<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/102831/nrf52840-dk-commissioning-with-chip-tool-fail</link><description>Hi, I have a nRF52840-DK that is flashed with lock-application from the nRF Connect SDK (v2.4.1). I am running a OpenThread Border Router (OTBR). I am not able to commission/onboard my nRF52840-DK to the OTBR. Sometimes it seems to work and when I look</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 22 Aug 2023 13:07:52 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/102831/nrf52840-dk-commissioning-with-chip-tool-fail" /><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/442576?ContentTypeID=1</link><pubDate>Tue, 22 Aug 2023 13:07:52 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:89a110ff-bbbf-4c26-abbc-e701e52ba3c1</guid><dc:creator>Amanda Hsieh</dc:creator><description>&lt;p&gt;Happy to know you solved it. &lt;span class="emoticon" data-url="https://devzone.nordicsemi.com/cfs-file/__key/system/emoji/1f642.svg" title="Slight smile"&gt;&amp;#x1f642;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;-Amanda H.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/442420?ContentTypeID=1</link><pubDate>Tue, 22 Aug 2023 06:19:48 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:cca03e1a-03bd-438a-8fae-b7f545123edf</guid><dc:creator>MatsL</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;We have also found that problem. For some reason my computer could not handle router&amp;nbsp;advertisement and could not resolve IPV6 addresses.&lt;br /&gt;I think I have solved it now.&lt;br /&gt;Thank you for helping out.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/442323?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 13:33:43 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:265a02f3-9732-4df7-b59d-97340cf819d8</guid><dc:creator>Amanda Hsieh</dc:creator><description>&lt;p&gt;Hi,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;It seems that there is a problem with the test environment and routing configuration, it does not say how OTBR is configured which is crucial here, for example, it could be running on Raspberry Pi or in the docker container. What does the environment look like? What instructions do you follow?&lt;/p&gt;
&lt;p&gt;-Amanda H.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/442018?ContentTypeID=1</link><pubDate>Fri, 18 Aug 2023 07:29:15 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a7f8ba6f-ae99-476d-8e55-820f4c0b85ec</guid><dc:creator>MatsL</dc:creator><description>&lt;p&gt;nRF52840-DK_2023-08-16.log&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;uart*** Booting Zephyr OS build v3.3.99-ncs1-1 ***
:~$ I: Init CHIP stack
I: 219 [DL]BLE address: E1:3E:0C:06:BC:27
I: 227 [DL]OpenThread SED interval is 1000ms
I: 234 [DL]OpenThread started: OK
I: 237 [DL]Setting OpenThread device type to SLEEPY END DEVICE
I: 243 [SVR]Subscription persistence not supported
I: 247 [SVR]Server initializing...
I: 251 [TS]Last Known Good Time: 2023-08-14T14:58:38
I: 257 [DMG]AccessControl: initializing
I: 260 [DMG]Examples::AccessControlDelegate::Init
I: 265 [DMG]AccessControl: setting
I: 268 [DMG]DefaultAclStorage: initializing
I: 272 [DMG]DefaultAclStorage: 0 entries loaded
D: 276 [IN]UDP::Init bind&amp;amp;listen port=5540
E: 280 [IN]SO_REUSEPORT failed: 109
D: 284 [IN]UDP::Init bound to port=5540
D: 287 [IN]BLEBase::Init - setting/overriding transport
D: 292 [IN]TransportMgr initialized
D: 300 [DL]Using Thread extended MAC for hostname.
I: 307 [ZCL]Using ZAP configuration...
I: 312 [DMG]AccessControlCluster: initializing
D: 316 [DL]Boot reason: 1
I: 319 [ZCL]Initiating Admin Commissioning cluster.
I: 324 [ZCL]Door Lock server initialized
I: 327 [ZCL]Door Lock cluster initialized at endpoint #1
I: 333 [ZCL]0xce524ep 1 clus 0x0000_0101 attr 0x0000_0013 not supported
E: 339 [ZCL]Failed to set DoorLock number of RFID users: 86
I: 345 [DIS]Updating services using commissioning mode 0
E: 350 [DIS]Failed to remove advertised services: 3
D: 354 [DL]Using Thread extended MAC for hostname.
I: 360 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=0
E: 369 [DIS]Failed to advertise extended commissionable node: 3
D: 374 [DIS]Scheduling extended discovery timeout in 900s
E: 380 [DIS]Failed to finalize service update: 3
I: 384 [DIS]Delaying proxy of operational discovery: missing delegate
I: 390 [IN]CASE Server enabling CASE session setups
D: 395 [IN]SecureSession[0x20003728]: Allocated Type:2 LSID:16260
I: 401 [SVR]Joining Multicast groups
I: 405 [SVR]Server Listening...
I: 407 [DL]Device Configuration:
I: 411 [DL]  Serial Number: 11223344556677889900
I: 416 [DL]  Vendor Id: 65521 (0xFFF1)
I: 419 [DL]  Product Id: 32774 (0x8006)
I: 423 [DL]  Product Name: ++ MATS Lock ++
I: 427 [DL]  Hardware Version: 0
I: 431 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 437 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 444 [DL]  Manufacturing Date: (not set)
I: 448 [DL]  Device Type: 65535 (0xFFFF)
I: 453 [SVR]SetupQRCode: [MT:8IXS142C00KA0648G00]
I: 457 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 464 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A8IXS142C00KA0648G00
I: 473 [SVR]Manual pairing code: [34970112332]
I: 478 [DL]CHIP task running
I: 481 [DIS]Updating services using commissioning mode 0
E: 486 [DIS]Failed to remove advertised services: 3
D: 490 [DL]Using Thread extended MAC for hostname.
I: 496 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=0
E: 505 [DIS]Failed to advertise extended commissionable node: 3
E: 510 [DIS]Failed to finalize service update: 3
uart:~$
uart:~$
uart:~$ I: 9792 [DL]OpenThread SED interval is 200ms
D: 9799 [IN]SecureSession[0x200037e0]: Allocated Type:1 LSID:16261
D: 9805 [DL]CHIPoBLE advertising set to on
I: 9809 [DIS]Updating services using commissioning mode 1
E: 9814 [DIS]Failed to remove advertised services: 3
D: 9819 [DL]Using Thread extended MAC for hostname.
