_BUF_ACL_RX_COUNT=6
CONFIG_BT_BUF_EVT_RX_SIZE=68
CONFIG_BT_BUF_EVT_RX_COUNT=10
CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
CONFIG_BT_BUF_CMD_TX_SIZE=65
CONFIG_BT_HCI_VS=y
# CONFIG_BT_HCI_VS_EVT is not set
# CONFIG_BT_HCI_VS_FATAL_ERROR is not set
# CONFIG_BT_HCI_VS_EXT_DETECT is not set
# CONFIG_BT_HCI_MESH_EXT is not set
# CONFIG_BT_WAIT_NOP is not set
CONFIG_BT_RPA=y
CONFIG_BT_ASSERT=y
CONFIG_BT_ASSERT_VERBOSE=y
# CONFIG_BT_ASSERT_PANIC is not set
CONFIG_BT_DEBUG=y
# CONFIG_BT_DEBUG_NONE is not set
CONFIG_BT_DEBUG_LOG=y
# CONFIG_BT_DEBUG_MONITOR_UART is not set
# CONFIG_BT_DEBUG_MONITOR_RTT is not set
# CONFIG_BT_DEBUG_HCI_DRIVER is not set
CONFIG_BT_HCI_DRIVER_LOG_LEVEL=1
CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set
# CONFIG_BT_DEBUG_RPA is not set
CONFIG_BT_RPA_LOG_LEVEL=1
CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y
# CONFIG_BT_RPA_LOG_LEVEL_OFF is not set
# CONFIG_BT_RPA_LOG_LEVEL_ERR is not set
# CONFIG_BT_RPA_LOG_LEVEL_WRN is not set
# CONFIG_BT_RPA_LOG_LEVEL_INF is not set
# CONFIG_BT_RPA_LOG_LEVEL_DBG is not set
CONFIG_BT_LONG_WQ=y
CONFIG_BT_LONG_WQ_STACK_SIZE=1300
CONFIG_BT_LONG_WQ_PRIO=10
CONFIG_BT_HCI_HOST=y
# CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
CONFIG_BT_HCI_TX_PRIO=7
CONFIG_BT_HCI_RESERVE=1
# CONFIG_BT_RECV_BLOCKING is not set
# CONFIG_BT_RECV_WORKQ_SYS is not set
CONFIG_BT_RECV_WORKQ_BT=y
CONFIG_BT_RX_PRIO=8
CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
# CONFIG_BT_MESH is not set
# CONFIG_BT_AUDIO is not set
CONFIG_BT_HOST_CRYPTO=y
CONFIG_BT_HOST_CRYPTO_PRNG=y
CONFIG_BT_SETTINGS=y
CONFIG_BT_SETTINGS_CCC_LAZY_LOADING=y
CONFIG_BT_SETTINGS_CCC_STORE_ON_WRITE=y
CONFIG_BT_SETTINGS_USE_PRINTK=y
# CONFIG_BT_FILTER_ACCEPT_LIST is not set
CONFIG_BT_LIM_ADV_TIMEOUT=1
CONFIG_BT_CONN_TX_MAX=5
CONFIG_BT_AUTO_PHY_UPDATE=y
# CONFIG_BT_USER_DATA_LEN_UPDATE is not set
CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
# CONFIG_BT_REMOTE_INFO is not set
CONFIG_BT_SMP=y
# CONFIG_BT_PRIVACY is not set
# CONFIG_BT_SIGNING is not set
# CONFIG_BT_SMP_APP_PAIRING_ACCEPT is not set
# CONFIG_BT_SMP_SC_PAIR_ONLY is not set
# CONFIG_BT_SMP_SC_ONLY is not set
# CONFIG_BT_SMP_OOB_LEGACY_PAIR_ONLY is not set
# CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY is not set
# CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE is not set
# CONFIG_BT_ID_UNPAIR_MATCHING_BONDS is not set
# CONFIG_BT_ID_ALLOW_UNAUTH_OVERWRITE is not set
# CONFIG_BT_FIXED_PASSKEY is not set
# CONFIG_BT_USE_DEBUG_KEYS is not set
CONFIG_BT_BONDABLE=y
# CONFIG_BT_BONDING_REQUIRED is not set
# CONFIG_BT_STORE_DEBUG_KEYS is not set
# CONFIG_BT_SMP_ENFORCE_MITM is not set
CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
# CONFIG_BT_KEYS_SAVE_AGING_COUNTER_ON_PAIRING is not set
CONFIG_BT_SMP_MIN_ENC_KEY_SIZE=7
CONFIG_BT_L2CAP_TX_BUF_COUNT=5
CONFIG_BT_L2CAP_TX_FRAG_COUNT=4
# CONFIG_BT_L2CAP_DYNAMIC_CHANNEL is not set
# CONFIG_BT_DEBUG_L2CAP is not set
CONFIG_BT_L2CAP_LOG_LEVEL=1
CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
# CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
CONFIG_BT_ATT_ENFORCE_FLOW=y
CONFIG_BT_ATT_PREPARE_COUNT=5
CONFIG_BT_ATT_RETRY_ON_SEC_ERR=y
CONFIG_BT_GATT_SERVICE_CHANGED=y
CONFIG_BT_GATT_DYNAMIC_DB=y
CONFIG_BT_GATT_CACHING=y
# CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
# CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_READ_MULTIPLE=y
CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
# CONFIG_BT_GATT_AUTO_DISCOVER_CCC is not set
# CONFIG_BT_GATT_AUTO_UPDATE_MTU is not set
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42
CONFIG_BT_DEVICE_NAME_GATT_WRITABLE=y
CONFIG_DEVICE_NAME_GATT_WRITABLE_ENCRYPT=y
# CONFIG_DEVICE_NAME_GATT_WRITABLE_AUTHEN is not set
# CONFIG_BT_DEBUG_ATT is not set
CONFIG_BT_ATT_LOG_LEVEL=1
CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y
# CONFIG_BT_ATT_LOG_LEVEL_OFF is not set
# CONFIG_BT_ATT_LOG_LEVEL_ERR is not set
# CONFIG_BT_ATT_LOG_LEVEL_WRN is not set
# CONFIG_BT_ATT_LOG_LEVEL_INF is not set
# CONFIG_BT_ATT_LOG_LEVEL_DBG is not set
# CONFIG_BT_DEBUG_GATT is not set
CONFIG_BT_GATT_LOG_LEVEL=1
CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y
# CONFIG_BT_GATT_LOG_LEVEL_OFF is not set
# CONFIG_BT_GATT_LOG_LEVEL_ERR is not set
# CONFIG_BT_GATT_LOG_LEVEL_WRN is not set
# CONFIG_BT_GATT_LOG_LEVEL_INF is not set
# CONFIG_BT_GATT_LOG_LEVEL_DBG is not set
CONFIG_BT_MAX_PAIRED=1
CONFIG_BT_CREATE_CONN_TIMEOUT=3
CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048
CONFIG_BT_BACKGROUND_SCAN_WINDOW=18
# CONFIG_BT_SCAN_WITH_IDENTITY is not set
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
CONFIG_BT_DEVICE_NAME_MAX=65
CONFIG_BT_DEVICE_NAME=&amp;quot;&amp;quot;
# CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
CONFIG_BT_DEVICE_APPEARANCE=0
CONFIG_BT_ID_MAX=1
# CONFIG_BT_DF is not set
# CONFIG_BT_TINYCRYPT_ECC is not set
# CONFIG_BT_HOST_CCM is not set
# CONFIG_BT_DEBUG_SETTINGS is not set
CONFIG_BT_SETTINGS_LOG_LEVEL=1
CONFIG_BT_SETTINGS_LOG_LEVEL_INHERIT=y
# CONFIG_BT_SETTINGS_LOG_LEVEL_OFF is not set
# CONFIG_BT_SETTINGS_LOG_LEVEL_ERR is not set
# CONFIG_BT_SETTINGS_LOG_LEVEL_WRN is not set
# CONFIG_BT_SETTINGS_LOG_LEVEL_INF is not set
# CONFIG_BT_SETTINGS_LOG_LEVEL_DBG is not set
# CONFIG_BT_DEBUG_HCI_CORE is not set
CONFIG_BT_HCI_CORE_LOG_LEVEL=1
CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT=y
# CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set
# CONFIG_BT_DEBUG_CONN is not set
CONFIG_BT_CONN_LOG_LEVEL=1
CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y
# CONFIG_BT_CONN_LOG_LEVEL_OFF is not set
# CONFIG_BT_CONN_LOG_LEVEL_ERR is not set
# CONFIG_BT_CONN_LOG_LEVEL_WRN is not set
# CONFIG_BT_CONN_LOG_LEVEL_INF is not set
# CONFIG_BT_CONN_LOG_LEVEL_DBG is not set
# CONFIG_BT_DEBUG_ISO is not set
CONFIG_BT_ISO_LOG_LEVEL=1
CONFIG_BT_ISO_LOG_LEVEL_INHERIT=y
# CONFIG_BT_ISO_LOG_LEVEL_OFF is not set
# CONFIG_BT_ISO_LOG_LEVEL_ERR is not set
# CONFIG_BT_ISO_LOG_LEVEL_WRN is not set
# CONFIG_BT_ISO_LOG_LEVEL_INF is not set
# CONFIG_BT_ISO_LOG_LEVEL_DBG is not set
# CONFIG_BT_DEBUG_KEYS is not set
CONFIG_BT_KEYS_LOG_LEVEL=1
CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y
# CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set
# CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set
# CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set
# CONFIG_BT_KEYS_LOG_LEVEL_INF is not set
# CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set
# CONFIG_BT_DEBUG_SMP is not set
CONFIG_BT_SMP_LOG_LEVEL=1
CONFIG_BT_SMP_LOG_LEVEL_INHERIT=y
# CONFIG_BT_SMP_LOG_LEVEL_OFF is not set
# CONFIG_BT_SMP_LOG_LEVEL_ERR is not set
# CONFIG_BT_SMP_LOG_LEVEL_WRN is not set
# CONFIG_BT_SMP_LOG_LEVEL_INF is not set
# CONFIG_BT_SMP_LOG_LEVEL_DBG is not set
CONFIG_BT_RFCOMM_LOG_LEVEL=1
CONFIG_BT_RFCOMM_LOG_LEVEL_INHERIT=y
# CONFIG_BT_RFCOMM_LOG_LEVEL_OFF is not set
# CONFIG_BT_RFCOMM_LOG_LEVEL_ERR is not set
# CONFIG_BT_RFCOMM_LOG_LEVEL_WRN is not set
# CONFIG_BT_RFCOMM_LOG_LEVEL_INF is not set
# CONFIG_BT_RFCOMM_LOG_LEVEL_DBG is not set
CONFIG_BT_HFP_HF_LOG_LEVEL=1
CONFIG_BT_HFP_HF_LOG_LEVEL_INHERIT=y
# CONFIG_BT_HFP_HF_LOG_LEVEL_OFF is not set
# CONFIG_BT_HFP_HF_LOG_LEVEL_ERR is not set
# CONFIG_BT_HFP_HF_LOG_LEVEL_WRN is not set
# CONFIG_BT_HFP_HF_LOG_LEVEL_INF is not set
# CONFIG_BT_HFP_HF_LOG_LEVEL_DBG is not set
CONFIG_BT_AVDTP_LOG_LEVEL=1
CONFIG_BT_AVDTP_LOG_LEVEL_INHERIT=y
# CONFIG_BT_AVDTP_LOG_LEVEL_OFF is not set
# CONFIG_BT_AVDTP_LOG_LEVEL_ERR is not set
# CONFIG_BT_AVDTP_LOG_LEVEL_WRN is not set
# CONFIG_BT_AVDTP_LOG_LEVEL_INF is not set
# CONFIG_BT_AVDTP_LOG_LEVEL_DBG is not set
CONFIG_BT_A2DP_LOG_LEVEL=1
CONFIG_BT_A2DP_LOG_LEVEL_INHERIT=y
# CONFIG_BT_A2DP_LOG_LEVEL_OFF is not set
# CONFIG_BT_A2DP_LOG_LEVEL_ERR is not set
# CONFIG_BT_A2DP_LOG_LEVEL_WRN is not set
# CONFIG_BT_A2DP_LOG_LEVEL_INF is not set
# CONFIG_BT_A2DP_LOG_LEVEL_DBG is not set
CONFIG_BT_SDP_LOG_LEVEL=1
CONFIG_BT_SDP_LOG_LEVEL_INHERIT=y
# CONFIG_BT_SDP_LOG_LEVEL_OFF is not set
# CONFIG_BT_SDP_LOG_LEVEL_ERR is not set
# CONFIG_BT_SDP_LOG_LEVEL_WRN is not set
# CONFIG_BT_SDP_LOG_LEVEL_INF is not set
# CONFIG_BT_SDP_LOG_LEVEL_DBG is not set
# CONFIG_BT_DEBUG_SERVICE is not set
CONFIG_BT_SERVICE_LOG_LEVEL=1
CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y
# CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set
# CONFIG_BT_LOG_SNIFFER_INFO is not set
# CONFIG_BT_TESTING is not set
# CONFIG_BT_BREDR is not set
# CONFIG_BT_HCI_VS_EVT_USER is not set
CONFIG_BT_CRYPTO=y
# CONFIG_BT_DEBUG_CRYPTO is not set
CONFIG_BT_CRYPTO_LOG_LEVEL=1
CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y
# CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set
# DFU
# end of DFU
# CONFIG_ESB_LOG_LEVEL_OFF is not set
# CONFIG_ESB_LOG_LEVEL_ERR is not set
# CONFIG_ESB_LOG_LEVEL_WRN is not set
CONFIG_ESB_LOG_LEVEL_INF=y
# CONFIG_ESB_LOG_LEVEL_DBG is not set
CONFIG_ESB_LOG_LEVEL=3
# CONFIG_PCD_APP is not set
# Networking
# nRF Cloud
# CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_WRN is not set
CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_INF=y
# CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL=3
# CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
# CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LEVEL=3
# end of nRF Cloud
# end of Networking
# NFC
# end of NFC
CONFIG_APP_EVENT_MANAGER=y
CONFIG_APP_EVENT_MANAGER_SHOW_EVENTS=y
# CONFIG_APP_EVENT_MANAGER_SHOW_EVENT_HANDLERS is not set
# CONFIG_APP_EVENT_MANAGER_TRACE_EVENT_DATA is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_OFF is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_ERR is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_WRN is not set
CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_INF=y
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DBG is not set
CONFIG_APP_EVENT_MANAGER_LOG_LEVEL=3
# CONFIG_APP_EVENT_MANAGER_USE_DEPRECATED_LOG_FUN is not set
CONFIG_APP_EVENT_MANAGER_LOG_EVENT_TYPE=y
CONFIG_APP_EVENT_MANAGER_MAX_EVENT_CNT=32
# CONFIG_APP_EVENT_MANAGER_PROVIDE_EVENT_SIZE is not set
# CONFIG_APP_EVENT_MANAGER_POSTINIT_HOOK is not set
# CONFIG_APP_EVENT_MANAGER_SUBMIT_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_PREPROCESS_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_POSTPROCESS_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_PROFILER_TRACER is not set
# CONFIG_EVENT_MANAGER_PROXY is not set
# Debug
# end of Debug
# CONFIG_SHELL_BT_NUS is not set
# CONFIG_SHELL_IPC is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
CONFIG_MPSL_FEM_LOG_LEVEL_INF=y
