<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>After adding dfu, gpio 0.00 pin control is not available.</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/104367/after-adding-dfu-gpio-0-00-pin-control-is-not-available</link><description>Hello, I added the dfu function to the firmware I&amp;#39;m testing, but the gpio0.00 pin is out of control. Is there a solution?
 Below is the sdk_config.h file.
 thank you</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 10 Oct 2023 10:19:03 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/104367/after-adding-dfu-gpio-0-00-pin-control-is-not-available" /><item><title>RE: After adding dfu, gpio 0.00 pin control is not available.</title><link>https://devzone.nordicsemi.com/thread/449514?ContentTypeID=1</link><pubDate>Tue, 10 Oct 2023 10:19:03 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:c8461d79-cae2-46a3-8800-fe4587056cd7</guid><dc:creator>JILUNGIE</dc:creator><description>&lt;p&gt;Hello,&lt;br /&gt;Yes, the sdk_config.h file in the example &amp;#39;secure_bootloader_ble_s132_pca10040&amp;#39; also changed the LF clock to RC.&lt;/p&gt;
&lt;p&gt;The following is a modified sdk_config.h from the bootloader file.&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;/**
 * Copyright (c) 2017 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
 * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA &amp;quot;AS IS&amp;quot; AND ANY EXPRESS
#ifndef SDK_CONFIG_H
#define SDK_CONFIG_H
// &amp;lt;&amp;lt;&amp;lt; Use Configuration Wizard in Context Menu &amp;gt;&amp;gt;&amp;gt;\n
#ifdef USE_APP_CONFIG
#include &amp;quot;app_config.h&amp;quot;
// &amp;lt;h&amp;gt; nRF_Bootloader 
// &amp;lt;h&amp;gt; nrf_bootloader - Bootloader settings
// &amp;lt;h&amp;gt; Application integrity checks 
// &amp;lt;q&amp;gt; NRF_BL_APP_CRC_CHECK_SKIPPED_ON_GPREGRET2  - Skip CRC integrity check of the application when bit 1 (0-indexed) is set in the GPREGRET2 register.
// &amp;lt;i&amp;gt; Only CRC checks can be skipped. For other boot validation types, the GPREGRET2 register is ignored.
#ifndef NRF_BL_APP_CRC_CHECK_SKIPPED_ON_GPREGRET2
#define NRF_BL_APP_CRC_CHECK_SKIPPED_ON_GPREGRET2 1
// &amp;lt;q&amp;gt; NRF_BL_APP_CRC_CHECK_SKIPPED_ON_SYSTEMOFF_RESET  - Skip integrity check of the application when waking up from the System Off state.
// &amp;lt;i&amp;gt; Only CRC checks can be skipped. For other boot validation types, the reset state is ignored.
#ifndef NRF_BL_APP_CRC_CHECK_SKIPPED_ON_SYSTEMOFF_RESET
#define NRF_BL_APP_CRC_CHECK_SKIPPED_ON_SYSTEMOFF_RESET 1
// &amp;lt;q&amp;gt; NRF_BL_APP_SIGNATURE_CHECK_REQUIRED  - Perform signature check on the app. Requires the signature to be sent in the init packet.
#ifndef NRF_BL_APP_SIGNATURE_CHECK_REQUIRED
#define NRF_BL_APP_SIGNATURE_CHECK_REQUIRED 0
// &amp;lt;q&amp;gt; NRF_BL_DFU_ALLOW_UPDATE_FROM_APP  - Whether to allow the app to receive firmware updates for the bootloader to activate.
// &amp;lt;i&amp;gt; Enable this to allow the app to instruct the bootloader to activate firmware.
// &amp;lt;i&amp;gt; The bootloader will do its own postvalidation.
#ifndef NRF_BL_DFU_ALLOW_UPDATE_FROM_APP
#define NRF_BL_DFU_ALLOW_UPDATE_FROM_APP 0
// &amp;lt;/h&amp;gt; 
// &amp;lt;h&amp;gt; DFU mode enter method 
// &amp;lt;e&amp;gt; NRF_BL_DFU_ENTER_METHOD_BUTTON - Enter DFU mode on button press.
#ifndef NRF_BL_DFU_ENTER_METHOD_BUTTON
#define NRF_BL_DFU_ENTER_METHOD_BUTTON 1
// &amp;lt;o&amp;gt; NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN  - Button for entering DFU mode.
// &amp;lt;0=&amp;gt; 0 (P0.0) 
// &amp;lt;1=&amp;gt; 1 (P0.1) 
// &amp;lt;2=&amp;gt; 2 (P0.2) 
// &amp;lt;3=&amp;gt; 3 (P0.3) 
// &amp;lt;4=&amp;gt; 4 (P0.4) 
// &amp;lt;5=&amp;gt; 5 (P0.5) 
// &amp;lt;6=&amp;gt; 6 (P0.6) 
// &amp;lt;7=&amp;gt; 7 (P0.7) 
// &amp;lt;8=&amp;gt; 8 (P0.8) 
// &amp;lt;9=&amp;gt; 9 (P0.9) 
// &amp;lt;10=&amp;gt; 10 (P0.10) 
// &amp;lt;11=&amp;gt; 11 (P0.11) 
// &amp;lt;12=&amp;gt; 12 (P0.12) 
// &amp;lt;13=&amp;gt; 13 (P0.13) 
// &amp;lt;14=&amp;gt; 14 (P0.14) 
// &amp;lt;15=&amp;gt; 15 (P0.15) 
// &amp;lt;16=&amp;gt; 16 (P0.16) 
// &amp;lt;17=&amp;gt; 17 (P0.17) 
// &amp;lt;18=&amp;gt; 18 (P0.18) 
// &amp;lt;19=&amp;gt; 19 (P0.19) 
// &amp;lt;20=&amp;gt; 20 (P0.20) 
// &amp;lt;21=&amp;gt; 21 (P0.21) 
// &amp;lt;22=&amp;gt; 22 (P0.22) 
// &amp;lt;23=&amp;gt; 23 (P0.23) 
// &amp;lt;24=&amp;gt; 24 (P0.24) 
// &amp;lt;25=&amp;gt; 25 (P0.25) 
// &amp;lt;26=&amp;gt; 26 (P0.26) 
// &amp;lt;27=&amp;gt; 27 (P0.27) 
// &amp;lt;28=&amp;gt; 28 (P0.28) 
// &amp;lt;29=&amp;gt; 29 (P0.29) 
// &amp;lt;30=&amp;gt; 30 (P0.30) 
// &amp;lt;31=&amp;gt; 31 (P0.31) 
#ifndef NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN
#define NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN 16
// &amp;lt;/e&amp;gt;
// &amp;lt;q&amp;gt; NRF_BL_DFU_ENTER_METHOD_PINRESET  - Enter DFU mode on pin reset.
#ifndef NRF_BL_DFU_ENTER_METHOD_PINRESET
#define NRF_BL_DFU_ENTER_METHOD_PINRESET 0
// &amp;lt;q&amp;gt; NRF_BL_DFU_ENTER_METHOD_GPREGRET  - Enter DFU mode when bit 0 is set in the NRF_POWER_GPREGRET register.
#ifndef NRF_BL_DFU_ENTER_METHOD_GPREGRET
#define NRF_BL_DFU_ENTER_METHOD_GPREGRET 1
// &amp;lt;q&amp;gt; NRF_BL_DFU_ENTER_METHOD_BUTTONLESS  - Enter DFU mode when the Boolean enter_buttonless_dfu in DFU settings is true.
#ifndef NRF_BL_DFU_ENTER_METHOD_BUTTONLESS
#define NRF_BL_DFU_ENTER_METHOD_BUTTONLESS 0
// &amp;lt;h&amp;gt; DFU timers 
// &amp;lt;o&amp;gt; NRF_BL_DFU_CONTINUATION_TIMEOUT_MS - Timeout in ms when expecting an update immediately.  &amp;lt;100-60000000&amp;gt; 
// &amp;lt;i&amp;gt; This timeout is used after updating the SoftDevice, when there is
// &amp;lt;i&amp;gt; already a valid application present. The bootloader will enter DFU mode
// &amp;lt;i&amp;gt; for a short time instead of booting the old application to allow the host
// &amp;lt;i&amp;gt; to immediately transfer a new application if it wishes.
#ifndef NRF_BL_DFU_CONTINUATION_TIMEOUT_MS
#define NRF_BL_DFU_CONTINUATION_TIMEOUT_MS 10000
// &amp;lt;o&amp;gt; NRF_BL_DFU_INACTIVITY_TIMEOUT_MS - Timeout in ms before automatically starting a valid application due to inactivity.  &amp;lt;0-60000000&amp;gt; 
// &amp;lt;i&amp;gt; If 0, no inactivity timer will be used. Values 1-99 are invalid.
#ifndef NRF_BL_DFU_INACTIVITY_TIMEOUT_MS
#define NRF_BL_DFU_INACTIVITY_TIMEOUT_MS 120000
// &amp;lt;h&amp;gt; Watchdog timer 
// &amp;lt;o&amp;gt; NRF_BL_WDT_MAX_SCHEDULER_LATENCY_MS - Maximum latency of the scheduler in miliseconds 
// &amp;lt;i&amp;gt; Maximum latency of the scheduler is compared with
// &amp;lt;i&amp;gt; watchdog counter reload value (CRV). If latency is big
// &amp;lt;i&amp;gt; enough, the watchdog will be fed from internal timer
// &amp;lt;i&amp;gt; handler along with feed from user function. If latency
// &amp;lt;i&amp;gt; is smaller than CRV, the watchdog will not be internally fed once
// &amp;lt;i&amp;gt; it will be externally fed. Maximum latency is mainly affected
// &amp;lt;i&amp;gt; by flash operations.
#ifndef NRF_BL_WDT_MAX_SCHEDULER_LATENCY_MS
#define NRF_BL_WDT_MAX_SCHEDULER_LATENCY_MS 10000
// &amp;lt;h&amp;gt; Misc Bootloader settings 
// &amp;lt;q&amp;gt; NRF_BL_DEBUG_PORT_DISABLE  - Disable access to the chip via the debug port.
// &amp;lt;i&amp;gt; Disable access to the chip via the debug port.
// &amp;lt;i&amp;gt; This modifies the APPROTECT and DEBUGCTRL registers.
// &amp;lt;i&amp;gt; Enable this option in production code if such
// &amp;lt;i&amp;gt; access should be prohibited. Read about the registers
// &amp;lt;i&amp;gt; for more details.
#ifndef NRF_BL_DEBUG_PORT_DISABLE
#define NRF_BL_DEBUG_PORT_DISABLE 0
// &amp;lt;o&amp;gt; NRF_BL_FW_COPY_PROGRESS_STORE_STEP - Number of pages copied after which progress in the settings page is updated. 
// &amp;lt;i&amp;gt; Progress stored in the settings page allows the bootloader to resume
// &amp;lt;i&amp;gt; copying the new firmware in case of interruption (reset).
// &amp;lt;i&amp;gt; If the value is small, then the resume point is more accurate. However,
// &amp;lt;i&amp;gt;  it also impacts negatively on flash wear.
#ifndef NRF_BL_FW_COPY_PROGRESS_STORE_STEP
#define NRF_BL_FW_COPY_PROGRESS_STORE_STEP 8
// &amp;lt;o&amp;gt; NRF_BL_RESET_DELAY_MS - Time to wait before resetting the bootloader. 
// &amp;lt;i&amp;gt; Time (in ms) to wait before resetting the bootloader after DFU has been completed or aborted. This allows more time for e.g. disconnecting the BLE link or writing logs.
#ifndef NRF_BL_RESET_DELAY_MS
#define NRF_BL_RESET_DELAY_MS 0
// &amp;lt;h&amp;gt; nRF_Crypto 
// &amp;lt;e&amp;gt; NRF_CRYPTO_ENABLED - nrf_crypto - Cryptography library.
#ifndef NRF_CRYPTO_ENABLED
#define NRF_CRYPTO_ENABLED 1
// &amp;lt;o&amp;gt; NRF_CRYPTO_ALLOCATOR  - Memory allocator
// &amp;lt;i&amp;gt; Choose memory allocator used by nrf_crypto. Default is alloca if possible or nrf_malloc otherwise. If &amp;#39;User macros&amp;#39; are selected, the user has to create &amp;#39;nrf_crypto_allocator.h&amp;#39; file that contains NRF_CRYPTO_ALLOC, NRF_CRYPTO_FREE, and NRF_CRYPTO_ALLOC_ON_STACK.
// &amp;lt;0=&amp;gt; Default 
// &amp;lt;1=&amp;gt; User macros 
// &amp;lt;2=&amp;gt; On stack (alloca) 
// &amp;lt;3=&amp;gt; C dynamic memory (malloc) 
// &amp;lt;4=&amp;gt; SDK Memory Manager (nrf_malloc) 
#ifndef NRF_CRYPTO_ALLOCATOR
#define NRF_CRYPTO_ALLOCATOR 1
// &amp;lt;e&amp;gt; NRF_CRYPTO_BACKEND_CC310_BL_ENABLED - Enable the ARM Cryptocell CC310 reduced backend.
// &amp;lt;i&amp;gt; The CC310 hardware-accelerated cryptography backend with reduced functionality and footprint (only available on nRF52840).
#ifndef NRF_CRYPTO_BACKEND_CC310_BL_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_BL_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_BL_ECC_SECP224R1_ENABLED  - Enable the secp224r1 elliptic curve support using CC310_BL.
#ifndef NRF_CRYPTO_BACKEND_CC310_BL_ECC_SECP224R1_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_BL_ECC_SECP224R1_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_BL_ECC_SECP256R1_ENABLED  - Enable the secp256r1 elliptic curve support using CC310_BL.
#ifndef NRF_CRYPTO_BACKEND_CC310_BL_ECC_SECP256R1_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_BL_ECC_SECP256R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_BL_HASH_SHA256_ENABLED  - CC310_BL SHA-256 hash functionality.
// &amp;lt;i&amp;gt; CC310_BL backend implementation for hardware-accelerated SHA-256.
#ifndef NRF_CRYPTO_BACKEND_CC310_BL_HASH_SHA256_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_BL_HASH_SHA256_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_BL_HASH_AUTOMATIC_RAM_BUFFER_ENABLED  - nrf_cc310_bl buffers to RAM before running hash operation
// &amp;lt;i&amp;gt; Enabling this makes hashing of addresses in FLASH range possible. Size of buffer allocated for hashing is set by NRF_CRYPTO_BACKEND_CC310_BL_HASH_AUTOMATIC_RAM_BUFFER_SIZE
#ifndef NRF_CRYPTO_BACKEND_CC310_BL_HASH_AUTOMATIC_RAM_BUFFER_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_BL_HASH_AUTOMATIC_RAM_BUFFER_ENABLED 0
// &amp;lt;o&amp;gt; NRF_CRYPTO_BACKEND_CC310_BL_HASH_AUTOMATIC_RAM_BUFFER_SIZE - nrf_cc310_bl hash outputs digests in little endian 
// &amp;lt;i&amp;gt; Makes the nrf_cc310_bl hash functions output digests in little endian format. Only for use in nRF SDK DFU!
#ifndef NRF_CRYPTO_BACKEND_CC310_BL_HASH_AUTOMATIC_RAM_BUFFER_SIZE
#define NRF_CRYPTO_BACKEND_CC310_BL_HASH_AUTOMATIC_RAM_BUFFER_SIZE 4096
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_BL_INTERRUPTS_ENABLED  - Enable Interrupts while support using CC310 bl.
// &amp;lt;i&amp;gt; Select a library version compatible with the configuration. When interrupts are disable, a version named _noint must be used
#ifndef NRF_CRYPTO_BACKEND_CC310_BL_INTERRUPTS_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_BL_INTERRUPTS_ENABLED 1
// &amp;lt;e&amp;gt; NRF_CRYPTO_BACKEND_CC310_ENABLED - Enable the ARM Cryptocell CC310 backend.
