<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>PWM parameter settings problems.</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/105494/pwm-parameter-settings-problems</link><description>(1) Is the SDK clock configuration incorrect?
 When configured as shown above with the nrf_drv_pwm_config_t structure:
 I expected the waveform to be:
 1us * 200 = 200us = 5000Hz
 However, when I measured it, it turned out to be 1kHz. Why is that</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Wed, 15 Nov 2023 09:11:26 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/105494/pwm-parameter-settings-problems" /><item><title>RE: PWM parameter settings problems.</title><link>https://devzone.nordicsemi.com/thread/455707?ContentTypeID=1</link><pubDate>Wed, 15 Nov 2023 09:11:26 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:569a9c30-8d0b-42be-b31e-0c50c310dafd</guid><dc:creator>kkuma256</dc:creator><description>&lt;p&gt;I found the cause.&lt;/p&gt;
&lt;p&gt;When using:&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;.load_mode = NRF_PWM_LOAD_COMMON,
&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;the type of &amp;#39;seq_values&amp;#39; set in:&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;.values.p_individual = seq_values,
&lt;p&gt;should also be &amp;#39;nrf_pwm_values_common_t&amp;#39;. I mistakenly set it as &amp;#39;nrf_pwm_values_individual_t&amp;#39;, which caused the reported issue.&lt;/p&gt;
&lt;p&gt;Checking the compile-time warning, it correctly warned:&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;initialization of &amp;#39;const nrf_pwm_values_common_t *&amp;#39; {aka &amp;#39;const short unsigned int *&amp;#39;} from incompatible pointer type &amp;#39;nrf_pwm_values_individual_t *&amp;#39; [-Wincompatible-pointer-types]&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;I should have checked the warning first.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Thank you for your cooperation.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PWM parameter settings problems.</title><link>https://devzone.nordicsemi.com/thread/455695?ContentTypeID=1</link><pubDate>Wed, 15 Nov 2023 07:33:05 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:0b398792-0a65-4550-8f8f-f68fb5092cb8</guid><dc:creator>kkuma256</dc:creator><description>&lt;p&gt;Afterwards, I adjusted the sample program (&amp;#39;pwm_driver&amp;#39;) to work on the &amp;#39;KAGA ES2811AA2&amp;#39; board, and I found that it operates as expected in the sample program.&lt;/p&gt;
&lt;p&gt;However, in the program under development, even with exactly the same parameters, the behavior is different when initializing PWM.&lt;/p&gt;
&lt;p&gt;I confirmed in SES that the values set in the register (0x4001C000) for parameters like PRESCALER, MODE, etc., are exactly the same for both the sample program and my own program.&lt;/p&gt;
&lt;p&gt;Therefore, I can only think of differences in the hardware setup that occurs just before execution. However, I&amp;#39;m not sure where to check.&lt;/p&gt;
&lt;p&gt;If you have any hints or suggestions, I would greatly appreciate it&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PWM parameter settings problems.</title><link>https://devzone.nordicsemi.com/thread/455686?ContentTypeID=1</link><pubDate>Wed, 15 Nov 2023 03:18:07 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:bc2895a2-2ad0-4340-b491-e1359f0ae7c2</guid><dc:creator>kkuma256</dc:creator><description>&lt;p&gt;Thank you for the advice.&lt;/p&gt;
&lt;p&gt;I appreciate your feedback on the structure setting. Indeed, there was a mistake.&lt;/p&gt;
&lt;p&gt;However, even after the correction, the phenomenon did not change.&lt;/p&gt;
&lt;blockquote&gt;
&lt;p&gt;m_demo1_seq_values.channel_0 = 0; stops pwm operation.&lt;/p&gt;
&lt;/blockquote&gt;