I: 9824 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=1
E: 9833 [DIS]Failed to advertise commissionable node: 3
E: 9838 [DIS]Failed to finalize service update: 3
I: 9845 [DL]CHIPoBLE advertising started
I: 9850 [DL]NFC Tag emulation started
uart:~$
uart:~$
I: 39849 [DL]CHIPoBLE advertising mode changed to slow
I: 39856 [DL]CHIPoBLE advertising started
uart:~$
uart:~$
I: 112259 [DL]BLE connection established (ConnId: 0x00)
I: 112264 [DL]Current number of connections: 1/1
I: 112268 [DL]CHIPoBLE advertising stopped
I: 112272 [DL]NFC Tag emulation stopped
D: 114123 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 114130 [BLE]local and remote recv window sizes = 5
I: 114135 [BLE]selected BTP version 4
I: 114138 [BLE]using BTP fragment sizes rx 244 / tx 244.
D: 114213 [DL]ConnId: 0x00, New CCCD value: 0x0002
D: 114217 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6)
D: 114225 [IN]BLE EndPoint 0x2000ffb0 Connection Complete
I: 114230 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247)
D: 114303 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 114311 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 114319 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28530r S:0 M:205354517] (U) Msg RX from 0:7EC22A099E0669E8 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
I: 114332 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28530r S:0 M:168352059] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
I: 114344 [IN](U) Sending msg 168352059 to IP address &amp;#39;BLE&amp;#39;
D: 114350 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 140)
D: 114438 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 114483 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 114490 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28530r S:0 M:205354518] (U) Msg RX from 0:7EC22A099E0669E8 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
I: 116186 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28530r S:0 M:168352060] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
I: 116198 [IN](U) Sending msg 168352060 to IP address &amp;#39;BLE&amp;#39;
D: 116203 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 132)
E: 116211 [DL]Long dispatch time: 1729 ms, for event type 16388
D: 116283 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 116291 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 116299 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28530r S:0 M:205354519] (U) Msg RX from 0:7EC22A099E0669E8 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
I: 116311 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28530r S:0 M:168352061] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 116323 [IN](U) Sending msg 168352061 to IP address &amp;#39;BLE&amp;#39;
D: 116328 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35)
I: 116337 [SC]SecureSession[0x200037e0]: Moving from state &amp;#39;kEstablishing&amp;#39; --&amp;gt; &amp;#39;kActive&amp;#39;
D: 116345 [IN]SecureSession[0x200037e0]: Activated - Type:1 LSID:16261
D: 116351 [IN]New secure session activated for device &amp;lt;FFFFFFFB00000000, 0&amp;gt;, LSID:16261 PSID:41023!
I: 116360 [SVR]Commissioning completed session establishment step
I: 116367 [DIS]Updating services using commissioning mode 0
E: 116372 [DIS]Failed to remove advertised services: 3
D: 116377 [DL]Using Thread extended MAC for hostname.
I: 116383 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=0
E: 116392 [DIS]Failed to advertise extended commissionable node: 3
D: 116398 [DIS]Scheduling extended discovery timeout in 900s
E: 116404 [DIS]Failed to finalize service update: 3
D: 116408 [DL]CHIPoBLE advertising set to off
I: 116413 [SVR]Device completed Rendezvous process
E: 116418 [DL]Long dispatch time: 127 ms, for event type 16388
D: 116425 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 116463 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 116471 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28531r S:16261 M:237205927] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
D: 116482 [IM]Received Read request
I: 116491 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28531r S:16261 M:243742841] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
I: 116502 [IN](S) Sending msg 243742841 on secure session with LSID: 16261
D: 116509 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 116597 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 116605 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 21)
D: 116688 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 116696 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 116704 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28532r S:16261 M:237205928] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 116717 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
I: 116724 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28532r S:16261 M:243742842] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 116736 [IN](S) Sending msg 243742842 on secure session with LSID: 16261
D: 116742 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 116823 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 116867 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 116876 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28533r S:16261 M:237205929] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 116890 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28533r S:16261 M:243742843] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 116901 [IN](S) Sending msg 243742843 on secure session with LSID: 16261
D: 116908 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 117003 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 117011 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 117019 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28534r S:16261 M:237205930] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 117032 [ZCL]OpCreds: Certificate Chain request received for PAI
I: 117041 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28534r S:16261 M:243742844] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 117053 [IN](S) Sending msg 243742844 on secure session with LSID: 16261
D: 117060 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 117137 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 117145 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 117227 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 117235 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 48)
D: 117318 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 117326 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 117334 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28535r S:16261 M:237205931] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 117347 [ZCL]OpCreds: Certificate Chain request received for DAC
I: 117356 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28535r S:16261 M:243742845] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 117368 [IN](S) Sending msg 243742845 on secure session with LSID: 16261
D: 117375 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 117452 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 117460 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 117542 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 117550 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 76)
D: 117633 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 117722 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 117731 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28536r S:16261 M:237205932] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 117743 [ZCL]OpCreds: Received an AttestationRequest command
I: 117783 [ZCL]OpCreds: AttestationRequest successful.
I: 117792 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28536r S:16261 M:243742846] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 117803 [IN](S) Sending msg 243742846 on secure session with LSID: 16261
D: 117810 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 117902 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 117910 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
D: 117992 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 118000 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 235)
D: 118082 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 118130 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 118138 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28537r S:16261 M:237205933] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 118150 [ZCL]OpCreds: Received a CSRRequest command
I: 118327 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
I: 118366 [ZCL]OpCreds: CSRRequest successful.
I: 118373 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28537r S:16261 M:243742847] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 118384 [IN](S) Sending msg 243742847 on secure session with LSID: 16261
D: 118391 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 244)
E: 118399 [DL]Long dispatch time: 270 ms, for event type 16388
D: 118487 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 118495 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 138)
D: 118577 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 118628 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 118714 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 118723 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28538r S:16261 M:237205934] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 118735 [ZCL]OpCreds: Received an AddTrustedRootCertificate command
I: 118805 [ZCL]OpCreds: AddTrustedRootCertificate successful.