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL=3
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
CONFIG_MPSL_LOG_LEVEL_INF=y
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL=3
# Partition Manager
CONFIG_RPMSG_NRF53_SRAM_SIZE=0x10000
CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000
# CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL is not set
CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE=0x4000
# CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
CONFIG_MGMT_FMFU_LOG_LEVEL_INF=y
# CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
CONFIG_MGMT_FMFU_LOG_LEVEL=3
# Libraries
# Binary libraries
# CONFIG_FPROTECT is not set
CONFIG_DK_LIBRARY=y
CONFIG_DK_LIBRARY_BUTTON_SCAN_INTERVAL=10
CONFIG_DK_LIBRARY_DYNAMIC_BUTTON_HANDLERS=y
# CONFIG_DK_LIBRARY_LOG_LEVEL_OFF is not set
# CONFIG_DK_LIBRARY_LOG_LEVEL_ERR is not set
# CONFIG_DK_LIBRARY_LOG_LEVEL_WRN is not set
CONFIG_DK_LIBRARY_LOG_LEVEL_INF=y
# CONFIG_DK_LIBRARY_LOG_LEVEL_DBG is not set
CONFIG_DK_LIBRARY_LOG_LEVEL=3
# CONFIG_AT_CMD_PARSER is not set
CONFIG_RESET_ON_FATAL_ERROR=y
# CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
CONFIG_FATAL_ERROR_LOG_LEVEL_INF=y
# CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
CONFIG_FATAL_ERROR_LOG_LEVEL=3
CONFIG_DATE_TIME=y
# CONFIG_DATE_TIME_AUTO_UPDATE is not set
CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=14400
CONFIG_DATE_TIME_TOO_OLD_SECONDS=3600
# CONFIG_DATE_TIME_NTP is not set
CONFIG_DATE_TIME_THREAD_STACK_SIZE=1280
CONFIG_DATE_TIME_NTP_QUERY_TIME_SECONDS=5
# CONFIG_DATE_TIME_LOG_LEVEL_OFF is not set
# CONFIG_DATE_TIME_LOG_LEVEL_ERR is not set
# CONFIG_DATE_TIME_LOG_LEVEL_WRN is not set
CONFIG_DATE_TIME_LOG_LEVEL_INF=y
# CONFIG_DATE_TIME_LOG_LEVEL_DBG is not set
CONFIG_DATE_TIME_LOG_LEVEL=3
# CONFIG_MODEM_SLM is not set
# end of Libraries
# Device Drivers
CONFIG_HW_CC3XX=y
# CONFIG_BH1749 is not set
# CONFIG_SENSOR_SIM is not set
# CONFIG_SENSOR_STUB is not set
# CONFIG_PMW3360 is not set
# CONFIG_PAW3212 is not set
# CONFIG_IPC_UART is not set
# Test
# Mocks
# end of Mocks
# end of Test
# MCUboot
# CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is not set
# CONFIG_MCUBOOT_BUILD_STRATEGY_USE_HEX_FILE is not set
# CONFIG_MCUBOOT_BUILD_STRATEGY_SKIP_BUILD is not set
CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE=y
CONFIG_MCUBOOT_IMAGE_VERSION=&amp;quot;4.0.1&amp;quot;
CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
# CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set
CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS=y
# end of MCUboot
# CONFIG_CJSON_LIB is not set
# Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_DPPI=y
CONFIG_NRFX_IPC=y
CONFIG_NRFX_NVMC=y
CONFIG_NRFX_POWER=y
CONFIG_NRFX_PWM=y
CONFIG_NRFX_PWM0=y
CONFIG_NRFX_PWM1=y
CONFIG_NRFX_QSPI=y
CONFIG_NRFX_SPIM=y
CONFIG_NRFX_SPIM3=y
CONFIG_NRFX_TWIM=y
CONFIG_NRFX_TWIM1=y
CONFIG_NRFX_UARTE=y
CONFIG_NRFX_UARTE2=y
CONFIG_NRFX_USBD=y
# CONFIG_NRFX_WDT0 is not set
# CONFIG_NRFX_WDT1 is not set
# CONFIG_LIBLC3 is not set
CONFIG_ZCBOR=y
# CONFIG_ZCBOR_CANONICAL is not set
# CONFIG_ZCBOR_STOP_ON_ERROR is not set
# CONFIG_ZCBOR_VERBOSE is not set
# Nordic nrfxlib
CONFIG_NRFXLIB_CRYPTO=y
# CONFIG_NRF_CC310_BL is not set
# CONFIG_SW_CODEC_LC3_T2_SOFTWARE is not set
# CONFIG_CMSIS_DSP is not set
CONFIG_LIBMETAL=y
CONFIG_LIBMETAL_SRC_PATH=&amp;quot;libmetal&amp;quot;
CONFIG_OPENAMP=y
CONFIG_OPENAMP_SRC_PATH=&amp;quot;open-amp&amp;quot;
CONFIG_OPENAMP_MASTER=y
CONFIG_OPENAMP_SLAVE=y
# CONFIG_TINYCRYPT_CTR_PRNG is not set
CONFIG_TINYCRYPT_SHA256=y
CONFIG_TINYCRYPT_SHA256_HMAC=y
CONFIG_TINYCRYPT_SHA256_HMAC_PRNG=y
# CONFIG_TINYCRYPT_ECC_DH is not set
# CONFIG_TINYCRYPT_ECC_DSA is not set
CONFIG_TINYCRYPT_AES=y
# CONFIG_TINYCRYPT_AES_CBC is not set
# CONFIG_TINYCRYPT_AES_CTR is not set
# CONFIG_TINYCRYPT_AES_CCM is not set
CONFIG_TINYCRYPT_AES_CMAC=y
CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set
CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF=y
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3
CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
# end of Modules
# Board Options
CONFIG_MBOX_NRFX_IPC=y
CONFIG_BOARD_SERIAL_BACKEND_CDC_ACM=y
CONFIG_DOMAIN_CPUNET_BOARD=&amp;quot;thingy53_nrf5340_cpunet&amp;quot;
CONFIG_HAS_SWO=y
CONFIG_HAS_HW_NRF_UARTE2=y
CONFIG_SOC_NRF_GPIO_FORWARDER_FOR_NRF5340=y
CONFIG_NRF53_SYNC_RTC=y
# CONFIG_SYNC_RTC_LOG_LEVEL_OFF is not set
# CONFIG_SYNC_RTC_LOG_LEVEL_ERR is not set
# CONFIG_SYNC_RTC_LOG_LEVEL_WRN is not set
CONFIG_SYNC_RTC_LOG_LEVEL_INF=y
# CONFIG_SYNC_RTC_LOG_LEVEL_DBG is not set
CONFIG_SYNC_RTC_LOG_LEVEL=3
CONFIG_NRF53_SYNC_RTC_INIT_PRIORITY=90
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=1
CONFIG_NRF53_SYNC_RTC_LOG_TIMESTAMP=y
CONFIG_NRF53_SYNC_RTC_IPM_OUT=7
CONFIG_NRF53_SYNC_RTC_IPM_IN=8
CONFIG_IPM_MSG_CH_8_ENABLE=y
CONFIG_IPM_MSG_CH_8_RX=y
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
CONFIG_SOC_LOG_LEVEL_INF=y