&lt;p&gt;This code snippet was mixed in from another sample while experimenting with various things. It was a variable not used in the current application. Just to be sure, I removed it, but the phenomenon did not change.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PWM parameter settings problems.</title><link>https://devzone.nordicsemi.com/thread/455632?ContentTypeID=1</link><pubDate>Tue, 14 Nov 2023 18:27:39 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:ffc8fc26-aacd-4193-861b-6c6303fa413f</guid><dc:creator>hmolesworth</dc:creator><description>&lt;p&gt;Possibly not a major issue, but the code is set to &lt;em&gt;NRF_PWM_LOAD_COMMON&lt;/em&gt;&amp;nbsp;but the data is&amp;nbsp;&lt;em&gt;nrf_pwm_values_individual_t;&lt;/em&gt;&amp;nbsp;&lt;em&gt;nrf_pwm_values_common_t&lt;/em&gt; would be the correct type. Also&amp;nbsp;&lt;em&gt;m_demo1_seq_values.channel_0 = 0&lt;/em&gt;; stops pwm operation ..&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PWM parameter settings problems.</title><link>https://devzone.nordicsemi.com/thread/455622?ContentTypeID=1</link><pubDate>Tue, 14 Nov 2023 17:14:27 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:78b530e2-a9ec-4d59-b4be-216096e45c57</guid><dc:creator>kkuma256</dc:creator><description>&lt;p&gt;&lt;span&gt;Is it ultimately stating that &amp;#39;Switching to NCS is the solution for this matter, and the operation with the older SDK is not guaranteed&amp;#39;?&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PWM parameter settings problems.</title><link>https://devzone.nordicsemi.com/thread/455189?ContentTypeID=1</link><pubDate>Sat, 11 Nov 2023 11:43:11 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:fa2728b5-6861-491e-8bba-5a22154a7122</guid><dc:creator>kkuma256</dc:creator><description>&lt;p&gt;Is the term &amp;quot;complete project code&amp;quot; referring to the &amp;quot;*.emProject&amp;quot; file? It&amp;#39;s not feasible for me to disclose all source code as it&amp;#39;s still in development. I&amp;#39;ll provide any other relevant and shareable information. Additionally, the CPU board is KAGA&amp;#39;s EFI ES2811AA2.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;*.emProject&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;&amp;lt;!DOCTYPE CrossStudio_Project_File&amp;gt;
&amp;lt;solution Name=&amp;quot;PWM&amp;quot; target=&amp;quot;8&amp;quot; version=&amp;quot;2&amp;quot;&amp;gt;
  &amp;lt;configuration
    Name=&amp;quot;Debug&amp;quot;
    c_preprocessor_definitions=&amp;quot;DEBUG; DEBUG_NRF&amp;quot;
    gcc_optimization_level=&amp;quot;None&amp;quot; /&amp;gt;
    Name=&amp;quot;Release&amp;quot;
    c_preprocessor_definitions=&amp;quot;NDEBUG&amp;quot;
    gcc_optimization_level=&amp;quot;Optimize For Size&amp;quot;
    link_time_optimization=&amp;quot;No&amp;quot; /&amp;gt;
  &amp;lt;project Name=&amp;quot;PWM&amp;quot;&amp;gt;
      Name=&amp;quot;Common&amp;quot;
      arm_architecture=&amp;quot;v7EM&amp;quot;
      arm_core_type=&amp;quot;Cortex-M4&amp;quot;
      arm_endian=&amp;quot;Little&amp;quot;
      arm_fp_abi=&amp;quot;Hard&amp;quot;
      arm_fpu_type=&amp;quot;FPv4-SP-D16&amp;quot;
      arm_linker_heap_size=&amp;quot;8192&amp;quot;
      arm_linker_process_stack_size=&amp;quot;0&amp;quot;
      arm_linker_stack_size=&amp;quot;8192&amp;quot;
      arm_linker_treat_warnings_as_errors=&amp;quot;No&amp;quot;
      arm_simulator_memory_simulation_parameter=&amp;quot;RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD&amp;quot;
      arm_target_device_name=&amp;quot;nRF52811_xxAA&amp;quot;
      arm_target_interface_type=&amp;quot;SWD&amp;quot;
      c_preprocessor_definitions=&amp;quot;BOARD_CUSTOM;BSP_DEFINES_ONLY;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52811_XXAA;__HEAP_SIZE__=1024&amp;quot;
      c_user_include_directories=&amp;quot;../../../config;$(NrfSdkDir)/components;$(NrfSdkDir)/components/boards;$(NrfSdkDir)/components/drivers_nrf/nrf_soc_nosd;$(NrfSdkDir)/components/libraries/atomic;$(NrfSdkDir)/components/libraries/balloc;$(NrfSdkDir)/components/libraries/block_dev;$(NrfSdkDir)/components/libraries/block_dev/sdc;$(NrfSdkDir)/components/libraries/bsp;$(NrfSdkDir)/components/libraries/delay;$(NrfSdkDir)/components/libraries/experimental_section_vars;$(NrfSdkDir)/components/libraries/fifo;$(NrfSdkDir)/components/libraries/log;$(NrfSdkDir)/components/libraries/log/src;$(NrfSdkDir)/components/libraries/memobj;$(NrfSdkDir)/components/libraries/ringbuf;$(NrfSdkDir)/components/libraries/sdcard;$(NrfSdkDir)/components/libraries/strerror;$(NrfSdkDir)/components/libraries/uart;$(NrfSdkDir)/components/libraries/util;$(NrfSdkDir)/components/toolchain/cmsis/include;../../..;$(NrfSdkDir)/external/fatfs/port;$(NrfSdkDir)/external/fatfs/src;$(NrfSdkDir)/external/fprintf;$(NrfSdkDir)/external/protothreads;$(NrfSdkDir)/external/protothreads/pt-1.4;$(NrfSdkDir)/external/segger_rtt;$(NrfSdkDir)/integration/nrfx;$(NrfSdkDir)/integration/nrfx/legacy;$(NrfSdkDir)/modules/nrfx;$(NrfSdkDir)/modules/nrfx/drivers/include;$(NrfSdkDir)/modules/nrfx/hal;$(NrfSdkDir)/modules/nrfx/mdk;../config;&amp;quot;
