<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>52833 pins issue</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/103866/52833-pins-issue</link><description>Please explain the role of these two pins in the power supply of the 52833 system. During the after-sales repair, it was found that the two pin chip pads had fallen off.
 Does this B1 pin power the entire MCU? For DEC1; DEC4; DEC3; DEC6; DEC5, what role</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 26 Sep 2023 11:14:24 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/103866/52833-pins-issue" /><item><title>RE: 52833 pins issue</title><link>https://devzone.nordicsemi.com/thread/447687?ContentTypeID=1</link><pubDate>Tue, 26 Sep 2023 11:14:24 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:9a001917-bf3c-4a56-b8b1-e994da59cd88</guid><dc:creator>Kazi Afroza Sultana</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;&lt;span dir="ltr"&gt;DCC pin is for DCDC mode. So,&amp;nbsp;when there is LDO mode this pin will be floating.&amp;nbsp;DEC1 is voltage regulatory decoupling pin which is always needed for both LDO and DCDC mode. B3 pin is always used for the filter for DCDC. You can see the pin assignments here&amp;nbsp;&lt;a href="https://infocenter.nordicsemi.com/topic/ps_nrf52833/pin.html?cp=5_1_0_6_0"&gt;https://infocenter.nordicsemi.com/topic/ps_nrf52833/pin.html?cp=5_1_0_6_0&lt;/a&gt;.&amp;nbsp;&amp;nbsp;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span dir="ltr"&gt;Thanks.&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 52833 pins issue</title><link>https://devzone.nordicsemi.com/thread/446791?ContentTypeID=1</link><pubDate>Wed, 20 Sep 2023 07:41:05 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:afa4c3c2-591c-41e8-92b1-7a04853ad389</guid><dc:creator>Francis Feng</dc:creator><description>&lt;p&gt;Thanks Kazi!&lt;/p&gt;
&lt;p&gt;More questions:&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Which of these pins is applicable in DCDC and not applicable in LDO mode, or is it necessary to use these pins in both modes?&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;DEC1_nRF52833 pin if the pad has fallen off, then the chip can run in DCDC mode, can run in LDO mode?&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: 52833 pins issue</title><link>https://devzone.nordicsemi.com/thread/446481?ContentTypeID=1</link><pubDate>Mon, 18 Sep 2023 14:19:52 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:9119ce3d-2f44-4582-b20d-40bb57cc2e0c</guid><dc:creator>Kazi Afroza Sultana</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
[quote user=""]Does this B1 pin power the entire MCU?[/quote]
&lt;p&gt;No. B1 pin is related to only powering the SoC. The nRF52833 has 5V boost regulator that gives a 5V stable output from few sources like USB connector J for the interface MCU, USB connector J3 for the nRF52833 SoC and few more you can find this from the following link.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;a href="https://infocenter.nordicsemi.com/topic/ug_nrf52833_dk/UG/dk/5V_power_sources.html?cp=5_1_4_7_2_0"&gt;https://infocenter.nordicsemi.com/topic/ug_nrf52833_dk/UG/dk/5V_power_sources.html?cp=5_1_4_7_2_0&lt;/a&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;These&amp;nbsp;&lt;span&gt;DEC1;&lt;/span&gt;&lt;span&gt;&amp;nbsp;DEC4;&lt;/span&gt;&lt;span&gt;&amp;nbsp;DEC3;&lt;/span&gt;&lt;span&gt;&amp;nbsp;DEC6;&lt;/span&gt;&lt;span&gt;&amp;nbsp;DEC5 chips act as supply voltage decoupler. It enables the DC/DC regulators through DCDCEN register.&amp;nbsp;Using the DC/DC regulator will reduce current consumption compared to when using the LDO regulator, but the DC/DC regulator requires an external LC filter to be connected.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1695046703974v2.png" alt=" " /&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Thanks.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;BR&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Kazi&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
