<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/102947/problem-to-create-a-build-configuration</link><description>Hello,
 I&amp;#39;m using nRF Connect SDK v2.4.1 in VS Code. I have a project which have been working fine until I updated nRF Connect SDK. After the update there is not any build configuration and when I try to create one I receive the following error code</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 22 Aug 2023 13:46:54 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/102947/problem-to-create-a-build-configuration" /><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442597?ContentTypeID=1</link><pubDate>Tue, 22 Aug 2023 13:46:54 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:fbe9592d-10fe-435c-b73d-e23a2f6254ec</guid><dc:creator>msu7xi</dc:creator><description>&lt;p&gt;Hello Hung Bui,&lt;/p&gt;
&lt;p&gt;This solved the problem. Thanks!&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442589?ContentTypeID=1</link><pubDate>Tue, 22 Aug 2023 13:32:12 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:dedce50b-652f-4466-a14e-1b482326fbb9</guid><dc:creator>Hung Bui</dc:creator><description>&lt;p&gt;Hi Marco,&amp;nbsp;&lt;br /&gt;Sorry for that the case taking so long to resolve. I thought that you have tested with other sample and got the same issue. But if the issue was only in your application then it&amp;#39;s easier to solve.&amp;nbsp;&lt;br /&gt;If you look at your project you will find a .west folder:&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1692711015344v1.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;This folder has some predefined configuration for example path or base.&amp;nbsp;&lt;br /&gt;If you remove this &amp;quot;.west&amp;quot; folder and build again, it should work . I did a test here and saw the same issue as you before I remove the folder.&amp;nbsp;&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442545?ContentTypeID=1</link><pubDate>Tue, 22 Aug 2023 12:06:24 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:0c0d11af-42e7-4dbf-9144-ade6ead1559e</guid><dc:creator>msu7xi</dc:creator><description>&lt;p&gt;Hello Hung Bui,&lt;/p&gt;
&lt;p&gt;I can build the &amp;quot;hello_world&amp;quot; example.&lt;/p&gt;
&lt;p&gt;In my project I cannot click build as I cannot even create a build configuration. Below the screenshots:&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-from-2023_2D00_08_2D00_22-13_2D00_57_2D00_04.png" /&gt;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-from-2023_2D00_08_2D00_22-13_2D00_57_2D00_58.png" /&gt;&lt;/p&gt;
&lt;p&gt;How come the SDK can build some projects but not mine which was working fine before the upgrade?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442530?ContentTypeID=1</link><pubDate>Tue, 22 Aug 2023 11:46:25 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:77c02467-c0f1-4f8f-aa1a-edbd6dcba771</guid><dc:creator>Hung Bui</dc:creator><description>&lt;p&gt;Hi Marco,&amp;nbsp;&lt;br /&gt;I don&amp;#39;t think it has anything to do with your application. If you build an sample in the SDK I would assume you will see the same error ?&amp;nbsp;&lt;br /&gt;Could you please take a screenshot when you click build ?&amp;nbsp;&lt;br /&gt;I would need to report this to the team as I run out of idea what could be wrong.&amp;nbsp;&lt;br /&gt;My suggestion is to try uninstalling python and west. And then install SDK again with Toolchain manager.&amp;nbsp;&lt;br /&gt;Another option is to follow the guide to install the SDK manually :&amp;nbsp;&lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/installation/installing.html"&gt;https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/installation/installing.html&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442497?ContentTypeID=1</link><pubDate>Tue, 22 Aug 2023 10:56:47 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d509befe-df49-4d20-8cdb-f7d9e65db62d</guid><dc:creator>msu7xi</dc:creator><description>&lt;p&gt;Hello Hung Bui,&lt;/p&gt;
&lt;p&gt;I have tried by erasing ncs2\toolchains but the result is the same.&lt;/p&gt;
&lt;p&gt;The v2.3.0 version is also installed but I&amp;#39;ve just realized that even with this SDK I cannot create a build configuration.&lt;/p&gt;
&lt;p&gt;And yes, I used nRF Connect terminal as you showed me (I clicked on the + symbol and selected &amp;quot;nRF Connect&amp;quot;).&lt;/p&gt;
&lt;p&gt;Attached you will find my project so you can check if the problem is there:&lt;/p&gt;
