<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>nRF Cloud internal failure whilst deploying FOTA</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/105401/nrf-cloud-internal-failure-whilst-deploying-fota</link><description>I&amp;#39;ve created a new firmware image for an nRF9160 device in the field. I can create the application bundle okay, but when I deploy the update, after around 30s nRFcloud just cancels the update with the details &amp;#39;Internal failure occurred&amp;#39;. Job Executions</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Wed, 22 Nov 2023 01:56:58 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/105401/nrf-cloud-internal-failure-whilst-deploying-fota" /><item><title>RE: nRF Cloud internal failure whilst deploying FOTA</title><link>https://devzone.nordicsemi.com/thread/456801?ContentTypeID=1</link><pubDate>Wed, 22 Nov 2023 01:56:58 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:10bc306d-337c-4ad8-85e0-0f6317adb574</guid><dc:creator>Lincoln Thomas</dc:creator><description>&lt;p&gt;Ok, thanks for the follow-up. We will close this issue and watch for similar issues.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF Cloud internal failure whilst deploying FOTA</title><link>https://devzone.nordicsemi.com/thread/456796?ContentTypeID=1</link><pubDate>Tue, 21 Nov 2023 23:30:41 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:77fe61b8-4075-4c31-99ed-6a7a1319beb6</guid><dc:creator>RossJ</dc:creator><description>&lt;p&gt;Thanks Lincoln for looking into this further. I&amp;#39;m certain that there was one device in the group as I had just created the group and assigned the device to it expressly to do the FOTA. The group still exists and still has the device in it. I agree that the error reported is likely due to there being no device left in the upgrade since the summary list of upgrades shows 0/0. However, I suspect the device was dropped from the upgrade for some reason which resulted in there being no devices left in the upgrade. Just why the device was &amp;#39;dropped&amp;#39; I can&amp;#39;t say. Perhaps something about the device was deemed incompatible with the upgrade being requested?&lt;br /&gt;&lt;br /&gt;Anyway, probably little point investigating this further as the problem seems to have gone away after I rebuilt (in a different way) and reprogrammed the starting version of the FOTA upgrade. I could try to reproduce it again if that&amp;#39;s of any value. But I&amp;#39;m happy to just let this go.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF Cloud internal failure whilst deploying FOTA</title><link>https://devzone.nordicsemi.com/thread/456792?ContentTypeID=1</link><pubDate>Tue, 21 Nov 2023 22:55:18 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:fbd009b4-590d-4f41-a4c6-ce8b726ae234</guid><dc:creator>Lincoln Thomas</dc:creator><description>&lt;p&gt;One way you can get into that state is if the group you&amp;#39;ve defined for a FOTA job no longer has any devices in it. For example, you can delete devices from a group after creating (but not starting) a FOTA job. We will change the error message to say something like &amp;ldquo;No devices in the group &amp;lt;groupname&amp;gt;, therefore no updates to apply.&amp;rdquo; Could this be what happened to you?&lt;/p&gt;
&lt;p&gt;We haven&amp;#39;t found out anything else in our records for your FOTA jobs that explain what happened.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF Cloud internal failure whilst deploying FOTA</title><link>https://devzone.nordicsemi.com/thread/454806?ContentTypeID=1</link><pubDate>Thu, 09 Nov 2023 00:44:48 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:1b33f8bf-09bc-40f3-a261-c252c1194567</guid><dc:creator>RossJ</dc:creator><description>&lt;p&gt;Hi Charlie,&lt;br /&gt;&lt;br /&gt;After successfully upgrading a different device (AX720), I had another attempt at upgrading the original device (AX700) which failed again with the same internal failure message (see attached screenshot). I then reprogrammed the firmware of AX700 using the Programmer tool instead of VSCode. This time the firmware upgrade via nRF Cloud succeeded.&lt;br /&gt;&lt;br /&gt;I still believe there is a fault of some kind with nRF Cloud, as it should never be reporting an &amp;#39;internal failure&amp;#39; for any reason. Presumably there&amp;#39;s a server log detailing the exact cause. I have a thought as to what might be partly responsible for this... I can see from the Firmware Updates screen that the update is shown as 0/0 successful devices. Is it possible that something led to the one and only device not being accepted, then the update contained zero devices, leading to an internal server error? Of course this doesn&amp;#39;t explain why the server had a problem with the original firmware of AX700.&lt;br /&gt;&lt;br /&gt;So this problem appears to be only impacting my development unit (not devices in the field), and then probably something about how it got programmed in VSCode. While I have previously used VSCode to program all other devices, this time I was pulling up an older version to test the upgrade. Perhaps I did something wrong when setting it up in VSCode. Anyway, I don&amp;#39;t think there&amp;#39;s anything further to investigate from my point of view. You may still want to catch whatever was causing the internal error though.&lt;br /&gt;&lt;br /&gt;FWIW... My devices are customer hardware/firmware running on nRF9160 SICA B1 using SDK 2.3.0. All tools are updated to the latest.&lt;br /&gt;&lt;br /&gt;Regards, Ross&lt;/p&gt;