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL=3
# ARM Options
CONFIG_CPU_CORTEX=y
CONFIG_ISA_THUMB2=y
CONFIG_FAULT_DUMP=2
CONFIG_ARM_STORE_EXC_RETURN=y
CONFIG_FP_HARDABI=y
# CONFIG_FP_SOFTABI is not set
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
CONFIG_ARMV8_M_SE=y
CONFIG_ARM_MPU=y
CONFIG_ARM=y
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
CONFIG_ARCH_LOG_LEVEL_INF=y
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL=3
CONFIG_MPU=y
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
CONFIG_MPU_LOG_LEVEL_INF=y
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL=3
CONFIG_FPU_SHARING=y
# Cache Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
CONFIG_KERNEL_LOG_LEVEL_INF=y
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_MULTITHREADING=y
CONFIG_ERRNO=y
CONFIG_SCHED_DUMB=y
CONFIG_WAITQ_DUMB=y
CONFIG_BOOT_BANNER=y
CONFIG_BOOT_DELAY=0
CONFIG_THREAD_MONITOR=y
CONFIG_THREAD_NAME=y
CONFIG_THREAD_MAX_NAME_LEN=32
# Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
CONFIG_POLL=y
CONFIG_XIP=y
# Security Options
# SMP Options
# Device Options
# Device Drivers
# Bluetooth HCI Driver Options
# CONFIG_BT_H4 is not set
# CONFIG_BT_H5 is not set
CONFIG_BT_RPMSG=y
# CONFIG_BT_SPI is not set
# CONFIG_BT_STM32_IPM is not set
# CONFIG_BT_ESP32 is not set
# CONFIG_BT_B91 is not set
# CONFIG_BT_NO_DRIVER is not set
CONFIG_CONSOLE=y
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
CONFIG_UART_CONSOLE_INPUT_EXPIRED=y
CONFIG_UART_CONSOLE_INPUT_EXPIRED_TIMEOUT=15000
# CONFIG_RAM_CONSOLE is not set
CONFIG_RTT_CONSOLE=y
CONFIG_RTT_TX_RETRY_CNT=2
CONFIG_RTT_TX_RETRY_DELAY_MS=2
# CONFIG_RTT_TX_RETRY_IN_INTERRUPT is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y
# CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
CONFIG_UART_CONSOLE_LOG_LEVEL=3
# CONFIG_GSM_MUX is not set
# CONFIG_EFI_CONSOLE is not set
CONFIG_USE_SEGGER_RTT=y
CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=4096
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=64
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
# CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
CONFIG_SEGGER_RTT_MODE=0
# CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
CONFIG_SEGGER_RTT_SECTION_NONE=y
# CONFIG_SEGGER_RTT_SECTION_DTCM is not set
# Capabilities
CONFIG_SERIAL_SUPPORT_ASYNC=y
# CONFIG_UART_LOG_LEVEL_OFF is not set
# CONFIG_UART_LOG_LEVEL_ERR is not set
# CONFIG_UART_LOG_LEVEL_WRN is not set
CONFIG_UART_LOG_LEVEL_INF=y
# CONFIG_UART_LOG_LEVEL_DBG is not set
CONFIG_UART_LOG_LEVEL=3
CONFIG_UART_ASYNC_API=y
# CONFIG_UART_LINE_CTRL is not set
# Serial Drivers
CONFIG_UART_NRFX=y
CONFIG_UART_ASYNC_TX_CACHE_SIZE=8
CONFIG_UART_2_NRF_UARTE=y
# CONFIG_UART_2_INTERRUPT_DRIVEN is not set
CONFIG_UART_2_ASYNC=y
CONFIG_UART_2_ENHANCED_POLL_OUT=y
# CONFIG_UART_2_NRF_PARITY_BIT is not set
CONFIG_UART_2_NRF_TX_BUFFER_SIZE=32
# CONFIG_UART_2_NRF_HW_ASYNC is not set
# CONFIG_UART_2_NRF_ASYNC_LOW_POWER is not set
CONFIG_UART_ENHANCED_POLL_OUT=y
CONFIG_NRF_UARTE_PERIPHERAL=y
# CONFIG_INTC_LOG_LEVEL_OFF is not set
# CONFIG_INTC_LOG_LEVEL_ERR is not set
# CONFIG_INTC_LOG_LEVEL_WRN is not set
CONFIG_INTC_LOG_LEVEL_INF=y
# CONFIG_INTC_LOG_LEVEL_DBG is not set
CONFIG_INTC_LOG_LEVEL=3
# Timer Drivers
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
CONFIG_GPIO_LOG_LEVEL_INF=y
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL=3
CONFIG_GPIO_NRFX=y
# CONFIG_FXL6408_LOG_LEVEL_OFF is not set
# CONFIG_FXL6408_LOG_LEVEL_ERR is not set
# CONFIG_FXL6408_LOG_LEVEL_WRN is not set
CONFIG_FXL6408_LOG_LEVEL_INF=y
# CONFIG_FXL6408_LOG_LEVEL_DBG is not set
CONFIG_FXL6408_LOG_LEVEL=3
# CONFIG_SPI_ASYNC is not set
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPI_EXTENDED_MODES is not set
CONFIG_SPI_INIT_PRIORITY=70
CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
# CONFIG_SPI_LOG_LEVEL_OFF is not set
# CONFIG_SPI_LOG_LEVEL_ERR is not set
# CONFIG_SPI_LOG_LEVEL_WRN is not set
CONFIG_SPI_LOG_LEVEL_INF=y
# CONFIG_SPI_LOG_LEVEL_DBG is not set
CONFIG_SPI_LOG_LEVEL=3
CONFIG_SPI_NRFX=y
CONFIG_SPI_3_NRF_SPIM=y
CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
# CONFIG_I2C_CALLBACK is not set
# CONFIG_I2C_TARGET is not set
CONFIG_I2C_NRFX=y
CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500
CONFIG_I2C_1_NRF_TWIM=y
CONFIG_I2C_INIT_PRIORITY=50
# CONFIG_I2C_LOG_LEVEL_OFF is not set
# CONFIG_I2C_LOG_LEVEL_ERR is not set
# CONFIG_I2C_LOG_LEVEL_WRN is not set
CONFIG_I2C_LOG_LEVEL_INF=y
# CONFIG_I2C_LOG_LEVEL_DBG is not set
CONFIG_I2C_LOG_LEVEL=3
CONFIG_PWM=y
# CONFIG_PWM_LOG_LEVEL_OFF is not set
# CONFIG_PWM_LOG_LEVEL_ERR is not set
# CONFIG_PWM_LOG_LEVEL_WRN is not set
CONFIG_PWM_LOG_LEVEL_INF=y
# CONFIG_PWM_LOG_LEVEL_DBG is not set
CONFIG_PWM_LOG_LEVEL=3
CONFIG_PWM_INIT_PRIORITY=50
# CONFIG_PWM_CAPTURE is not set
CONFIG_PWM_NRFX=y
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_FLASH=y
# CONFIG_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_FLASH_LOG_LEVEL_WRN is not set
CONFIG_FLASH_LOG_LEVEL_INF=y
# CONFIG_FLASH_LOG_LEVEL_DBG is not set
CONFIG_FLASH_LOG_LEVEL=3
# CONFIG_SENSOR_LOG_LEVEL_OFF is not set
# CONFIG_SENSOR_LOG_LEVEL_ERR is not set
# CONFIG_SENSOR_LOG_LEVEL_WRN is not set
CONFIG_SENSOR_LOG_LEVEL_INF=y