I: 118811 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28538r S:16261 M:243742848] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 118823 [IN](S) Sending msg 243742848 on secure session with LSID: 16261
D: 118830 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68)
E: 118838 [DL]Long dispatch time: 124 ms, for event type 16388
D: 118893 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 118941 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 119033 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 119119 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 119130 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28539r S:16261 M:237205935] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 119142 [ZCL]OpCreds: Received an AddNOC command
I: 119150 [FP]Validating NOC chain
I: 119279 [FP]NOC chain validation successful
I: 119283 [FP]Added new fabric at index: 0x1
I: 119287 [FP]Assigned compressed fabric ID: 0xFD86F6B230A188DD, node ID: 0x0000000000000001
I: 119296 [TS]Last Known Good Time: 2023-08-14T14:58:38
I: 119301 [TS]New proposed Last Known Good Time: 2021-01-01T00:00:00
I: 119307 [TS]Retaining current Last Known Good Time
I: 119330 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x000000000001B669
D: 119339 [DL]Using Thread extended MAC for hostname.
I: 119344 [DIS]Advertise operational node FD86F6B230A188DD-0000000000000001
I: 119351 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC
I: 119358 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28539r S:16261 M:243742849] (S) Msg TX to 1:FFFFFFFB00000000 [88DD] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 119370 [IN](S) Sending msg 243742849 on secure session with LSID: 16261
D: 119377 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
E: 119385 [DL]Long dispatch time: 266 ms, for event type 16388
D: 119433 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 119479 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 119488 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28540r S:16261 M:237205936] (S) Msg RX from 1:FFFFFFFB00000000 [88DD] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 119507 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28540r S:16261 M:243742850] (S) Msg TX to 1:FFFFFFFB00000000 [88DD] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 119518 [IN](S) Sending msg 243742850 on secure session with LSID: 16261
D: 119525 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 119613 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 119621 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 119629 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28541r S:16261 M:237205937] (S) Msg RX from 1:FFFFFFFB00000000 [88DD] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 119642 [FS]GeneralCommissioning: Received ArmFailSafe (87s)
I: 119649 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28541r S:16261 M:243742851] (S) Msg TX to 1:FFFFFFFB00000000 [88DD] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 119661 [IN](S) Sending msg 243742851 on secure session with LSID: 16261
D: 119667 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
D: 119748 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 119792 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
I: 119801 [EM]&amp;gt;&amp;gt;&amp;gt; [E:28542r S:16261 M:237205938] (S) Msg RX from 1:FFFFFFFB00000000 [88DD] --- Type 0001:08 (IM:InvokeCommandRequest)
D: 119854 [DL]OpenThread State Changed (Flags: 0x1017c100)
D: 119860 [DL]   Network Name: OpenThreadDemo
D: 119864 [DL]   PAN Id: 0x1234
D: 119867 [DL]   Extended PAN Id: 0x1111111122222222
D: 119872 [DL]   Channel: 15
D: 119876 [DL]   Mesh Prefix: fdc2:40f9:e941:ab80::/64
D: 119882 [DL]OpenThread State Changed (Flags: 0x0100103d)
D: 119888 [DL]   Device Role: DETACHED
D: 119892 [DL]   Thread Unicast Addresses:
D: 119896 [DL]        fdc2:40f9:e941:ab80:0:ff:fe00:c401/64 valid rloc
D: 119903 [DL]        fdc2:40f9:e941:ab80:198:3c52:e246:60f5/64 valid
D: 119909 [DL]        fe80::9cae:6f24:e80e:3f84/64 valid preferred
D: 120571 [DL]OpenThread State Changed (Flags: 0x10000040)
I: 121850 [DL]SRP Client was started, detected server: fdc2:40f9:e941:ab80:ca18:08fa:0847:084a
D: 121860 [DL]OpenThread State Changed (Flags: 0x200002a4)
D: 121866 [DL]   Device Role: CHILD
D: 121870 [DL]   Partition Id: 0x299667FE
D: 121875 [DL]OpenThread State Changed (Flags: 0x00000001)
D: 121880 [DL]   Thread Unicast Addresses:
D: 121884 [DL]        fd11:22::83e2:94d:8e52:7e55/64 valid preferred
D: 121890 [DL]        fdc2:40f9:e941:ab80:0:ff:fe00:1801/64 valid rloc
D: 121896 [DL]        fdc2:40f9:e941:ab80:198:3c52:e246:60f5/64 valid
D: 121903 [DL]        fe80::9cae:6f24:e80e:3f84/64 valid preferred
I: 121911 [EM]&amp;lt;&amp;lt;&amp;lt; [E:28542r S:16261 M:243742852] (S) Msg TX to 1:FFFFFFFB00000000 [88DD] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 121923 [IN](S) Sending msg 243742852 on secure session with LSID: 16261
D: 121930 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 70)
D: 121937 [DL]Using Thread extended MAC for hostname.
I: 121942 [DIS]Advertise operational node FD86F6B230A188DD-0000000000000001
I: 121949 [SVR]Operational advertising enabled
D: 121997 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
D: 122757 [DL]SRP update succeeded
I: 122761 [DIS]Setting operational delegate post init
I: 122769 [SWU]Stopping the watchdog timer
I: 122773 [SWU]Starting the periodic query timer, timeout: 86400 seconds
E: 122780 [SVR]Server initialization complete
I: 122784 [DIS]Updating services using commissioning mode 0
D: 122789 [DL]Using Thread extended MAC for hostname.
I: 122794 [DIS]Advertise operational node FD86F6B230A188DD-0000000000000001
I: 122801 [DL]advertising srp service: FD86F6B230A188DD-0000000000000001._matter._tcp
D: 122809 [DL]Using Thread extended MAC for hostname.
I: 122815 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=0
I: 122824 [DL]advertising srp service: 3DFFA03505837BBD._matterc._udp
D: 124472 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
D: 124494 [DL]SRP update succeeded
D: 125732 [DL]ConnId: 0x00, New CCCD value: 0x0000
D: 125737 [IN]Clearing BLE pending packets.
I: 125741 [BLE]Releasing end point&amp;#39;s BLE connection back to application.
I: 125747 [DL]Closing BLE GATT connection (ConnId 00)
I: 125867 [DL]BLE GAP connection terminated (reason 0x16)
I: 125872 [DL]Current number of connections: 0/1
I: 206647 [FS]Fail-safe timer expired
E: 206651 [SVR]Failsafe timer expired
D: 206654 [IN]SecureSession[0x200037e0]: MarkForEviction Type:1 LSID:16261
I: 206661 [SC]SecureSession[0x200037e0]: Moving from state &amp;#39;kActive&amp;#39; --&amp;gt; &amp;#39;kPendingEviction&amp;#39;
D: 206669 [IN]SecureSession[0x200037e0]: Released - Type:1 LSID:16261
E: 206675 [SVR]Commissioning failed (attempt 1): 32
D: 206682 [IN]SecureSession[0x200037e0]: Allocated Type:1 LSID:16262
D: 206689 [DL]CHIPoBLE advertising set to on
I: 206693 [DIS]Updating services using commissioning mode 1
D: 206698 [DL]Using Thread extended MAC for hostname.
