<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>VDDHDIV5 with Normal Voltage Mode</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/105164/vddhdiv5-with-normal-voltage-mode</link><description>My circuit use nRF52833 I connected VDDH to the battery and VDD to LDO along with other devices
 The original expectation was to use VDDHDIV5 to save the circuit and IO required to measure the battery voltage. It worked fine at first, until the battery</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 14 Nov 2023 11:42:08 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/105164/vddhdiv5-with-normal-voltage-mode" /><item><title>RE: VDDHDIV5 with Normal Voltage Mode</title><link>https://devzone.nordicsemi.com/thread/455501?ContentTypeID=1</link><pubDate>Tue, 14 Nov 2023 11:42:08 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:4b0ca73b-3efa-4ae2-a7a3-2b1ee11ca6a1</guid><dc:creator>JONATHAN LL</dc:creator><description>[quote user="SmallBee"]1. In order to ensure startup in HV mode, is it useful to delay the startup time of LDO?[/quote]
&lt;p&gt;The external LDO should not have its output connected to the nRF52833 VDD pins when the nRF52833 is to run in High voltage mode.&amp;nbsp;&lt;br /&gt;When the nRF52833 is in High voltage mode then VDD pins on the nRF52833 is an output.&amp;nbsp;&amp;nbsp;&lt;br /&gt;&lt;br /&gt;&lt;br /&gt;&lt;/p&gt;
[quote user="SmallBee"]2. If it is useful, how many milliseconds should I maintain the gap in how many volts?[/quote]
&lt;p&gt;It is not really recommended to supply power to VDD in this way so would not consider this useful.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Regards,&lt;br /&gt;Jonathan&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: VDDHDIV5 with Normal Voltage Mode</title><link>https://devzone.nordicsemi.com/thread/454565?ContentTypeID=1</link><pubDate>Wed, 08 Nov 2023 03:53:08 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8fabd18b-569a-4002-bff9-17705ff1a8e6</guid><dc:creator>SmallBee</dc:creator><description>&lt;p&gt;1. In order to ensure startup in HV mode, is it useful to delay the startup time of LDO?&lt;/p&gt;
&lt;p&gt;2. If it is useful, how many milliseconds should I maintain the gap in how many volts?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: VDDHDIV5 with Normal Voltage Mode</title><link>https://devzone.nordicsemi.com/thread/454515?ContentTypeID=1</link><pubDate>Tue, 07 Nov 2023 15:06:22 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:148a11e9-19b8-47a5-8925-c78663189397</guid><dc:creator>Kazi Afroza Sultana</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;yes, I can see from the diagram that when VBAT is not powered enough to connect VDDH the high voltage mode is turned to normal voltage mode. In our PS, it is not explicitly mentioned that &amp;#39;&amp;#39;VDDHDIV5 can not be used in norma voltage mode&amp;#39;&amp;#39;. This undefined behavior works in your case does not mean we recommend doing this.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: VDDHDIV5 with Normal Voltage Mode</title><link>https://devzone.nordicsemi.com/thread/453408?ContentTypeID=1</link><pubDate>Wed, 01 Nov 2023 03:43:20 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:e254f050-9f3b-4ebb-972a-307bd8d6c87b</guid><dc:creator>SmallBee</dc:creator><description>&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1698810128193v1.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;This is a simplified circuit&lt;/p&gt;
&lt;p&gt;When the system boots with VUSB power&lt;br /&gt;If VBAT is too low, it may cause the system to start in Normal Voltage Mode.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: VDDHDIV5 with Normal Voltage Mode</title><link>https://devzone.nordicsemi.com/thread/453241?ContentTypeID=1</link><pubDate>Tue, 31 Oct 2023 11:37:14 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:72e070cd-ef01-4951-9b5f-d1b895edbc92</guid><dc:creator>Kazi Afroza Sultana</dc:creator><description>&lt;p&gt;Some addition to my previous comment- You can&amp;nbsp;&lt;span&gt;&lt;span class="ui-provider ef bdx azq bri brj brk brl brm brn bro brp brq brr brs brt bru brv brw brx bry brz bsa bsb bsc bsd bse bsf bsg bsh bsi bsj bsk bsl bsm bsn" dir="ltr"&gt;provide some examples of the measurements you are making in either case, along with the configuration you are using for the SAADC. I guess there may be some issue with the input output voltage range.&lt;/span&gt;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: VDDHDIV5 with Normal Voltage Mode</title><link>https://devzone.nordicsemi.com/thread/453212?ContentTypeID=1</link><pubDate>Tue, 31 Oct 2023 09:55:35 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:ef6aa1d4-fb01-4da4-9df9-81e3303e4d09</guid><dc:creator>Kazi Afroza Sultana</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;&amp;#39;&amp;#39;&lt;span&gt;I connected VDDH to the battery and VDD to LDO along with other devices&amp;#39;&amp;#39;.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;You are using high voltage mode. What do you mean by saying &amp;#39;&amp;#39;VDD to LDO along with other&amp;nbsp;devices&amp;#39;&amp;#39;. Do you mean VDD is connected to REG0?&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&amp;#39;&amp;#39;But the magic is if I enable VDD as input source in another ADC CH&lt;br /&gt;The value of VDDHDIV5 becomes normal.&amp;#39;&amp;#39; - Plese explain this also elaborately.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Thanks.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;BR&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Kazi&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
