<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>How to change the field names on a Garmin device using the PDA10056 DK</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/104393/how-to-change-the-field-names-on-a-garmin-device-using-the-pda10056-dk</link><description>I am working on a project to send AQI (Air Quality Index) readings to a Garmin cycle computer.(EDGE830) using the PDA10056 &amp;amp; PDA10049 Development kits
 To get me up and running I am using the HeartRate example provided in the SDK,
 The heart rate information</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 06 Oct 2023 08:37:18 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/104393/how-to-change-the-field-names-on-a-garmin-device-using-the-pda10056-dk" /><item><title>RE: How to change the field names on a Garmin device using the PDA10056 DK</title><link>https://devzone.nordicsemi.com/thread/449131?ContentTypeID=1</link><pubDate>Fri, 06 Oct 2023 08:37:18 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:29c18d4c-b199-408c-a8af-765db88842ac</guid><dc:creator>Chiprobot</dc:creator><description>&lt;p&gt;That seems to make sense with regards to the UUID. Thanks for your info BTW&lt;/p&gt;
&lt;p&gt;My First Solution (which works)&amp;nbsp; :-&lt;/p&gt;
&lt;p&gt;You can add extra content to the Garmin devices, using Connect IQ apps.&lt;/p&gt;
&lt;p&gt;I found an app called Appbuilder 5+ (which has to be loaded into the Garmin) , this allows you to control extra data Fields to the Garmin (the plus thing with this is that allows me to direct the ant+ TX_ed Air Quality Index data (which is really pretending to be heart rate data) and more importantly adjust the displayed label ( out with heart rate and in with AQI).&lt;/p&gt;
&lt;p&gt;This is not the best solution, however it does work, until I work out the UUID for an i2c ENS160/AHT2x AQI module.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: How to change the field names on a Garmin device using the PDA10056 DK</title><link>https://devzone.nordicsemi.com/thread/449002?ContentTypeID=1</link><pubDate>Thu, 05 Oct 2023 12:08:43 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:80cf5e32-0e6e-4536-9230-9a42ea9b569a</guid><dc:creator>Hung Bui</dc:creator><description>&lt;p&gt;Hi,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;I&amp;#39;m not so familiar with the Garmin device, so I don&amp;#39;t know how you create a &amp;quot;side app&amp;quot; on the Garmin device.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;The &amp;quot;&lt;span&gt;Heart Rate&amp;quot; text you see on the Garmin device is most likely comes from the Heart Rate Service &amp;amp; Characteristic UUID that you use in the heart rate example.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;The Garmin device is designed so that it will look for the Heart Rate service (by looking at the UUID) and then read the value and display it as &amp;quot;Heart Rate&amp;quot; value. So I don&amp;#39;t see an easy way you can manipulate the device to display something else.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: How to change the field names on a Garmin device using the PDA10056 DK</title><link>https://devzone.nordicsemi.com/thread/448952?ContentTypeID=1</link><pubDate>Thu, 05 Oct 2023 09:00:34 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:cbdceb83-51b5-4293-80bd-adde2fa6732c</guid><dc:creator>Chiprobot</dc:creator><description>&lt;p&gt;I am beginning to think the displayed field names are allocated from the Garmin its self.... (i.e. so do not appear in the segger nrf code files).&amp;nbsp;&lt;/p&gt;
&lt;p&gt;If this is the case then I just need to a create a &amp;quot;side app&amp;quot; field in the Garmin to port the AQI with appropriate display label.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;I am still hope_ing its still possible within the segger nrf code initiation - it would make life a tad easier.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