// &amp;lt;i&amp;gt; The CC310 hardware-accelerated cryptography backend (only available on nRF52840).
#ifndef NRF_CRYPTO_BACKEND_CC310_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_AES_CBC_ENABLED  - Enable the AES CBC mode using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_AES_CBC_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_AES_CBC_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_AES_CTR_ENABLED  - Enable the AES CTR mode using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_AES_CTR_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_AES_CTR_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_AES_ECB_ENABLED  - Enable the AES ECB mode using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_AES_ECB_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_AES_ECB_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_AES_CBC_MAC_ENABLED  - Enable the AES CBC_MAC mode using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_AES_CBC_MAC_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_AES_CBC_MAC_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_AES_CMAC_ENABLED  - Enable the AES CMAC mode using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_AES_CMAC_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_AES_CMAC_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_AES_CCM_ENABLED  - Enable the AES CCM mode using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_AES_CCM_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_AES_CCM_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_AES_CCM_STAR_ENABLED  - Enable the AES CCM* mode using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_AES_CCM_STAR_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_AES_CCM_STAR_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_CHACHA_POLY_ENABLED  - Enable the CHACHA-POLY mode using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_CHACHA_POLY_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_CHACHA_POLY_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_SECP160R1_ENABLED  - Enable the secp160r1 elliptic curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_SECP160R1_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_SECP160R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_SECP160R2_ENABLED  - Enable the secp160r2 elliptic curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_SECP160R2_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_SECP160R2_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_SECP192R1_ENABLED  - Enable the secp192r1 elliptic curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_SECP192R1_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_SECP192R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_SECP224R1_ENABLED  - Enable the secp224r1 elliptic curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_SECP224R1_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_SECP224R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_SECP256R1_ENABLED  - Enable the secp256r1 elliptic curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_SECP256R1_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_SECP256R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_SECP384R1_ENABLED  - Enable the secp384r1 elliptic curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_SECP384R1_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_SECP384R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_SECP521R1_ENABLED  - Enable the secp521r1 elliptic curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_SECP521R1_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_SECP521R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_SECP160K1_ENABLED  - Enable the secp160k1 elliptic curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_SECP160K1_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_SECP160K1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_SECP192K1_ENABLED  - Enable the secp192k1 elliptic curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_SECP192K1_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_SECP192K1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_SECP224K1_ENABLED  - Enable the secp224k1 elliptic curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_SECP224K1_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_SECP224K1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_SECP256K1_ENABLED  - Enable the secp256k1 elliptic curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_SECP256K1_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_SECP256K1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_CURVE25519_ENABLED  - Enable the Curve25519 curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_CURVE25519_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_CURVE25519_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_ECC_ED25519_ENABLED  - Enable the Ed25519 curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_ED25519_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_ED25519_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_HASH_SHA256_ENABLED  - CC310 SHA-256 hash functionality.
// &amp;lt;i&amp;gt; CC310 backend implementation for hardware-accelerated SHA-256.
#ifndef NRF_CRYPTO_BACKEND_CC310_HASH_SHA256_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_HASH_SHA256_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_HASH_SHA512_ENABLED  - CC310 SHA-512 hash functionality
// &amp;lt;i&amp;gt; CC310 backend implementation for SHA-512 (in software).
#ifndef NRF_CRYPTO_BACKEND_CC310_HASH_SHA512_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_HASH_SHA512_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_HMAC_SHA256_ENABLED  - CC310 HMAC using SHA-256
// &amp;lt;i&amp;gt; CC310 backend implementation for HMAC using hardware-accelerated SHA-256.
#ifndef NRF_CRYPTO_BACKEND_CC310_HMAC_SHA256_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_HMAC_SHA256_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_HMAC_SHA512_ENABLED  - CC310 HMAC using SHA-512
// &amp;lt;i&amp;gt; CC310 backend implementation for HMAC using SHA-512 (in software).
#ifndef NRF_CRYPTO_BACKEND_CC310_HMAC_SHA512_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_HMAC_SHA512_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_RNG_ENABLED  - Enable RNG support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_RNG_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_RNG_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CC310_INTERRUPTS_ENABLED  - Enable Interrupts while support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_INTERRUPTS_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_INTERRUPTS_ENABLED 1
// &amp;lt;e&amp;gt; NRF_CRYPTO_BACKEND_CIFRA_ENABLED - Enable the Cifra backend.
#ifndef NRF_CRYPTO_BACKEND_CIFRA_ENABLED
#define NRF_CRYPTO_BACKEND_CIFRA_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_CIFRA_AES_EAX_ENABLED  - Enable the AES EAX mode using Cifra.
#ifndef NRF_CRYPTO_BACKEND_CIFRA_AES_EAX_ENABLED
#define NRF_CRYPTO_BACKEND_CIFRA_AES_EAX_ENABLED 1
// &amp;lt;e&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ENABLED - Enable the mbed TLS backend.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_AES_CBC_ENABLED  - Enable the AES CBC mode mbed TLS.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_AES_CBC_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_AES_CBC_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_AES_CTR_ENABLED  - Enable the AES CTR mode using mbed TLS.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_AES_CTR_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_AES_CTR_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_AES_CFB_ENABLED  - Enable the AES CFB mode using mbed TLS.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_AES_CFB_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_AES_CFB_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_AES_ECB_ENABLED  - Enable the AES ECB mode using mbed TLS.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_AES_ECB_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_AES_ECB_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_AES_CBC_MAC_ENABLED  - Enable the AES CBC MAC mode using mbed TLS.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_AES_CBC_MAC_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_AES_CBC_MAC_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_AES_CMAC_ENABLED  - Enable the AES CMAC mode using mbed TLS.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_AES_CMAC_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_AES_CMAC_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_AES_CCM_ENABLED  - Enable the AES CCM mode using mbed TLS.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_AES_CCM_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_AES_CCM_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_AES_GCM_ENABLED  - Enable the AES GCM mode using mbed TLS.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_AES_GCM_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_AES_GCM_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP192R1_ENABLED  - Enable secp192r1 (NIST 192-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp192r1 (NIST 192-bit) support using MBEDTLS
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP192R1_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP192R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP224R1_ENABLED  - Enable secp224r1 (NIST 224-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp224r1 (NIST 224-bit) support using MBEDTLS
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP224R1_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP224R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP256R1_ENABLED  - Enable secp256r1 (NIST 256-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp256r1 (NIST 256-bit) support using MBEDTLS
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP256R1_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP256R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP384R1_ENABLED  - Enable secp384r1 (NIST 384-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp384r1 (NIST 384-bit) support using MBEDTLS
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP384R1_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP384R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP521R1_ENABLED  - Enable secp521r1 (NIST 521-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp521r1 (NIST 521-bit) support using MBEDTLS
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP521R1_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP521R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP192K1_ENABLED  - Enable secp192k1 (Koblitz 192-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp192k1 (Koblitz 192-bit) support using MBEDTLS
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP192K1_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP192K1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP224K1_ENABLED  - Enable secp224k1 (Koblitz 224-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp224k1 (Koblitz 224-bit) support using MBEDTLS
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP224K1_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP224K1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP256K1_ENABLED  - Enable secp256k1 (Koblitz 256-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp256k1 (Koblitz 256-bit) support using MBEDTLS
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP256K1_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_SECP256K1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP256R1_ENABLED  - Enable bp256r1 (Brainpool 256-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need bp256r1 (Brainpool 256-bit) support using MBEDTLS
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP256R1_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP256R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP384R1_ENABLED  - Enable bp384r1 (Brainpool 384-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need bp384r1 (Brainpool 384-bit) support using MBEDTLS
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP384R1_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP384R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP512R1_ENABLED  - Enable bp512r1 (Brainpool 512-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need bp512r1 (Brainpool 512-bit) support using MBEDTLS
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP512R1_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_BP512R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_ECC_CURVE25519_ENABLED  - Enable Curve25519 curve
// &amp;lt;i&amp;gt; Enable this setting if you need Curve25519 support using MBEDTLS
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_ECC_CURVE25519_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_ECC_CURVE25519_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_HASH_SHA256_ENABLED  - Enable mbed TLS SHA-256 hash functionality.
// &amp;lt;i&amp;gt; mbed TLS backend implementation for SHA-256.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_HASH_SHA256_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_HASH_SHA256_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_HASH_SHA512_ENABLED  - Enable mbed TLS SHA-512 hash functionality.
// &amp;lt;i&amp;gt; mbed TLS backend implementation for SHA-512.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_HASH_SHA512_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_HASH_SHA512_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_HMAC_SHA256_ENABLED  - Enable mbed TLS HMAC using SHA-256.
// &amp;lt;i&amp;gt; mbed TLS backend implementation for HMAC using SHA-256.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_HMAC_SHA256_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_HMAC_SHA256_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MBEDTLS_HMAC_SHA512_ENABLED  - Enable mbed TLS HMAC using SHA-512.
// &amp;lt;i&amp;gt; mbed TLS backend implementation for HMAC using SHA-512.
#ifndef NRF_CRYPTO_BACKEND_MBEDTLS_HMAC_SHA512_ENABLED
#define NRF_CRYPTO_BACKEND_MBEDTLS_HMAC_SHA512_ENABLED 1
// &amp;lt;e&amp;gt; NRF_CRYPTO_BACKEND_MICRO_ECC_ENABLED - Enable the micro-ecc backend.
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP192R1_ENABLED  - Enable secp192r1 (NIST 192-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp192r1 (NIST 192-bit) support using micro-ecc
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP192R1_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP192R1_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP224R1_ENABLED  - Enable secp224r1 (NIST 224-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp224r1 (NIST 224-bit) support using micro-ecc
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP224R1_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP224R1_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP256R1_ENABLED  - Enable secp256r1 (NIST 256-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp256r1 (NIST 256-bit) support using micro-ecc
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP256R1_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP256R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP256K1_ENABLED  - Enable secp256k1 (Koblitz 256-bit) curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp256k1 (Koblitz 256-bit) support using micro-ecc
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP256K1_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_ECC_SECP256K1_ENABLED 0
// &amp;lt;e&amp;gt; NRF_CRYPTO_BACKEND_NRF_HW_RNG_ENABLED - Enable the nRF HW RNG backend.
// &amp;lt;i&amp;gt; The nRF HW backend provide access to RNG peripheral in nRF5x devices.
#ifndef NRF_CRYPTO_BACKEND_NRF_HW_RNG_ENABLED
#define NRF_CRYPTO_BACKEND_NRF_HW_RNG_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_NRF_HW_RNG_MBEDTLS_CTR_DRBG_ENABLED  - Enable mbed TLS CTR-DRBG algorithm.
// &amp;lt;i&amp;gt; Enable mbed TLS CTR-DRBG standardized by NIST (NIST SP 800-90A Rev. 1). The nRF HW RNG is used as an entropy source for seeding.
#ifndef NRF_CRYPTO_BACKEND_NRF_HW_RNG_MBEDTLS_CTR_DRBG_ENABLED
#define NRF_CRYPTO_BACKEND_NRF_HW_RNG_MBEDTLS_CTR_DRBG_ENABLED 1
// &amp;lt;e&amp;gt; NRF_CRYPTO_BACKEND_NRF_SW_ENABLED - Enable the legacy nRFx sw for crypto.
// &amp;lt;i&amp;gt; The nRF SW cryptography backend (only used in bootloader context).
#ifndef NRF_CRYPTO_BACKEND_NRF_SW_ENABLED
#define NRF_CRYPTO_BACKEND_NRF_SW_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_NRF_SW_HASH_SHA256_ENABLED  - nRF SW hash backend support for SHA-256
// &amp;lt;i&amp;gt; The nRF SW backend provide access to nRF SDK legacy hash implementation of SHA-256.
#ifndef NRF_CRYPTO_BACKEND_NRF_SW_HASH_SHA256_ENABLED
#define NRF_CRYPTO_BACKEND_NRF_SW_HASH_SHA256_ENABLED 1
// &amp;lt;e&amp;gt; NRF_CRYPTO_BACKEND_OBERON_ENABLED - Enable the Oberon backend
// &amp;lt;i&amp;gt; The Oberon backend
#ifndef NRF_CRYPTO_BACKEND_OBERON_ENABLED
#define NRF_CRYPTO_BACKEND_OBERON_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_OBERON_CHACHA_POLY_ENABLED  - Enable the CHACHA-POLY mode using Oberon.
#ifndef NRF_CRYPTO_BACKEND_OBERON_CHACHA_POLY_ENABLED
#define NRF_CRYPTO_BACKEND_OBERON_CHACHA_POLY_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_OBERON_ECC_SECP256R1_ENABLED  - Enable secp256r1 curve
// &amp;lt;i&amp;gt; Enable this setting if you need secp256r1 curve support using Oberon library
#ifndef NRF_CRYPTO_BACKEND_OBERON_ECC_SECP256R1_ENABLED
#define NRF_CRYPTO_BACKEND_OBERON_ECC_SECP256R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_OBERON_ECC_CURVE25519_ENABLED  - Enable Curve25519 ECDH
// &amp;lt;i&amp;gt; Enable this setting if you need Curve25519 ECDH support using Oberon library
#ifndef NRF_CRYPTO_BACKEND_OBERON_ECC_CURVE25519_ENABLED
#define NRF_CRYPTO_BACKEND_OBERON_ECC_CURVE25519_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_OBERON_ECC_ED25519_ENABLED  - Enable Ed25519 signature scheme
// &amp;lt;i&amp;gt; Enable this setting if you need Ed25519 support using Oberon library
#ifndef NRF_CRYPTO_BACKEND_OBERON_ECC_ED25519_ENABLED
#define NRF_CRYPTO_BACKEND_OBERON_ECC_ED25519_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_OBERON_HASH_SHA256_ENABLED  - Oberon SHA-256 hash functionality
// &amp;lt;i&amp;gt; Oberon backend implementation for SHA-256.
#ifndef NRF_CRYPTO_BACKEND_OBERON_HASH_SHA256_ENABLED
#define NRF_CRYPTO_BACKEND_OBERON_HASH_SHA256_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_OBERON_HASH_SHA512_ENABLED  - Oberon SHA-512 hash functionality
// &amp;lt;i&amp;gt; Oberon backend implementation for SHA-512.
#ifndef NRF_CRYPTO_BACKEND_OBERON_HASH_SHA512_ENABLED
#define NRF_CRYPTO_BACKEND_OBERON_HASH_SHA512_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_OBERON_HMAC_SHA256_ENABLED  - Oberon HMAC using SHA-256
// &amp;lt;i&amp;gt; Oberon backend implementation for HMAC using SHA-256.
#ifndef NRF_CRYPTO_BACKEND_OBERON_HMAC_SHA256_ENABLED
#define NRF_CRYPTO_BACKEND_OBERON_HMAC_SHA256_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_OBERON_HMAC_SHA512_ENABLED  - Oberon HMAC using SHA-512
// &amp;lt;i&amp;gt; Oberon backend implementation for HMAC using SHA-512.
#ifndef NRF_CRYPTO_BACKEND_OBERON_HMAC_SHA512_ENABLED
#define NRF_CRYPTO_BACKEND_OBERON_HMAC_SHA512_ENABLED 0
// &amp;lt;e&amp;gt; NRF_CRYPTO_BACKEND_OPTIGA_ENABLED - Enable the nrf_crypto Optiga Trust X backend.
// &amp;lt;i&amp;gt; Enables the nrf_crypto backend for Optiga Trust X devices.
#ifndef NRF_CRYPTO_BACKEND_OPTIGA_ENABLED
#define NRF_CRYPTO_BACKEND_OPTIGA_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_OPTIGA_RNG_ENABLED  - Optiga backend support for RNG
// &amp;lt;i&amp;gt; The Optiga backend provide external chip RNG.