      debug_register_definition_file=&amp;quot;$(NrfSdkDir)/modules/nrfx/mdk/nrf52811.svd&amp;quot;
      debug_start_from_entry_point_symbol=&amp;quot;No&amp;quot;
      debug_target_connection=&amp;quot;J-Link&amp;quot;
      gcc_debugging_level=&amp;quot;Level 3&amp;quot;
      gcc_entry_point=&amp;quot;Reset_Handler&amp;quot;
      linker_output_format=&amp;quot;hex&amp;quot;
      linker_printf_fmt_level=&amp;quot;long&amp;quot;
      linker_printf_width_precision_supported=&amp;quot;Yes&amp;quot;
      linker_scanf_fmt_level=&amp;quot;long&amp;quot;
      linker_section_placement_file=&amp;quot;flash_placement.xml&amp;quot;
      linker_section_placement_macros=&amp;quot;FLASH_PH_START=0x0;FLASH_PH_SIZE=0x30000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x6000;FLASH_START=0x0;FLASH_SIZE=0x30000;RAM_START=0x20000000;RAM_SIZE=0x6000&amp;quot;
      linker_section_placements_segments=&amp;quot;FLASH1 RX 0x0 0x30000;RAM1 RWX 0x20000000 0x6000&amp;quot;
      macros=&amp;quot;CMSIS_CONFIG_TOOL=$(NrfSdkDir)/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar&amp;quot;
      project_directory=&amp;quot;&amp;quot;
      project_type=&amp;quot;Executable&amp;quot; /&amp;gt;
      JLinkLogFileName=&amp;quot;c:\Test\jlink.log&amp;quot;
      arm_fp_abi=&amp;quot;Soft&amp;quot;
      c_preprocessor_definitions=&amp;quot;_USE_LFN=1&amp;quot; /&amp;gt;
    &amp;lt;configuration Name=&amp;quot;Release&amp;quot; arm_fp_abi=&amp;quot;Soft&amp;quot; /&amp;gt;
    &amp;lt;folder Name=&amp;quot;Application&amp;quot;&amp;gt;
      &amp;lt;file file_name=&amp;quot;../../../clock.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;../../../clock.h&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;../../../defines.h&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;../../../global.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;../../../global.h&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;../../../main.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;../../../pwm.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;../../../pwm.h&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;../../../sdcard.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;../../../sdcard.h&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;../config/sdk_config.h&amp;quot; /&amp;gt;
    &amp;lt;/folder&amp;gt;
    &amp;lt;folder Name=&amp;quot;Board Definition&amp;quot;&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/boards/boards.c&amp;quot; /&amp;gt;
    &amp;lt;folder Name=&amp;quot;FATFS&amp;quot;&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/external/fatfs/port/diskio_blkdev.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/external/fatfs/src/ff.c&amp;quot; /&amp;gt;
    &amp;lt;folder Name=&amp;quot;None&amp;quot;&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/mdk/ses_startup_nrf52811.s&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/mdk/ses_startup_nrf_common.s&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/mdk/system_nrf52811.c&amp;quot; /&amp;gt;
    &amp;lt;folder Name=&amp;quot;nRF_Drivers&amp;quot;&amp;gt;
      &amp;lt;folder Name=&amp;quot;Common&amp;quot;&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/soc/nrfx_atomic.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;C:/Program Files/Nordic/nRF5_SDK_17.1.0_ddde560/modules/nrfx/drivers/src/nrfx_systick.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/drivers/src/nrfx_timer.c&amp;quot; /&amp;gt;
      &amp;lt;folder Name=&amp;quot;GPIO&amp;quot;&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/drivers/src/nrfx_gpiote.c&amp;quot; /&amp;gt;