# CONFIG_SENSOR_LOG_LEVEL_DBG is not set
CONFIG_SENSOR_LOG_LEVEL=3
CONFIG_SENSOR_INIT_PRIORITY=90
# CONFIG_SENSOR_INFO is not set
# Device Drivers
CONFIG_ADXL362=y
CONFIG_ADXL362_ACCEL_RANGE_RUNTIME=y
# CONFIG_ADXL362_ACCEL_RANGE_2G is not set
# CONFIG_ADXL362_ACCEL_RANGE_4G is not set
# CONFIG_ADXL362_ACCEL_RANGE_8G is not set
CONFIG_ADXL362_ACCEL_ODR_RUNTIME=y
# CONFIG_ADXL362_ACCEL_ODR_12_5 is not set
# CONFIG_ADXL362_ACCEL_ODR_25 is not set
# CONFIG_ADXL362_ACCEL_ODR_50 is not set
# CONFIG_ADXL362_ACCEL_ODR_100 is not set
# CONFIG_ADXL362_ACCEL_ODR_200 is not set
# CONFIG_ADXL362_ACCEL_ODR_400 is not set
CONFIG_ADXL362_TRIGGER_NONE=y
# CONFIG_ADXL362_TRIGGER_GLOBAL_THREAD is not set
# CONFIG_ADXL362_TRIGGER_OWN_THREAD is not set
CONFIG_ADXL362_ACTIVITY_THRESHOLD=1000
CONFIG_ADXL362_ACTIVITY_TIME=1
CONFIG_ADXL362_INACTIVITY_THRESHOLD=100
CONFIG_ADXL362_INACTIVITY_TIME=1
CONFIG_ADXL362_INTERRUPT_MODE=0
CONFIG_ADXL362_ABS_REF_MODE=0
# CONFIG_APP_FLASH is not set
CONFIG_BMI270=y
CONFIG_BMI270_BUS_SPI=y
CONFIG_BMM150=y
# CONFIG_BMM150_PRESET_LOW_POWER is not set
CONFIG_BMM150_PRESET_REGULAR=y
# CONFIG_BMM150_PRESET_ENHANCED_REGULAR is not set
# CONFIG_BMM150_PRESET_HIGH_ACCURACY is not set
# CONFIG_BMM150_SAMPLING_RATE_RUNTIME is not set
# CONFIG_BMM150_SAMPLING_REP_XY is not set
# CONFIG_BMM150_SAMPLING_REP_Z is not set
CONFIG_TMP112_FULL_SCALE_RUNTIME=y
CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME=y
CONFIG_USB_NRFX=y
# CONFIG_USB_DRIVER_LOG_LEVEL_OFF is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_ERR is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_WRN is not set
CONFIG_USB_DRIVER_LOG_LEVEL_INF=y
# CONFIG_USB_DRIVER_LOG_LEVEL_DBG is not set
CONFIG_USB_DRIVER_LOG_LEVEL=3
CONFIG_HWINFO=y
# CONFIG_HWINFO_LOG_LEVEL_OFF is not set
# CONFIG_HWINFO_LOG_LEVEL_ERR is not set
# CONFIG_HWINFO_LOG_LEVEL_WRN is not set
CONFIG_HWINFO_LOG_LEVEL_INF=y
# CONFIG_HWINFO_LOG_LEVEL_DBG is not set
CONFIG_HWINFO_LOG_LEVEL=3
CONFIG_HWINFO_NRF=y
# CONFIG_REGULATOR_LOG_LEVEL_OFF is not set
# CONFIG_REGULATOR_LOG_LEVEL_ERR is not set
# CONFIG_REGULATOR_LOG_LEVEL_WRN is not set
CONFIG_REGULATOR_LOG_LEVEL_INF=y
# CONFIG_REGULATOR_LOG_LEVEL_DBG is not set
CONFIG_REGULATOR_LOG_LEVEL=3
# CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
# CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
# CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
CONFIG_PINCTRL_LOG_LEVEL_INF=y
# CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
CONFIG_PINCTRL_LOG_LEVEL=3
CONFIG_MBOX=y
CONFIG_MBOX_INIT_PRIORITY=50
# CONFIG_MBOX_LOG_LEVEL_OFF is not set
# CONFIG_MBOX_LOG_LEVEL_ERR is not set
# CONFIG_MBOX_LOG_LEVEL_WRN is not set
CONFIG_MBOX_LOG_LEVEL_INF=y
# CONFIG_MBOX_LOG_LEVEL_DBG is not set
CONFIG_MBOX_LOG_LEVEL=3
# CONFIG_USBC_LOG_LEVEL_OFF is not set
# CONFIG_USBC_LOG_LEVEL_ERR is not set
# CONFIG_USBC_LOG_LEVEL_WRN is not set
CONFIG_USBC_LOG_LEVEL_INF=y
# CONFIG_USBC_LOG_LEVEL_DBG is not set
CONFIG_USBC_LOG_LEVEL=3
# end of Device Drivers
# C Library
# CONFIG_MINIMAL_LIBC is not set
CONFIG_NEWLIB_LIBC=y
CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
# CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
# CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set
CONFIG_STDOUT_CONSOLE=y
# end of C Library
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
CONFIG_CRC=y
CONFIG_ONOFF=y
CONFIG_REBOOT=y
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_CBPRINTF_N_SPECIFIER=y
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF=y
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
# CONFIG_PTHREAD_IPC is not set
CONFIG_POSIX_CLOCK=y
# Util libraries
CONFIG_BT=y
# CONFIG_BT_LOG_LEVEL_OFF is not set
CONFIG_BT_LOG_LEVEL_ERR=y
# CONFIG_BT_LOG_LEVEL_WRN is not set
# CONFIG_BT_LOG_LEVEL_INF is not set
# CONFIG_BT_LOG_LEVEL_DBG is not set
CONFIG_BT_LOG_LEVEL=1
CONFIG_BT_HCI=y
# CONFIG_BT_CUSTOM is not set
# CONFIG_BT_HCI_RAW is not set
# CONFIG_BT_HCI_RAW_H4 is not set
# CONFIG_BT_HCI_RAW_CMD_EXT is not set
CONFIG_BT_CONN_TX=y
# CONFIG_BT_PER_ADV_SYNC_TRANSFER_RECEIVER is not set
# CONFIG_BT_PER_ADV_SYNC_TRANSFER_SENDER is not set
# CONFIG_BT_SCA_UPDATE is not set
# CONFIG_BT_ISO_PERIPHERAL is not set
# CONFIG_BT_ISO_CENTRAL is not set
# CONFIG_BT_ISO_BROADCASTER is not set
# CONFIG_BT_ISO_SYNC_RECEIVER is not set
# Bluetooth buffer configuration
# end of Bluetooth buffer configuration
# Bluetooth Host
# L2CAP Options
# end of L2CAP Options
# ATT and GATT Options
# end of ATT and GATT Options
# GATT Services
# end of GATT Services
# end of Bluetooth Host
# CONFIG_BT_SHELL is not set
CONFIG_BT_COMPANY_ID=0x05F1
# Debugging Options
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
CONFIG_DEBUG_INFO=y
CONFIG_EXCEPTION_STACK_TRACE=y
CONFIG_DEBUG_THREAD_INFO=y
# File Systems
CONFIG_NVS=y
# CONFIG_NVS_LOOKUP_CACHE is not set
# CONFIG_NVS_LOG_LEVEL_OFF is not set
# CONFIG_NVS_LOG_LEVEL_ERR is not set
# CONFIG_NVS_LOG_LEVEL_WRN is not set
CONFIG_NVS_LOG_LEVEL_INF=y
# CONFIG_NVS_LOG_LEVEL_DBG is not set
CONFIG_NVS_LOG_LEVEL=3
CONFIG_IPC_SERVICE=y
CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY=46