#ifndef NRF_CRYPTO_BACKEND_OPTIGA_RNG_ENABLED
#define NRF_CRYPTO_BACKEND_OPTIGA_RNG_ENABLED 0
// &amp;lt;q&amp;gt; NRF_CRYPTO_BACKEND_OPTIGA_ECC_SECP256R1_ENABLED  - Optiga backend support for ECC secp256r1
// &amp;lt;i&amp;gt; The Optiga backend provide external chip ECC using secp256r1.
#ifndef NRF_CRYPTO_BACKEND_OPTIGA_ECC_SECP256R1_ENABLED
#define NRF_CRYPTO_BACKEND_OPTIGA_ECC_SECP256R1_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_CURVE25519_BIG_ENDIAN_ENABLED  - Big-endian byte order in raw Curve25519 data
// &amp;lt;i&amp;gt; Enable big-endian byte order in Curve25519 API, if set to 1. Use little-endian, if set to 0.
#ifndef NRF_CRYPTO_CURVE25519_BIG_ENDIAN_ENABLED
#define NRF_CRYPTO_CURVE25519_BIG_ENDIAN_ENABLED 0
// &amp;lt;h&amp;gt; nrf_crypto_rng - RNG Configuration
// &amp;lt;q&amp;gt; NRF_CRYPTO_RNG_STATIC_MEMORY_BUFFERS_ENABLED  - Use static memory buffers for context and temporary init buffer.
// &amp;lt;i&amp;gt; Always recommended when using the nRF HW RNG as the context and temporary buffers are small. Consider disabling if using the CC310 RNG in a RAM constrained application. In this case, memory must be provided to nrf_crypto_rng_init, or it can be allocated internally provided that NRF_CRYPTO_ALLOCATOR does not allocate memory on the stack.
#ifndef NRF_CRYPTO_RNG_STATIC_MEMORY_BUFFERS_ENABLED
#define NRF_CRYPTO_RNG_STATIC_MEMORY_BUFFERS_ENABLED 1
// &amp;lt;q&amp;gt; NRF_CRYPTO_RNG_AUTO_INIT_ENABLED  - Initialize the RNG module automatically when nrf_crypto is initialized.
// &amp;lt;i&amp;gt; Automatic initialization is only supported with static or internally allocated context and temporary memory.
#ifndef NRF_CRYPTO_RNG_AUTO_INIT_ENABLED
#define NRF_CRYPTO_RNG_AUTO_INIT_ENABLED 1
// &amp;lt;h&amp;gt; nRF_DFU 
// &amp;lt;h&amp;gt; DFU security - nrf_dfu_validation - DFU validation
// &amp;lt;q&amp;gt; NRF_DFU_APP_ACCEPT_SAME_VERSION  - Whether to accept application upgrades with the same version as the current application.
// &amp;lt;i&amp;gt; This applies to application updates, and possibly to SoftDevice updates.
// &amp;lt;i&amp;gt; Bootloader upgrades always require higher versions. SoftDevice upgrades
// &amp;lt;i&amp;gt; look at the sd_req field independently of this config.
// &amp;lt;i&amp;gt; Disabling this protects against replay attacks wearing out the flash of the device.
// &amp;lt;i&amp;gt; This config only has an effect when NRF_DFU_APP_DOWNGRADE_PREVENTION is enabled.
#ifndef NRF_DFU_APP_ACCEPT_SAME_VERSION
#define NRF_DFU_APP_ACCEPT_SAME_VERSION 1
// &amp;lt;q&amp;gt; NRF_DFU_APP_DOWNGRADE_PREVENTION  - Check the firmware version and SoftDevice requirements of application (and SoftDevice) updates.
// &amp;lt;i&amp;gt; Whether to check the incoming version against the version of the existing app and/or
// &amp;lt;i&amp;gt; the incoming SoftDevice requirements against the existing SoftDevice.
// &amp;lt;i&amp;gt; Disabling this causes the checks to always ignore the incoming firmware version and
// &amp;lt;i&amp;gt; to ignore the SoftDevice requirements if the first requirement is 0.
// &amp;lt;i&amp;gt; This does not apply the bootloader updates. If the bootloader depends on the SoftDevice
// &amp;lt;i&amp;gt; e.g. for BLE transport, this does not apply to SoftDevice updates.
// &amp;lt;i&amp;gt; See @ref lib_bootloader_dfu_validation for more information.
// &amp;lt;i&amp;gt; When signed updates are required, version checking should always be enabled.
#ifndef NRF_DFU_APP_DOWNGRADE_PREVENTION
#define NRF_DFU_APP_DOWNGRADE_PREVENTION 1
// &amp;lt;q&amp;gt; NRF_DFU_EXTERNAL_APP_VERSIONING  - Require versioning for external applications.
// &amp;lt;i&amp;gt; This configuration is only used if NRF_DFU_SUPPORTS_EXTERNAL_APP is set to 1.
// &amp;lt;i&amp;gt; Setting this will require that any FW images using the FW upgrade type 
// &amp;lt;i&amp;gt; DFU_FW_TYPE_EXTERNAL_APPLICATION must follow a monotonic versioning scheme
// &amp;lt;i&amp;gt; where the FW version of an upgrade must always be larger than the previously stored 
// &amp;lt;i&amp;gt; FW version.
#ifndef NRF_DFU_EXTERNAL_APP_VERSIONING
#define NRF_DFU_EXTERNAL_APP_VERSIONING 1
// &amp;lt;q&amp;gt; NRF_DFU_FORCE_DUAL_BANK_APP_UPDATES  - Accept only dual-bank application updates.
// &amp;lt;i&amp;gt; If not enabled then if there is not enough space to perform dual-bank update
// &amp;lt;i&amp;gt; application is deleted and single-bank update is performed. In case it is considered
// &amp;lt;i&amp;gt; security concern user can prefer to discard update request rather than overwrite
// &amp;lt;i&amp;gt; current application.
#ifndef NRF_DFU_FORCE_DUAL_BANK_APP_UPDATES
#define NRF_DFU_FORCE_DUAL_BANK_APP_UPDATES 0
// &amp;lt;o&amp;gt; NRF_DFU_HW_VERSION - Device hardware version. 
// &amp;lt;i&amp;gt; This is used to determine if given update is targeting the device.
// &amp;lt;i&amp;gt; It is checked against the hw_version value in the init packet
#ifndef NRF_DFU_HW_VERSION
#define NRF_DFU_HW_VERSION 52
// &amp;lt;q&amp;gt; NRF_DFU_REQUIRE_SIGNED_APP_UPDATE  - Require a valid signature to update the application or SoftDevice.
#ifndef NRF_DFU_REQUIRE_SIGNED_APP_UPDATE
#define NRF_DFU_REQUIRE_SIGNED_APP_UPDATE 1
// &amp;lt;q&amp;gt; NRF_DFU_SINGLE_BANK_APP_UPDATES  - Place the application and the SoftDevice directly where they are supposed to be.
// &amp;lt;i&amp;gt; Note that this creates security concerns when signing and  version checks
// &amp;lt;i&amp;gt; are enabled. An attacker will be able to delete (but not replace)
// &amp;lt;i&amp;gt; the current app or SoftDevice without knowing the signature key.
#ifndef NRF_DFU_SINGLE_BANK_APP_UPDATES
#define NRF_DFU_SINGLE_BANK_APP_UPDATES 0
// &amp;lt;q&amp;gt; NRF_DFU_SETTINGS_COMPATIBILITY_MODE  - nrf_dfu_settings - DFU Settings
#ifndef NRF_DFU_SETTINGS_COMPATIBILITY_MODE
#define NRF_DFU_SETTINGS_COMPATIBILITY_MODE 1
// &amp;lt;h&amp;gt; nrf_dfu - Device Firmware Upgrade
// &amp;lt;h&amp;gt; DFU transport 
// &amp;lt;e&amp;gt; NRF_DFU_TRANSPORT_ANT - ANT transport settings
#ifndef NRF_DFU_TRANSPORT_ANT
#define NRF_DFU_TRANSPORT_ANT 0
// &amp;lt;o&amp;gt; NRF_DFU_ANT_MTU - MTU size used for firmware bursts. 
// &amp;lt;i&amp;gt; Sets the maximum burst size used for DFU write commands.
#ifndef NRF_DFU_ANT_MTU
#define NRF_DFU_ANT_MTU 1024
// &amp;lt;h&amp;gt; ANT DFU buffers 
// &amp;lt;e&amp;gt; NRF_DFU_ANT_BUFFERS_OVERRIDE 
// &amp;lt;i&amp;gt; Check this option to override the default number of buffers.
#ifndef NRF_DFU_ANT_BUFFERS_OVERRIDE
#define NRF_DFU_ANT_BUFFERS_OVERRIDE 0
// &amp;lt;o&amp;gt; NRF_DFU_ANT_BUFFERS - Number of buffers in the ANT transport. 
// &amp;lt;i&amp;gt; Number of buffers to store incoming data while it is being written to flash.
// &amp;lt;i&amp;gt; Reduce this value to save RAM. If this value is too low, the DFU process will fail.
#define NRF_DFU_ANT_BUFFERS 8
// &amp;lt;h&amp;gt; ANT DFU Channel Configuration 
// &amp;lt;o&amp;gt; NRF_DFU_ANT_RF_FREQ - DFU RF channel. 
#ifndef NRF_DFU_ANT_RF_FREQ
#define NRF_DFU_ANT_RF_FREQ 66
// &amp;lt;o&amp;gt; NRF_DFU_ANT_DEV_TYPE - Device type field to use for DFU channel id. 
#ifndef NRF_DFU_ANT_DEV_TYPE
#define NRF_DFU_ANT_DEV_TYPE 10
// &amp;lt;o&amp;gt; NRF_DFU_ANT_CHANNEL_PERIOD - Channel period of DFU ANT channel. 
#ifndef NRF_DFU_ANT_CHANNEL_PERIOD
#define NRF_DFU_ANT_CHANNEL_PERIOD 2048
// &amp;lt;e&amp;gt; NRF_DFU_TRANSPORT_BLE - BLE transport settings
#ifndef NRF_DFU_TRANSPORT_BLE
#define NRF_DFU_TRANSPORT_BLE 1
// &amp;lt;q&amp;gt; NRF_DFU_BLE_SKIP_SD_INIT  - Skip the SoftDevice and interrupt vector table initialization.
#ifndef NRF_DFU_BLE_SKIP_SD_INIT
#define NRF_DFU_BLE_SKIP_SD_INIT 0
// &amp;lt;s&amp;gt; NRF_DFU_BLE_ADV_NAME - Default advertising name.
#ifndef NRF_DFU_BLE_ADV_NAME
#define NRF_DFU_BLE_ADV_NAME &amp;quot;DfuTarg&amp;quot;
// &amp;lt;o&amp;gt; NRF_DFU_BLE_ADV_INTERVAL - Advertising interval (in units of 0.625 ms) 
#ifndef NRF_DFU_BLE_ADV_INTERVAL
#define NRF_DFU_BLE_ADV_INTERVAL 40
// &amp;lt;h&amp;gt; BLE DFU security 
// &amp;lt;q&amp;gt; NRF_DFU_BLE_REQUIRES_BONDS  - Require bond with peer.
#ifndef NRF_DFU_BLE_REQUIRES_BONDS
#define NRF_DFU_BLE_REQUIRES_BONDS 0
// &amp;lt;h&amp;gt; BLE DFU connection 
// &amp;lt;o&amp;gt; NRF_DFU_BLE_MIN_CONN_INTERVAL - Minimum connection interval (units). 
// &amp;lt;i&amp;gt; Minimum GAP connection interval, in 1.25 ms units.
#ifndef NRF_DFU_BLE_MIN_CONN_INTERVAL
#define NRF_DFU_BLE_MIN_CONN_INTERVAL 12
// &amp;lt;o&amp;gt; NRF_DFU_BLE_MAX_CONN_INTERVAL - Maximum connection interval (units). 
// &amp;lt;i&amp;gt; Maximum GAP connection interval, in 1.25 ms units.
#ifndef NRF_DFU_BLE_MAX_CONN_INTERVAL
#define NRF_DFU_BLE_MAX_CONN_INTERVAL 12
// &amp;lt;o&amp;gt; NRF_DFU_BLE_CONN_SUP_TIMEOUT_MS - Supervision timeout (ms). 
// &amp;lt;i&amp;gt; GAP connection supervision timeout, in milliseconds.
#ifndef NRF_DFU_BLE_CONN_SUP_TIMEOUT_MS
#define NRF_DFU_BLE_CONN_SUP_TIMEOUT_MS 6000
// &amp;lt;h&amp;gt; BLE DFU buffers 
// &amp;lt;e&amp;gt; NRF_DFU_BLE_BUFFERS_OVERRIDE 
#ifndef NRF_DFU_BLE_BUFFERS_OVERRIDE
#define NRF_DFU_BLE_BUFFERS_OVERRIDE 0
// &amp;lt;o&amp;gt; NRF_DFU_BLE_BUFFERS - Number of buffers in the BLE transport. 
#define NRF_DFU_BLE_BUFFERS 8
// &amp;lt;h&amp;gt; DFU protocol 
// &amp;lt;q&amp;gt; NRF_DFU_PROTOCOL_FW_VERSION_MSG  - Firmware version message support.
// &amp;lt;i&amp;gt; Firmware version message support.
// &amp;lt;i&amp;gt; If disabled, firmware version requests will return NRF_DFU_RES_CODE_OP_CODE_NOT_SUPPORTED.
#ifndef NRF_DFU_PROTOCOL_FW_VERSION_MSG
#define NRF_DFU_PROTOCOL_FW_VERSION_MSG 1
// &amp;lt;q&amp;gt; NRF_DFU_PROTOCOL_REDUCED  - Reduced protocol opcode selection.
// &amp;lt;i&amp;gt; Only support a minimal set of opcodes; return NRF_DFU_RES_CODE_OP_CODE_NOT_SUPPORTED 
// &amp;lt;i&amp;gt; for unsupported opcodes. The supported opcodes are:NRF_DFU_OP_OBJECT_CREATE, 
// &amp;lt;i&amp;gt; NRF_DFU_OP_OBJECT_EXECUTE, NRF_DFU_OP_OBJECT_SELECT, NRF_DFU_OP_OBJECT_WRITE, 
// &amp;lt;i&amp;gt; NRF_DFU_OP_CRC_GET, NRF_DFU_OP_RECEIPT_NOTIF_SET, and NRF_DFU_OP_ABORT. 
// &amp;lt;i&amp;gt; This reduced feature set is used by the BLE transport to reduce flash usage.
#ifndef NRF_DFU_PROTOCOL_REDUCED
#define NRF_DFU_PROTOCOL_REDUCED 1
// &amp;lt;q&amp;gt; NRF_DFU_PROTOCOL_VERSION_MSG  - Protocol version message support.
// &amp;lt;i&amp;gt; Protocol version message support.
// &amp;lt;i&amp;gt; If disabled, protocol version requests will return NRF_DFU_RES_CODE_OP_CODE_NOT_SUPPORTED.
#ifndef NRF_DFU_PROTOCOL_VERSION_MSG
#define NRF_DFU_PROTOCOL_VERSION_MSG 1
// &amp;lt;h&amp;gt; Misc DFU settings 
// &amp;lt;o&amp;gt; NRF_DFU_APP_DATA_AREA_SIZE - The size (in bytes) of the flash area reserved for application data. 
// &amp;lt;i&amp;gt; This area is found at the end of the application area, next to the start of
// &amp;lt;i&amp;gt; the bootloader. This area will not be erased by the bootloader during a
// &amp;lt;i&amp;gt; firmware upgrade. The size must be a multiple of the flash page size.
#ifndef NRF_DFU_APP_DATA_AREA_SIZE
#define NRF_DFU_APP_DATA_AREA_SIZE 12288
// &amp;lt;q&amp;gt; NRF_DFU_IN_APP  - Specifies that this code is in the app, not the bootloader, so some settings are off-limits.