I: 206703 [DIS]Advertise operational node FD86F6B230A188DD-0000000000000001
D: 206710 [DL]Using Thread extended MAC for hostname.
I: 206716 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=1
I: 206725 [DL]advertising srp service: 3DFFA03505837BBD._matterc._udp
E: 206732 [ZCL]OpCreds: Got FailSafeTimerExpired
E: 206736 [ZCL]OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry!
D: 206743 [IN]Expiring all sessions for fabric 0x1!!
E: 206748 [FP]Reverting pending fabric data for fabric 0x1
E: 206755 [FP]Warning: metadata not found during delete of fabric 0x1
I: 206767 [FP]Fabric (0x1) deleted.
I: 206770 [ZCL][OnFabricRemoved] Handling a fabric removal from the door lock server [endpointId=1,fabricIndex=1]
I: 206780 [ZCL]Getting lock user 1: available
I: 206784 [ZCL]Getting lock user 2: available
I: 206788 [ZCL]Getting lock user 3: available
I: 206792 [ZCL]Getting lock user 4: available
I: 206797 [ZCL]Getting lock user 5: available
I: 206801 [ZCL]Getting lock user 6: available
I: 206805 [ZCL]Getting lock user 7: available
I: 206809 [ZCL]Getting lock user 8: available
I: 206813 [ZCL]Getting lock user 9: available
I: 206817 [ZCL]Getting lock user 10: available
I: 206821 [ZCL]Getting lock credential 1: available
I: 206826 [ZCL]Getting lock credential 2: available
I: 206831 [ZCL]Getting lock credential 3: available
I: 206835 [ZCL]Getting lock credential 4: available
I: 206840 [ZCL]Getting lock credential 5: available
I: 206845 [ZCL]Getting lock credential 6: available
I: 206849 [ZCL]Getting lock credential 7: available
I: 206854 [ZCL]Getting lock credential 8: available
I: 206859 [ZCL]Getting lock credential 9: available
I: 206863 [ZCL]Getting lock credential 10: available
E: 206868 [ZCL][clearFabricFromCredentials] Unable to clear fabric from credential - couldn&amp;#39;t read credential from database [endpointId=1,credentialType=0,credentialIndex=0,fabricIdToRemove=1]
I: 206885 [ZCL]OpCreds: Fabric index 0x1 was removed
I: 206890 [DIS]Updating services using commissioning mode 1
D: 206895 [DL]Using Thread extended MAC for hostname.
I: 206901 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=1
I: 206911 [DL]advertising srp service: 3DFFA03505837BBD._matterc._udp
I: 206917 [DL]removing srp service: FD86F6B230A188DD-0000000000000001._matter._tcp
I: 206944 [TS]Pending Last Known Good Time: 2023-08-14T14:58:38
I: 206951 [TS]Previous Last Known Good Time: 2023-08-14T14:58:38
I: 206957 [TS]Reverted Last Known Good Time to previous value
E: 206964 [FP]Warning: metadata not found during delete of fabric 0x1
E: 206973 [ZCL]OpCreds: failed to delete fabric at index 1: d8
I: 206979 [NP]Reverting Thread operational dataset
E: 206991 [DL]Long dispatch time: 340 ms, for event type 32782
I: 206997 [FS]Fail-safe cleanly disarmed
I: 207002 [DL]CHIPoBLE advertising started
D: 207006 [DL]OpenThread State Changed (Flags: 0x11002046)
D: 207011 [DL]   Device Role: DISABLED
D: 207015 [DL]   Thread Unicast Addresses:
D: 207019 [DL]        fd11:22::83e2:94d:8e52:7e55/64 valid preferred
D: 207026 [DL]OpenThread State Changed (Flags: 0x10000000)
I: 207033 [DL]NFC Tag emulation started
&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;chip-tool_2023-08-16.log&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;pre class="ui-code" data-mode="text"&gt;./chip-tool-release pairing ble-thread 1 hex:0e08000000000001000035060004001fffe00708fdc240f9e941ab800c0402a0f7f8051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f0410445f2b5ca6f2a93a55ce570a70efeecb000300000f0208111111112222222201021234 20202021 3840
[1692169377.990106][301339:301339] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-G1xLl0)
[1692169377.990165][301339:301339] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1692169377.990175][301339:301339] CHIP:DL: NVS set: chip-counters/reboot-count = 11 (0xB)
[1692169377.990456][301339:301339] CHIP:DL: Got Ethernet interface: enp4s0
[1692169377.990681][301339:301339] CHIP:DL: Found the primary Ethernet interface:enp4s0
[1692169377.990963][301339:301339] CHIP:DL: Failed to get WiFi interface
[1692169377.990968][301339:301339] CHIP:DL: Failed to reset WiFi statistic counts
[1692169377.991044][301339:301339] CHIP:TS: Last Known Good Time: 2023-08-15T13:18:23
[1692169377.991183][301339:301339] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0xFD86F6B230A188DD, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1692169377.991434][301339:301339] CHIP:ZCL: Using ZAP configuration...
[1692169377.992549][301339:301339] CHIP:DL: Avahi client registered
[1692169377.993299][301339:301339] CHIP:CTL: Setting attestation nonce to random value
[1692169377.993311][301339:301339] CHIP:CTL: Setting CSR nonce to random value
[1692169377.993453][301339:301343] CHIP:CTL: Setting attestation nonce to random value
[1692169377.993462][301339:301343] CHIP:CTL: Setting CSR nonce to random value
[1692169377.996352][301339:301343] CHIP:CTL: Generating NOC
[1692169377.999238][301339:301343] CHIP:FP: Validating NOC chain
[1692169378.010761][301339:301343] CHIP:FP: NOC chain validation successful
[1692169378.010777][301339:301343] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1692169378.010783][301339:301343] CHIP:TS: Last Known Good Time: 2023-08-15T13:18:23
[1692169378.010786][301339:301343] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1692169378.010789][301339:301343] CHIP:TS: Retaining current Last Known Good Time
[1692169378.011265][301339:301343] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1692169378.011449][301339:301343] CHIP:TS: Committing Last Known Good Time to storage: 2023-08-15T13:18:23
[1692169378.011620][301339:301343] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: FD86F6B230A188DD)
[1692169378.013893][301339:301343] CHIP:CTL: Setting thread operational dataset from parameters
[1692169378.013903][301339:301343] CHIP:CTL: Setting attestation nonce to random value
[1692169378.013912][301339:301343] CHIP:CTL: Setting CSR nonce to random value
[1692169378.013918][301339:301343] CHIP:CTL: Commission called for node ID 0x0000000000000001
[1692169378.018768][301339:301342] CHIP:BLE: BLE removing known devices.