      &amp;lt;folder Name=&amp;quot;PWM&amp;quot;&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/drivers/src/nrfx_pwm.c&amp;quot; /&amp;gt;
      &amp;lt;folder Name=&amp;quot;RTC&amp;quot;&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/integration/nrfx/legacy/nrf_drv_clock.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/drivers_nrf/nrf_soc_nosd/nrf_nvic.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/drivers_nrf/nrf_soc_nosd/nrf_soc.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/drivers/src/nrfx_clock.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/drivers/src/nrfx_rtc.c&amp;quot; /&amp;gt;
      &amp;lt;folder Name=&amp;quot;Saadc&amp;quot;&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/integration/nrfx/legacy/nrf_drv_ppi.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/drivers/src/nrfx_ppi.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/drivers/src/nrfx_saadc.c&amp;quot; /&amp;gt;
      &amp;lt;folder Name=&amp;quot;Storage&amp;quot;&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/integration/nrfx/legacy/nrf_drv_spi.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/integration/nrfx/legacy/nrf_drv_uart.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/drivers/src/prs/nrfx_prs.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/drivers/src/nrfx_spi.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/drivers/src/nrfx_spim.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/drivers/src/nrfx_uart.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/modules/nrfx/drivers/src/nrfx_uarte.c&amp;quot; /&amp;gt;
    &amp;lt;folder Name=&amp;quot;nRF_Libraries&amp;quot;&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/util/app_error.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/util/app_error_handler_gcc.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/util/app_error_weak.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/util/app_util_platform.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/util/nrf_assert.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/atomic/nrf_atomic.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/balloc/nrf_balloc.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/external/fprintf/nrf_fprintf.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/external/fprintf/nrf_fprintf_format.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/memobj/nrf_memobj.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/ringbuf/nrf_ringbuf.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/strerror/nrf_strerror.c&amp;quot; /&amp;gt;
      &amp;lt;folder Name=&amp;quot;RTC&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/fifo/app_fifo.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/sdcard/app_sdcard.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/uart/app_uart_fifo.c&amp;quot; /&amp;gt;
        &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/block_dev/sdc/nrf_block_dev_sdc.c&amp;quot; /&amp;gt;
    &amp;lt;folder Name=&amp;quot;nRF_Log&amp;quot;&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/log/src/nrf_log_backend_rtt.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/log/src/nrf_log_backend_serial.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/log/src/nrf_log_backend_uart.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/log/src/nrf_log_default_backends.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/log/src/nrf_log_frontend.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/components/libraries/log/src/nrf_log_str_formatter.c&amp;quot; /&amp;gt;
    &amp;lt;folder Name=&amp;quot;nRF_Segger_RTT&amp;quot;&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/external/segger_rtt/SEGGER_RTT.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/external/segger_rtt/SEGGER_RTT_printf.c&amp;quot; /&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(NrfSdkDir)/external/segger_rtt/SEGGER_RTT_Syscalls_GCC.c&amp;quot; /&amp;gt;
    &amp;lt;folder Name=&amp;quot;Segger Startup Files&amp;quot;&amp;gt;
      &amp;lt;file file_name=&amp;quot;$(StudioDir)/source/thumb_crt0.s&amp;quot; /&amp;gt;
  &amp;lt;/project&amp;gt;