CONFIG_IPC_SERVICE_BACKEND_RPMSG=y
CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE=1024
CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE=2
CONFIG_IPC_SERVICE_RPMSG=y
CONFIG_IPC_SERVICE_STATIC_VRINGS=y
CONFIG_IPC_SERVICE_STATIC_VRINGS_ALIGNMENT=4
# CONFIG_IPC_SERVICE_ICMSG is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_OFF is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_ERR is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_WRN is not set
CONFIG_IPC_SERVICE_LOG_LEVEL_INF=y
# CONFIG_IPC_SERVICE_LOG_LEVEL_DBG is not set
CONFIG_IPC_SERVICE_LOG_LEVEL=3
# Logging
CONFIG_LOG=y
# CONFIG_LOG_MODE_DEFERRED is not set
CONFIG_LOG_MODE_IMMEDIATE=y
# CONFIG_LOG_MODE_MINIMAL is not set
# CONFIG_LOG_FRONTEND is not set
# CONFIG_LOG_MULTIDOMAIN is not set
# Logging levels filtering
# CONFIG_LOG_RUNTIME_FILTERING is not set
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# end of Logging levels filtering
# Processing
CONFIG_LOG_PRINTK=y
CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
# CONFIG_LOG_TIMESTAMP_64BIT is not set
# end of Processing
# Output Formatting
# Prepend non-hexdump log message with function name
CONFIG_LOG_FUNC_NAME_PREFIX_ERR=y
CONFIG_LOG_FUNC_NAME_PREFIX_WRN=y
CONFIG_LOG_FUNC_NAME_PREFIX_INF=y
CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
# end of Prepend non-hexdump log message with function name
# CONFIG_LOG_MIPI_SYST_ENABLE is not set
# CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
# CONFIG_LOG_IMMEDIATE_CLEAN_OUTPUT is not set
CONFIG_LOG_BACKEND_SHOW_COLOR=y
# CONFIG_LOG_INFO_COLOR_GREEN is not set
CONFIG_LOG_TAG_MAX_LEN=0
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
# CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
# end of Output Formatting
# Backends
CONFIG_LOG_BACKEND_RTT=y
# CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
# CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
# CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
CONFIG_LOG_BACKEND_RTT_BUFFER=0
CONFIG_LOG_BACKEND_RTT_FORCE_PRINTK=y
# CONFIG_LOG_BACKEND_SWO is not set
CONFIG_LOG_BACKEND_UART=y
# CONFIG_LOG_BACKEND_UART_ASYNC is not set
CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1
CONFIG_LOG_BACKEND_UART_AUTOSTART=y
CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set
# CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set
CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0
# CONFIG_LOG_BACKEND_IPC_SERVICE is not set
# end of Backends
# Misc
CONFIG_LOG_DOMAIN_ID=0
CONFIG_LOG_USE_VLA=y
CONFIG_LOG_ALWAYS_RUNTIME=y
# CONFIG_LOG_FMT_SECTION is not set
# CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
# end of Misc
CONFIG_LOG_OUTPUT=y
# end of Logging
# Device Management
CONFIG_MCUMGR=y
# CONFIG_MCUMGR_LOG_LEVEL_OFF is not set
# CONFIG_MCUMGR_LOG_LEVEL_ERR is not set
# CONFIG_MCUMGR_LOG_LEVEL_WRN is not set
CONFIG_MCUMGR_LOG_LEVEL_INF=y
# CONFIG_MCUMGR_LOG_LEVEL_DBG is not set
CONFIG_MCUMGR_LOG_LEVEL=3
CONFIG_MCUMGR_SMP_WORKQUEUE_STACK_SIZE=2048
CONFIG_MCUMGR_SMP_WORKQUEUE_THREAD_PRIO=3
# CONFIG_MGMT_VERBOSE_ERR_RESPONSE is not set
CONFIG_MGMT_MAX_MAIN_MAP_ENTRIES=15
CONFIG_MGMT_MIN_DECODING_LEVELS=2
CONFIG_MGMT_MIN_DECODING_LEVEL_2=y
CONFIG_MGMT_MAX_DECODING_LEVELS=2
# CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS is not set
# Command Handlers
CONFIG_MCUMGR_CMD_IMG_MGMT=y
# CONFIG_IMG_MGMT_USE_HEAP_FOR_FLASH_IMG_CONTEXT is not set
CONFIG_IMG_MGMT_UPDATABLE_IMAGE_NUMBER=2
# CONFIG_IMG_MGMT_VERBOSE_ERR is not set
# CONFIG_IMG_MGMT_DUMMY_HDR is not set
# CONFIG_IMG_MGMT_DIRECT_IMAGE_UPLOAD is not set
# CONFIG_IMG_MGMT_REJECT_DIRECT_XIP_MISMATCHED_SLOT is not set
# CONFIG_IMG_MGMT_FRUGAL_LIST is not set
# CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_OFF is not set
# CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_ERR is not set
# CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_WRN is not set
CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_INF=y
# CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_DBG is not set
CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL=3
CONFIG_MCUMGR_CMD_OS_MGMT=y
CONFIG_OS_MGMT_RESET_MS=250
# CONFIG_OS_MGMT_TASKSTAT is not set
CONFIG_OS_MGMT_ECHO=y
# CONFIG_MCUMGR_GRP_OS_INFO is not set
# CONFIG_MCUMGR_ZEPHYR_GRP_LOG_LEVEL_OFF is not set
# CONFIG_MCUMGR_ZEPHYR_GRP_LOG_LEVEL_ERR is not set
# CONFIG_MCUMGR_ZEPHYR_GRP_LOG_LEVEL_WRN is not set
CONFIG_MCUMGR_ZEPHYR_GRP_LOG_LEVEL_INF=y
# CONFIG_MCUMGR_ZEPHYR_GRP_LOG_LEVEL_DBG is not set
CONFIG_MCUMGR_ZEPHYR_GRP_LOG_LEVEL=3
# end of Command Handlers
# Transports and Transport Related Configuration Options
CONFIG_MCUMGR_SMP_REASSEMBLY=y
CONFIG_MCUMGR_BUF_COUNT=4
CONFIG_MCUMGR_BUF_USER_DATA_SIZE=8
# CONFIG_MCUMGR_SMP_DUMMY is not set
CONFIG_MCUMGR_SMP_BT=y
CONFIG_MCUMGR_SMP_REASSEMBLY_BT=y
CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL=y
CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL_MIN_INT=6
CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL_MAX_INT=9
CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL_LATENCY=0
CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL_TIMEOUT=42
CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL_RESTORE_TIME=5000
CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL_RETRY_TIME=1000
# CONFIG_MCUMGR_SMP_UART is not set
# end of Transports and Transport Related Configuration Options
# CONFIG_MCUMGR_SMP_LOG_LEVEL_OFF is not set
# CONFIG_MCUMGR_SMP_LOG_LEVEL_ERR is not set
# CONFIG_MCUMGR_SMP_LOG_LEVEL_WRN is not set
CONFIG_MCUMGR_SMP_LOG_LEVEL_INF=y
# CONFIG_MCUMGR_SMP_LOG_LEVEL_DBG is not set
CONFIG_MCUMGR_SMP_LOG_LEVEL=3
# Networking
CONFIG_NET_BUF=y
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
# CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
# CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
CONFIG_NET_BUF_LOG_LEVEL_INF=y
# CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
CONFIG_NET_BUF_LOG_LEVEL=3
# CONFIG_NET_BUF_POOL_USAGE is not set
# end of Networking
# Portability
# Power Management
# CONFIG_PM_LOG_LEVEL_OFF is not set
# CONFIG_PM_LOG_LEVEL_ERR is not set
# CONFIG_PM_LOG_LEVEL_WRN is not set
CONFIG_PM_LOG_LEVEL_INF=y
# CONFIG_PM_LOG_LEVEL_DBG is not set
CONFIG_PM_LOG_LEVEL=3
# CONFIG_PM_S2RAM is not set
CONFIG_PM_POLICY_DEFAULT=y
# CONFIG_PM_POLICY_CUSTOM is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_OFF is not set
CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y
# CONFIG_USB_DEVICE_LOG_LEVEL_WRN is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_INF is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_DBG is not set
CONFIG_USB_DEVICE_LOG_LEVEL=1
CONFIG_USB_DEVICE_MANUFACTURER=&amp;quot;ZEPHYR&amp;quot;
CONFIG_USB_COMPOSITE_DEVICE=y
CONFIG_USB_DEVICE_BLUETOOTH_BIG_BUF=y
CONFIG_USB_CDC_ACM_LOG_LEVEL_OFF=y
# CONFIG_USB_CDC_ACM_LOG_LEVEL_ERR is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_WRN is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_INF is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_DBG is not set
CONFIG_USB_CDC_ACM_LOG_LEVEL=0
# CONFIG_USB_DFU_CLASS is not set
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
CONFIG_IMG_BLOCK_BUF_SIZE=512
# CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
CONFIG_IMG_MANAGER_LOG_LEVEL_INF=y
# CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
CONFIG_IMG_MANAGER_LOG_LEVEL=3
# Storage
CONFIG_FLASH_MAP=y
CONFIG_STREAM_FLASH=y
CONFIG_STREAM_FLASH_ERASE=y
# CONFIG_STREAM_FLASH_PROGRESS is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
CONFIG_STREAM_FLASH_LOG_LEVEL_INF=y
# CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
CONFIG_STREAM_FLASH_LOG_LEVEL=3
# end of Storage
CONFIG_SETTINGS=y
# CONFIG_SETTINGS_LOG_LEVEL_OFF is not set
# CONFIG_SETTINGS_LOG_LEVEL_ERR is not set
# CONFIG_SETTINGS_LOG_LEVEL_WRN is not set
CONFIG_SETTINGS_LOG_LEVEL_INF=y
# CONFIG_SETTINGS_LOG_LEVEL_DBG is not set
CONFIG_SETTINGS_LOG_LEVEL=3
# CONFIG_SETTINGS_RUNTIME is not set
CONFIG_SETTINGS_DYNAMIC_HANDLERS=y
CONFIG_SETTINGS_NVS=y
# CONFIG_SETTINGS_NVS_NAME_CACHE is not set
# CONFIG_SETTINGS_CUSTOM is not set
# CONFIG_SETTINGS_NONE is not set
CONFIG_SETTINGS_NVS_SECTOR_SIZE_MULT=1
CONFIG_SETTINGS_NVS_SECTOR_COUNT=8
# Testing
# end of Testing
# Linker Options
# Linker Sections
# Compiler Options
# CONFIG_SIZE_OPTIMIZATIONS is not set
CONFIG_DEBUG_OPTIMIZATIONS=y
# CONFIG_FORTIFY_SOURCE_NONE is not set
CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
# Build Options
# Boot Options
CONFIG_MCUBOOT_SIGNATURE_KEY_FILE=&amp;quot;&amp;quot;
CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=&amp;quot;&amp;quot;
# CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
# CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
# Compatibility
# end of Zephyr Kernel
&lt;/pre&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NCS 2.3.0 FOTA issue when flashing from NCS 1.9.1</title><link>https://devzone.nordicsemi.com/thread/440050?ContentTypeID=1</link><pubDate>Mon, 07 Aug 2023 07:13:17 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d7788efc-8001-400a-943d-b7f7bb1cbf72</guid><dc:creator>Hieu</dc:creator><description>&lt;p&gt;Could you please get me the compiled Kconfig of the MCUboot child image and your main application?&lt;/p&gt;
&lt;p&gt;For the MCUboot child image, it is the file with the path: &amp;lt;build folder&amp;gt;/mcuboot/zephyr/.confg&lt;/p&gt;
&lt;p&gt;For the main application, it is the file with the path:&amp;nbsp;&amp;lt;build folder&amp;gt;/zephyr/.confg&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NCS 2.3.0 FOTA issue when flashing from NCS 1.9.1</title><link>https://devzone.nordicsemi.com/thread/439823?ContentTypeID=1</link><pubDate>Fri, 04 Aug 2023 07:17:37 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:92855787-74fa-4621-8a04-79a3a33e4f90</guid><dc:creator>Sachin Rawat</dc:creator><description>&lt;p&gt;Thanks for replying&lt;/p&gt;
[quote userid="9456" url="~/f/nordic-q-a/102452/ncs-2-3-0-fota-issue-when-flashing-from-ncs-1-9-1/439469"]Are you using the&amp;nbsp;USB CDC ACM interface to program the Thingy53, and not the 10-pin debug port?[/quote]
&lt;p&gt;No, using 10 pin debug port which is connected to nRF5340Dk.&lt;/p&gt;
[quote userid="9456" url="~/f/nordic-q-a/102452/ncs-2-3-0-fota-issue-when-flashing-from-ncs-1-9-1/439469"]Is the default MCUboot bootloader still on the Thingy53?[/quote]