&lt;p&gt;&lt;a href="https://devzone.nordicsemi.com/cfs-file/__key/communityserver-discussions-components-files/4/7801.central_5F00_uart.zip"&gt;devzone.nordicsemi.com/.../7801.central_5F00_uart.zip&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442475?ContentTypeID=1</link><pubDate>Tue, 22 Aug 2023 09:42:29 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:081fbb2c-f04b-4c26-8344-61fe4b91b13c</guid><dc:creator>Hung Bui</dc:creator><description>&lt;p&gt;Hi Marco,&amp;nbsp;&lt;br /&gt;I&amp;#39;m not so sure what could be wrong, but it&amp;#39;s most likely something to do with the toolchains.&amp;nbsp;&lt;br /&gt;Please make sure you erase the toolchains folder&amp;nbsp; (ncs2\toolchains) when you do a fresh install as well.&amp;nbsp;&lt;br /&gt;Could you try to install v2.3.0 ? There could be some issue with v2.4.0 toolchain.&amp;nbsp;&lt;br /&gt;Please take a screenshot of the window so I know which terminal you were using, did you use the nRF Connect terminal as I showed in my screenshot ?&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442361?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 14:47:46 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b0da9e2e-684c-4abc-87ae-e8432e37a312</guid><dc:creator>msu7xi</dc:creator><description>&lt;p&gt;Hello Hung Bui,&lt;/p&gt;
&lt;p&gt;Below the Welcome screen of VS Code:&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-from-2023_2D00_08_2D00_21-16_2D00_40_2D00_02.png" /&gt;&lt;/p&gt;
&lt;p&gt;When I type &amp;quot;west&amp;quot; I get the following output:&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-from-2023_2D00_08_2D00_21-16_2D00_42_2D00_20.png" /&gt;&lt;/p&gt;
&lt;p&gt;I still cannot create a build configuration. How can I solve this problem?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442359?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 14:35:56 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:37acf5ce-37ba-4696-887f-2f8a03e5b886</guid><dc:creator>Hung Bui</dc:creator><description>&lt;p&gt;Hi Marco,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Could you show the welcome screen in VSCode when you open it ?&amp;nbsp;&lt;br /&gt;Could you try to open VSCode from the Toolchain Manager software ?&amp;nbsp;&lt;br /&gt;The Welcome screen should select the SDK and the toolchain, for example:&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1692627698943v1.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;This should be in the extension setting:&amp;nbsp;&lt;br /&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1692628029532v2.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;If you open a nRF Connect terminal, and type west , you should see &amp;quot;build&amp;quot; in the list of commands:&amp;nbsp;&lt;br /&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1692628552111v3.png" alt=" " /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442304?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 12:44:34 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:672974b4-be4f-4fd7-a7da-6bc00dfd6708</guid><dc:creator>msu7xi</dc:creator><description>&lt;p&gt;Hello Hung Bui,&lt;/p&gt;
&lt;p&gt;I&amp;#39;ve created a new folder named &amp;quot;ncs2&amp;quot; and I have tried to install v2.4.1. This time the v2.4.1 folder looks like the one you showed me:&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-from-2023_2D00_08_2D00_21-14_2D00_42_2D00_07.png" /&gt;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-from-2023_2D00_08_2D00_21-14_2D00_42_2D00_23.png" /&gt;&lt;/p&gt;
&lt;p&gt;Nevertheless, I still cannot create a build configuration for my project. Which could be the problem for this and why I cannot install v2.4.1 in &amp;quot;ncs&amp;quot; folder?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442265?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 11:08:23 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:e6cad33a-48ca-4c13-8b69-dbde9947429e</guid><dc:creator>msu7xi</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;I&amp;#39;ve just installed v2.4.0 and I have the same problem. For information, below my ncs folder:&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-from-2023_2D00_08_2D00_21-13_2D00_08_2D00_04.png" /&gt;&lt;/p&gt;
&lt;p&gt;Do you see anything wrong?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442263?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 11:02:28 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:02eed5fa-027c-4112-8eee-3d6e713908ab</guid><dc:creator>Hung Bui</dc:creator><description>&lt;p&gt;Hi Marco,&amp;nbsp;&lt;br /&gt;If you install other NCS version do you see anything there ?&amp;nbsp;&lt;br /&gt;We would need to check if it&amp;#39;s the problem with only NCS v2.4.1 or it&amp;#39;s the issue with all NCS version so it can be that it&amp;#39;s the issue with maybe accessing the server from your computer&amp;nbsp;maybe firewall ?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;br /&gt;If it is the issue with only NCS v2.4.1 then it could be something wrong on our side.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442252?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 10:32:26 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:5f2ee123-8d70-45ac-84e6-5427f98a5754</guid><dc:creator>msu7xi</dc:creator><description>&lt;p&gt;Hello Hung Bui,&lt;/p&gt;