// &amp;lt;i&amp;gt; Enable this to disable writing to areas of the settings that are protected
// &amp;lt;i&amp;gt; by the bootlader. If this is not enabled in the app, certain settings write
// &amp;lt;i&amp;gt; operations will cause HardFaults or will be ignored. Enabling this option
// &amp;lt;i&amp;gt; also causes postvalidation to be disabled since this is meant to be done
// &amp;lt;i&amp;gt; in the bootloader. NRF_BL_DFU_ALLOW_UPDATE_FROM_APP must be enabled in the bootloader.
#ifndef NRF_DFU_IN_APP
#define NRF_DFU_IN_APP 0
// &amp;lt;q&amp;gt; NRF_DFU_SAVE_PROGRESS_IN_FLASH  - Save DFU progress in flash.
// &amp;lt;i&amp;gt; Save DFU progress to flash so that it can be resumed if interrupted, instead of being restarted.
// &amp;lt;i&amp;gt; Keep this setting disabled to maximize transfer speed and minimize flash wear.
// &amp;lt;i&amp;gt; The init packet is always saved in flash, regardless of this setting.
#ifndef NRF_DFU_SAVE_PROGRESS_IN_FLASH
#define NRF_DFU_SAVE_PROGRESS_IN_FLASH 0
// &amp;lt;q&amp;gt; NRF_DFU_SUPPORTS_EXTERNAL_APP  - [Experimental] Support for external app.
// &amp;lt;i&amp;gt; External apps are apps that will not be activated. They can 
// &amp;lt;i&amp;gt; e.g. be apps to be sent to a third party. External app updates 
// &amp;lt;i&amp;gt; are verified upon reception, but will remain in bank 1, and 
// &amp;lt;i&amp;gt; will never be booted. An external app will be overwritten if 
// &amp;lt;i&amp;gt; a new DFU procedure is performed. Note: This functionality is 
// &amp;lt;i&amp;gt; experimental and not yet used in any examples.
#ifndef NRF_DFU_SUPPORTS_EXTERNAL_APP
#define NRF_DFU_SUPPORTS_EXTERNAL_APP 0
// &amp;lt;h&amp;gt; nRF_Libraries 
// &amp;lt;e&amp;gt; APP_SCHEDULER_ENABLED - app_scheduler - Events scheduler
#ifndef APP_SCHEDULER_ENABLED
#define APP_SCHEDULER_ENABLED 1
// &amp;lt;q&amp;gt; APP_SCHEDULER_WITH_PAUSE  - Enabling pause feature
#ifndef APP_SCHEDULER_WITH_PAUSE
#define APP_SCHEDULER_WITH_PAUSE 0
// &amp;lt;q&amp;gt; APP_SCHEDULER_WITH_PROFILER  - Enabling scheduler profiling
#ifndef APP_SCHEDULER_WITH_PROFILER
#define APP_SCHEDULER_WITH_PROFILER 0
// &amp;lt;q&amp;gt; CRC32_ENABLED  - crc32 - CRC32 calculation routines
#ifndef CRC32_ENABLED
#define CRC32_ENABLED 1
// &amp;lt;e&amp;gt; MEM_MANAGER_ENABLED - mem_manager - Dynamic memory allocator
#ifndef MEM_MANAGER_ENABLED
#define MEM_MANAGER_ENABLED 1
// &amp;lt;o&amp;gt; MEMORY_MANAGER_SMALL_BLOCK_COUNT - Size of each memory blocks identified as &amp;#39;small&amp;#39; block.  &amp;lt;0-255&amp;gt; 
#ifndef MEMORY_MANAGER_SMALL_BLOCK_COUNT
#define MEMORY_MANAGER_SMALL_BLOCK_COUNT 1
// &amp;lt;o&amp;gt; MEMORY_MANAGER_SMALL_BLOCK_SIZE -  Size of each memory blocks identified as &amp;#39;small&amp;#39; block. 
// &amp;lt;i&amp;gt;  Size of each memory blocks identified as &amp;#39;small&amp;#39; block. Memory block are recommended to be word-sized.
#ifndef MEMORY_MANAGER_SMALL_BLOCK_SIZE
#define MEMORY_MANAGER_SMALL_BLOCK_SIZE 32
// &amp;lt;o&amp;gt; MEMORY_MANAGER_MEDIUM_BLOCK_COUNT - Size of each memory blocks identified as &amp;#39;medium&amp;#39; block.  &amp;lt;0-255&amp;gt; 
#ifndef MEMORY_MANAGER_MEDIUM_BLOCK_COUNT
#define MEMORY_MANAGER_MEDIUM_BLOCK_COUNT 0
// &amp;lt;o&amp;gt; MEMORY_MANAGER_MEDIUM_BLOCK_SIZE -  Size of each memory blocks identified as &amp;#39;medium&amp;#39; block. 
// &amp;lt;i&amp;gt;  Size of each memory blocks identified as &amp;#39;medium&amp;#39; block. Memory block are recommended to be word-sized.
#ifndef MEMORY_MANAGER_MEDIUM_BLOCK_SIZE
#define MEMORY_MANAGER_MEDIUM_BLOCK_SIZE 256
// &amp;lt;o&amp;gt; MEMORY_MANAGER_LARGE_BLOCK_COUNT - Size of each memory blocks identified as &amp;#39;large&amp;#39; block.  &amp;lt;0-255&amp;gt; 
#ifndef MEMORY_MANAGER_LARGE_BLOCK_COUNT
#define MEMORY_MANAGER_LARGE_BLOCK_COUNT 0
// &amp;lt;o&amp;gt; MEMORY_MANAGER_LARGE_BLOCK_SIZE -  Size of each memory blocks identified as &amp;#39;large&amp;#39; block. 
// &amp;lt;i&amp;gt;  Size of each memory blocks identified as &amp;#39;large&amp;#39; block. Memory block are recommended to be word-sized.
#ifndef MEMORY_MANAGER_LARGE_BLOCK_SIZE
#define MEMORY_MANAGER_LARGE_BLOCK_SIZE 256
// &amp;lt;o&amp;gt; MEMORY_MANAGER_XLARGE_BLOCK_COUNT - Size of each memory blocks identified as &amp;#39;extra large&amp;#39; block.  &amp;lt;0-255&amp;gt; 
#ifndef MEMORY_MANAGER_XLARGE_BLOCK_COUNT
#define MEMORY_MANAGER_XLARGE_BLOCK_COUNT 0
// &amp;lt;o&amp;gt; MEMORY_MANAGER_XLARGE_BLOCK_SIZE -  Size of each memory blocks identified as &amp;#39;extra large&amp;#39; block. 
// &amp;lt;i&amp;gt;  Size of each memory blocks identified as &amp;#39;extra large&amp;#39; block. Memory block are recommended to be word-sized.
#ifndef MEMORY_MANAGER_XLARGE_BLOCK_SIZE
#define MEMORY_MANAGER_XLARGE_BLOCK_SIZE 1320
// &amp;lt;o&amp;gt; MEMORY_MANAGER_XXLARGE_BLOCK_COUNT - Size of each memory blocks identified as &amp;#39;extra extra large&amp;#39; block.  &amp;lt;0-255&amp;gt; 
#ifndef MEMORY_MANAGER_XXLARGE_BLOCK_COUNT
#define MEMORY_MANAGER_XXLARGE_BLOCK_COUNT 0
// &amp;lt;o&amp;gt; MEMORY_MANAGER_XXLARGE_BLOCK_SIZE -  Size of each memory blocks identified as &amp;#39;extra extra large&amp;#39; block. 
// &amp;lt;i&amp;gt;  Size of each memory blocks identified as &amp;#39;extra extra large&amp;#39; block. Memory block are recommended to be word-sized.
#ifndef MEMORY_MANAGER_XXLARGE_BLOCK_SIZE
#define MEMORY_MANAGER_XXLARGE_BLOCK_SIZE 3444
// &amp;lt;o&amp;gt; MEMORY_MANAGER_XSMALL_BLOCK_COUNT - Size of each memory blocks identified as &amp;#39;extra small&amp;#39; block.  &amp;lt;0-255&amp;gt; 
#ifndef MEMORY_MANAGER_XSMALL_BLOCK_COUNT
#define MEMORY_MANAGER_XSMALL_BLOCK_COUNT 0
// &amp;lt;o&amp;gt; MEMORY_MANAGER_XSMALL_BLOCK_SIZE -  Size of each memory blocks identified as &amp;#39;extra small&amp;#39; block. 
#ifndef MEMORY_MANAGER_XSMALL_BLOCK_SIZE
#define MEMORY_MANAGER_XSMALL_BLOCK_SIZE 64
// &amp;lt;o&amp;gt; MEMORY_MANAGER_XXSMALL_BLOCK_COUNT - Size of each memory blocks identified as &amp;#39;extra extra small&amp;#39; block.  &amp;lt;0-255&amp;gt; 
#ifndef MEMORY_MANAGER_XXSMALL_BLOCK_COUNT
#define MEMORY_MANAGER_XXSMALL_BLOCK_COUNT 0
// &amp;lt;o&amp;gt; MEMORY_MANAGER_XXSMALL_BLOCK_SIZE -  Size of each memory blocks identified as &amp;#39;extra extra small&amp;#39; block. 
// &amp;lt;i&amp;gt;  Size of each memory blocks identified as &amp;#39;extra extra small&amp;#39; block. Memory block are recommended to be word-sized.
#ifndef MEMORY_MANAGER_XXSMALL_BLOCK_SIZE
#define MEMORY_MANAGER_XXSMALL_BLOCK_SIZE 32
// &amp;lt;e&amp;gt; MEM_MANAGER_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef MEM_MANAGER_CONFIG_LOG_ENABLED
#define MEM_MANAGER_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; MEM_MANAGER_CONFIG_LOG_LEVEL  - Default Severity level
// &amp;lt;0=&amp;gt; Off 
// &amp;lt;1=&amp;gt; Error 
// &amp;lt;2=&amp;gt; Warning 
// &amp;lt;3=&amp;gt; Info 
// &amp;lt;4=&amp;gt; Debug 
#ifndef MEM_MANAGER_CONFIG_LOG_LEVEL
#define MEM_MANAGER_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; MEM_MANAGER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// &amp;lt;1=&amp;gt; Black 
// &amp;lt;2=&amp;gt; Red 
// &amp;lt;3=&amp;gt; Green 
// &amp;lt;4=&amp;gt; Yellow 
// &amp;lt;5=&amp;gt; Blue 
// &amp;lt;6=&amp;gt; Magenta 
// &amp;lt;7=&amp;gt; Cyan 
// &amp;lt;8=&amp;gt; White 
#ifndef MEM_MANAGER_CONFIG_INFO_COLOR
#define MEM_MANAGER_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; MEM_MANAGER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef MEM_MANAGER_CONFIG_DEBUG_COLOR
#define MEM_MANAGER_CONFIG_DEBUG_COLOR 0
// &amp;lt;q&amp;gt; MEM_MANAGER_DISABLE_API_PARAM_CHECK  - Disable API parameter checks in the module.
#ifndef MEM_MANAGER_DISABLE_API_PARAM_CHECK
#define MEM_MANAGER_DISABLE_API_PARAM_CHECK 0
// &amp;lt;e&amp;gt; NRF_BALLOC_ENABLED - nrf_balloc - Block allocator module
#ifndef NRF_BALLOC_ENABLED
#define NRF_BALLOC_ENABLED 1
// &amp;lt;e&amp;gt; NRF_BALLOC_CONFIG_DEBUG_ENABLED - Enables debug mode in the module.
#ifndef NRF_BALLOC_CONFIG_DEBUG_ENABLED
#define NRF_BALLOC_CONFIG_DEBUG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_BALLOC_CONFIG_HEAD_GUARD_WORDS - Number of words used as head guard.  &amp;lt;0-255&amp;gt; 
#ifndef NRF_BALLOC_CONFIG_HEAD_GUARD_WORDS
#define NRF_BALLOC_CONFIG_HEAD_GUARD_WORDS 1
// &amp;lt;o&amp;gt; NRF_BALLOC_CONFIG_TAIL_GUARD_WORDS - Number of words used as tail guard.  &amp;lt;0-255&amp;gt; 
#ifndef NRF_BALLOC_CONFIG_TAIL_GUARD_WORDS
#define NRF_BALLOC_CONFIG_TAIL_GUARD_WORDS 1
// &amp;lt;q&amp;gt; NRF_BALLOC_CONFIG_BASIC_CHECKS_ENABLED  - Enables basic checks in this module.
#ifndef NRF_BALLOC_CONFIG_BASIC_CHECKS_ENABLED
#define NRF_BALLOC_CONFIG_BASIC_CHECKS_ENABLED 0
// &amp;lt;q&amp;gt; NRF_BALLOC_CONFIG_DOUBLE_FREE_CHECK_ENABLED  - Enables double memory free check in this module.
#ifndef NRF_BALLOC_CONFIG_DOUBLE_FREE_CHECK_ENABLED
#define NRF_BALLOC_CONFIG_DOUBLE_FREE_CHECK_ENABLED 0
// &amp;lt;q&amp;gt; NRF_BALLOC_CONFIG_DATA_TRASHING_CHECK_ENABLED  - Enables free memory corruption check in this module.
#ifndef NRF_BALLOC_CONFIG_DATA_TRASHING_CHECK_ENABLED
#define NRF_BALLOC_CONFIG_DATA_TRASHING_CHECK_ENABLED 0
// &amp;lt;q&amp;gt; NRF_BALLOC_CLI_CMDS  - Enable CLI commands specific to the module
#ifndef NRF_BALLOC_CLI_CMDS
#define NRF_BALLOC_CLI_CMDS 0
// &amp;lt;e&amp;gt; NRF_FSTORAGE_ENABLED - nrf_fstorage - Flash abstraction library
#ifndef NRF_FSTORAGE_ENABLED
#define NRF_FSTORAGE_ENABLED 1
// &amp;lt;h&amp;gt; nrf_fstorage - Common settings
// &amp;lt;i&amp;gt; Common settings to all fstorage implementations
// &amp;lt;q&amp;gt; NRF_FSTORAGE_PARAM_CHECK_DISABLED  - Disable user input validation
// &amp;lt;i&amp;gt; If selected, use ASSERT to validate user input.
// &amp;lt;i&amp;gt; This effectively removes user input validation in production code.
// &amp;lt;i&amp;gt; Recommended setting: OFF, only enable this setting if size is a major concern.
#ifndef NRF_FSTORAGE_PARAM_CHECK_DISABLED
#define NRF_FSTORAGE_PARAM_CHECK_DISABLED 1
// &amp;lt;h&amp;gt; nrf_fstorage_sd - Implementation using the SoftDevice
// &amp;lt;i&amp;gt; Configuration options for the fstorage implementation using the SoftDevice
// &amp;lt;o&amp;gt; NRF_FSTORAGE_SD_QUEUE_SIZE - Size of the internal queue of operations 
// &amp;lt;i&amp;gt; Increase this value if API calls frequently return the error @ref NRF_ERROR_NO_MEM.
#ifndef NRF_FSTORAGE_SD_QUEUE_SIZE
#define NRF_FSTORAGE_SD_QUEUE_SIZE 16
// &amp;lt;o&amp;gt; NRF_FSTORAGE_SD_MAX_RETRIES - Maximum number of attempts at executing an operation when the SoftDevice is busy 
// &amp;lt;i&amp;gt; Increase this value if events frequently return the @ref NRF_ERROR_TIMEOUT error.
// &amp;lt;i&amp;gt; The SoftDevice might fail to schedule flash access due to high BLE activity.
#ifndef NRF_FSTORAGE_SD_MAX_RETRIES
#define NRF_FSTORAGE_SD_MAX_RETRIES 8
// &amp;lt;o&amp;gt; NRF_FSTORAGE_SD_MAX_WRITE_SIZE - Maximum number of bytes to be written to flash in a single operation 
// &amp;lt;i&amp;gt; This value must be a multiple of four.
// &amp;lt;i&amp;gt; Lowering this value can increase the chances of the SoftDevice being able to execute flash operations in between radio activity.