&lt;p&gt;I don&amp;#39;t know&lt;/p&gt;
[quote userid="9456" url="~/f/nordic-q-a/102452/ncs-2-3-0-fota-issue-when-flashing-from-ncs-1-9-1/439469"]&amp;quot;the flash process does not complete?&amp;quot;[/quote]
&lt;p&gt;At first I flash the ncs v1.9.1 code using VS code, after successful flash, I connect the board with nrf connect for mobile and try to DFU OTA with the .zip that is created after build for ncs 2.3.0 code. The update looks well. But after this when I again tried to DFU OTA through nrf connect for mobile app with the .zip file of ncs 2.3.0, It won&amp;#39;t update to new firmware(I checked logs).&lt;br /&gt;&lt;br /&gt;&lt;/p&gt;
[quote userid="9456" url="~/f/nordic-q-a/102452/ncs-2-3-0-fota-issue-when-flashing-from-ncs-1-9-1/439469"]Or is the entire process just frozen?[/quote]
&lt;p&gt;Nothing Froze.&lt;/p&gt;
[quote userid="9456" url="~/f/nordic-q-a/102452/ncs-2-3-0-fota-issue-when-flashing-from-ncs-1-9-1/439469"]Do you have the log of the process?[/quote]
&lt;p&gt;Let me show you the message when I flashed the ncs2.3.0 in old SDK ncs 1.9.1 first time(which BTW looks good) using DFU OTA.&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;[00:04:20.353,424] &amp;lt;inf&amp;gt; mcuboot_util: Swap type: none
[00:04:20.360,015] &amp;lt;dbg&amp;gt; mcuboot_util: boot_write_magic: writing magic; fa_id=2 off=0xedff0 (0xedff0)
[00:04:20.371,124] &amp;lt;dbg&amp;gt; mcuboot_util: boot_write_swap_info: writing swap_info; fa_id=2 off=0xedfd8 (0xedfd8), swap_type=0x2 image_num=0x0
[00:04:20.386,108] &amp;lt;inf&amp;gt; mcuboot_util: Swap type: test
[00:04:20.393,127] &amp;lt;inf&amp;gt; mcuboot_util: Swap type: test
[00:04:20.400,268] &amp;lt;inf&amp;gt; mcuboot_util: Swap type: none
Send &amp;quot;IMU&amp;quot; failed
[00:04:20.567,565] &amp;lt;inf&amp;gt; mcuboot_util: Swap type: none
[00:04:20.574,157] &amp;lt;dbg&amp;gt; mcuboot_util: boot_write_magic: writing magic; fa_id=8 off=0x3fff0 (0x12dff0)
[00:04:20.585,296] &amp;lt;dbg&amp;gt; mcuboot_util: boot_write_swap_info: writing swap_info; fa_id=8 off=0x3ffd8 (0x12dfd8), swap_type=0x2 image_num=0x0
[00:04:20.600,372] &amp;lt;inf&amp;gt; mcuboot_util: Swap type: test
[00:04:20.607,421] &amp;lt;inf&amp;gt; mcuboot_util: Swap type: test
[00:04:20.614,501] &amp;lt;inf&amp;gt; mcuboot_util: Swap type: test
*** Booting Zephyr OS build v3.2.99-ncs2 ***&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;But after that, when I flash DFU OTA again it is showing this only&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;07&amp;gt; [00:01:40.386,871] &amp;lt;inf&amp;gt; mcuboot_util: boot_swap_type_multi: Swap type: none
07&amp;gt; [00:01:40.389,404] &amp;lt;inf&amp;gt; mcuboot_util: boot_swap_type_multi: Swap type: test
07&amp;gt; [00:01:40.391,143] &amp;lt;inf&amp;gt; mcuboot_util: boot_swap_type_multi: Swap type: test
07&amp;gt; [00:01:40.392,883] &amp;lt;inf&amp;gt; mcuboot_util: boot_swap_type_multi: Swap type: none
07&amp;gt; [00:01:40.477,478] &amp;lt;inf&amp;gt; mcuboot_util: boot_swap_type_multi: Swap type: none
07&amp;gt; [00:01:40.480,010] &amp;lt;inf&amp;gt; mcuboot_util: boot_swap_type_multi: Swap type: test
07&amp;gt; [00:01:40.481,750] &amp;lt;inf&amp;gt; mcuboot_util: boot_swap_type_multi: Swap type: test
07&amp;gt; [00:01:40.483,489] &amp;lt;inf&amp;gt; mcuboot_util: boot_swap_type_multi: Swap type: tes&lt;/pre&gt;&lt;/p&gt;
[quote userid="9456" url="~/f/nordic-q-a/102452/ncs-2-3-0-fota-issue-when-flashing-from-ncs-1-9-1/439469"]Have you been able to flash the device with anything else since then?[/quote]
&lt;p&gt;I have been working on ncs 1.9.1 since long time(on which DFU OTA is working perfectly fine), so recently I switched to ncs 2.3.0.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;BTW, If I flash the firmware of ncs&amp;nbsp; 2.3.0 from VS code, each time it is working perfectly fine.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NCS 2.3.0 FOTA issue when flashing from NCS 1.9.1</title><link>https://devzone.nordicsemi.com/thread/439469?ContentTypeID=1</link><pubDate>Wed, 02 Aug 2023 10:50:12 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b27d6bea-146e-4118-81c3-d3369161ea8a</guid><dc:creator>Hieu</dc:creator><description>&lt;p&gt;Hi Sachin,&lt;/p&gt;
&lt;p&gt;I would like to ask some question to better understand your situation first.&lt;/p&gt;
&lt;ul&gt;
&lt;li&gt;Are you using the&amp;nbsp;USB CDC ACM interface to program the Thingy53, and not the 10-pin debug port?&lt;br /&gt;&lt;br /&gt;&lt;/li&gt;
&lt;li&gt;Is the default MCUboot bootloader still on the Thingy53?&lt;br /&gt;&lt;br /&gt;&lt;/li&gt;
&lt;li&gt;Could you provide some more details of what went wrong when&amp;nbsp;&amp;quot;the flash process does not complete?&amp;quot; &lt;br /&gt;Were there some error messages? &lt;br /&gt;Or is the entire process just frozen?&lt;br /&gt;Do you have the log of the process?&lt;br /&gt;&lt;br /&gt;&lt;/li&gt;
&lt;li&gt;Have you been able to flash the device with anything else since then? If yes, can you now flash your new NCS 2.3.0 FW?&lt;/li&gt;
&lt;/ul&gt;
&lt;p&gt;Hieu&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