[1692169378.019166][301339:301342] CHIP:BLE: BLE initiating scan.
[1692169378.139499][301339:301342] CHIP:BLE: New device scanned: E1:3E:0C:06:BC:27
[1692169378.139544][301339:301342] CHIP:BLE: Device discriminator match. Attempting to connect.
[1692169379.913536][301339:301343] CHIP:DIS: Closing all BLE connections
[1692169379.913760][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28530i S:0 M:205354517] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
[1692169379.913783][301339:301343] CHIP:IN: (U) Sending msg 205354517 to IP address &amp;#39;BLE&amp;#39;
[1692169380.444776][301339:301343] CHIP:BLE: subscribe complete, ep = 0x55881bfdfd00
[1692169380.445834][301339:301343] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
[1692169380.445879][301339:301343] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
[1692169380.445903][301339:301343] CHIP:BLE: local and remote recv window size = 5
[1692169380.582023][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28530i S:0 M:168352059] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
[1692169380.596446][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28530i S:0 M:205354518] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
[1692169380.596465][301339:301343] CHIP:IN: (U) Sending msg 205354518 to IP address &amp;#39;BLE&amp;#39;
[1692169382.427584][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28530i S:0 M:168352060] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
[1692169382.447235][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28530i S:0 M:205354519] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
[1692169382.447261][301339:301343] CHIP:IN: (U) Sending msg 205354519 to IP address &amp;#39;BLE&amp;#39;
[1692169382.560750][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28530i S:0 M:168352061] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
[1692169382.560883][301339:301343] CHIP:SC: SecureSession[0x7f761800f400]: Moving from state &amp;#39;kEstablishing&amp;#39; --&amp;gt; &amp;#39;kActive&amp;#39;
[1692169382.560910][301339:301343] CHIP:TOO: Pairing Success
[1692169382.560926][301339:301343] CHIP:TOO: PASE establishment successful
[1692169382.560944][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;SecurePairing&amp;#39; -&amp;gt; &amp;#39;ReadCommissioningInfo&amp;#39;
[1692169382.560963][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;ReadCommissioningInfo&amp;#39;
[1692169382.560979][301339:301343] CHIP:CTL: Sending request for commissioning information
[1692169382.561100][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28531i S:41023 M:237205927] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
[1692169382.561137][301339:301343] CHIP:IN: (S) Sending msg 237205927 on secure session with LSID: 41023
[1692169382.830586][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28531i S:41023 M:243742841] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
[1692169382.832322][301339:301343] CHIP:CTL: ----- NetworkCommissioning Features: has Thread. endpointid = 0
[1692169382.832414][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;ReadCommissioningInfo&amp;#39;
[1692169382.832451][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;ReadCommissioningInfo&amp;#39; -&amp;gt; &amp;#39;ArmFailSafe&amp;#39;
[1692169382.832474][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;ArmFailSafe&amp;#39;
[1692169382.832490][301339:301343] CHIP:CTL: Arming failsafe (60 seconds)
[1692169382.832606][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28532i S:41023 M:237205928] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1692169382.832650][301339:301343] CHIP:IN: (S) Sending msg 237205928 on secure session with LSID: 41023
[1692169382.964819][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28532i S:41023 M:243742842] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1692169382.964870][301339:301343] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1692169382.964885][301339:301343] CHIP:CTL: Received ArmFailSafe response errorCode=0
[1692169382.964890][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;ArmFailSafe&amp;#39;
[1692169382.964894][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;ArmFailSafe&amp;#39; -&amp;gt; &amp;#39;ConfigRegulatory&amp;#39;
[1692169382.964898][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;ConfigRegulatory&amp;#39;
[1692169382.964901][301339:301343] CHIP:CTL: Setting Regulatory Config
[1692169382.964905][301339:301343] CHIP:CTL: Device does not support configurable regulatory location
[1692169382.964934][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28533i S:41023 M:237205929] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1692169382.964941][301339:301343] CHIP:IN: (S) Sending msg 237205929 on secure session with LSID: 41023
[1692169383.146363][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28533i S:41023 M:243742843] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1692169383.146615][301339:301343] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
[1692169383.146688][301339:301343] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
[1692169383.146716][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;ConfigRegulatory&amp;#39;
[1692169383.146734][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;ConfigRegulatory&amp;#39; -&amp;gt; &amp;#39;SendPAICertificateRequest&amp;#39;
[1692169383.146755][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;SendPAICertificateRequest&amp;#39;
[1692169383.146771][301339:301343] CHIP:CTL: Sending request for PAI certificate
[1692169383.146901][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28534i S:41023 M:237205930] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1692169383.146941][301339:301343] CHIP:IN: (S) Sending msg 237205930 on secure session with LSID: 41023
[1692169383.460623][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28534i S:41023 M:243742844] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1692169383.460797][301339:301343] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1692169383.460829][301339:301343] CHIP:CTL: Received certificate chain from the device
[1692169383.460848][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;SendPAICertificateRequest&amp;#39;
[1692169383.460863][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;SendPAICertificateRequest&amp;#39; -&amp;gt; &amp;#39;SendDACCertificateRequest&amp;#39;
[1692169383.460882][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;SendDACCertificateRequest&amp;#39;
[1692169383.460900][301339:301343] CHIP:CTL: Sending request for DAC certificate
[1692169383.460985][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28535i S:41023 M:237205931] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1692169383.461011][301339:301343] CHIP:IN: (S) Sending msg 237205931 on secure session with LSID: 41023
[1692169383.775607][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28535i S:41023 M:243742845] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1692169383.775679][301339:301343] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1692169383.775691][301339:301343] CHIP:CTL: Received certificate chain from the device
[1692169383.775701][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;SendDACCertificateRequest&amp;#39;
[1692169383.775708][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;SendDACCertificateRequest&amp;#39; -&amp;gt; &amp;#39;SendAttestationRequest&amp;#39;
[1692169383.775717][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;SendAttestationRequest&amp;#39;
[1692169383.775722][301339:301343] CHIP:CTL: Sending Attestation Request to the device.