// &amp;lt;i&amp;gt; This value is bound by the maximum number of bytes that can be written to flash in a single call to @ref sd_flash_write.
// &amp;lt;i&amp;gt; That is 1024 bytes for nRF51 ICs and 4096 bytes for nRF52 ICs.
#ifndef NRF_FSTORAGE_SD_MAX_WRITE_SIZE
#define NRF_FSTORAGE_SD_MAX_WRITE_SIZE 20
// &amp;lt;q&amp;gt; NRF_MEMOBJ_ENABLED  - nrf_memobj - Linked memory allocator module
#ifndef NRF_MEMOBJ_ENABLED
#define NRF_MEMOBJ_ENABLED 1
// &amp;lt;e&amp;gt; NRF_QUEUE_ENABLED - nrf_queue - Queue module
#ifndef NRF_QUEUE_ENABLED
#define NRF_QUEUE_ENABLED 0
// &amp;lt;q&amp;gt; NRF_QUEUE_CLI_CMDS  - Enable CLI commands specific to the module
#ifndef NRF_QUEUE_CLI_CMDS
#define NRF_QUEUE_CLI_CMDS 0
// &amp;lt;q&amp;gt; NRF_SECTION_ITER_ENABLED  - nrf_section_iter - Section iterator
#ifndef NRF_SECTION_ITER_ENABLED
#define NRF_SECTION_ITER_ENABLED 1
// &amp;lt;q&amp;gt; NRF_STRERROR_ENABLED  - nrf_strerror - Library for converting error code to string.
#ifndef NRF_STRERROR_ENABLED
#define NRF_STRERROR_ENABLED 1
// &amp;lt;h&amp;gt; nrf_fprintf - fprintf function.
// &amp;lt;q&amp;gt; NRF_FPRINTF_ENABLED  - Enable/disable fprintf module.
#ifndef NRF_FPRINTF_ENABLED
#define NRF_FPRINTF_ENABLED 1
// &amp;lt;q&amp;gt; NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED  - For each printed LF, function will add CR.
#ifndef NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED
#define NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 1
// &amp;lt;q&amp;gt; NRF_FPRINTF_DOUBLE_ENABLED  - Enable IEEE-754 double precision formatting.
#ifndef NRF_FPRINTF_DOUBLE_ENABLED
#define NRF_FPRINTF_DOUBLE_ENABLED 0
// &amp;lt;h&amp;gt; nRF_Log 
// &amp;lt;e&amp;gt; NRF_LOG_ENABLED - nrf_log - Logger
#ifndef NRF_LOG_ENABLED
#define NRF_LOG_ENABLED 0
// &amp;lt;h&amp;gt; Log message pool - Configuration of log message pool
// &amp;lt;o&amp;gt; NRF_LOG_MSGPOOL_ELEMENT_SIZE - Size of a single element in the pool of memory objects. 
// &amp;lt;i&amp;gt; If a small value is set, then performance of logs processing
// &amp;lt;i&amp;gt; is degraded because data is fragmented. Bigger value impacts
// &amp;lt;i&amp;gt; RAM memory utilization. The size is set to fit a message with
// &amp;lt;i&amp;gt; a timestamp and up to 2 arguments in a single memory object.
#ifndef NRF_LOG_MSGPOOL_ELEMENT_SIZE
#define NRF_LOG_MSGPOOL_ELEMENT_SIZE 20
// &amp;lt;o&amp;gt; NRF_LOG_MSGPOOL_ELEMENT_COUNT - Number of elements in the pool of memory objects 
// &amp;lt;i&amp;gt; If a small value is set, then it may lead to a deadlock
// &amp;lt;i&amp;gt; in certain cases if backend has high latency and holds
// &amp;lt;i&amp;gt; multiple messages for long time. Bigger value impacts
// &amp;lt;i&amp;gt; RAM memory usage.
#ifndef NRF_LOG_MSGPOOL_ELEMENT_COUNT
#define NRF_LOG_MSGPOOL_ELEMENT_COUNT 8
// &amp;lt;q&amp;gt; NRF_LOG_ALLOW_OVERFLOW  - Configures behavior when circular buffer is full.
// &amp;lt;i&amp;gt; If set then oldest logs are overwritten. Otherwise a 
// &amp;lt;i&amp;gt; marker is injected informing about overflow.
#ifndef NRF_LOG_ALLOW_OVERFLOW
#define NRF_LOG_ALLOW_OVERFLOW 1
// &amp;lt;o&amp;gt; NRF_LOG_BUFSIZE  - Size of the buffer for storing logs (in bytes).
// &amp;lt;i&amp;gt; Must be power of 2 and multiple of 4.
// &amp;lt;i&amp;gt; If NRF_LOG_DEFERRED = 0 then buffer size can be reduced to minimum.
// &amp;lt;128=&amp;gt; 128 
// &amp;lt;256=&amp;gt; 256 
// &amp;lt;512=&amp;gt; 512 
// &amp;lt;1024=&amp;gt; 1024 
// &amp;lt;2048=&amp;gt; 2048 
// &amp;lt;4096=&amp;gt; 4096 
// &amp;lt;8192=&amp;gt; 8192 
// &amp;lt;16384=&amp;gt; 16384 
#ifndef NRF_LOG_BUFSIZE
#define NRF_LOG_BUFSIZE 1024
// &amp;lt;q&amp;gt; NRF_LOG_CLI_CMDS  - Enable CLI commands for the module.
#ifndef NRF_LOG_CLI_CMDS
#define NRF_LOG_CLI_CMDS 0
// &amp;lt;o&amp;gt; NRF_LOG_DEFAULT_LEVEL  - Default Severity level
#ifndef NRF_LOG_DEFAULT_LEVEL
#define NRF_LOG_DEFAULT_LEVEL 3
// &amp;lt;q&amp;gt; NRF_LOG_DEFERRED  - Enable deffered logger.
// &amp;lt;i&amp;gt; Log data is buffered and can be processed in idle.
#ifndef NRF_LOG_DEFERRED
#define NRF_LOG_DEFERRED 1
// &amp;lt;q&amp;gt; NRF_LOG_FILTERS_ENABLED  - Enable dynamic filtering of logs.
#ifndef NRF_LOG_FILTERS_ENABLED
#define NRF_LOG_FILTERS_ENABLED 0
// &amp;lt;q&amp;gt; NRF_LOG_NON_DEFFERED_CRITICAL_REGION_ENABLED  - Enable use of critical region for non deffered mode when flushing logs.
// &amp;lt;i&amp;gt; When enabled NRF_LOG_FLUSH is called from critical section when non deffered mode is used.
// &amp;lt;i&amp;gt; Log output will never be corrupted as access to the log backend is exclusive
// &amp;lt;i&amp;gt; but system will spend significant amount of time in critical section
#ifndef NRF_LOG_NON_DEFFERED_CRITICAL_REGION_ENABLED
#define NRF_LOG_NON_DEFFERED_CRITICAL_REGION_ENABLED 0
// &amp;lt;o&amp;gt; NRF_LOG_STR_PUSH_BUFFER_SIZE  - Size of the buffer dedicated for strings stored using @ref NRF_LOG_PUSH.
// &amp;lt;32=&amp;gt; 32 
// &amp;lt;64=&amp;gt; 64 
#ifndef NRF_LOG_STR_PUSH_BUFFER_SIZE
#define NRF_LOG_STR_PUSH_BUFFER_SIZE 128
// &amp;lt;e&amp;gt; NRF_LOG_USES_COLORS - If enabled then ANSI escape code for colors is prefixed to every string
#ifndef NRF_LOG_USES_COLORS
#define NRF_LOG_USES_COLORS 0
// &amp;lt;o&amp;gt; NRF_LOG_COLOR_DEFAULT  - ANSI escape code prefix.
#ifndef NRF_LOG_COLOR_DEFAULT
#define NRF_LOG_COLOR_DEFAULT 0
// &amp;lt;o&amp;gt; NRF_LOG_ERROR_COLOR  - ANSI escape code prefix.
#ifndef NRF_LOG_ERROR_COLOR
#define NRF_LOG_ERROR_COLOR 2
// &amp;lt;o&amp;gt; NRF_LOG_WARNING_COLOR  - ANSI escape code prefix.
#ifndef NRF_LOG_WARNING_COLOR
#define NRF_LOG_WARNING_COLOR 4
// &amp;lt;e&amp;gt; NRF_LOG_USES_TIMESTAMP - Enable timestamping
// &amp;lt;i&amp;gt; Function for getting the timestamp is provided by the user
#ifndef NRF_LOG_USES_TIMESTAMP
#define NRF_LOG_USES_TIMESTAMP 0
// &amp;lt;o&amp;gt; NRF_LOG_TIMESTAMP_DEFAULT_FREQUENCY - Default frequency of the timestamp (in Hz) or 0 to use app_timer frequency. 
#ifndef NRF_LOG_TIMESTAMP_DEFAULT_FREQUENCY
#define NRF_LOG_TIMESTAMP_DEFAULT_FREQUENCY 0
// &amp;lt;h&amp;gt; nrf_log module configuration 
// &amp;lt;h&amp;gt; nrf_log in nRF_Core 
// &amp;lt;e&amp;gt; NRF_MPU_LIB_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_MPU_LIB_CONFIG_LOG_ENABLED
#define NRF_MPU_LIB_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_MPU_LIB_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_MPU_LIB_CONFIG_LOG_LEVEL
#define NRF_MPU_LIB_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_MPU_LIB_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_MPU_LIB_CONFIG_INFO_COLOR
#define NRF_MPU_LIB_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_MPU_LIB_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_MPU_LIB_CONFIG_DEBUG_COLOR
#define NRF_MPU_LIB_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_STACK_GUARD_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_STACK_GUARD_CONFIG_LOG_ENABLED
#define NRF_STACK_GUARD_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_STACK_GUARD_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_STACK_GUARD_CONFIG_LOG_LEVEL
#define NRF_STACK_GUARD_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_STACK_GUARD_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_STACK_GUARD_CONFIG_INFO_COLOR
#define NRF_STACK_GUARD_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_STACK_GUARD_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_STACK_GUARD_CONFIG_DEBUG_COLOR
#define NRF_STACK_GUARD_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; TASK_MANAGER_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef TASK_MANAGER_CONFIG_LOG_ENABLED
#define TASK_MANAGER_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; TASK_MANAGER_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef TASK_MANAGER_CONFIG_LOG_LEVEL
#define TASK_MANAGER_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; TASK_MANAGER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef TASK_MANAGER_CONFIG_INFO_COLOR
#define TASK_MANAGER_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; TASK_MANAGER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef TASK_MANAGER_CONFIG_DEBUG_COLOR
#define TASK_MANAGER_CONFIG_DEBUG_COLOR 0
// &amp;lt;h&amp;gt; nrf_log in nRF_Drivers 
// &amp;lt;e&amp;gt; CLOCK_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef CLOCK_CONFIG_LOG_ENABLED
#define CLOCK_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; CLOCK_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef CLOCK_CONFIG_LOG_LEVEL
#define CLOCK_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; CLOCK_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef CLOCK_CONFIG_INFO_COLOR
#define CLOCK_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; CLOCK_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef CLOCK_CONFIG_DEBUG_COLOR
#define CLOCK_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; COMP_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef COMP_CONFIG_LOG_ENABLED
#define COMP_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; COMP_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef COMP_CONFIG_LOG_LEVEL
#define COMP_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; COMP_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef COMP_CONFIG_INFO_COLOR
#define COMP_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; COMP_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef COMP_CONFIG_DEBUG_COLOR
#define COMP_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; GPIOTE_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef GPIOTE_CONFIG_LOG_ENABLED
#define GPIOTE_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; GPIOTE_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef GPIOTE_CONFIG_LOG_LEVEL
#define GPIOTE_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; GPIOTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef GPIOTE_CONFIG_INFO_COLOR
#define GPIOTE_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; GPIOTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef GPIOTE_CONFIG_DEBUG_COLOR
#define GPIOTE_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; LPCOMP_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef LPCOMP_CONFIG_LOG_ENABLED
#define LPCOMP_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; LPCOMP_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef LPCOMP_CONFIG_LOG_LEVEL
#define LPCOMP_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; LPCOMP_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef LPCOMP_CONFIG_INFO_COLOR
#define LPCOMP_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; LPCOMP_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef LPCOMP_CONFIG_DEBUG_COLOR
#define LPCOMP_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRFX_CLOCK_ENABLED - nrfx_clock - CLOCK peripheral driver
#ifndef NRFX_CLOCK_ENABLED
#define NRFX_CLOCK_ENABLED 1
// &amp;lt;o&amp;gt; NRFX_CLOCK_CONFIG_LF_SRC  - LF Clock Source
// &amp;lt;0=&amp;gt; RC 
// &amp;lt;1=&amp;gt; XTAL 
// &amp;lt;2=&amp;gt; Synth 
// &amp;lt;131073=&amp;gt; External Low Swing 
// &amp;lt;196609=&amp;gt; External Full Swing 
#ifndef NRFX_CLOCK_CONFIG_LF_SRC
#define NRFX_CLOCK_CONFIG_LF_SRC __LF_SRC
// &amp;lt;o&amp;gt; NRFX_CLOCK_CONFIG_IRQ_PRIORITY  - Interrupt priority
// &amp;lt;0=&amp;gt; 0 (highest) 
// &amp;lt;1=&amp;gt; 1 
// &amp;lt;2=&amp;gt; 2 
// &amp;lt;3=&amp;gt; 3 
// &amp;lt;4=&amp;gt; 4 
// &amp;lt;5=&amp;gt; 5 
// &amp;lt;6=&amp;gt; 6 
// &amp;lt;7=&amp;gt; 7 
// &amp;lt;e&amp;gt; MAX3421E_HOST_CONFIG_LOG_ENABLED - Enable logging in the module
#ifndef MAX3421E_HOST_CONFIG_LOG_ENABLED
#define MAX3421E_HOST_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; MAX3421E_HOST_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef MAX3421E_HOST_CONFIG_LOG_LEVEL
#define MAX3421E_HOST_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; MAX3421E_HOST_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef MAX3421E_HOST_CONFIG_INFO_COLOR
#define MAX3421E_HOST_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; MAX3421E_HOST_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef MAX3421E_HOST_CONFIG_DEBUG_COLOR
#define MAX3421E_HOST_CONFIG_DEBUG_COLOR 0
// &amp;lt;/e&amp;gt;
// &amp;lt;e&amp;gt; NRFX_USBD_CONFIG_LOG_ENABLED - Enable logging in the module
#ifndef NRFX_USBD_CONFIG_LOG_ENABLED
#define NRFX_USBD_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_USBD_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_USBD_CONFIG_LOG_LEVEL
#define NRFX_USBD_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_USBD_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_USBD_CONFIG_INFO_COLOR
#define NRFX_USBD_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_USBD_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_USBD_CONFIG_DEBUG_COLOR
#define NRFX_USBD_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; PDM_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef PDM_CONFIG_LOG_ENABLED
#define PDM_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; PDM_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef PDM_CONFIG_LOG_LEVEL
#define PDM_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; PDM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef PDM_CONFIG_INFO_COLOR
#define PDM_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; PDM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef PDM_CONFIG_DEBUG_COLOR
#define PDM_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; PPI_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef PPI_CONFIG_LOG_ENABLED
#define PPI_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; PPI_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef PPI_CONFIG_LOG_LEVEL
#define PPI_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; PPI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef PPI_CONFIG_INFO_COLOR
#define PPI_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; PPI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef PPI_CONFIG_DEBUG_COLOR
#define PPI_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; PWM_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef PWM_CONFIG_LOG_ENABLED
#define PWM_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; PWM_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef PWM_CONFIG_LOG_LEVEL
#define PWM_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; PWM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef PWM_CONFIG_INFO_COLOR
#define PWM_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; PWM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef PWM_CONFIG_DEBUG_COLOR
#define PWM_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; QDEC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef QDEC_CONFIG_LOG_ENABLED
#define QDEC_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; QDEC_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef QDEC_CONFIG_LOG_LEVEL
#define QDEC_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; QDEC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef QDEC_CONFIG_INFO_COLOR
#define QDEC_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; QDEC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef QDEC_CONFIG_DEBUG_COLOR
#define QDEC_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; RNG_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef RNG_CONFIG_LOG_ENABLED
#define RNG_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; RNG_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef RNG_CONFIG_LOG_LEVEL
#define RNG_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; RNG_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef RNG_CONFIG_INFO_COLOR
#define RNG_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; RNG_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef RNG_CONFIG_DEBUG_COLOR
#define RNG_CONFIG_DEBUG_COLOR 0
// &amp;lt;q&amp;gt; RNG_CONFIG_RANDOM_NUMBER_LOG_ENABLED  - Enables logging of random numbers.