&lt;p&gt;&lt;br /&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/Screenshot-_2800_1042_2900_.png" /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF Cloud internal failure whilst deploying FOTA</title><link>https://devzone.nordicsemi.com/thread/454381?ContentTypeID=1</link><pubDate>Tue, 07 Nov 2023 09:56:54 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b37569f8-2990-41b6-a4a1-15927b50f40c</guid><dc:creator>Charlie</dc:creator><description>&lt;p&gt;Hi Ross,&lt;/p&gt;
&lt;p&gt;Thanks for your update. Just let me know if you need more help.&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Charlie&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF Cloud internal failure whilst deploying FOTA</title><link>https://devzone.nordicsemi.com/thread/454221?ContentTypeID=1</link><pubDate>Mon, 06 Nov 2023 13:38:06 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:4e03c47c-d553-4b99-9ad7-3938fdccba54</guid><dc:creator>RossJ</dc:creator><description>&lt;p&gt;Hi Charlie,&lt;/p&gt;
&lt;p&gt;An hour or so ago I decided to have a go again but with a different device. I used the same bundle but created another group with the second device in it. I then created and deployed an update and it worked correctly. I&amp;#39;ll have another go with the original device tomorrow. Either the problem was specific to that one device or the server problem went away over the few hours since I last tried it. I&amp;#39;ll let you know what I find.&lt;/p&gt;
&lt;p&gt;Cheers, Ross&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF Cloud internal failure whilst deploying FOTA</title><link>https://devzone.nordicsemi.com/thread/454214?ContentTypeID=1</link><pubDate>Mon, 06 Nov 2023 13:30:32 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a8d6a7a1-52c1-4026-86c0-878aba1b5827</guid><dc:creator>Charlie</dc:creator><description>&lt;p&gt;Hi Ross,&lt;/p&gt;
&lt;p&gt;Could you provide more details about your test with deploying FOTA? Like the sample you are trying, version, HW, and logs.&lt;/p&gt;
&lt;p&gt;Did you play with&amp;nbsp;&lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.5.0/nrf/samples/cellular/nrf_cloud_rest_fota/README.html"&gt;Cellular: nRF Cloud REST FOTA — nRF Connect SDK 2.5.0 documentation (nordicsemi.com)&lt;/a&gt;&amp;nbsp;successfully?&lt;/p&gt;
&lt;p&gt;I did a quick try with this sample and it work as expected, here is the log, you can see the App version changed from 1.0.0 to&amp;nbsp;v1.0.0-FOTA-TEST.&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;*** Booting nRF Connect SDK v2.5.0 ***
[00:00:00.257,995] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: nRF Cloud REST FOTA Sample, version: 1.0.0
[00:00:00.505,920] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Application Name: nRF_Cloud_REST_FOTA_Sample
[00:00:00.514,526] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: nRF Connect SDK version: v2.5.0
[00:00:00.614,105] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Device ID: 504b5839-3738-xxxxxxxxxxxxxx
[00:00:00.623,046] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Waiting for network...
+CEREG: 2,&amp;quot;81A3&amp;quot;,&amp;quot;03238D05&amp;quot;,7
+CSCON: 1
+CEREG: 1,&amp;quot;81A3&amp;quot;,&amp;quot;03238D05&amp;quot;,7,0,2,&amp;quot;11100000&amp;quot;,&amp;quot;11100000&amp;quot;
[00:00:02.405,670] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Connected
[00:00:02.443,572] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Modem FW Ver: mfw_nrf9160_1.3.5
[00:00:02.451,080] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Waiting for modem to acquire network time...
[00:00:05.466,400] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Network time obtained
[00:00:05.550,933] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Sending device status...
[00:00:07.901,306] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA enabled in device shadow
[00:00:07.996,520] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Checking for FOTA job...
[00:00:08.509,277] &amp;lt;err&amp;gt; nrf_cloud_codec_internal: REST error msg: No pending [IN_PROGRESS or QUEUED] jobs found for device id 504b5839-3738-4e52-807f-1125f8a66a1e
[00:00:08.524,658] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: No pending FOTA job
[00:00:08.532,775] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Retrying in 15 minute(s) or when button 1 is pressed
+CSCON: 0
[00:04:24.697,875] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Checking for FOTA job...
+CSCON: 1
[00:04:25.918,243] &amp;lt;err&amp;gt; nrf_cloud_codec_internal: REST error msg: No pending [IN_PROGRESS or QUEUED] jobs found for device id 504b5839-3738-4e52-807f-1125f8a66a1e
[00:04:25.933,593] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: No pending FOTA job
[00:04:25.941,375] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Retrying in 15 minute(s) or when button 1 is pressed
+CSCON: 0
[00:04:57.174,865] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Checking for FOTA job...