&amp;lt;/solution&amp;gt;
&lt;p&gt;sdk_config.h&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;/**
 * Copyright (c) 2017 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
 * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA &amp;quot;AS IS&amp;quot; AND ANY EXPRESS
#ifndef SDK_CONFIG_H
#define SDK_CONFIG_H
// &amp;lt;&amp;lt;&amp;lt; Use Configuration Wizard in Context Menu &amp;gt;&amp;gt;&amp;gt;\n
#ifdef USE_APP_CONFIG
#include &amp;quot;app_config.h&amp;quot;
// &amp;lt;h&amp;gt; nRF_Drivers 
// &amp;lt;e&amp;gt; GPIOTE_ENABLED - nrf_drv_gpiote - GPIOTE peripheral driver - legacy layer
#ifndef GPIOTE_ENABLED
#define GPIOTE_ENABLED 1
// &amp;lt;o&amp;gt; GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS - Number of lower power input pins 
#ifndef GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS
#define GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS 1
// &amp;lt;o&amp;gt; GPIOTE_CONFIG_IRQ_PRIORITY  - Interrupt priority
// &amp;lt;i&amp;gt; Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
// &amp;lt;0=&amp;gt; 0 (highest) 
// &amp;lt;1=&amp;gt; 1 
// &amp;lt;2=&amp;gt; 2 
// &amp;lt;3=&amp;gt; 3 
// &amp;lt;4=&amp;gt; 4 
// &amp;lt;5=&amp;gt; 5 
// &amp;lt;6=&amp;gt; 6 
// &amp;lt;7=&amp;gt; 7 
#ifndef GPIOTE_CONFIG_IRQ_PRIORITY
#define GPIOTE_CONFIG_IRQ_PRIORITY 6
// &amp;lt;/e&amp;gt;
// &amp;lt;e&amp;gt; NRFX_GPIOTE_ENABLED - nrfx_gpiote - GPIOTE peripheral driver
#ifndef NRFX_GPIOTE_ENABLED
#define NRFX_GPIOTE_ENABLED 1
// &amp;lt;o&amp;gt; NRFX_GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS - Number of lower power input pins 
#ifndef NRFX_GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS
#define NRFX_GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS 1
// &amp;lt;o&amp;gt; NRFX_GPIOTE_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef NRFX_GPIOTE_CONFIG_IRQ_PRIORITY
#define NRFX_GPIOTE_CONFIG_IRQ_PRIORITY 6
// &amp;lt;e&amp;gt; NRFX_GPIOTE_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_GPIOTE_CONFIG_LOG_ENABLED
#define NRFX_GPIOTE_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_GPIOTE_CONFIG_LOG_LEVEL  - Default Severity level
// &amp;lt;0=&amp;gt; Off 
// &amp;lt;1=&amp;gt; Error 
// &amp;lt;2=&amp;gt; Warning 
// &amp;lt;3=&amp;gt; Info 
// &amp;lt;4=&amp;gt; Debug 
#ifndef NRFX_GPIOTE_CONFIG_LOG_LEVEL
#define NRFX_GPIOTE_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_GPIOTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// &amp;lt;0=&amp;gt; Default 
// &amp;lt;1=&amp;gt; Black 
// &amp;lt;2=&amp;gt; Red 
// &amp;lt;3=&amp;gt; Green 
// &amp;lt;4=&amp;gt; Yellow 
// &amp;lt;5=&amp;gt; Blue 
// &amp;lt;6=&amp;gt; Magenta 
// &amp;lt;7=&amp;gt; Cyan 
// &amp;lt;8=&amp;gt; White 
#ifndef NRFX_GPIOTE_CONFIG_INFO_COLOR
#define NRFX_GPIOTE_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_GPIOTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_GPIOTE_CONFIG_DEBUG_COLOR
#define NRFX_GPIOTE_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRFX_PPI_ENABLED - nrfx_ppi - PPI peripheral allocator
#ifndef NRFX_PPI_ENABLED
#define NRFX_PPI_ENABLED 1
// &amp;lt;e&amp;gt; NRFX_PPI_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_PPI_CONFIG_LOG_ENABLED
#define NRFX_PPI_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_PPI_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_PPI_CONFIG_LOG_LEVEL
#define NRFX_PPI_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_PPI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_PPI_CONFIG_INFO_COLOR
#define NRFX_PPI_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_PPI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_PPI_CONFIG_DEBUG_COLOR
#define NRFX_PPI_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRFX_SAADC_ENABLED - nrfx_saadc - SAADC peripheral driver
#ifndef NRFX_SAADC_ENABLED
#define NRFX_SAADC_ENABLED 1
// &amp;lt;o&amp;gt; NRFX_SAADC_CONFIG_RESOLUTION  - Resolution
// &amp;lt;0=&amp;gt; 8 bit 
// &amp;lt;1=&amp;gt; 10 bit 
// &amp;lt;2=&amp;gt; 12 bit 
// &amp;lt;3=&amp;gt; 14 bit 
#ifndef NRFX_SAADC_CONFIG_RESOLUTION
#define NRFX_SAADC_CONFIG_RESOLUTION 2
// &amp;lt;o&amp;gt; NRFX_SAADC_CONFIG_OVERSAMPLE  - Sample period
// &amp;lt;0=&amp;gt; Disabled 