[1692169383.775758][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28536i S:41023 M:237205932] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1692169383.775769][301339:301343] CHIP:IN: (S) Sending msg 237205932 on secure session with LSID: 41023
[1692169384.230341][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28536i S:41023 M:243742846] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1692169384.230594][301339:301343] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
[1692169384.230630][301339:301343] CHIP:CTL: Received Attestation Information from the device
[1692169384.230658][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;SendAttestationRequest&amp;#39;
[1692169384.230696][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;SendAttestationRequest&amp;#39; -&amp;gt; &amp;#39;AttestationVerification&amp;#39;
[1692169384.230720][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;AttestationVerification&amp;#39;
[1692169384.230732][301339:301343] CHIP:CTL: Verifying attestation
[1692169384.254195][301339:301343] CHIP:CR: mbedTLS error: ERROR - Generic error
[1692169384.279642][301339:301343] CHIP:CTL: Successfully validated &amp;#39;Attestation Information&amp;#39; command received from the device.
[1692169384.279663][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;AttestationVerification&amp;#39;
[1692169384.279669][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;AttestationVerification&amp;#39; -&amp;gt; &amp;#39;SendOpCertSigningRequest&amp;#39;
[1692169384.279677][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;SendOpCertSigningRequest&amp;#39;
[1692169384.279733][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28537i S:41023 M:237205933] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1692169384.279744][301339:301343] CHIP:IN: (S) Sending msg 237205933 on secure session with LSID: 41023
[1692169384.723117][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28537i S:41023 M:243742847] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1692169384.723345][301339:301343] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0005
[1692169384.723380][301339:301343] CHIP:CTL: Received certificate signing request from the device
[1692169384.723402][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;SendOpCertSigningRequest&amp;#39;
[1692169384.723420][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;SendOpCertSigningRequest&amp;#39; -&amp;gt; &amp;#39;ValidateCSR&amp;#39;
[1692169384.723441][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;ValidateCSR&amp;#39;
[1692169384.751096][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;ValidateCSR&amp;#39;
[1692169384.751129][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;ValidateCSR&amp;#39; -&amp;gt; &amp;#39;GenerateNOCChain&amp;#39;
[1692169384.751144][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;GenerateNOCChain&amp;#39;
[1692169384.751154][301339:301343] CHIP:CTL: Getting certificate chain for the device from the issuer
[1692169384.751205][301339:301343] CHIP:CTL: Verifying Certificate Signing Request
[1692169384.763727][301339:301343] CHIP:CTL: Generating NOC
[1692169384.768214][301339:301343] CHIP:CTL: Providing certificate chain to the commissioner
[1692169384.768227][301339:301343] CHIP:CTL: Received callback from the CA for NOC Chain generation. Status src/controller/ExampleOperationalCredentialsIssuer.cpp:396: Success
[1692169384.768238][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;GenerateNOCChain&amp;#39;
[1692169384.768289][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;SendTrustedRootCert&amp;#39;
[1692169384.768296][301339:301343] CHIP:CTL: Sending root certificate to the device
[1692169384.768346][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28538i S:41023 M:237205934] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1692169384.768359][301339:301343] CHIP:IN: (S) Sending msg 237205934 on secure session with LSID: 41023
[1692169384.768512][301339:301343] CHIP:CTL: Sent root certificate to the device
[1692169385.035960][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28538i S:41023 M:243742848] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1692169385.036109][301339:301343] CHIP:DMG: Received Command Response Status for Endpoint=0 Cluster=0x0000_003E Command=0x0000_000B Status=0x0
[1692169385.036130][301339:301343] CHIP:CTL: Device confirmed that it has received the root certificate
[1692169385.036145][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;SendTrustedRootCert&amp;#39;
[1692169385.036163][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;SendTrustedRootCert&amp;#39; -&amp;gt; &amp;#39;SendNOC&amp;#39;
[1692169385.036179][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;SendNOC&amp;#39;
[1692169385.036275][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28539i S:41023 M:237205935] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1692169385.036305][301339:301343] CHIP:IN: (S) Sending msg 237205935 on secure session with LSID: 41023
[1692169385.036625][301339:301343] CHIP:CTL: Sent operational certificate to the device
[1692169385.576225][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28539i S:41023 M:243742849] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1692169385.576467][301339:301343] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0008
[1692169385.576507][301339:301343] CHIP:CTL: Device returned status 0 on receiving the NOC
[1692169385.576522][301339:301343] CHIP:CTL: Operational credentials provisioned on device 0x7f761800c600
[1692169385.576540][301339:301343] CHIP:TOO: Secure Pairing Success
[1692169385.576559][301339:301343] CHIP:TOO: CASE establishment successful
[1692169385.576591][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;SendNOC&amp;#39;
[1692169385.576614][301339:301343] CHIP:CTL: No NetworkScan enabled or WiFi/Thread endpoint not specified, skipping ScanNetworks
[1692169385.576634][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;SendNOC&amp;#39; -&amp;gt; &amp;#39;ThreadNetworkSetup&amp;#39;
[1692169385.576656][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;ThreadNetworkSetup&amp;#39;
[1692169385.576789][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28540i S:41023 M:237205936] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1692169385.576830][301339:301343] CHIP:IN: (S) Sending msg 237205936 on secure session with LSID: 41023
[1692169385.756250][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28540i S:41023 M:243742850] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1692169385.756463][301339:301343] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0005
[1692169385.756539][301339:301343] CHIP:CTL: Received NetworkConfig response, networkingStatus=0
[1692169385.756567][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;ThreadNetworkSetup&amp;#39;
[1692169385.756588][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;ThreadNetworkSetup&amp;#39; -&amp;gt; &amp;#39;FailsafeBeforeThreadEnable&amp;#39;
[1692169385.756675][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;FailsafeBeforeThreadEnable&amp;#39;
[1692169385.756700][301339:301343] CHIP:CTL: Arming failsafe (87 seconds)
[1692169385.756824][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28541i S:41023 M:237205937] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1692169385.756862][301339:301343] CHIP:IN: (S) Sending msg 237205937 on secure session with LSID: 41023
[1692169385.890224][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28541i S:41023 M:243742851] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1692169385.890305][301339:301343] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1692169385.890320][301339:301343] CHIP:CTL: Received ArmFailSafe response errorCode=0
[1692169385.890329][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;FailsafeBeforeThreadEnable&amp;#39;
[1692169385.890335][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;FailsafeBeforeThreadEnable&amp;#39; -&amp;gt; &amp;#39;ThreadNetworkEnable&amp;#39;
[1692169385.890344][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;ThreadNetworkEnable&amp;#39;
[1692169385.890388][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28542i S:41023 M:237205938] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1692169385.890403][301339:301343] CHIP:IN: (S) Sending msg 237205938 on secure session with LSID: 41023
[1692169388.025619][301339:301343] CHIP:BLE: BLE scan error: src/platform/Linux/bluez/ChipDeviceScanner.cpp:154: CHIP Error 0x00000032: Timeout
[1692169388.141413][301339:301343] CHIP:EM: &amp;gt;&amp;gt;&amp;gt; [E:28542i S:41023 M:243742852] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1692169388.141624][301339:301343] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0007
[1692169388.141666][301339:301343] CHIP:CTL: Received ConnectNetwork response, networkingStatus=0
[1692169388.141695][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;ThreadNetworkEnable&amp;#39;
[1692169388.141716][301339:301343] CHIP:CTL: Commissioning stage next step: &amp;#39;ThreadNetworkEnable&amp;#39; -&amp;gt; &amp;#39;FindOperational&amp;#39;
[1692169388.141763][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;FindOperational&amp;#39;
[1692169388.141807][301339:301343] CHIP:DIS: Resolving FD86F6B230A188DD:0000000000000001 ...