+CSCON: 1
[00:04:58.305,603] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA Job: 90c0e225-1e1f-4f33-bba1-981538fe9efe, type: 0
[00:04:58.315,765] &amp;lt;inf&amp;gt; download_client: Downloading: ef22cbf0-d0f3-487d-abf7-cd66804aaa30/APP*d22549f7*v1.0.0-FOTA-TEST/app_update.bin [0]
[00:04:58.437,530] &amp;lt;inf&amp;gt; download_client: Setting up TLS credentials, sec tag count 1
[00:04:58.445,831] &amp;lt;inf&amp;gt; download_client: Connecting to firmware.nrfcloud.com
[00:05:00.621,398] &amp;lt;inf&amp;gt; download_client: Downloaded 1400/212003 bytes (0%)
[00:05:00.726,440] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 0
[00:05:00.955,596] &amp;lt;inf&amp;gt; download_client: Downloaded 2800/212003 bytes (1%)
[00:05:00.980,285] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 1
[00:05:01.168,701] &amp;lt;inf&amp;gt; download_client: Downloaded 4200/212003 bytes (1%)
[00:05:01.193,389] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 1
[00:05:01.390,716] &amp;lt;inf&amp;gt; download_client: Downloaded 5600/212003 bytes (2%)
[00:05:01.495,574] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 2
[00:05:01.638,732] &amp;lt;inf&amp;gt; download_client: Downloaded 7000/212003 bytes (3%)
[00:05:01.663,208] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 3
[00:05:01.798,767] &amp;lt;inf&amp;gt; download_client: Downloaded 8400/212003 bytes (3%)
[00:05:01.823,272] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 3
[00:05:01.944,671] &amp;lt;inf&amp;gt; download_client: Downloaded 9800/212003 bytes (4%)
[00:05:02.055,084] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 4
[00:05:02.187,744] &amp;lt;inf&amp;gt; download_client: Downloaded 11200/212003 bytes (5%)
[00:05:02.206,665] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 5
[00:05:02.332,824] &amp;lt;inf&amp;gt; download_client: Downloaded 12600/212003 bytes (5%)
[00:05:02.357,482] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 5
[00:05:02.500,823] &amp;lt;inf&amp;gt; download_client: Downloaded 14000/212003 bytes (6%)
[00:05:02.611,358] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 6
[00:05:02.733,825] &amp;lt;inf&amp;gt; download_client: Downloaded 15400/212003 bytes (7%)
[00:05:02.758,575] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 7
[00:05:02.904,724] &amp;lt;inf&amp;gt; download_client: Downloaded 16800/212003 bytes (7%)
[00:05:02.923,706] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 7
[00:05:03.059,936] &amp;lt;inf&amp;gt; download_client: Downloaded 18200/212003 bytes (8%)
[00:05:03.170,410] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 8
[00:05:03.317,810] &amp;lt;inf&amp;gt; download_client: Downloaded 19600/212003 bytes (9%)
[00:05:03.342,376] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 9
[00:05:03.457,824] &amp;lt;inf&amp;gt; download_client: Downloaded 21000/212003 bytes (9%)
[00:05:03.568,481] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 9
[00:05:03.694,915] &amp;lt;inf&amp;gt; download_client: Downloaded 22400/212003 bytes (10%)
[00:05:03.713,897] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 10
[00:05:03.850,830] &amp;lt;inf&amp;gt; download_client: Downloaded 23800/212003 bytes (11%)
[00:05:03.875,427] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 11
[00:05:04.022,949] &amp;lt;inf&amp;gt; download_client: Downloaded 25200/212003 bytes (11%)
[00:05:04.133,605] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 11
[00:05:04.267,883] &amp;lt;inf&amp;gt; download_client: Downloaded 26600/212003 bytes (12%)
[00:05:04.286,926] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 12
[00:05:04.413,757] &amp;lt;inf&amp;gt; download_client: Downloaded 28000/212003 bytes (13%)
[00:05:04.438,415] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 13
[00:05:04.613,006] &amp;lt;inf&amp;gt; download_client: Downloaded 29400/212003 bytes (13%)
[00:05:04.723,571] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 13
[00:05:04.917,877] &amp;lt;inf&amp;gt; download_client: Downloaded 30800/212003 bytes (14%)
[00:05:04.942,718] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 14
[00:05:05.057,891] &amp;lt;inf&amp;gt; download_client: Downloaded 32200/212003 bytes (15%)
[00:05:05.076,934] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 15
[00:05:05.218,017] &amp;lt;inf&amp;gt; download_client: Downloaded 33600/212003 bytes (15%)
[00:05:05.328,643] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 15
[00:05:05.468,811] &amp;lt;inf&amp;gt; download_client: Downloaded 35000/212003 bytes (16%)
[00:05:05.493,499] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 16
[00:05:05.628,814] &amp;lt;inf&amp;gt; download_client: Downloaded 36400/212003 bytes (17%)
[00:05:05.653,472] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 17
[00:05:05.795,989] &amp;lt;inf&amp;gt; download_client: Downloaded 37800/212003 bytes (17%)
