<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Running my nRF52840 DK from a Li-Po</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/104549/running-my-nrf52840-dk-from-a-li-po</link><description>Hi there,
 I&amp;#39;m attempting to run my nRF52840 DK from a Li-Po plugged into the port on the DK. I plug it in, set SW9 to Li-Po, then switch the power switch, SW8, ON. It does not run my script (I have a central that picks up it&amp;#39;s advertisements, and it</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Mon, 16 Oct 2023 12:12:49 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/104549/running-my-nrf52840-dk-from-a-li-po" /><item><title>RE: Running my nRF52840 DK from a Li-Po</title><link>https://devzone.nordicsemi.com/thread/450556?ContentTypeID=1</link><pubDate>Mon, 16 Oct 2023 12:12:49 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:398b8476-c0df-427d-bd06-ff5a9e408329</guid><dc:creator>Naeem Maroof</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;I am not sure if it is okay or not, but as per our documentation the SW9 should be in Li-Po position if we want to use the power from J6/P27 (Li-po battery), and then as the high voltage regulator is used, the VDD_nRF voltage can be set by the firmware of the SoC.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Running my nRF52840 DK from a Li-Po</title><link>https://devzone.nordicsemi.com/thread/450365?ContentTypeID=1</link><pubDate>Fri, 13 Oct 2023 15:23:51 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:626f66f7-b85e-4872-b7c8-6c6f6e681b75</guid><dc:creator>swood</dc:creator><description>&lt;p&gt;Thank you, Naeem! It works when I don&amp;#39;t put SW9&amp;nbsp;in the Li-Po position. Is this okay, instead of changing the value on the UICR (something something control register?)?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Running my nRF52840 DK from a Li-Po</title><link>https://devzone.nordicsemi.com/thread/450361?ContentTypeID=1</link><pubDate>Fri, 13 Oct 2023 15:18:39 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:dcafdae3-354f-445d-a4bb-40dd8a8db670</guid><dc:creator>Naeem Maroof</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Thank you for your patience.&lt;/p&gt;
&lt;p&gt;Li-po is to be connected to J6 connector. It should be chaged, but as you are&amp;nbsp;checking voltage from P27, and it is 3.8V, doesn&amp;#39;t look like any charging issue.&lt;/p&gt;
&lt;p&gt;SW9 should be in li-on position and then we turn on the DK using SW8.&lt;/p&gt;
&lt;p&gt;The nRF52840DK has a 5V boost regulator. It gives a stable output from Li-Po (J6) connectors.&lt;/p&gt;
&lt;p&gt;The nRF52840 SoC has a high voltage buck regulator that can support up to 5 V input. When the SW9 in in li-po position, the high voltage regulator of the SoC is supplied directly from the Li-Po batter (J6). REGOUT0 register in the UICR contains the value for Output Voltage from REG0 regulator (high-voltage regulator) stage. Its default value is 1.8V.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;BR, Naeem&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Running my nRF52840 DK from a Li-Po</title><link>https://devzone.nordicsemi.com/thread/449970?ContentTypeID=1</link><pubDate>Thu, 12 Oct 2023 07:56:31 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b326981b-3e1b-4ad0-9265-0ee84d56981f</guid><dc:creator>Naeem Maroof</dc:creator><description>&lt;p&gt;Hi Steph,&lt;/p&gt;
&lt;p&gt;I have been assigned this ticket, and I will look into it and will respond to you accordingly.&lt;/p&gt;
&lt;p&gt;Thank you for being patient.&lt;/p&gt;
&lt;p&gt;BR, Naeem&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
