<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>FOTA of Thingy 91 does not take effect after uploading</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/105100/fota-of-thingy-91-does-not-take-effect-after-uploading</link><description>Hello Everyone,
 I&amp;#39;m working on implementing FOTA (Firmware Over-the-Air) updates for a Thingy 91 device. Specifically, I want to transition from connecting to the NRF Cloud to using the LwM2M Coiote server.
 Manually flashing the firmware with a J</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 27 Oct 2023 13:21:52 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/105100/fota-of-thingy-91-does-not-take-effect-after-uploading" /><item><title>RE: FOTA of Thingy 91 does not take effect after uploading</title><link>https://devzone.nordicsemi.com/thread/452800?ContentTypeID=1</link><pubDate>Fri, 27 Oct 2023 13:21:52 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:c8b30f27-423f-44b4-a0d3-8c98623b9bf4</guid><dc:creator>Didrik Rokhaug</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;As &lt;a href="https://devzone.nordicsemi.com/members/wisph"&gt;wisph&lt;/a&gt; said, does the new application run once, but on the next reboot it reverts back to the old application?&lt;/p&gt;
&lt;p&gt;Or does the new application simply never run?&lt;/p&gt;
&lt;p&gt;Are you using the default bootloader on the Thingy:91?&lt;/p&gt;
&lt;p&gt;If you have overwritten the default bootloader, you can try to add a static flash partitioning file to ensure that the flash partitions doesn&amp;#39;t change between the builds.&lt;/p&gt;
&lt;p&gt;See the documentation for more information:&lt;/p&gt;
&lt;p&gt;&lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.4.0/nrf/scripts/partition_manager/partition_manager.html#static-configuration"&gt;https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.4.0/nrf/scripts/partition_manager/partition_manager.html#static-configuration&lt;/a&gt;&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Didrik&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: FOTA of Thingy 91 does not take effect after uploading</title><link>https://devzone.nordicsemi.com/thread/452737?ContentTypeID=1</link><pubDate>Fri, 27 Oct 2023 08:49:02 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:e96aa9ec-6a2f-4193-bbc2-8e346920bd6c</guid><dc:creator>wisph</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;First order of business would be to make sure the OTA update is installed AND RETAINED.&lt;/p&gt;
&lt;p&gt;The last part is what cought me once, the ota installs, boots and reports happiness.. Tho on the first next boot, the image got reverted.&lt;br /&gt;Turned out; the image_confirmed bit did not get written to the correct place, in our case this was because: we changed SDK &amp;amp; changed filesystem configuration.&lt;/p&gt;
&lt;p&gt;Hope it helps.&lt;/p&gt;
&lt;p&gt;Grts,&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