[00:05:05.901,000] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 17
[00:05:06.129,882] &amp;lt;inf&amp;gt; download_client: Downloaded 39200/212003 bytes (18%)
[00:05:06.154,632] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 18
[00:05:06.361,938] &amp;lt;inf&amp;gt; download_client: Downloaded 40600/212003 bytes (19%)
[00:05:06.386,688] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 19
[00:05:06.519,927] &amp;lt;inf&amp;gt; download_client: Downloaded 42000/212003 bytes (19%)
[00:05:06.630,737] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 19
[00:05:06.830,017] &amp;lt;inf&amp;gt; download_client: Downloaded 43400/212003 bytes (20%)
[00:05:06.849,029] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 20
[00:05:07.054,870] &amp;lt;inf&amp;gt; download_client: Downloaded 44800/212003 bytes (21%)
[00:05:07.079,620] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 21
[00:05:07.230,102] &amp;lt;inf&amp;gt; download_client: Downloaded 46200/212003 bytes (21%)
[00:05:07.340,728] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 21
[00:05:07.542,083] &amp;lt;inf&amp;gt; download_client: Downloaded 47600/212003 bytes (22%)
[00:05:07.561,035] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 22
[00:05:07.719,024] &amp;lt;inf&amp;gt; download_client: Downloaded 49000/212003 bytes (23%)
[00:05:07.743,804] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 23
[00:05:07.879,028] &amp;lt;inf&amp;gt; download_client: Downloaded 50400/212003 bytes (23%)
[00:05:07.989,624] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 23
[00:05:08.190,063] &amp;lt;inf&amp;gt; download_client: Downloaded 51800/212003 bytes (24%)
[00:05:08.214,874] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 24
[00:05:08.359,069] &amp;lt;inf&amp;gt; download_client: Downloaded 53200/212003 bytes (25%)
[00:05:08.378,051] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 25
[00:05:08.509,033] &amp;lt;inf&amp;gt; download_client: Downloaded 54600/212003 bytes (25%)
[00:05:08.619,628] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 25
[00:05:08.818,939] &amp;lt;inf&amp;gt; download_client: Downloaded 56000/212003 bytes (26%)
[00:05:08.843,719] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 26
[00:05:08.993,225] &amp;lt;inf&amp;gt; download_client: Downloaded 57400/212003 bytes (27%)
[00:05:09.017,974] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 27
[00:05:09.138,061] &amp;lt;inf&amp;gt; download_client: Downloaded 58800/212003 bytes (27%)
[00:05:09.243,011] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 27
[00:05:09.382,110] &amp;lt;inf&amp;gt; download_client: Downloaded 60200/212003 bytes (28%)
[00:05:09.406,951] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 28
[00:05:09.553,131] &amp;lt;inf&amp;gt; download_client: Downloaded 61600/212003 bytes (29%)
[00:05:09.577,941] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 29
[00:05:09.698,089] &amp;lt;inf&amp;gt; download_client: Downloaded 63000/212003 bytes (29%)
[00:05:09.808,624] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 29
[00:05:09.933,990] &amp;lt;inf&amp;gt; download_client: Downloaded 64400/212003 bytes (30%)
[00:05:09.952,972] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 30
[00:05:10.088,989] &amp;lt;inf&amp;gt; download_client: Downloaded 65800/212003 bytes (31%)
[00:05:10.113,647] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 31
[00:05:10.255,035] &amp;lt;inf&amp;gt; download_client: Downloaded 67200/212003 bytes (31%)
[00:05:10.365,600] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 31
[00:05:10.495,025] &amp;lt;inf&amp;gt; download_client: Downloaded 68600/212003 bytes (32%)
[00:05:10.514,068] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 32
[00:05:10.653,106] &amp;lt;inf&amp;gt; download_client: Downloaded 70000/212003 bytes (33%)
[00:05:10.677,825] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 33
[00:05:10.814,117] &amp;lt;inf&amp;gt; download_client: Downloaded 71400/212003 bytes (33%)
[00:05:10.924,621] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 33
[00:05:11.054,046] &amp;lt;inf&amp;gt; download_client: Downloaded 72800/212003 bytes (34%)
[00:05:11.078,674] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 34
[00:05:11.215,057] &amp;lt;inf&amp;gt; download_client: Downloaded 74200/212003 bytes (34%)
[00:05:11.234,069] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 34
[00:05:11.374,053] &amp;lt;inf&amp;gt; download_client: Downloaded 75600/212003 bytes (35%)
[00:05:11.484,558] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 35
[00:05:11.613,128] &amp;lt;inf&amp;gt; download_client: Downloaded 77000/212003 bytes (36%)
[00:05:11.637,725] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 36
[00:05:11.775,085] &amp;lt;inf&amp;gt; download_client: Downloaded 78400/212003 bytes (36%)