#ifndef RNG_CONFIG_RANDOM_NUMBER_LOG_ENABLED
#define RNG_CONFIG_RANDOM_NUMBER_LOG_ENABLED 0
// &amp;lt;e&amp;gt; RTC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef RTC_CONFIG_LOG_ENABLED
#define RTC_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; RTC_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef RTC_CONFIG_LOG_LEVEL
#define RTC_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; RTC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef RTC_CONFIG_INFO_COLOR
#define RTC_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; RTC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// &amp;lt;0=&amp;gt; Default 
#ifndef RTC_CONFIG_DEBUG_COLOR
#define RTC_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; SAADC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef SAADC_CONFIG_LOG_ENABLED
#define SAADC_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; SAADC_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef SAADC_CONFIG_LOG_LEVEL
#define SAADC_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; SAADC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef SAADC_CONFIG_INFO_COLOR
#define SAADC_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; SAADC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef SAADC_CONFIG_DEBUG_COLOR
#define SAADC_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; SPIS_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef SPIS_CONFIG_LOG_ENABLED
#define SPIS_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; SPIS_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef SPIS_CONFIG_LOG_LEVEL
#define SPIS_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; SPIS_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef SPIS_CONFIG_INFO_COLOR
#define SPIS_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; SPIS_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef SPIS_CONFIG_DEBUG_COLOR
#define SPIS_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; SPI_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef SPI_CONFIG_LOG_ENABLED
#define SPI_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; SPI_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef SPI_CONFIG_LOG_LEVEL
#define SPI_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; SPI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef SPI_CONFIG_INFO_COLOR
#define SPI_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; SPI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef SPI_CONFIG_DEBUG_COLOR
#define SPI_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; TIMER_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef TIMER_CONFIG_LOG_ENABLED
#define TIMER_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; TIMER_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef TIMER_CONFIG_LOG_LEVEL
#define TIMER_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; TIMER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef TIMER_CONFIG_INFO_COLOR
#define TIMER_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; TIMER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef TIMER_CONFIG_DEBUG_COLOR
#define TIMER_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; TWIS_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef TWIS_CONFIG_LOG_ENABLED
#define TWIS_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; TWIS_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef TWIS_CONFIG_LOG_LEVEL
#define TWIS_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; TWIS_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef TWIS_CONFIG_INFO_COLOR
#define TWIS_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; TWIS_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef TWIS_CONFIG_DEBUG_COLOR
#define TWIS_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; TWI_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef TWI_CONFIG_LOG_ENABLED
#define TWI_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; TWI_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef TWI_CONFIG_LOG_LEVEL
#define TWI_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; TWI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef TWI_CONFIG_INFO_COLOR
#define TWI_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; TWI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef TWI_CONFIG_DEBUG_COLOR
#define TWI_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; UART_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef UART_CONFIG_LOG_ENABLED
#define UART_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; UART_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef UART_CONFIG_LOG_LEVEL
#define UART_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; UART_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef UART_CONFIG_INFO_COLOR
#define UART_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; UART_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef UART_CONFIG_DEBUG_COLOR
#define UART_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; USBD_CONFIG_LOG_ENABLED - Enable logging in the module
#ifndef USBD_CONFIG_LOG_ENABLED
#define USBD_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; USBD_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef USBD_CONFIG_LOG_LEVEL
#define USBD_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; USBD_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef USBD_CONFIG_INFO_COLOR
#define USBD_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; USBD_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef USBD_CONFIG_DEBUG_COLOR
#define USBD_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; WDT_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef WDT_CONFIG_LOG_ENABLED
#define WDT_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; WDT_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef WDT_CONFIG_LOG_LEVEL
#define WDT_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; WDT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef WDT_CONFIG_INFO_COLOR
#define WDT_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; WDT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef WDT_CONFIG_DEBUG_COLOR
#define WDT_CONFIG_DEBUG_COLOR 0
// &amp;lt;/h&amp;gt; 
// &amp;lt;h&amp;gt; nrf_log in nRF_Libraries 
// &amp;lt;e&amp;gt; APP_BUTTON_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef APP_BUTTON_CONFIG_LOG_ENABLED
#define APP_BUTTON_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_BUTTON_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_BUTTON_CONFIG_LOG_LEVEL
#define APP_BUTTON_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_BUTTON_CONFIG_INITIAL_LOG_LEVEL  - Initial severity level if dynamic filtering is enabled.
// &amp;lt;i&amp;gt; If module generates a lot of logs, initial log level can
// &amp;lt;i&amp;gt; be decreased to prevent flooding. Severity level can be
// &amp;lt;i&amp;gt; increased on instance basis.
#ifndef APP_BUTTON_CONFIG_INITIAL_LOG_LEVEL
#define APP_BUTTON_CONFIG_INITIAL_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_BUTTON_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_BUTTON_CONFIG_INFO_COLOR
#define APP_BUTTON_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_BUTTON_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_BUTTON_CONFIG_DEBUG_COLOR
#define APP_BUTTON_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; APP_TIMER_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef APP_TIMER_CONFIG_LOG_ENABLED
#define APP_TIMER_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_TIMER_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_TIMER_CONFIG_LOG_LEVEL
#define APP_TIMER_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_TIMER_CONFIG_INITIAL_LOG_LEVEL  - Initial severity level if dynamic filtering is enabled.
#ifndef APP_TIMER_CONFIG_INITIAL_LOG_LEVEL
#define APP_TIMER_CONFIG_INITIAL_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_TIMER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_TIMER_CONFIG_INFO_COLOR
#define APP_TIMER_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_TIMER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_TIMER_CONFIG_DEBUG_COLOR
#define APP_TIMER_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; APP_USBD_CDC_ACM_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef APP_USBD_CDC_ACM_CONFIG_LOG_ENABLED
#define APP_USBD_CDC_ACM_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_USBD_CDC_ACM_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_USBD_CDC_ACM_CONFIG_LOG_LEVEL
#define APP_USBD_CDC_ACM_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_USBD_CDC_ACM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_CDC_ACM_CONFIG_INFO_COLOR
#define APP_USBD_CDC_ACM_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_USBD_CDC_ACM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_CDC_ACM_CONFIG_DEBUG_COLOR
#define APP_USBD_CDC_ACM_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; APP_USBD_CONFIG_LOG_ENABLED - Enable logging in the module.
#ifndef APP_USBD_CONFIG_LOG_ENABLED
#define APP_USBD_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_USBD_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_USBD_CONFIG_LOG_LEVEL
#define APP_USBD_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_USBD_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_CONFIG_INFO_COLOR
#define APP_USBD_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_USBD_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_CONFIG_DEBUG_COLOR
#define APP_USBD_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; APP_USBD_DUMMY_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef APP_USBD_DUMMY_CONFIG_LOG_ENABLED
#define APP_USBD_DUMMY_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_USBD_DUMMY_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_USBD_DUMMY_CONFIG_LOG_LEVEL
#define APP_USBD_DUMMY_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_USBD_DUMMY_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_DUMMY_CONFIG_INFO_COLOR
#define APP_USBD_DUMMY_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_USBD_DUMMY_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_DUMMY_CONFIG_DEBUG_COLOR
#define APP_USBD_DUMMY_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; APP_USBD_MSC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef APP_USBD_MSC_CONFIG_LOG_ENABLED
#define APP_USBD_MSC_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_USBD_MSC_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_USBD_MSC_CONFIG_LOG_LEVEL
#define APP_USBD_MSC_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_USBD_MSC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_MSC_CONFIG_INFO_COLOR
#define APP_USBD_MSC_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_USBD_MSC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_MSC_CONFIG_DEBUG_COLOR
#define APP_USBD_MSC_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_ENABLED
#define APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_LEVEL
#define APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_USBD_NRF_DFU_TRIGGER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_NRF_DFU_TRIGGER_CONFIG_INFO_COLOR
#define APP_USBD_NRF_DFU_TRIGGER_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_USBD_NRF_DFU_TRIGGER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_NRF_DFU_TRIGGER_CONFIG_DEBUG_COLOR
#define APP_USBD_NRF_DFU_TRIGGER_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_ATFIFO_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_ATFIFO_CONFIG_LOG_ENABLED
#define NRF_ATFIFO_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_ATFIFO_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_ATFIFO_CONFIG_LOG_LEVEL
#define NRF_ATFIFO_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_ATFIFO_CONFIG_LOG_INIT_FILTER_LEVEL  - Initial severity level if dynamic filtering is enabled
#ifndef NRF_ATFIFO_CONFIG_LOG_INIT_FILTER_LEVEL
#define NRF_ATFIFO_CONFIG_LOG_INIT_FILTER_LEVEL 3
// &amp;lt;o&amp;gt; NRF_ATFIFO_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_ATFIFO_CONFIG_INFO_COLOR
#define NRF_ATFIFO_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_ATFIFO_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_ATFIFO_CONFIG_DEBUG_COLOR
#define NRF_ATFIFO_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_BALLOC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_BALLOC_CONFIG_LOG_ENABLED
#define NRF_BALLOC_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_BALLOC_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_BALLOC_CONFIG_LOG_LEVEL
#define NRF_BALLOC_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BALLOC_CONFIG_INITIAL_LOG_LEVEL  - Initial severity level if dynamic filtering is enabled.
#ifndef NRF_BALLOC_CONFIG_INITIAL_LOG_LEVEL
#define NRF_BALLOC_CONFIG_INITIAL_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BALLOC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_BALLOC_CONFIG_INFO_COLOR
#define NRF_BALLOC_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_BALLOC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_BALLOC_CONFIG_DEBUG_COLOR
#define NRF_BALLOC_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_ENABLED
#define NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_LEVEL
#define NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_INIT_FILTER_LEVEL  - Initial severity level if dynamic filtering is enabled
#ifndef NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_INIT_FILTER_LEVEL
#define NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_INIT_FILTER_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_EMPTY_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_BLOCK_DEV_EMPTY_CONFIG_INFO_COLOR
#define NRF_BLOCK_DEV_EMPTY_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_EMPTY_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_BLOCK_DEV_EMPTY_CONFIG_DEBUG_COLOR
#define NRF_BLOCK_DEV_EMPTY_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED
#define NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL
#define NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_QSPI_CONFIG_LOG_INIT_FILTER_LEVEL  - Initial severity level if dynamic filtering is enabled
#ifndef NRF_BLOCK_DEV_QSPI_CONFIG_LOG_INIT_FILTER_LEVEL
#define NRF_BLOCK_DEV_QSPI_CONFIG_LOG_INIT_FILTER_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_QSPI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_BLOCK_DEV_QSPI_CONFIG_INFO_COLOR
#define NRF_BLOCK_DEV_QSPI_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_QSPI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_BLOCK_DEV_QSPI_CONFIG_DEBUG_COLOR
#define NRF_BLOCK_DEV_QSPI_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_BLOCK_DEV_RAM_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_BLOCK_DEV_RAM_CONFIG_LOG_ENABLED
#define NRF_BLOCK_DEV_RAM_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_RAM_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_BLOCK_DEV_RAM_CONFIG_LOG_LEVEL
#define NRF_BLOCK_DEV_RAM_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_RAM_CONFIG_LOG_INIT_FILTER_LEVEL  - Initial severity level if dynamic filtering is enabled
#ifndef NRF_BLOCK_DEV_RAM_CONFIG_LOG_INIT_FILTER_LEVEL
#define NRF_BLOCK_DEV_RAM_CONFIG_LOG_INIT_FILTER_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_RAM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_BLOCK_DEV_RAM_CONFIG_INFO_COLOR
#define NRF_BLOCK_DEV_RAM_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_RAM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_BLOCK_DEV_RAM_CONFIG_DEBUG_COLOR
#define NRF_BLOCK_DEV_RAM_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_CLI_BLE_UART_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_CLI_BLE_UART_CONFIG_LOG_ENABLED
#define NRF_CLI_BLE_UART_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_CLI_BLE_UART_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_CLI_BLE_UART_CONFIG_LOG_LEVEL
#define NRF_CLI_BLE_UART_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_CLI_BLE_UART_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_CLI_BLE_UART_CONFIG_INFO_COLOR
#define NRF_CLI_BLE_UART_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_CLI_BLE_UART_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_CLI_BLE_UART_CONFIG_DEBUG_COLOR
#define NRF_CLI_BLE_UART_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_CLI_LIBUARTE_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_CLI_LIBUARTE_CONFIG_LOG_ENABLED
#define NRF_CLI_LIBUARTE_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_CLI_LIBUARTE_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_CLI_LIBUARTE_CONFIG_LOG_LEVEL
#define NRF_CLI_LIBUARTE_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_CLI_LIBUARTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_CLI_LIBUARTE_CONFIG_INFO_COLOR
#define NRF_CLI_LIBUARTE_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_CLI_LIBUARTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_CLI_LIBUARTE_CONFIG_DEBUG_COLOR
#define NRF_CLI_LIBUARTE_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_CLI_UART_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_CLI_UART_CONFIG_LOG_ENABLED
#define NRF_CLI_UART_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_CLI_UART_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_CLI_UART_CONFIG_LOG_LEVEL
#define NRF_CLI_UART_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_CLI_UART_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_CLI_UART_CONFIG_INFO_COLOR
#define NRF_CLI_UART_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_CLI_UART_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_CLI_UART_CONFIG_DEBUG_COLOR
#define NRF_CLI_UART_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_LIBUARTE_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_LIBUARTE_CONFIG_LOG_ENABLED
#define NRF_LIBUARTE_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_LIBUARTE_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_LIBUARTE_CONFIG_LOG_LEVEL
#define NRF_LIBUARTE_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_LIBUARTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_LIBUARTE_CONFIG_INFO_COLOR
#define NRF_LIBUARTE_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_LIBUARTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_LIBUARTE_CONFIG_DEBUG_COLOR
#define NRF_LIBUARTE_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_MEMOBJ_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_MEMOBJ_CONFIG_LOG_ENABLED
#define NRF_MEMOBJ_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_MEMOBJ_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_MEMOBJ_CONFIG_LOG_LEVEL
#define NRF_MEMOBJ_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_MEMOBJ_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_MEMOBJ_CONFIG_INFO_COLOR
#define NRF_MEMOBJ_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_MEMOBJ_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_MEMOBJ_CONFIG_DEBUG_COLOR
#define NRF_MEMOBJ_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_PWR_MGMT_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_PWR_MGMT_CONFIG_LOG_ENABLED
#define NRF_PWR_MGMT_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_PWR_MGMT_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_PWR_MGMT_CONFIG_LOG_LEVEL
#define NRF_PWR_MGMT_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_PWR_MGMT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_PWR_MGMT_CONFIG_INFO_COLOR
#define NRF_PWR_MGMT_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_PWR_MGMT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_PWR_MGMT_CONFIG_DEBUG_COLOR
#define NRF_PWR_MGMT_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_QUEUE_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_QUEUE_CONFIG_LOG_ENABLED
#define NRF_QUEUE_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_QUEUE_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_QUEUE_CONFIG_LOG_LEVEL
#define NRF_QUEUE_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_QUEUE_CONFIG_LOG_INIT_FILTER_LEVEL  - Initial severity level if dynamic filtering is enabled
#ifndef NRF_QUEUE_CONFIG_LOG_INIT_FILTER_LEVEL
#define NRF_QUEUE_CONFIG_LOG_INIT_FILTER_LEVEL 3
// &amp;lt;o&amp;gt; NRF_QUEUE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_QUEUE_CONFIG_INFO_COLOR
#define NRF_QUEUE_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_QUEUE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_QUEUE_CONFIG_DEBUG_COLOR
#define NRF_QUEUE_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_SDH_ANT_LOG_ENABLED - Enable logging in SoftDevice handler (ANT) module.