// &amp;lt;1=&amp;gt; 2x 
// &amp;lt;2=&amp;gt; 4x 
// &amp;lt;3=&amp;gt; 8x 
// &amp;lt;4=&amp;gt; 16x 
// &amp;lt;5=&amp;gt; 32x 
// &amp;lt;6=&amp;gt; 64x 
// &amp;lt;7=&amp;gt; 128x 
// &amp;lt;8=&amp;gt; 256x 
#ifndef NRFX_SAADC_CONFIG_OVERSAMPLE
#define NRFX_SAADC_CONFIG_OVERSAMPLE 0
// &amp;lt;q&amp;gt; NRFX_SAADC_CONFIG_LP_MODE  - Enabling low power mode
#ifndef NRFX_SAADC_CONFIG_LP_MODE
#define NRFX_SAADC_CONFIG_LP_MODE 0
// &amp;lt;o&amp;gt; NRFX_SAADC_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef NRFX_SAADC_CONFIG_IRQ_PRIORITY
// #define NRFX_SAADC_CONFIG_IRQ_PRIORITY 6
#define NRFX_SAADC_CONFIG_IRQ_PRIORITY 1
// &amp;lt;e&amp;gt; NRFX_SAADC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_SAADC_CONFIG_LOG_ENABLED
#define NRFX_SAADC_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_SAADC_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_SAADC_CONFIG_LOG_LEVEL
#define NRFX_SAADC_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_SAADC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_SAADC_CONFIG_INFO_COLOR
#define NRFX_SAADC_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_SAADC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_SAADC_CONFIG_DEBUG_COLOR
#define NRFX_SAADC_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; SAADC_ENABLED - nrf_drv_saadc - SAADC peripheral driver - legacy layer
#ifndef SAADC_ENABLED
#define SAADC_ENABLED 1
// &amp;lt;o&amp;gt; SAADC_CONFIG_RESOLUTION  - Resolution
#ifndef SAADC_CONFIG_RESOLUTION
#define SAADC_CONFIG_RESOLUTION 1
// &amp;lt;o&amp;gt; SAADC_CONFIG_OVERSAMPLE  - Sample period
#ifndef SAADC_CONFIG_OVERSAMPLE
#define SAADC_CONFIG_OVERSAMPLE 0
// &amp;lt;q&amp;gt; SAADC_CONFIG_LP_MODE  - Enabling low power mode
#ifndef SAADC_CONFIG_LP_MODE
#define SAADC_CONFIG_LP_MODE 0
// &amp;lt;o&amp;gt; SAADC_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef SAADC_CONFIG_IRQ_PRIORITY
#define SAADC_CONFIG_IRQ_PRIORITY 6
// &amp;lt;q&amp;gt; NRFX_SYSTICK_ENABLED  - nrfx_systick - ARM(R) SysTick driver
#ifndef NRFX_SYSTICK_ENABLED
#define NRFX_SYSTICK_ENABLED 1
// &amp;lt;q&amp;gt; SYSTICK_ENABLED  - nrf_drv_systick - ARM(R) SysTick driver - legacy layer
#ifndef SYSTICK_ENABLED
#define SYSTICK_ENABLED 1
// &amp;lt;e&amp;gt; NRFX_TIMER_ENABLED - nrfx_timer - TIMER periperal driver
#ifndef NRFX_TIMER_ENABLED
#define NRFX_TIMER_ENABLED 1
// &amp;lt;q&amp;gt; NRFX_TIMER0_ENABLED  - Enable TIMER0 instance
#ifndef NRFX_TIMER0_ENABLED
#define NRFX_TIMER0_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_TIMER1_ENABLED  - Enable TIMER1 instance
#ifndef NRFX_TIMER1_ENABLED
#define NRFX_TIMER1_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_TIMER2_ENABLED  - Enable TIMER2 instance
#ifndef NRFX_TIMER2_ENABLED
#define NRFX_TIMER2_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_TIMER3_ENABLED  - Enable TIMER3 instance
#ifndef NRFX_TIMER3_ENABLED
#define NRFX_TIMER3_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_TIMER4_ENABLED  - Enable TIMER4 instance
#ifndef NRFX_TIMER4_ENABLED
#define NRFX_TIMER4_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_TIMER_DEFAULT_CONFIG_FREQUENCY  - Timer frequency if in Timer mode
// &amp;lt;0=&amp;gt; 16 MHz 
// &amp;lt;1=&amp;gt; 8 MHz 
// &amp;lt;2=&amp;gt; 4 MHz 
// &amp;lt;3=&amp;gt; 2 MHz 
// &amp;lt;4=&amp;gt; 1 MHz 
// &amp;lt;5=&amp;gt; 500 kHz 
// &amp;lt;6=&amp;gt; 250 kHz 
// &amp;lt;7=&amp;gt; 125 kHz 
// &amp;lt;8=&amp;gt; 62.5 kHz 
// &amp;lt;9=&amp;gt; 31.25 kHz 
#ifndef NRFX_TIMER_DEFAULT_CONFIG_FREQUENCY
#define NRFX_TIMER_DEFAULT_CONFIG_FREQUENCY 0
// &amp;lt;o&amp;gt; NRFX_TIMER_DEFAULT_CONFIG_MODE  - Timer mode or operation
// &amp;lt;0=&amp;gt; Timer 
// &amp;lt;1=&amp;gt; Counter 
#ifndef NRFX_TIMER_DEFAULT_CONFIG_MODE
#define NRFX_TIMER_DEFAULT_CONFIG_MODE 0
// &amp;lt;o&amp;gt; NRFX_TIMER_DEFAULT_CONFIG_BIT_WIDTH  - Timer counter bit width
// &amp;lt;0=&amp;gt; 16 bit 
// &amp;lt;1=&amp;gt; 8 bit 
// &amp;lt;2=&amp;gt; 24 bit 
// &amp;lt;3=&amp;gt; 32 bit 
#ifndef NRFX_TIMER_DEFAULT_CONFIG_BIT_WIDTH
#define NRFX_TIMER_DEFAULT_CONFIG_BIT_WIDTH 0
// &amp;lt;o&amp;gt; NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY
#define NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY 6
// &amp;lt;e&amp;gt; NRFX_TIMER_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_TIMER_CONFIG_LOG_ENABLED
#define NRFX_TIMER_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_TIMER_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_TIMER_CONFIG_LOG_LEVEL
#define NRFX_TIMER_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_TIMER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_TIMER_CONFIG_INFO_COLOR
#define NRFX_TIMER_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_TIMER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_TIMER_CONFIG_DEBUG_COLOR
#define NRFX_TIMER_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; TIMER_ENABLED - nrf_drv_timer - TIMER periperal driver - legacy layer
#ifndef TIMER_ENABLED
#define TIMER_ENABLED 1
// &amp;lt;o&amp;gt; TIMER_DEFAULT_CONFIG_FREQUENCY  - Timer frequency if in Timer mode
#ifndef TIMER_DEFAULT_CONFIG_FREQUENCY
#define TIMER_DEFAULT_CONFIG_FREQUENCY 0
// &amp;lt;o&amp;gt; TIMER_DEFAULT_CONFIG_MODE  - Timer mode or operation
#ifndef TIMER_DEFAULT_CONFIG_MODE
#define TIMER_DEFAULT_CONFIG_MODE 0
// &amp;lt;o&amp;gt; TIMER_DEFAULT_CONFIG_BIT_WIDTH  - Timer counter bit width
#ifndef TIMER_DEFAULT_CONFIG_BIT_WIDTH
#define TIMER_DEFAULT_CONFIG_BIT_WIDTH 3
// &amp;lt;o&amp;gt; TIMER_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef TIMER_DEFAULT_CONFIG_IRQ_PRIORITY
#define TIMER_DEFAULT_CONFIG_IRQ_PRIORITY 6
// &amp;lt;q&amp;gt; TIMER0_ENABLED  - Enable TIMER0 instance
#ifndef TIMER0_ENABLED
#define TIMER0_ENABLED 1
// &amp;lt;q&amp;gt; TIMER1_ENABLED  - Enable TIMER1 instance
#ifndef TIMER1_ENABLED
#define TIMER1_ENABLED 0
// &amp;lt;q&amp;gt; TIMER2_ENABLED  - Enable TIMER2 instance
#ifndef TIMER2_ENABLED
#define TIMER2_ENABLED 0
// &amp;lt;q&amp;gt; TIMER3_ENABLED  - Enable TIMER3 instance
#ifndef TIMER3_ENABLED
#define TIMER3_ENABLED 0
// &amp;lt;q&amp;gt; TIMER4_ENABLED  - Enable TIMER4 instance
#ifndef TIMER4_ENABLED
#define TIMER4_ENABLED 0
// &amp;lt;e&amp;gt; NRFX_CLOCK_ENABLED - nrfx_clock - CLOCK peripheral driver
#ifndef NRFX_CLOCK_ENABLED
#define NRFX_CLOCK_ENABLED 1
// &amp;lt;o&amp;gt; NRFX_CLOCK_CONFIG_LF_SRC  - LF Clock Source
// &amp;lt;0=&amp;gt; RC 
// &amp;lt;1=&amp;gt; XTAL 
// &amp;lt;2=&amp;gt; Synth 
// &amp;lt;131073=&amp;gt; External Low Swing 
// &amp;lt;196609=&amp;gt; External Full Swing 
#ifndef NRFX_CLOCK_CONFIG_LF_SRC
#define NRFX_CLOCK_CONFIG_LF_SRC 1
// &amp;lt;o&amp;gt; NRFX_CLOCK_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef NRFX_CLOCK_CONFIG_IRQ_PRIORITY
#define NRFX_CLOCK_CONFIG_IRQ_PRIORITY 6
// &amp;lt;e&amp;gt; NRFX_CLOCK_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_CLOCK_CONFIG_LOG_ENABLED
#define NRFX_CLOCK_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_CLOCK_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_CLOCK_CONFIG_LOG_LEVEL
#define NRFX_CLOCK_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_CLOCK_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_CLOCK_CONFIG_INFO_COLOR
#define NRFX_CLOCK_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_CLOCK_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_CLOCK_CONFIG_DEBUG_COLOR
#define NRFX_CLOCK_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRFX_RTC_ENABLED - nrfx_rtc - RTC peripheral driver
#ifndef NRFX_RTC_ENABLED
#define NRFX_RTC_ENABLED 1
// &amp;lt;q&amp;gt; NRFX_RTC0_ENABLED  - Enable RTC0 instance
#ifndef NRFX_RTC0_ENABLED
#define NRFX_RTC0_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_RTC1_ENABLED  - Enable RTC1 instance
#ifndef NRFX_RTC1_ENABLED
#define NRFX_RTC1_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_RTC2_ENABLED  - Enable RTC2 instance
#ifndef NRFX_RTC2_ENABLED
#define NRFX_RTC2_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_RTC_MAXIMUM_LATENCY_US - Maximum possible time[us] in highest priority interrupt 
#ifndef NRFX_RTC_MAXIMUM_LATENCY_US
#define NRFX_RTC_MAXIMUM_LATENCY_US 2000
// &amp;lt;o&amp;gt; NRFX_RTC_DEFAULT_CONFIG_FREQUENCY - Frequency  &amp;lt;16-32768&amp;gt; 
#ifndef NRFX_RTC_DEFAULT_CONFIG_FREQUENCY
#define NRFX_RTC_DEFAULT_CONFIG_FREQUENCY 32768