[00:05:11.885,711] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 36
[00:05:12.012,298] &amp;lt;inf&amp;gt; download_client: Downloaded 79800/212003 bytes (37%)
[00:05:12.031,250] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 37
[00:05:12.195,434] &amp;lt;inf&amp;gt; download_client: Downloaded 81200/212003 bytes (38%)
[00:05:12.220,184] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 38
[00:05:12.333,160] &amp;lt;inf&amp;gt; download_client: Downloaded 82600/212003 bytes (38%)
[00:05:12.443,725] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 38
[00:05:12.573,150] &amp;lt;inf&amp;gt; download_client: Downloaded 84000/212003 bytes (39%)
[00:05:12.597,808] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 39
[00:05:12.744,476] &amp;lt;inf&amp;gt; download_client: Downloaded 85400/212003 bytes (40%)
[00:05:12.763,519] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 40
[00:05:12.893,280] &amp;lt;inf&amp;gt; download_client: Downloaded 86800/212003 bytes (40%)
[00:05:13.003,753] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 40
[00:05:13.135,131] &amp;lt;inf&amp;gt; download_client: Downloaded 88200/212003 bytes (41%)
[00:05:13.159,912] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 41
[00:05:13.295,166] &amp;lt;inf&amp;gt; download_client: Downloaded 89600/212003 bytes (42%)
[00:05:13.319,824] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 42
[00:05:13.455,169] &amp;lt;inf&amp;gt; download_client: Downloaded 91000/212003 bytes (42%)
[00:05:13.560,058] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 42
[00:05:13.722,290] &amp;lt;inf&amp;gt; download_client: Downloaded 92400/212003 bytes (43%)
[00:05:13.747,131] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 43
[00:05:13.869,140] &amp;lt;inf&amp;gt; download_client: Downloaded 93800/212003 bytes (44%)
[00:05:13.893,890] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 44
[00:05:14.253,295] &amp;lt;inf&amp;gt; download_client: Downloaded 95200/212003 bytes (44%)
[00:05:14.358,215] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 44
[00:05:14.522,094] &amp;lt;inf&amp;gt; download_client: Downloaded 96600/212003 bytes (45%)
[00:05:14.546,905] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 45
[00:05:14.671,203] &amp;lt;inf&amp;gt; download_client: Downloaded 98000/212003 bytes (46%)
[00:05:14.695,831] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 46
[00:05:14.840,270] &amp;lt;inf&amp;gt; download_client: Downloaded 99400/212003 bytes (46%)
[00:05:14.950,836] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 46
[00:05:15.149,230] &amp;lt;inf&amp;gt; download_client: Downloaded 100800/212003 bytes (47%)
[00:05:15.168,304] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 47
[00:05:15.327,301] &amp;lt;inf&amp;gt; download_client: Downloaded 102200/212003 bytes (48%)
[00:05:15.352,020] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 48
[00:05:15.565,338] &amp;lt;inf&amp;gt; download_client: Downloaded 103600/212003 bytes (48%)
[00:05:15.676,208] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 48
[00:05:15.884,399] &amp;lt;inf&amp;gt; download_client: Downloaded 105000/212003 bytes (49%)
[00:05:15.909,301] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 49
[00:05:16.042,327] &amp;lt;inf&amp;gt; download_client: Downloaded 106400/212003 bytes (50%)
[00:05:16.061,492] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 50
[00:05:16.194,366] &amp;lt;inf&amp;gt; download_client: Downloaded 107800/212003 bytes (50%)
[00:05:16.305,053] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 50
[00:05:16.522,277] &amp;lt;inf&amp;gt; download_client: Downloaded 109200/212003 bytes (51%)
[00:05:16.547,180] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 51
[00:05:16.682,434] &amp;lt;inf&amp;gt; download_client: Downloaded 110600/212003 bytes (52%)
[00:05:16.707,122] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 52
[00:05:16.833,435] &amp;lt;inf&amp;gt; download_client: Downloaded 112000/212003 bytes (52%)
[00:05:16.938,568] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 52
[00:05:17.156,433] &amp;lt;inf&amp;gt; download_client: Downloaded 113400/212003 bytes (53%)
[00:05:17.181,304] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 53
[00:05:17.347,381] &amp;lt;inf&amp;gt; download_client: Downloaded 114800/212003 bytes (54%)
[00:05:17.372,222] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 54
[00:05:17.568,450] &amp;lt;inf&amp;gt; download_client: Downloaded 116200/212003 bytes (54%)
[00:05:17.673,522] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 54
[00:05:17.898,437] &amp;lt;inf&amp;gt; download_client: Downloaded 117600/212003 bytes (55%)
[00:05:17.923,217] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 55