#ifndef NRF_SDH_ANT_LOG_ENABLED
#define NRF_SDH_ANT_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_SDH_ANT_LOG_LEVEL  - Default Severity level
#ifndef NRF_SDH_ANT_LOG_LEVEL
#define NRF_SDH_ANT_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_SDH_ANT_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_ANT_INFO_COLOR
#define NRF_SDH_ANT_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_SDH_ANT_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_ANT_DEBUG_COLOR
#define NRF_SDH_ANT_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_SDH_BLE_LOG_ENABLED - Enable logging in SoftDevice handler (BLE) module.
#ifndef NRF_SDH_BLE_LOG_ENABLED
#define NRF_SDH_BLE_LOG_ENABLED 1
// &amp;lt;o&amp;gt; NRF_SDH_BLE_LOG_LEVEL  - Default Severity level
#ifndef NRF_SDH_BLE_LOG_LEVEL
#define NRF_SDH_BLE_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_SDH_BLE_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_BLE_INFO_COLOR
#define NRF_SDH_BLE_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_SDH_BLE_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_BLE_DEBUG_COLOR
#define NRF_SDH_BLE_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_SDH_LOG_ENABLED - Enable logging in SoftDevice handler module.
#ifndef NRF_SDH_LOG_ENABLED
#define NRF_SDH_LOG_ENABLED 1
// &amp;lt;o&amp;gt; NRF_SDH_LOG_LEVEL  - Default Severity level
#ifndef NRF_SDH_LOG_LEVEL
#define NRF_SDH_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_SDH_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_INFO_COLOR
#define NRF_SDH_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_SDH_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_DEBUG_COLOR
#define NRF_SDH_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_SDH_SOC_LOG_ENABLED - Enable logging in SoftDevice handler (SoC) module.
#ifndef NRF_SDH_SOC_LOG_ENABLED
#define NRF_SDH_SOC_LOG_ENABLED 1
// &amp;lt;o&amp;gt; NRF_SDH_SOC_LOG_LEVEL  - Default Severity level
#ifndef NRF_SDH_SOC_LOG_LEVEL
#define NRF_SDH_SOC_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_SDH_SOC_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_SOC_INFO_COLOR
#define NRF_SDH_SOC_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_SDH_SOC_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_SOC_DEBUG_COLOR
#define NRF_SDH_SOC_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_SORTLIST_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_SORTLIST_CONFIG_LOG_ENABLED
#define NRF_SORTLIST_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_SORTLIST_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_SORTLIST_CONFIG_LOG_LEVEL
#define NRF_SORTLIST_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_SORTLIST_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_SORTLIST_CONFIG_INFO_COLOR
#define NRF_SORTLIST_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_SORTLIST_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_SORTLIST_CONFIG_DEBUG_COLOR
#define NRF_SORTLIST_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_TWI_SENSOR_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_TWI_SENSOR_CONFIG_LOG_ENABLED
#define NRF_TWI_SENSOR_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_TWI_SENSOR_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_TWI_SENSOR_CONFIG_LOG_LEVEL
#define NRF_TWI_SENSOR_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_TWI_SENSOR_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_TWI_SENSOR_CONFIG_INFO_COLOR
#define NRF_TWI_SENSOR_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_TWI_SENSOR_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_TWI_SENSOR_CONFIG_DEBUG_COLOR
#define NRF_TWI_SENSOR_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; PM_LOG_ENABLED - Enable logging in Peer Manager and its submodules.
#ifndef PM_LOG_ENABLED
#define PM_LOG_ENABLED 1
// &amp;lt;o&amp;gt; PM_LOG_LEVEL  - Default Severity level
#ifndef PM_LOG_LEVEL
#define PM_LOG_LEVEL 3
// &amp;lt;o&amp;gt; PM_LOG_INFO_COLOR  - ANSI escape code prefix.
#ifndef PM_LOG_INFO_COLOR
#define PM_LOG_INFO_COLOR 0
// &amp;lt;o&amp;gt; PM_LOG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef PM_LOG_DEBUG_COLOR
#define PM_LOG_DEBUG_COLOR 0
// &amp;lt;h&amp;gt; nrf_log in nRF_Serialization 
// &amp;lt;e&amp;gt; SER_HAL_TRANSPORT_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef SER_HAL_TRANSPORT_CONFIG_LOG_ENABLED
#define SER_HAL_TRANSPORT_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; SER_HAL_TRANSPORT_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef SER_HAL_TRANSPORT_CONFIG_LOG_LEVEL
#define SER_HAL_TRANSPORT_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; SER_HAL_TRANSPORT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef SER_HAL_TRANSPORT_CONFIG_INFO_COLOR
#define SER_HAL_TRANSPORT_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; SER_HAL_TRANSPORT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef SER_HAL_TRANSPORT_CONFIG_DEBUG_COLOR
#define SER_HAL_TRANSPORT_CONFIG_DEBUG_COLOR 0
// &amp;lt;q&amp;gt; NRF_LOG_STR_FORMATTER_TIMESTAMP_FORMAT_ENABLED  - nrf_log_str_formatter - Log string formatter
#ifndef NRF_LOG_STR_FORMATTER_TIMESTAMP_FORMAT_ENABLED
#define NRF_LOG_STR_FORMATTER_TIMESTAMP_FORMAT_ENABLED 1
// &amp;lt;h&amp;gt; nRF_SoftDevice 
// &amp;lt;e&amp;gt; NRF_SDH_BLE_ENABLED - nrf_sdh_ble - SoftDevice BLE event handler
#ifndef NRF_SDH_BLE_ENABLED
#define NRF_SDH_BLE_ENABLED 1
// &amp;lt;h&amp;gt; BLE Stack configuration - Stack configuration parameters
// &amp;lt;i&amp;gt; The SoftDevice handler will configure the stack with these parameters when calling @ref nrf_sdh_ble_default_cfg_set.
// &amp;lt;i&amp;gt; Other libraries might depend on these values; keep them up-to-date even if you are not explicitely calling @ref nrf_sdh_ble_default_cfg_set.
// &amp;lt;o&amp;gt; NRF_SDH_BLE_GAP_DATA_LENGTH   &amp;lt;27-251&amp;gt; 
// &amp;lt;i&amp;gt; Requested BLE GAP data length to be negotiated.
#ifndef NRF_SDH_BLE_GAP_DATA_LENGTH
#define NRF_SDH_BLE_GAP_DATA_LENGTH 27
// &amp;lt;o&amp;gt; NRF_SDH_BLE_PERIPHERAL_LINK_COUNT - Maximum number of peripheral links. 
#ifndef NRF_SDH_BLE_PERIPHERAL_LINK_COUNT
#define NRF_SDH_BLE_PERIPHERAL_LINK_COUNT 1
// &amp;lt;o&amp;gt; NRF_SDH_BLE_CENTRAL_LINK_COUNT - Maximum number of central links. 
#ifndef NRF_SDH_BLE_CENTRAL_LINK_COUNT
#define NRF_SDH_BLE_CENTRAL_LINK_COUNT 0
// &amp;lt;o&amp;gt; NRF_SDH_BLE_TOTAL_LINK_COUNT - Total link count. 
// &amp;lt;i&amp;gt; Maximum number of total concurrent connections using the default configuration.
#ifndef NRF_SDH_BLE_TOTAL_LINK_COUNT
#define NRF_SDH_BLE_TOTAL_LINK_COUNT 1
// &amp;lt;o&amp;gt; NRF_SDH_BLE_GAP_EVENT_LENGTH - GAP event length. 
// &amp;lt;i&amp;gt; The time set aside for this connection on every connection interval in 1.25 ms units.
#ifndef NRF_SDH_BLE_GAP_EVENT_LENGTH
#define NRF_SDH_BLE_GAP_EVENT_LENGTH 6
// &amp;lt;o&amp;gt; NRF_SDH_BLE_GATT_MAX_MTU_SIZE - Static maximum MTU size. 
#ifndef NRF_SDH_BLE_GATT_MAX_MTU_SIZE
#define NRF_SDH_BLE_GATT_MAX_MTU_SIZE 247
// &amp;lt;o&amp;gt; NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE - Attribute Table size in bytes. The size must be a multiple of 4. 
#ifndef NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE
#define NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE 1408
// &amp;lt;o&amp;gt; NRF_SDH_BLE_VS_UUID_COUNT - The number of vendor-specific UUIDs. 
#ifndef NRF_SDH_BLE_VS_UUID_COUNT
#define NRF_SDH_BLE_VS_UUID_COUNT 1
// &amp;lt;q&amp;gt; NRF_SDH_BLE_SERVICE_CHANGED  - Include the Service Changed characteristic in the Attribute Table.
#ifndef NRF_SDH_BLE_SERVICE_CHANGED
#define NRF_SDH_BLE_SERVICE_CHANGED 0
// &amp;lt;h&amp;gt; BLE Observers - Observers and priority levels
// &amp;lt;o&amp;gt; NRF_SDH_BLE_OBSERVER_PRIO_LEVELS - Total number of priority levels for BLE observers. 
// &amp;lt;i&amp;gt; This setting configures the number of priority levels available for BLE event handlers.
// &amp;lt;i&amp;gt; The priority level of a handler determines the order in which it receives events, with respect to other handlers.
#ifndef NRF_SDH_BLE_OBSERVER_PRIO_LEVELS
#define NRF_SDH_BLE_OBSERVER_PRIO_LEVELS 4
// &amp;lt;h&amp;gt; BLE Observers priorities - Invididual priorities
// &amp;lt;o&amp;gt; BLE_ADV_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Advertising module.
#ifndef BLE_ADV_BLE_OBSERVER_PRIO
#define BLE_ADV_BLE_OBSERVER_PRIO 1
// &amp;lt;o&amp;gt; BLE_ANCS_C_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Apple Notification Service Client.
#ifndef BLE_ANCS_C_BLE_OBSERVER_PRIO
#define BLE_ANCS_C_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_ANS_C_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Alert Notification Service Client.
#ifndef BLE_ANS_C_BLE_OBSERVER_PRIO
#define BLE_ANS_C_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_BAS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Battery Service.
#ifndef BLE_BAS_BLE_OBSERVER_PRIO
#define BLE_BAS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_BAS_C_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Battery Service Client.
#ifndef BLE_BAS_C_BLE_OBSERVER_PRIO
#define BLE_BAS_C_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_BPS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Blood Pressure Service.
#ifndef BLE_BPS_BLE_OBSERVER_PRIO
#define BLE_BPS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_CONN_PARAMS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Connection parameters module.
#ifndef BLE_CONN_PARAMS_BLE_OBSERVER_PRIO
#define BLE_CONN_PARAMS_BLE_OBSERVER_PRIO 1
// &amp;lt;o&amp;gt; BLE_CONN_STATE_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Connection State module.
#ifndef BLE_CONN_STATE_BLE_OBSERVER_PRIO
#define BLE_CONN_STATE_BLE_OBSERVER_PRIO 0
// &amp;lt;o&amp;gt; BLE_CSCS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Cycling Speed and Cadence Service.
#ifndef BLE_CSCS_BLE_OBSERVER_PRIO
#define BLE_CSCS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_CTS_C_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Current Time Service Client.
#ifndef BLE_CTS_C_BLE_OBSERVER_PRIO
#define BLE_CTS_C_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_DB_DISC_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Database Discovery module.
#ifndef BLE_DB_DISC_BLE_OBSERVER_PRIO
#define BLE_DB_DISC_BLE_OBSERVER_PRIO 1
// &amp;lt;o&amp;gt; BLE_DFU_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the DFU Service.
#ifndef BLE_DFU_BLE_OBSERVER_PRIO
#define BLE_DFU_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_DIS_C_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Device Information Client.
#ifndef BLE_DIS_C_BLE_OBSERVER_PRIO
#define BLE_DIS_C_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_GLS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Glucose Service.
#ifndef BLE_GLS_BLE_OBSERVER_PRIO
#define BLE_GLS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_HIDS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Human Interface Device Service.
#ifndef BLE_HIDS_BLE_OBSERVER_PRIO
#define BLE_HIDS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_HRS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Heart Rate Service.
#ifndef BLE_HRS_BLE_OBSERVER_PRIO
#define BLE_HRS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_HRS_C_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Heart Rate Service Client.
#ifndef BLE_HRS_C_BLE_OBSERVER_PRIO
#define BLE_HRS_C_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_HTS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Health Thermometer Service.
#ifndef BLE_HTS_BLE_OBSERVER_PRIO
#define BLE_HTS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_IAS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Immediate Alert Service.
#ifndef BLE_IAS_BLE_OBSERVER_PRIO
#define BLE_IAS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_IAS_C_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Immediate Alert Service Client.
#ifndef BLE_IAS_C_BLE_OBSERVER_PRIO
#define BLE_IAS_C_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_LBS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the LED Button Service.
#ifndef BLE_LBS_BLE_OBSERVER_PRIO
#define BLE_LBS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_LBS_C_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the LED Button Service Client.
#ifndef BLE_LBS_C_BLE_OBSERVER_PRIO
#define BLE_LBS_C_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_LLS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Link Loss Service.
#ifndef BLE_LLS_BLE_OBSERVER_PRIO
#define BLE_LLS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_LNS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Location Navigation Service.
#ifndef BLE_LNS_BLE_OBSERVER_PRIO
#define BLE_LNS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_NUS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the UART Service.
#ifndef BLE_NUS_BLE_OBSERVER_PRIO
#define BLE_NUS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_NUS_C_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the UART Central Service.
#ifndef BLE_NUS_C_BLE_OBSERVER_PRIO
#define BLE_NUS_C_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_OTS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Object transfer service.
#ifndef BLE_OTS_BLE_OBSERVER_PRIO
#define BLE_OTS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_OTS_C_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Object transfer service client.
#ifndef BLE_OTS_C_BLE_OBSERVER_PRIO
#define BLE_OTS_C_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_RSCS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Running Speed and Cadence Service.
#ifndef BLE_RSCS_BLE_OBSERVER_PRIO
#define BLE_RSCS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_RSCS_C_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Running Speed and Cadence Client.
#ifndef BLE_RSCS_C_BLE_OBSERVER_PRIO
#define BLE_RSCS_C_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BLE_TPS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the TX Power Service.
#ifndef BLE_TPS_BLE_OBSERVER_PRIO
#define BLE_TPS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; BSP_BTN_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Button Control module.
#ifndef BSP_BTN_BLE_OBSERVER_PRIO
#define BSP_BTN_BLE_OBSERVER_PRIO 1
// &amp;lt;o&amp;gt; NFC_BLE_PAIR_LIB_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the NFC pairing library.
#ifndef NFC_BLE_PAIR_LIB_BLE_OBSERVER_PRIO
#define NFC_BLE_PAIR_LIB_BLE_OBSERVER_PRIO 1
// &amp;lt;o&amp;gt; NRF_BLE_BMS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Bond Management Service.
#ifndef NRF_BLE_BMS_BLE_OBSERVER_PRIO
#define NRF_BLE_BMS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; NRF_BLE_CGMS_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Contiuon Glucose Monitoring Service.
#ifndef NRF_BLE_CGMS_BLE_OBSERVER_PRIO
#define NRF_BLE_CGMS_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; NRF_BLE_ES_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Eddystone module.