&lt;p&gt;I&amp;#39;ve tried to install in path ncs/new. Below the result:&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-from-2023_2D00_08_2D00_21-12_2D00_31_2D00_25.png" /&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-from-2023_2D00_08_2D00_21-12_2D00_31_2D00_58.png" /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442243?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 09:22:45 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d1c1e728-badf-4753-ad49-4b899f37872a</guid><dc:creator>Hung Bui</dc:creator><description>&lt;p&gt;Hi Marco,&amp;nbsp;&lt;br /&gt;It&amp;#39;s pretty strange. Could you try install it on a different folder?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Click Settings -&amp;gt; Installation directory&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442230?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 08:42:07 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:604cfcce-9e1c-42d6-96ca-a774c208b5a8</guid><dc:creator>msu7xi</dc:creator><description>&lt;p&gt;Hello Hung Bui,&lt;/p&gt;
&lt;p&gt;I have removed the SDK with the Toolchain Manager and I have reinstalled the version 2.4.1. Nevertheless, after the installation the folder is empty:&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-from-2023_2D00_08_2D00_21-10_2D00_40_2D00_22.png" /&gt;&lt;/p&gt;
&lt;p&gt;I have tried this procedure twice obtaining the same result.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442227?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 08:25:59 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8a9602aa-d81a-43c9-b6e4-b5a9b995aa71</guid><dc:creator>Hung Bui</dc:creator><description>&lt;p&gt;Hi Marco,&amp;nbsp;&lt;br /&gt;I would do &amp;quot;Remove&amp;quot; in the Toolchain Manager and then click Install again. (make sure the folder is erased after you click Remove)&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442225?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 08:16:48 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a94b9522-5cd7-44b9-ba5b-f29d1ff7de59</guid><dc:creator>msu7xi</dc:creator><description>&lt;p&gt;Hello Hung Bui,&lt;/p&gt;
&lt;p&gt;Below the screenshot of the v2.4.1 folder:&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-from-2023_2D00_08_2D00_21-10_2D00_15_2D00_58.png" /&gt;&lt;/p&gt;
&lt;p&gt;For reinstalling do I have to erase the folder?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442222?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 08:13:39 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:31b10561-f87d-4853-86e9-e6f20583a104</guid><dc:creator>Hung Bui</dc:creator><description>&lt;p&gt;Hi Marco,&amp;nbsp;&lt;br /&gt;Could you take a screenshot of NCS v2.4.1 folder ?&amp;nbsp;&lt;br /&gt;My suspicious is that it&amp;#39;s a corrupted installation.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;It should look like this:&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1692605591452v1.png" alt=" " /&gt;&lt;br /&gt;If it doesn&amp;#39;t my suggestion is to remove the SDK and try install it again with nRF Connect Toolchain manager.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442206?ContentTypeID=1</link><pubDate>Mon, 21 Aug 2023 07:39:37 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:190bab19-e162-4db5-8004-769abb33d292</guid><dc:creator>msu7xi</dc:creator><description>&lt;p&gt;Hello Hung Bui,&lt;/p&gt;
&lt;p&gt;I updated NCS SDK with the graphical interface of nRF Connect. I have also tried by running &lt;span style="font-family:courier new, courier;"&gt;west update&lt;/span&gt; when I realized my project was not capable to be built anymore.&lt;/p&gt;
&lt;p&gt;How do I check if I&amp;#39;m pointing the correct SDK folder in VSCode? I have not changed anything after the update.&lt;/p&gt;
&lt;p&gt;I also have the following warning in the &amp;quot;Welcome to nRF Connect&amp;quot; tab:&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-from-2023_2D00_08_2D00_21-09_2D00_48_2D00_50.png" /&gt;&lt;/p&gt;
&lt;p&gt;How can I solve this?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Problem to create a build configuration</title><link>https://devzone.nordicsemi.com/thread/442059?ContentTypeID=1</link><pubDate>Fri, 18 Aug 2023 11:01:49 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:ca430c80-f30b-43bc-af82-937d0941b11c</guid><dc:creator>Hung Bui</dc:creator><description>&lt;p&gt;Hi Marco,&amp;nbsp;&lt;br /&gt;Could you tell what did you do to update the NCS SDK ? Did you run west update ?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;A customer reported similar issue here:&amp;nbsp;&lt;br /&gt;&lt;a href="https://devzone.nordicsemi.com/f/nordic-q-a/89008/west-build-is-invalid-choice"&gt;west build is invalid choice&lt;/a&gt;&lt;/p&gt;
&lt;p&gt;It has something to do with Zephyr base. Have you made sure you pointed to the correct SDK folder in VSCode ?&amp;nbsp;&lt;br /&gt;Please also check if the toolchain folder is correct.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