[00:05:18.120,391] &amp;lt;inf&amp;gt; download_client: Downloaded 119000/212003 bytes (56%)
[00:05:18.145,141] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 56
[00:05:18.271,423] &amp;lt;inf&amp;gt; download_client: Downloaded 120400/212003 bytes (56%)
[00:05:18.382,080] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 56
[00:05:18.610,443] &amp;lt;inf&amp;gt; download_client: Downloaded 121800/212003 bytes (57%)
[00:05:18.629,547] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 57
[00:05:18.768,524] &amp;lt;inf&amp;gt; download_client: Downloaded 123200/212003 bytes (58%)
[00:05:18.793,395] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 58
[00:05:19.002,655] &amp;lt;inf&amp;gt; download_client: Downloaded 124600/212003 bytes (58%)
[00:05:19.113,250] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 58
[00:05:19.310,516] &amp;lt;inf&amp;gt; download_client: Downloaded 126000/212003 bytes (59%)
[00:05:19.335,357] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 59
[00:05:19.479,522] &amp;lt;inf&amp;gt; download_client: Downloaded 127400/212003 bytes (60%)
[00:05:19.498,626] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 60
[00:05:19.623,413] &amp;lt;inf&amp;gt; download_client: Downloaded 128800/212003 bytes (60%)
[00:05:19.734,069] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 60
[00:05:19.867,553] &amp;lt;inf&amp;gt; download_client: Downloaded 130200/212003 bytes (61%)
[00:05:19.892,456] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 61
[00:05:20.029,449] &amp;lt;inf&amp;gt; download_client: Downloaded 131600/212003 bytes (62%)
[00:05:20.140,136] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 62
[00:05:20.367,675] &amp;lt;inf&amp;gt; download_client: Downloaded 133000/212003 bytes (62%)
[00:05:20.386,718] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 62
[00:05:20.507,598] &amp;lt;inf&amp;gt; download_client: Downloaded 134400/212003 bytes (63%)
[00:05:20.532,470] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 63
[00:05:20.668,548] &amp;lt;inf&amp;gt; download_client: Downloaded 135800/212003 bytes (64%)
[00:05:20.779,144] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 64
[00:05:20.982,574] &amp;lt;inf&amp;gt; download_client: Downloaded 137200/212003 bytes (64%)
[00:05:21.001,739] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 64
[00:05:21.133,514] &amp;lt;inf&amp;gt; download_client: Downloaded 138600/212003 bytes (65%)
[00:05:21.158,416] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 65
[00:05:21.295,501] &amp;lt;inf&amp;gt; download_client: Downloaded 140000/212003 bytes (66%)
[00:05:21.406,127] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 66
[00:05:21.533,569] &amp;lt;inf&amp;gt; download_client: Downloaded 141400/212003 bytes (66%)
[00:05:21.558,380] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 66
[00:05:21.695,526] &amp;lt;inf&amp;gt; download_client: Downloaded 142800/212003 bytes (67%)
[00:05:21.714,752] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 67
[00:05:21.872,650] &amp;lt;inf&amp;gt; download_client: Downloaded 144200/212003 bytes (68%)
[00:05:21.983,276] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 68
[00:05:22.183,654] &amp;lt;inf&amp;gt; download_client: Downloaded 145600/212003 bytes (68%)
[00:05:22.208,343] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 68
[00:05:22.348,571] &amp;lt;inf&amp;gt; download_client: Downloaded 147000/212003 bytes (69%)
[00:05:22.373,504] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 69
[00:05:22.499,542] &amp;lt;inf&amp;gt; download_client: Downloaded 148400/212003 bytes (69%)
[00:05:22.604,400] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 69
[00:05:22.983,001] &amp;lt;inf&amp;gt; download_client: Downloaded 149800/212003 bytes (70%)
[00:05:23.007,812] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 70
[00:05:23.158,721] &amp;lt;inf&amp;gt; download_client: Downloaded 151200/212003 bytes (71%)
[00:05:23.183,410] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 71
[00:05:23.335,601] &amp;lt;inf&amp;gt; download_client: Downloaded 152600/212003 bytes (71%)
[00:05:23.446,502] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 71
[00:05:23.642,578] &amp;lt;inf&amp;gt; download_client: Downloaded 154000/212003 bytes (72%)
[00:05:23.661,682] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 72
[00:05:23.795,654] &amp;lt;inf&amp;gt; download_client: Downloaded 155400/212003 bytes (73%)
[00:05:23.820,526] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 73
[00:05:23.969,665] &amp;lt;inf&amp;gt; download_client: Downloaded 156800/212003 bytes (73%)
[00:05:24.080,474] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 73
[00:05:24.280,670] &amp;lt;inf&amp;gt; download_client: Downloaded 158200/212003 bytes (74%)
[00:05:24.299,743] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 74