[1692169388.342286][301339:301343] CHIP:DIS: Checking node lookup status after 200 ms
[1692169391.866264][301339:301343] CHIP:DL: Avahi resolve found
[1692169391.866340][301339:301343] CHIP:DIS: Node ID resolved for FD86F6B230A188DD:0000000000000001
[1692169391.866980][301339:301343] CHIP:DIS: UDP:[fd11:22::83e2:94d:8e52:7e55%enp5s0]:5540: new best score: 4
[1692169391.867024][301339:301343] CHIP:DIS: Checking node lookup status after 3725 ms
[1692169391.867121][301339:301343] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -&amp;gt; 0x0000000000000001
[1692169391.880581][301339:301343] CHIP:EM: &amp;lt;&amp;lt;&amp;lt; [E:28543i S:0 M:205354520] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
[1692169391.880652][301339:301343] CHIP:IN: (U) Sending msg 205354520 to IP address &amp;#39;UDP:[fd11:22::83e2:94d:8e52:7e55]:5540&amp;#39;
[1692169391.880762][301339:301343] CHIP:CTL: Device connection failed. Error src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1692169391.880802][301339:301343] CHIP:CTL: Error on commissioning step &amp;#39;FindOperational&amp;#39;: &amp;#39;src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable&amp;#39;
[1692169391.880822][301339:301343] CHIP:CTL: Failed to perform commissioning step 20
[1692169391.880846][301339:301343] CHIP:CTL: Going from commissioning step &amp;#39;FindOperational&amp;#39; with lastErr = &amp;#39;src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable&amp;#39; -&amp;gt; &amp;#39;Cleanup&amp;#39;
[1692169391.880877][301339:301343] CHIP:CTL: Performing next commissioning step &amp;#39;Cleanup&amp;#39; with completion status = &amp;#39;src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable&amp;#39;
[1692169391.880899][301339:301343] CHIP:CTL: Successfully finished commissioning step &amp;#39;Cleanup&amp;#39;
[1692169391.880930][301339:301343] CHIP:TOO: Device commissioning Failure: src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1692169391.882195][301339:301339] CHIP:DIS: Closing all BLE connections
[1692169391.882527][301339:301339] CHIP:BLE: Auto-closing end point&amp;#39;s BLE connection.
[1692169391.882555][301339:301339] CHIP:DL: Closing BLE GATT connection (con 0x7f7620049170)
[1692169392.056584][301339:301339] CHIP:SC: SecureSession[0x7f761800f400]: Moving from state &amp;#39;kActive&amp;#39; --&amp;gt; &amp;#39;kPendingEviction&amp;#39;
[1692169392.056666][301339:301339] CHIP:FP: Forgetting fabric 0x1
[1692169392.056704][301339:301339] CHIP:TS: Pending Last Known Good Time: 2023-08-15T13:18:23
[1692169392.056885][301339:301339] CHIP:TS: Previous Last Known Good Time: 2023-08-15T13:18:23
[1692169392.056909][301339:301339] CHIP:TS: Reverted Last Known Good Time to previous value
[1692169392.057574][301339:301342] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
[1692169392.058256][301339:301339] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1692169392.058311][301339:301339] CHIP:FP: Shutting down FabricTable
[1692169392.058345][301339:301339] CHIP:TS: Pending Last Known Good Time: 2023-08-15T13:18:23
[1692169392.058487][301339:301339] CHIP:TS: Previous Last Known Good Time: 2023-08-15T13:18:23
[1692169392.058508][301339:301339] CHIP:TS: Reverted Last Known Good Time to previous value
[1692169392.058692][301339:301339] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-I74CT2)
[1692169392.058981][301339:301339] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1692169392.059054][301339:301339] CHIP:DL: NVS set: chip-counters/total-operational-hours = 2 (0x2)
[1692169392.059082][301339:301339] CHIP:DL: Inet Layer shutdown
[1692169392.059105][301339:301339] CHIP:DL: BLE shutdown
[1692169392.060423][301339:301339] CHIP:DL: System Layer shutdown
[1692169392.060719][301339:301339] CHIP:TOO: Run command failure: src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
&lt;/pre&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/441868?ContentTypeID=1</link><pubDate>Thu, 17 Aug 2023 12:47:20 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:33a3735b-6e33-48cd-9f31-afe3c41ae131</guid><dc:creator>Amanda Hsieh</dc:creator><description>[quote user="MatsL"]Do I have to upload the files somewhere else, like Google Drive, to get an web URL to use with &amp;#39;Insert&amp;#39;?[/quote]
&lt;p&gt;That&amp;#39;s a good alternative. You can paste the link without &amp;quot;insert&amp;quot;.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;-Amanda H.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/441743?ContentTypeID=1</link><pubDate>Thu, 17 Aug 2023 05:47:28 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8101caae-072a-4653-b94a-89e67ad7d527</guid><dc:creator>MatsL</dc:creator><description>&lt;p&gt;It is not the file format that is the problem.&amp;nbsp;I don&amp;#39;t know how to express myself more clearly. I don&amp;#39;t understand how to upload files!&lt;br /&gt;I use Chrome for Linux. I&amp;#39;ve also tried using Firefox, but I don&amp;#39;t know what to do there either. Insert does not work. Do I have to upload the files somewhere else, like Google Drive, to get an web URL to use with &amp;#39;Insert&amp;#39;?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/441654?ContentTypeID=1</link><pubDate>Wed, 16 Aug 2023 13:48:39 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:e925b29f-ebcb-45a9-aaa6-b816cb6e1254</guid><dc:creator>Amanda Hsieh</dc:creator><description>&lt;p&gt;Try to pack them in one zip file to upload.