<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>NRF21540 EK interfacing using NRF5 SDK</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/104211/nrf21540-ek-interfacing-using-nrf5-sdk</link><description>I have been trying to use the nRF21540 EK FEM with nRF 21540 DK to extend the range of my bluetooth device using this guide . I have tried the GPIO mode and GPIO+SPI mode for the sheild. i have tried modifying the device tree and prj.config file according</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 15 Mar 2024 11:56:51 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/104211/nrf21540-ek-interfacing-using-nrf5-sdk" /><item><title>RE: NRF21540 EK interfacing using NRF5 SDK</title><link>https://devzone.nordicsemi.com/thread/474068?ContentTypeID=1</link><pubDate>Fri, 15 Mar 2024 11:56:51 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:072a618a-4a44-4038-a678-efce51c36c19</guid><dc:creator>Rajeev_k</dc:creator><description>&lt;p&gt;OK, The Device could be faulty.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Thanks&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NRF21540 EK interfacing using NRF5 SDK</title><link>https://devzone.nordicsemi.com/thread/448677?ContentTypeID=1</link><pubDate>Tue, 03 Oct 2023 14:00:41 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:bafae452-c494-4215-b896-f344f7e29290</guid><dc:creator>Karl Ylvisaker</dc:creator><description>&lt;p&gt;Hello Rajeev,&lt;br /&gt;&lt;br /&gt;What were the RSSI&amp;#39;s in these cases?&lt;br /&gt;You can also check this more easily (due to less variance) if you run the test with the devices placed right next to each other on the desk - this will eliminate most of the possible interference which you will see over 40 meters without line of sight.&lt;br /&gt;&lt;br /&gt;Best regards,&lt;br /&gt;Karl&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NRF21540 EK interfacing using NRF5 SDK</title><link>https://devzone.nordicsemi.com/thread/448352?ContentTypeID=1</link><pubDate>Fri, 29 Sep 2023 12:52:29 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:90c0f4cb-3937-42d3-bc77-1fec1bdd5ae7</guid><dc:creator>Rajeev_k</dc:creator><description>&lt;p&gt;Hi Karl, I did , checked the rssi value at a fixed distance (40 meter) before and after enabling the FEM. In both cases the device did not have Line Of Sight. Is this because of any other issue.&lt;/p&gt;
&lt;p&gt;Regards&lt;/p&gt;
&lt;p&gt;Rajeev&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NRF21540 EK interfacing using NRF5 SDK</title><link>https://devzone.nordicsemi.com/thread/448342?ContentTypeID=1</link><pubDate>Fri, 29 Sep 2023 12:08:03 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:61af7256-27c9-491e-b960-6a96ea47e2cd</guid><dc:creator>Karl Ylvisaker</dc:creator><description>&lt;p&gt;Hello,&lt;br /&gt;&lt;br /&gt;Thank you for providing the .conf file - looking through it it seems to me that you have all the necessary configurations present.&lt;br /&gt;&lt;br /&gt;Did you have a chance to check if there was any difference at all when using this, compared to when you do not enable FEM?&lt;br /&gt;&lt;br /&gt;Best regards,&lt;br /&gt;Karl&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NRF21540 EK interfacing using NRF5 SDK</title><link>https://devzone.nordicsemi.com/thread/448136?ContentTypeID=1</link><pubDate>Thu, 28 Sep 2023 11:43:35 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:6ea28f92-dc3d-4e61-ae79-1a1c0d6c59aa</guid><dc:creator>Rajeev_k</dc:creator><description>&lt;p&gt;attached here, I have renamed the file to config.txt for ease of uploading&lt;/p&gt;
&lt;p&gt;&lt;a href="https://devzone.nordicsemi.com/cfs-file/__key/communityserver-discussions-components-files/4/1663.config.txt"&gt;/cfs-file/__key/communityserver-discussions-components-files/4/1663.config.txt&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NRF21540 EK interfacing using NRF5 SDK</title><link>https://devzone.nordicsemi.com/thread/448120?ContentTypeID=1</link><pubDate>Thu, 28 Sep 2023 11:08:59 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:62cf850f-c81a-4535-8b08-8a95e8301ca0</guid><dc:creator>Karl Ylvisaker</dc:creator><description>&lt;p&gt;Hello Rajeev,&lt;br /&gt;&lt;br /&gt;Could you share your entire .conf file from the build you are running, so that I may take a look?&lt;br /&gt;You can find this file in the build/zephyr/ location, and it contains all the kconfigs that are set in the build.&lt;/p&gt;
[quote user="Rajeev_k"]is there a way to check if the FEM is enabled externally.&amp;nbsp;[/quote]
&lt;p&gt;The simplest way to check this externally is to just use the nRF Connect SDK application for Desktop or Smartphone to scan for your device, and then read out the RSSI of the advertising.&lt;br /&gt;You could also do measurements on the hardware directly, but this requires a proper lab setup, and you will get a good indication whether the TX Power have changed just using the RSSI.&lt;br /&gt;&lt;br /&gt;Best regards,&lt;br /&gt;Karl&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NRF21540 EK interfacing using NRF5 SDK</title><link>https://devzone.nordicsemi.com/thread/448056?ContentTypeID=1</link><pubDate>Thu, 28 Sep 2023 05:38:48 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:fe502948-769e-4e4a-acbc-1d4c8a0a3fa7</guid><dc:creator>Rajeev_k</dc:creator><description>&lt;p&gt;Hi Andreas,&lt;/p&gt;
&lt;p&gt;I have addded this&amp;nbsp;&lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/kconfig/index.html#CONFIG_BT_CTLR_TX_PWR_ANTENNA"&gt;CONFIG_BT_CTLR_TX_PWR_ANTENNA&lt;/a&gt;&lt;span&gt;&amp;nbsp;to my prj.config, still I havent been able to see any change in range. It would a great help if you can help me enable the FEM. PS. is there a way to check if the FEM is enabled externally.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Kind regards,&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Rajeev&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NRF21540 EK interfacing using NRF5 SDK</title><link>https://devzone.nordicsemi.com/thread/447929?ContentTypeID=1</link><pubDate>Wed, 27 Sep 2023 11:44:06 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:0adc0100-df7c-4a09-8624-d2150520ea2a</guid><dc:creator>AHaug</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;From&amp;nbsp;&amp;nbsp;&lt;a href="https://devzone.nordicsemi.com/f/nordic-q-a/101936/thingy-53-and-nrf21540-frontend-bluetooth-mesh---how-to-set-tx-power-via-spi"&gt;Thingy 53 and nRF21540 Frontend (Bluetooth Mesh) - How to set TX power via SPI&lt;/a&gt;&amp;nbsp;&amp;nbsp;you can see that adding&amp;nbsp;&lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/kconfig/index.html#CONFIG_BT_CTLR_TX_PWR_ANTENNA"&gt;CONFIG_BT_CTLR_TX_PWR_ANTENNA&lt;/a&gt;&amp;nbsp;should enable what you want&lt;/p&gt;
&lt;p&gt;Let me know if this resolves your issue&lt;/p&gt;
&lt;p&gt;Kind regards,&lt;br /&gt;Andreas&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