[00:05:24.450,744] &amp;lt;inf&amp;gt; download_client: Downloaded 159600/212003 bytes (75%)
[00:05:24.475,646] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 75
[00:05:24.689,727] &amp;lt;inf&amp;gt; download_client: Downloaded 161000/212003 bytes (75%)
[00:05:24.800,384] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 75
[00:05:25.000,701] &amp;lt;inf&amp;gt; download_client: Downloaded 162400/212003 bytes (76%)
[00:05:25.025,634] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 76
[00:05:25.193,908] &amp;lt;inf&amp;gt; download_client: Downloaded 163800/212003 bytes (77%)
[00:05:25.212,951] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 77
[00:05:25.435,882] &amp;lt;inf&amp;gt; download_client: Downloaded 165200/212003 bytes (77%)
[00:05:25.546,630] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 77
[00:05:25.789,825] &amp;lt;inf&amp;gt; download_client: Downloaded 166600/212003 bytes (78%)
[00:05:25.814,636] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 78
[00:05:25.978,790] &amp;lt;inf&amp;gt; download_client: Downloaded 168000/212003 bytes (79%)
[00:05:26.003,692] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 79
[00:05:26.206,787] &amp;lt;inf&amp;gt; download_client: Downloaded 169400/212003 bytes (79%)
[00:05:26.311,737] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 79
[00:05:26.528,778] &amp;lt;inf&amp;gt; download_client: Downloaded 170800/212003 bytes (80%)
[00:05:26.553,680] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 80
[00:05:26.751,708] &amp;lt;inf&amp;gt; download_client: Downloaded 172200/212003 bytes (81%)
[00:05:26.776,611] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 81
[00:05:26.911,773] &amp;lt;inf&amp;gt; download_client: Downloaded 173600/212003 bytes (81%)
[00:05:27.022,491] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 81
[00:05:27.226,837] &amp;lt;inf&amp;gt; download_client: Downloaded 175000/212003 bytes (82%)
[00:05:27.245,971] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 82
[00:05:27.388,854] &amp;lt;inf&amp;gt; download_client: Downloaded 176400/212003 bytes (83%)
[00:05:27.413,696] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 83
[00:05:27.538,848] &amp;lt;inf&amp;gt; download_client: Downloaded 177800/212003 bytes (83%)
[00:05:27.649,536] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 83
[00:05:27.789,886] &amp;lt;inf&amp;gt; download_client: Downloaded 179200/212003 bytes (84%)
[00:05:27.814,758] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 84
[00:05:27.964,843] &amp;lt;inf&amp;gt; download_client: Downloaded 180600/212003 bytes (85%)
[00:05:27.984,008] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 85
[00:05:28.105,773] &amp;lt;inf&amp;gt; download_client: Downloaded 182000/212003 bytes (85%)
[00:05:28.216,461] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 85
[00:05:28.366,882] &amp;lt;inf&amp;gt; download_client: Downloaded 183400/212003 bytes (86%)
[00:05:28.391,754] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 86
[00:05:28.597,930] &amp;lt;inf&amp;gt; download_client: Downloaded 184800/212003 bytes (87%)
[00:05:28.617,095] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 87
[00:05:28.738,830] &amp;lt;inf&amp;gt; download_client: Downloaded 186200/212003 bytes (87%)
[00:05:28.849,456] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 87
[00:05:28.998,046] &amp;lt;inf&amp;gt; download_client: Downloaded 187600/212003 bytes (88%)
[00:05:29.022,766] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 88
[00:05:29.158,905] &amp;lt;inf&amp;gt; download_client: Downloaded 189000/212003 bytes (89%)
[00:05:29.269,561] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 89
[00:05:29.472,869] &amp;lt;inf&amp;gt; download_client: Downloaded 190400/212003 bytes (89%)
[00:05:29.491,943] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 89
[00:05:29.631,896] &amp;lt;inf&amp;gt; download_client: Downloaded 191800/212003 bytes (90%)
[00:05:29.656,585] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 90
[00:05:29.791,900] &amp;lt;inf&amp;gt; download_client: Downloaded 193200/212003 bytes (91%)
[00:05:29.902,526] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 91
[00:05:30.136,962] &amp;lt;inf&amp;gt; download_client: Downloaded 194600/212003 bytes (91%)
[00:05:30.161,865] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 91
[00:05:30.353,027] &amp;lt;inf&amp;gt; download_client: Downloaded 196000/212003 bytes (92%)
[00:05:30.372,253] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 92
[00:05:30.502,960] &amp;lt;inf&amp;gt; download_client: Downloaded 197400/212003 bytes (93%)
[00:05:30.613,647] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 93
[00:05:30.751,953] &amp;lt;inf&amp;gt; download_client: Downloaded 198800/212003 bytes (93%)
[00:05:30.776,733] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 93
