<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Thingy91 - ADXL362 noise and range issue</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/104379/thingy91---adxl362-noise-and-range-issue</link><description>I am evaluating the accelerometers on the thingy91, and got a couple of questions i hope someone can answer.
 Using the accel_polling example i am reading the ADXL362 values. I noticed a large noise on the values. In the image below the thing91 is</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Thu, 05 Oct 2023 12:07:23 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/104379/thingy91---adxl362-noise-and-range-issue" /><item><title>RE: Thingy91 - ADXL362 noise and range issue</title><link>https://devzone.nordicsemi.com/thread/449000?ContentTypeID=1</link><pubDate>Thu, 05 Oct 2023 12:07:23 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:23585d66-0dd4-414b-856f-680e99dde1f6</guid><dc:creator>Huba</dc:creator><description>&lt;p&gt;&lt;span&gt;You were correct; running the accelerometer from the battery does result in improved accelerometer stability. I&amp;nbsp;did a simple test by having the LED blink whenever a specific threshold was&amp;nbsp;exceeded to confirm this.&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Thingy91 - ADXL362 noise and range issue</title><link>https://devzone.nordicsemi.com/thread/448995?ContentTypeID=1</link><pubDate>Thu, 05 Oct 2023 11:53:31 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:6245f08a-7915-47af-9d62-0108cfc22351</guid><dc:creator>Kenneth</dc:creator><description>[quote user="Huba"]As per the datasheet, the Thingy91 features a 1MB flash and 256kB of RAM. Are you aware of any sample code or examples that demonstrate how to save accelerometer data using this device?[/quote]
&lt;p&gt;Please make a new case for this, as I am not able to look into this at the moment.&lt;/p&gt;
&lt;p&gt;Kenneth&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Thingy91 - ADXL362 noise and range issue</title><link>https://devzone.nordicsemi.com/thread/448930?ContentTypeID=1</link><pubDate>Thu, 05 Oct 2023 06:53:22 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d45cc1b3-6379-49f7-91c0-747d783c3bc9</guid><dc:creator>Huba</dc:creator><description>&lt;p&gt;That&amp;#39;s a valid observation regarding the power supply. I initially powered it via USB, but I&amp;#39;ll experiment with running it on battery power instead. Consequently, I&amp;#39;ll need to implement data storage to retain the information for later analysis in order to assess its stability.&lt;/p&gt;
&lt;p&gt;As per the datasheet, the Thingy91 features a 1MB flash and 256kB of RAM. Are you aware of any sample code or examples that demonstrate how to save accelerometer data using this device?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Thingy91 - ADXL362 noise and range issue</title><link>https://devzone.nordicsemi.com/thread/448893?ContentTypeID=1</link><pubDate>Wed, 04 Oct 2023 19:27:24 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b7f1a1c5-3087-4eed-ad79-947687a6b59a</guid><dc:creator>Kenneth</dc:creator><description>&lt;p&gt;I would likely have checked with Analog Devices if they have any suggestion.&lt;/p&gt;
&lt;p&gt;Looking at an old case some years back I can find some readings were shared, this at least show less variation than you share:&lt;br /&gt;&lt;a href="https://devzone.nordicsemi.com/f/nordic-q-a/69176/adxl362-calibration"&gt;https://devzone.nordicsemi.com/f/nordic-q-a/69176/adxl362-calibration&lt;/a&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;I assume the surface the thingy is placed on is stable, so the other thing I would have checked then is the power supply; USB supplies are noisy, so running from battery during this test is likely a good idea (if you are not already).&lt;/p&gt;
&lt;p&gt;Kenneth&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
