<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>SAADC &amp;amp; PA LNA not working at a time</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/104897/saadc-pa-lna-not-working-at-a-time</link><description>Hi
 I am using Fanstel bt832x1 module as peripheral. I have to send analog value at channel 0 to central ( nrf connect app). I use SKYWORKS SKY66112-11 power amplifier for maximum range. As per the SKY66112_PAconfig.txt provided by FANSTEL Corporation</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 27 Oct 2023 08:54:30 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/104897/saadc-pa-lna-not-working-at-a-time" /><item><title>RE: SAADC &amp; PA LNA not working at a time</title><link>https://devzone.nordicsemi.com/thread/452740?ContentTypeID=1</link><pubDate>Fri, 27 Oct 2023 08:54:30 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:07a40350-6226-4485-8395-6459272e858b</guid><dc:creator>Karl Ylvisaker</dc:creator><description>&lt;p&gt;Hello Rahul Chavan,&lt;/p&gt;
[quote user="Rahul C"]I will check what&amp;#39;s issue. I required some time. After that i will inform you sir.[/quote]
&lt;p&gt;No problem at all - we will continue this whenever you get the chance, just let me know! :)&amp;nbsp;&lt;br /&gt;&lt;br /&gt;Best regards,&lt;br /&gt;Karl&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: SAADC &amp; PA LNA not working at a time</title><link>https://devzone.nordicsemi.com/thread/452694?ContentTypeID=1</link><pubDate>Fri, 27 Oct 2023 04:28:58 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:961c8344-8af6-42f9-83df-e07f79601e8c</guid><dc:creator>Rahul C</dc:creator><description>&lt;p&gt;&lt;span&gt;Hi Karl Ylvisaker Sir,&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&amp;nbsp; Thanks for support. I will check what&amp;#39;s issue. I required some time. After that i will inform you sir.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&amp;nbsp;Once again Thanks you Sir for support.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Thanks &amp;amp; Regards&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Rahul Chavan&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: SAADC &amp; PA LNA not working at a time</title><link>https://devzone.nordicsemi.com/thread/452265?ContentTypeID=1</link><pubDate>Wed, 25 Oct 2023 12:26:04 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:287b6264-d2c8-4ba6-84ad-229f788702e7</guid><dc:creator>Karl Ylvisaker</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
[quote user="Rahul C"]Thanks for your response.[/quote]
&lt;p&gt;No problem at all, I am happy to help! :)&amp;nbsp;&lt;/p&gt;
[quote user="Rahul C"]&lt;p&gt;In&amp;nbsp;&lt;span&gt;Fanstel bt832x1 module as per datasheet pin number P06 ,P17, P19 pins are used for PA. I configure&amp;nbsp;P02 pin for adc input, so&amp;nbsp;not any pins overlapping. &lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&amp;nbsp; Their is any other issue? any solution available?&lt;/span&gt;&lt;/p&gt;[/quote]
&lt;p&gt;Hmm, seeing as how the SAADC is working as expected until you call the pa_lna_setup function I would look into what that function is doing behind the scenes to see if it could be affecting the SAADC in any way.&lt;br /&gt;Are there any particular loggings or similar that occurs when you do the pa_lna_setup?&lt;br /&gt;&lt;br /&gt;If not, then I would suggest that you raise this question to Fanstel directly, since this is something they&amp;#39;ve made for use with their modules.&lt;br /&gt;&lt;br /&gt;Best regards,&lt;br /&gt;Karl&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: SAADC &amp; PA LNA not working at a time</title><link>https://devzone.nordicsemi.com/thread/452124?ContentTypeID=1</link><pubDate>Wed, 25 Oct 2023 03:43:20 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:ab422d2b-5acf-4f96-b2b8-1b2f6e497822</guid><dc:creator>Rahul C</dc:creator><description>&lt;p&gt;Hi Karl Ylvisaker Sir,&lt;/p&gt;
&lt;p&gt;&amp;nbsp; &amp;nbsp; Thanks for your response. In&amp;nbsp;&lt;span&gt;Fanstel bt832x1 module as per datasheet pin number P06 ,P17, P19 pins are used for PA. I configure&amp;nbsp;P02 pin for adc input, so&amp;nbsp;not any pins overlapping. &lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&amp;nbsp; Their is any other issue? any solution available?&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: SAADC &amp; PA LNA not working at a time</title><link>https://devzone.nordicsemi.com/thread/451508?ContentTypeID=1</link><pubDate>Fri, 20 Oct 2023 12:42:36 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:c429bddc-e313-4505-826f-173beb810ba4</guid><dc:creator>Karl Ylvisaker</dc:creator><description>&lt;p&gt;Hello,&lt;br /&gt;&lt;br /&gt;I must preface this by saying that I do not have any personal experience working with the&amp;nbsp;&lt;span&gt;Fanstel bt832x1 module, but it sounds to me like there might be an overlap in configuration/Pin usage, so that when you enable the FEM it will repurpose the SAADC pins you already had configured, and so your SAADC reads stops working.&lt;br /&gt;&lt;br /&gt;Do you have a datasheet for the module in which you could check what pins that the Fanstel module will use for its own functionality?&lt;br /&gt;&lt;br /&gt;Best regards,&lt;br /&gt;Karl&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