[00:05:30.929,046] &amp;lt;inf&amp;gt; download_client: Downloaded 200200/212003 bytes (94%)
[00:05:30.953,918] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 94
[00:05:31.159,942] &amp;lt;inf&amp;gt; download_client: Downloaded 201600/212003 bytes (95%)
[00:05:31.264,831] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 95
[00:05:31.463,012] &amp;lt;inf&amp;gt; download_client: Downloaded 203000/212003 bytes (95%)
[00:05:31.487,823] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 95
[00:05:31.631,988] &amp;lt;inf&amp;gt; download_client: Downloaded 204400/212003 bytes (96%)
[00:05:31.656,921] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 96
[00:05:31.791,076] &amp;lt;inf&amp;gt; download_client: Downloaded 205800/212003 bytes (97%)
[00:05:31.895,935] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 97
[00:05:32.040,069] &amp;lt;inf&amp;gt; download_client: Downloaded 207200/212003 bytes (97%)
[00:05:32.064,910] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 97
[00:05:32.192,016] &amp;lt;inf&amp;gt; download_client: Downloaded 208600/212003 bytes (98%)
[00:05:32.216,918] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 98
[00:05:32.351,074] &amp;lt;inf&amp;gt; download_client: Downloaded 210000/212003 bytes (99%)
[00:05:32.461,730] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 99
[00:05:32.683,197] &amp;lt;inf&amp;gt; download_client: Downloaded 211400/212003 bytes (99%)
[00:05:32.702,239] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 99
[00:05:32.795,227] &amp;lt;inf&amp;gt; download_client: Downloaded 212003/212003 bytes (100%)
[00:05:32.814,453] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download percent: 100
[00:05:32.821,472] &amp;lt;inf&amp;gt; download_client: Download complete
[00:05:32.914,184] &amp;lt;inf&amp;gt; dfu_target_mcuboot: MCUBoot image-0 upgrade scheduled. Reset device to apply
[00:05:32.925,537] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA download finished
+CEREG: 0
+CSCON: 0
[00:05:34.748,748] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Rebooting in 10s to complete FOTA update...
Attempting to boot slot 0.
Attempting to boot from address 0x8200.
Verifying signature against key 0.
Hash: 0x81...7e
Firmware signature verified.
Firmware version 1
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Image index: 0, Swap type: test
I: Starting swap using move algorithm.
I: Bootloader chainload address offset: 0x28000
*** Booting Zephyr OS build v3.2.99-ncs1 ***
[00:00:00.494,049] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: nRF Cloud REST FOTA Sample, version: v1.0.0-FOTA-TEST
[00:00:00.503,875] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Saved job: 90c0e225-1e1f-4f33-bba1-981538fe9efe, type: 0, validate: 1, bl: 0x0
[00:00:00.515,563] &amp;lt;inf&amp;gt; nrf_cloud_fota_common: App FOTA update confirmed
[00:00:00.522,735] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Application Name: nRF_Cloud_REST_FOTA_Sample
[00:00:00.531,311] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: nRF Connect SDK version: v2.2.0
[00:00:00.550,964] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Modem FW Ver: mfw_nrf9160_1.3.5
[00:00:00.650,604] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Device ID: 504b5839-3738-xxxxxxxxxx
[00:00:00.659,515] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Waiting for network...
+CSCON: 1
[00:00:02.297,424] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Connected
[00:00:02.303,314] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Waiting for modem to acquire network time...
[00:00:05.312,744] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Network time obtained
[00:00:05.407,043] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Updating FOTA job status...
[00:00:07.851,806] &amp;lt;wrn&amp;gt; rest_client: No data in a response body
[00:00:07.858,459] &amp;lt;inf&amp;gt; rest_client: Socket with id: 0 was kept alive and wasn&amp;#39;t closed
[00:00:07.866,943] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: FOTA job updated, status: 3
[00:00:07.875,213] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Checking for next FOTA update in 30s...
+CSCON: 0
[00:00:37.961,486] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Checking for FOTA job...
+CSCON: 1
[00:00:38.617,462] &amp;lt;inf&amp;gt; rest_client: Socket with id: 0 was kept alive and wasn&amp;#39;t closed
[00:00:38.626,342] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: No pending FOTA job
[00:00:38.634,399] &amp;lt;inf&amp;gt; nrf_cloud_rest_fota: Retrying in 15 minute(s) or when button 1 is pressed&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/2133.FOTA.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;Charlie&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