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/441639?ContentTypeID=1</link><pubDate>Wed, 16 Aug 2023 13:15:43 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:9ce8ff93-133a-4faf-a8db-caa3ef3e0979</guid><dc:creator>MatsL</dc:creator><description>&lt;p&gt;That didn&amp;#39;t work!&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/441637?ContentTypeID=1</link><pubDate>Wed, 16 Aug 2023 13:14:47 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:0e48729d-f30a-46db-8e6e-b2f393eaa8af</guid><dc:creator>MatsL</dc:creator><description>&lt;p&gt;&lt;a href="https://devzone.nordicsemi.com/home/matslm/Development/Scrum_Team/STREAM-3919-Matter_Demo_Build_and_onboard_lock/chip-tool_2023-08-16.log"&gt;devzone.nordicsemi.com/.../chip-tool_2023-08-16.log&lt;/a&gt;&lt;br /&gt;&lt;a href="https://devzone.nordicsemi.com/home/matslm/Development/Scrum_Team/STREAM-3919-Matter_Demo_Build_and_onboard_lock/nRF52840-DK_UART_2023-08-16.log"&gt;devzone.nordicsemi.com/.../nRF52840-DK_UART_2023-08-16.log&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/441634?ContentTypeID=1</link><pubDate>Wed, 16 Aug 2023 13:11:34 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:156f9084-adb7-4ae6-b318-e615521f980b</guid><dc:creator>Amanda Hsieh</dc:creator><description>&lt;p&gt;The link means website link.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Could you rename the file with the date as&amp;nbsp;&lt;span&gt;chip-tool_log_0816.txt and nRF52840DK_UART_log_0816.txt, and then upload them again?&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/441631?ContentTypeID=1</link><pubDate>Wed, 16 Aug 2023 13:08:02 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:4ca8b9d3-e3ee-478e-a9d2-78477480adf9</guid><dc:creator>MatsL</dc:creator><description>&lt;p&gt;I can not understand how to upload files? Your UI is not very intuitive. What type of link am I supposed to add to Insert? I have tried all types of links file://&amp;nbsp;or just /. The files are on my computer.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/441623?ContentTypeID=1</link><pubDate>Wed, 16 Aug 2023 13:01:17 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:907a9a91-888b-4f49-b544-f6d64a2946ad</guid><dc:creator>Amanda Hsieh</dc:creator><description>&lt;p&gt;I still cannot download those files. Please rename the files and upload them again. After those files are uploaded, please don&amp;#39;t modify the post.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;-Amanda H.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/441614?ContentTypeID=1</link><pubDate>Wed, 16 Aug 2023 12:41:14 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:60a5999a-8805-4f1e-83c0-2894fc20e278</guid><dc:creator>MatsL</dc:creator><description>&lt;p&gt;&lt;a href="https://devzone.nordicsemi.com/home/matslm/Development/Scrum_Team/STREAM-3919-Matter_Demo_Build_and_onboard_lock/chip-tool.log"&gt;devzone.nordicsemi.com/.../chip-tool.log&lt;/a&gt;&lt;br /&gt;&lt;a href="https://devzone.nordicsemi.com/home/matslm/Development/Scrum_Team/STREAM-3919-Matter_Demo_Build_and_onboard_lock/nRF52840-DK_UART.log"&gt;devzone.nordicsemi.com/.../nRF52840-DK_UART.log&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/441611?ContentTypeID=1</link><pubDate>Wed, 16 Aug 2023 12:33:44 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d73be067-e185-464b-8325-d44895fc8ff1</guid><dc:creator>Amanda Hsieh</dc:creator><description>&lt;p&gt;Insert -&amp;gt; Image/video/file to upload the file or &lt;span&gt;Insert -&amp;gt;&lt;/span&gt;code to past the context.&lt;/p&gt;
&lt;p&gt;-Amanda H.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/441504?ContentTypeID=1</link><pubDate>Wed, 16 Aug 2023 07:12:58 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:0829bf44-2aca-4188-ad39-6fe5e41d916a</guid><dc:creator>MatsL</dc:creator><description>&lt;p&gt;Hi,&lt;br /&gt;Yes I have downloaded chip-tool v2.4.1 from&amp;nbsp;&lt;a id="" href="https://github.com/nrfconnect/sdk-connectedhomeip/releases"&gt;https://github.com/nrfconnect/sdk-connectedhomeip/releases&lt;/a&gt;.&lt;br /&gt;How do I upload files? Insert does not seem to work (for me).&lt;br /&gt;Regards&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF52840 DK commissioning with chip-tool fail</title><link>https://devzone.nordicsemi.com/thread/441434?ContentTypeID=1</link><pubDate>Tue, 15 Aug 2023 15:38:39 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:5872aa2d-463f-4cd6-b26f-f2a18eb7940f</guid><dc:creator>Amanda Hsieh</dc:creator><description>&lt;p&gt;Hi,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Are you using&amp;nbsp;&lt;span&gt;chip-tool from&lt;/span&gt;&amp;nbsp;&lt;a href="https://github.com/nrfconnect/sdk-connectedhomeip/releases"&gt;https://github.com/nrfconnect/sdk-connectedhomeip/releases&lt;/a&gt;&lt;span&gt;? Make sure to download and use the same version as the SDK you are using.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;The chip-tool_log.txt&lt;span&gt;&amp;nbsp;and&amp;nbsp;&lt;/span&gt;nRF52840-DK_UART_log.txt cannot be downloaded. Please upload them again.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Regards,&lt;br /&gt;Amanda H.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