#ifndef NRF_BLE_ES_BLE_OBSERVER_PRIO
#define NRF_BLE_ES_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; NRF_BLE_GATTS_C_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the GATT Service Client.
#ifndef NRF_BLE_GATTS_C_BLE_OBSERVER_PRIO
#define NRF_BLE_GATTS_C_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; NRF_BLE_GATT_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the GATT module.
#ifndef NRF_BLE_GATT_BLE_OBSERVER_PRIO
#define NRF_BLE_GATT_BLE_OBSERVER_PRIO 1
// &amp;lt;o&amp;gt; NRF_BLE_GQ_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the GATT Queue module.
#ifndef NRF_BLE_GQ_BLE_OBSERVER_PRIO
#define NRF_BLE_GQ_BLE_OBSERVER_PRIO 1
// &amp;lt;o&amp;gt; NRF_BLE_QWR_BLE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which BLE events are dispatched to the Queued writes module.
#ifndef NRF_BLE_QWR_BLE_OBSERVER_PRIO
#define NRF_BLE_QWR_BLE_OBSERVER_PRIO 2
// &amp;lt;o&amp;gt; NRF_BLE_SCAN_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority for dispatching the BLE events to the Scanning Module.
#ifndef NRF_BLE_SCAN_OBSERVER_PRIO
#define NRF_BLE_SCAN_OBSERVER_PRIO 1
// &amp;lt;o&amp;gt; PM_BLE_OBSERVER_PRIO - Priority with which BLE events are dispatched to the Peer Manager module. 
#ifndef PM_BLE_OBSERVER_PRIO
#define PM_BLE_OBSERVER_PRIO 1
// &amp;lt;e&amp;gt; NRF_SDH_ENABLED - nrf_sdh - SoftDevice handler
#ifndef NRF_SDH_ENABLED
#define NRF_SDH_ENABLED 1
// &amp;lt;h&amp;gt; Dispatch model 
// &amp;lt;i&amp;gt; This setting configures how Stack events are dispatched to the application.
// &amp;lt;o&amp;gt; NRF_SDH_DISPATCH_MODEL
// &amp;lt;i&amp;gt; NRF_SDH_DISPATCH_MODEL_INTERRUPT: SoftDevice events are passed to the application from the interrupt context.
// &amp;lt;i&amp;gt; NRF_SDH_DISPATCH_MODEL_APPSH: SoftDevice events are scheduled using @ref app_scheduler.
// &amp;lt;i&amp;gt; NRF_SDH_DISPATCH_MODEL_POLLING: SoftDevice events are to be fetched manually.
// &amp;lt;0=&amp;gt; NRF_SDH_DISPATCH_MODEL_INTERRUPT 
// &amp;lt;1=&amp;gt; NRF_SDH_DISPATCH_MODEL_APPSH 
// &amp;lt;2=&amp;gt; NRF_SDH_DISPATCH_MODEL_POLLING 
#ifndef NRF_SDH_DISPATCH_MODEL
#define NRF_SDH_DISPATCH_MODEL 0
// &amp;lt;h&amp;gt; Clock - SoftDevice clock configuration
// &amp;lt;o&amp;gt; NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
// &amp;lt;0=&amp;gt; NRF_CLOCK_LF_SRC_RC 
// &amp;lt;1=&amp;gt; NRF_CLOCK_LF_SRC_XTAL 
// &amp;lt;2=&amp;gt; NRF_CLOCK_LF_SRC_SYNTH 
#ifndef NRF_SDH_CLOCK_LF_SRC
#define NRF_SDH_CLOCK_LF_SRC 0
// &amp;lt;o&amp;gt; NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval. 
#ifndef NRF_SDH_CLOCK_LF_RC_CTIV
#if NRF_SDH_CLOCK_LF_SRC == 0
#define NRF_SDH_CLOCK_LF_RC_CTIV 16
#else
#define NRF_SDH_CLOCK_LF_RC_CTIV 0
// &amp;lt;o&amp;gt; NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature. 
// &amp;lt;i&amp;gt; How often (in number of calibration intervals) the RC oscillator shall be calibrated
// &amp;lt;i&amp;gt;  if the temperature has not changed.
#ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
#define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
#else
#define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 0
// &amp;lt;o&amp;gt; NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
// &amp;lt;0=&amp;gt; NRF_CLOCK_LF_ACCURACY_250_PPM 
// &amp;lt;1=&amp;gt; NRF_CLOCK_LF_ACCURACY_500_PPM 
// &amp;lt;2=&amp;gt; NRF_CLOCK_LF_ACCURACY_150_PPM 
// &amp;lt;3=&amp;gt; NRF_CLOCK_LF_ACCURACY_100_PPM 
// &amp;lt;4=&amp;gt; NRF_CLOCK_LF_ACCURACY_75_PPM 
// &amp;lt;5=&amp;gt; NRF_CLOCK_LF_ACCURACY_50_PPM 
// &amp;lt;6=&amp;gt; NRF_CLOCK_LF_ACCURACY_30_PPM 
// &amp;lt;7=&amp;gt; NRF_CLOCK_LF_ACCURACY_20_PPM 
// &amp;lt;8=&amp;gt; NRF_CLOCK_LF_ACCURACY_10_PPM 
// &amp;lt;9=&amp;gt; NRF_CLOCK_LF_ACCURACY_5_PPM 
// &amp;lt;10=&amp;gt; NRF_CLOCK_LF_ACCURACY_2_PPM 
// &amp;lt;11=&amp;gt; NRF_CLOCK_LF_ACCURACY_1_PPM 
#ifndef NRF_SDH_CLOCK_LF_ACCURACY
#define NRF_SDH_CLOCK_LF_ACCURACY 1
#else
#define NRF_SDH_CLOCK_LF_ACCURACY 7
// &amp;lt;h&amp;gt; SDH Observers - Observers and priority levels
// &amp;lt;o&amp;gt; NRF_SDH_REQ_OBSERVER_PRIO_LEVELS - Total number of priority levels for request observers. 
// &amp;lt;i&amp;gt; This setting configures the number of priority levels available for the SoftDevice request event handlers.
#ifndef NRF_SDH_REQ_OBSERVER_PRIO_LEVELS
#define NRF_SDH_REQ_OBSERVER_PRIO_LEVELS 2
// &amp;lt;o&amp;gt; NRF_SDH_STATE_OBSERVER_PRIO_LEVELS - Total number of priority levels for state observers. 
// &amp;lt;i&amp;gt; This setting configures the number of priority levels available for the SoftDevice state event handlers.
#ifndef NRF_SDH_STATE_OBSERVER_PRIO_LEVELS
#define NRF_SDH_STATE_OBSERVER_PRIO_LEVELS 2
// &amp;lt;o&amp;gt; NRF_SDH_STACK_OBSERVER_PRIO_LEVELS - Total number of priority levels for stack event observers. 
// &amp;lt;i&amp;gt; This setting configures the number of priority levels available for the SoftDevice stack event handlers (ANT, BLE, SoC).
#ifndef NRF_SDH_STACK_OBSERVER_PRIO_LEVELS
#define NRF_SDH_STACK_OBSERVER_PRIO_LEVELS 2
// &amp;lt;h&amp;gt; State Observers priorities - Invididual priorities
// &amp;lt;o&amp;gt; CLOCK_CONFIG_STATE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which state events are dispatched to the Clock driver.
#ifndef CLOCK_CONFIG_STATE_OBSERVER_PRIO
#define CLOCK_CONFIG_STATE_OBSERVER_PRIO 0
// &amp;lt;o&amp;gt; POWER_CONFIG_STATE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which state events are dispatched to the Power driver.
#ifndef POWER_CONFIG_STATE_OBSERVER_PRIO
#define POWER_CONFIG_STATE_OBSERVER_PRIO 0
// &amp;lt;o&amp;gt; RNG_CONFIG_STATE_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which state events are dispatched to this module.
#ifndef RNG_CONFIG_STATE_OBSERVER_PRIO
#define RNG_CONFIG_STATE_OBSERVER_PRIO 0
// &amp;lt;h&amp;gt; Stack Event Observers priorities - Invididual priorities
// &amp;lt;o&amp;gt; NRF_SDH_ANT_STACK_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; This setting configures the priority with which ANT events are processed with respect to other events coming from the stack.
// &amp;lt;i&amp;gt; Modify this setting if you need to have ANT events dispatched before or after other stack events, such as BLE or SoC.
// &amp;lt;i&amp;gt; Zero is the highest priority.
#ifndef NRF_SDH_ANT_STACK_OBSERVER_PRIO
#define NRF_SDH_ANT_STACK_OBSERVER_PRIO 0
// &amp;lt;o&amp;gt; NRF_SDH_BLE_STACK_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; This setting configures the priority with which BLE events are processed with respect to other events coming from the stack.
// &amp;lt;i&amp;gt; Modify this setting if you need to have BLE events dispatched before or after other stack events, such as ANT or SoC.
#ifndef NRF_SDH_BLE_STACK_OBSERVER_PRIO
#define NRF_SDH_BLE_STACK_OBSERVER_PRIO 0
// &amp;lt;o&amp;gt; NRF_SDH_SOC_STACK_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; This setting configures the priority with which SoC events are processed with respect to other events coming from the stack.
// &amp;lt;i&amp;gt; Modify this setting if you need to have SoC events dispatched before or after other stack events, such as ANT or BLE.
#ifndef NRF_SDH_SOC_STACK_OBSERVER_PRIO
#define NRF_SDH_SOC_STACK_OBSERVER_PRIO 0
// &amp;lt;e&amp;gt; NRF_SDH_SOC_ENABLED - nrf_sdh_soc - SoftDevice SoC event handler
#ifndef NRF_SDH_SOC_ENABLED
#define NRF_SDH_SOC_ENABLED 1
// &amp;lt;h&amp;gt; SoC Observers - Observers and priority levels
// &amp;lt;o&amp;gt; NRF_SDH_SOC_OBSERVER_PRIO_LEVELS - Total number of priority levels for SoC observers. 
// &amp;lt;i&amp;gt; This setting configures the number of priority levels available for the SoC event handlers.
#ifndef NRF_SDH_SOC_OBSERVER_PRIO_LEVELS
#define NRF_SDH_SOC_OBSERVER_PRIO_LEVELS 2
// &amp;lt;h&amp;gt; SoC Observers priorities - Invididual priorities
// &amp;lt;o&amp;gt; BLE_DFU_SOC_OBSERVER_PRIO  
#ifndef BLE_DFU_SOC_OBSERVER_PRIO
#define BLE_DFU_SOC_OBSERVER_PRIO 1
// &amp;lt;o&amp;gt; CLOCK_CONFIG_SOC_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which SoC events are dispatched to the Clock driver.
#ifndef CLOCK_CONFIG_SOC_OBSERVER_PRIO
#define CLOCK_CONFIG_SOC_OBSERVER_PRIO 0
// &amp;lt;o&amp;gt; POWER_CONFIG_SOC_OBSERVER_PRIO  
// &amp;lt;i&amp;gt; Priority with which SoC events are dispatched to the Power driver.
#ifndef POWER_CONFIG_SOC_OBSERVER_PRIO
#define POWER_CONFIG_SOC_OBSERVER_PRIO 0
// &amp;lt;&amp;lt;&amp;lt; end of configuration section &amp;gt;&amp;gt;&amp;gt;
#endif //SDK_CONFIG_H
&lt;/pre&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: After adding dfu, gpio 0.00 pin control is not available.</title><link>https://devzone.nordicsemi.com/thread/449185?ContentTypeID=1</link><pubDate>Fri, 06 Oct 2023 13:30:18 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8a7e9f16-3bb3-4385-984c-014c46a6ec5b</guid><dc:creator>Amanda Hsieh</dc:creator><description>&lt;p&gt;Hi,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;span dir="ltr"&gt;Do you change the LF clock to RC in the bootloader as well?&amp;nbsp;&lt;/span&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;-Amanda H.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: After adding dfu, gpio 0.00 pin control is not available.</title><link>https://devzone.nordicsemi.com/thread/448908?ContentTypeID=1</link><pubDate>Thu, 05 Oct 2023 02:01:06 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:230a720b-c0dc-4448-83a5-85c0404ffb2c</guid><dc:creator>JILUNGIE</dc:creator><description>&lt;p&gt;Thank you for your answer. The nRF52 SDK version you are using is nRF5_SDK_17.1.0_ddde560. &lt;br /&gt;I&amp;#39;m using the gpio0.00 pin as a power retention function, and if the value of the 0.00 pin is 1, the power is maintained, and if the value is 0, the power is off.&lt;br /&gt;The gpio0.00 pin worked well before adding dfu, but after adding dfu, the output of the gpio0.00 pin does not work normally.&lt;/p&gt;
&lt;p&gt;Except for gpio0.00, the rest of the features seem to work well.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Below is the output of the debug terminal.&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;&amp;lt;info&amp;gt; PRS: Function: nrfx_prs_acquire, error code: NRF_SUCCESS.
&amp;lt;info&amp;gt; CLOCK: Function: nrfx_clock_init, error code: NRF_SUCCESS.
&amp;lt;info&amp;gt; CLOCK: Module enabled.
&amp;lt;info&amp;gt; clock: Function: nrf_drv_clock_init, error code: NRF_SUCCESS.
&amp;lt;info&amp;gt; app: Setting vector table to bootloader: 0x00078000
&amp;lt;info&amp;gt; app: Setting vector table to main app: 0x00026000
&amp;lt;info&amp;gt; app_timer: RTC: initialized.
&amp;lt;info&amp;gt; pwr_mgmt: Init
&amp;lt;debug&amp;gt; CLOCK: Event: NRF_CLOCK_EVENT_LFCLKSTARTED.
&amp;lt;info&amp;gt; GPIOTE: Function: nrfx_gpiote_in_init, error code: NRF_SUCCESS.
&amp;lt;debug&amp;gt; nrf_sdh: State request: 0x00000000
&amp;lt;debug&amp;gt; nrf_sdh: Notify observer 0x00038EF4 =&amp;gt; ready
&amp;lt;debug&amp;gt; nrf_sdh: State change: 0x00000000
&amp;lt;debug&amp;gt; nrf_sdh: State change: 0x00000001
&amp;lt;debug&amp;gt; nrf_sdh_ble: RAM starts at 0x20002AE8
&amp;lt;info&amp;gt; app: Advertising...
&amp;lt;debug&amp;gt; app: advertising is started
&amp;lt;info&amp;gt; app: BAT LEVEL : 2068
&amp;lt;info&amp;gt; app: Volate Level : 35
&amp;lt;info&amp;gt; app: BAT LEVEL : 2172
&amp;lt;info&amp;gt; app: Volate Level : 46
&amp;lt;info&amp;gt; app: BAT LEVEL : 2177
&amp;lt;info&amp;gt; app: Volate Level : 47
&amp;lt;info&amp;gt; app: PWR ON
&amp;lt;info&amp;gt; app: BAT LEVEL : 2175
&amp;lt;info&amp;gt; app: BAT LEVEL : 2176
&amp;lt;info&amp;gt; app: Volate Level : 47&lt;/pre&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: After adding dfu, gpio 0.01 pin control is not available.</title><link>https://devzone.nordicsemi.com/thread/448885?ContentTypeID=1</link><pubDate>Wed, 04 Oct 2023 16:45:33 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:ebffbdfe-1cab-4854-8bb9-1575f749383f</guid><dc:creator>Amanda Hsieh</dc:creator><description>&lt;p&gt;Hi,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Which nRF5 SDK version are you using?&lt;/p&gt;
[quote user=""]I added the dfu function in the firmware I&amp;#39;m testing, and the gpio0.01 pin is out of control.[/quote]
&lt;p&gt;What do you mean by &amp;quot;out of control&amp;quot;? Please elaborate in more detail. Does it work as expected before you&amp;nbsp;&lt;span&gt;add the DFU function?&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;Do you get any error logs? Please provide the device log if it is possible.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;Regards,&lt;br /&gt;Amanda H.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
