measurement of RSSI or transit time of a message via BLE with the Nordic 52840 and another slave board.
I have this problem, with a Nordic nRF52840 board I have to transmit a byte of known length, which I have to select a priori, and transmit it to a second slave evaluation board and then measure the RSSI value and the time it takes for the data packet to arrive depending on where the board is located, thus also going back to the distance value at which the two boards are located.
I would then also like to do the same thing with my android smartphone used as a slave.
I have tried to follow the examples I can find of nRF connect for desktop a bit, and in particular the codes available in visual studio code, but the standard codes there do not seem to answer my question.
Could you perhaps help me by explaining where to find an example code to modify to achieve this, and how to program the second board via the nRF52840?
thanks in advance!
    Leonardo Balocchi said:
    Are we sure that's the right way to programme the BC840E?
    From the doc, it seems like that. You also could use the J-Link debug probe to replace nRF52840DK for programming. Do you also try other BC840 E boards? If you also have programming issues with the J-Link debug probe, you should contact the provider since BC840 E is not produced by Nordic.
    -Amanda H.
  • Hi Amanda,
    I was able to solve the problem and now I can send the carrier from one board and view it via RSSI viewer on the other (with the "radio_test" application).
    I wanted to ask you another thing, now I would need to set up my experimental setup, as I told you, so that I select a single channel (out of the 40 available) and continuously send bit sequences interspersed between the two boards, so that the RSSI is measured.
    Is there a way to set the single channel and save all the RSSI values that are read so that I can then plot them in a graph?
    To go back to the previous problem, that is, the RSSI value measurement with the "nrf_dm" application, where I was seeing inconsistent RSSI values.
    Thanks in advance,
    Leonardo
    There is no such example, but you can take a look at this post or the hci_pwr_ctrl sample to get RSSI values.
    Could you elaborate more on what you mean by the "inconsistent RSSI values"?
    -Amanda H.
  • Hi Amanda, unfortunately the examples you gave me were not very helpful, they don't explain how to extract RSSI values over time.
    Concerning the second request, the problem is this, when I use the RSSI viewer on the nRF52840 DK, and the radio_test loaded on the BC840 then I read correctly the RSSI value from the RSSI viewer (the two boards are at a distance of 60 cm, so the path loss at 2.4 GHz is about 36 dB, then on the BC I mounted an antenna that has gain 5 dBi, and transmitting 0 dBm with the BC I see that the RSSI is about -34 dBm, as I expect).
    Leaving the same setup, with the nrf_dm example, it prints me an absolutely incorrect RSSI value, we are around -2 dBm (perhaps because in the latter case I see the sum of several channels?).
    So I cannot use the nrf_dm example to extract the RSSi values I need, but I should do it from the RSSI viewer, because from there I read the value I expect according to RSSI theory.
    So my problems are:
    1) how to save the RSSI values from the RSSI viewer desktop application (or if there is another way it may be ok, as long as the RSSI is always correct)
    2) how to keep the instructions sent from the terminal saved in the BC840's memory, because otherwise when I disconnect and then reconnect it, what happens is that the transmission instructions are lost (so I think they are saved in volatile memory)
    Is there a way perhaps to insert terminal commands directly within the main.c function in VS Code?
    Leonardo
    It cannot save the RSSI values from the RSSI viewer app which doesn't provide this feature.
    You could modify the sample and assign the value as you want.
    Amanda H.