// &amp;lt;q&amp;gt; NRFX_RTC_DEFAULT_CONFIG_RELIABLE  - Ensures safe compare event triggering
#ifndef NRFX_RTC_DEFAULT_CONFIG_RELIABLE
#define NRFX_RTC_DEFAULT_CONFIG_RELIABLE 0
// &amp;lt;o&amp;gt; NRFX_RTC_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef NRFX_RTC_DEFAULT_CONFIG_IRQ_PRIORITY
#define NRFX_RTC_DEFAULT_CONFIG_IRQ_PRIORITY 6
// &amp;lt;e&amp;gt; NRFX_RTC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_RTC_CONFIG_LOG_ENABLED
#define NRFX_RTC_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_RTC_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_RTC_CONFIG_LOG_LEVEL
#define NRFX_RTC_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_RTC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_RTC_CONFIG_INFO_COLOR
#define NRFX_RTC_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_RTC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_RTC_CONFIG_DEBUG_COLOR
#define NRFX_RTC_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_CLOCK_ENABLED - nrf_drv_clock - CLOCK peripheral driver - legacy layer
#ifndef NRF_CLOCK_ENABLED
#define NRF_CLOCK_ENABLED 1
// &amp;lt;o&amp;gt; CLOCK_CONFIG_LF_SRC  - LF Clock Source
#ifndef CLOCK_CONFIG_LF_SRC
#define CLOCK_CONFIG_LF_SRC 1
// &amp;lt;q&amp;gt; CLOCK_CONFIG_LF_CAL_ENABLED  - Calibration enable for LF Clock Source
#ifndef CLOCK_CONFIG_LF_CAL_ENABLED
#define CLOCK_CONFIG_LF_CAL_ENABLED 0
// &amp;lt;o&amp;gt; CLOCK_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef CLOCK_CONFIG_IRQ_PRIORITY
#define CLOCK_CONFIG_IRQ_PRIORITY 6
// &amp;lt;e&amp;gt; RTC_ENABLED - nrf_drv_rtc - RTC peripheral driver - legacy layer
#ifndef RTC_ENABLED
#define RTC_ENABLED 1
// &amp;lt;o&amp;gt; RTC_DEFAULT_CONFIG_FREQUENCY - Frequency  &amp;lt;16-32768&amp;gt; 
#ifndef RTC_DEFAULT_CONFIG_FREQUENCY
#define RTC_DEFAULT_CONFIG_FREQUENCY 32768
// &amp;lt;q&amp;gt; RTC_DEFAULT_CONFIG_RELIABLE  - Ensures safe compare event triggering
#ifndef RTC_DEFAULT_CONFIG_RELIABLE
#define RTC_DEFAULT_CONFIG_RELIABLE 0
// &amp;lt;o&amp;gt; RTC_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef RTC_DEFAULT_CONFIG_IRQ_PRIORITY
#define RTC_DEFAULT_CONFIG_IRQ_PRIORITY 6
// &amp;lt;q&amp;gt; RTC0_ENABLED  - Enable RTC0 instance
#ifndef RTC0_ENABLED
#define RTC0_ENABLED 1
// &amp;lt;q&amp;gt; RTC1_ENABLED  - Enable RTC1 instance
#ifndef RTC1_ENABLED
#define RTC1_ENABLED 0
// &amp;lt;q&amp;gt; RTC2_ENABLED  - Enable RTC2 instance
#ifndef RTC2_ENABLED
#define RTC2_ENABLED 0
// &amp;lt;o&amp;gt; NRF_MAXIMUM_LATENCY_US - Maximum possible time[us] in highest priority interrupt 
#ifndef NRF_MAXIMUM_LATENCY_US
#define NRF_MAXIMUM_LATENCY_US 2000
// &amp;lt;e&amp;gt; NRFX_PRS_ENABLED - nrfx_prs - Peripheral Resource Sharing module
#ifndef NRFX_PRS_ENABLED
#define NRFX_PRS_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_PRS_BOX_0_ENABLED  - Enables box 0 in the module.
#ifndef NRFX_PRS_BOX_0_ENABLED
#define NRFX_PRS_BOX_0_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_PRS_BOX_1_ENABLED  - Enables box 1 in the module.
#ifndef NRFX_PRS_BOX_1_ENABLED
#define NRFX_PRS_BOX_1_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_PRS_BOX_2_ENABLED  - Enables box 2 in the module.
#ifndef NRFX_PRS_BOX_2_ENABLED
#define NRFX_PRS_BOX_2_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_PRS_BOX_3_ENABLED  - Enables box 3 in the module.
#ifndef NRFX_PRS_BOX_3_ENABLED
#define NRFX_PRS_BOX_3_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_PRS_BOX_4_ENABLED  - Enables box 4 in the module.
#ifndef NRFX_PRS_BOX_4_ENABLED
#define NRFX_PRS_BOX_4_ENABLED 1
// &amp;lt;e&amp;gt; NRFX_PRS_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_PRS_CONFIG_LOG_ENABLED
#define NRFX_PRS_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_PRS_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_PRS_CONFIG_LOG_LEVEL
#define NRFX_PRS_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_PRS_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_PRS_CONFIG_INFO_COLOR
#define NRFX_PRS_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_PRS_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_PRS_CONFIG_DEBUG_COLOR
#define NRFX_PRS_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRFX_PWM_ENABLED - nrfx_pwm - PWM peripheral driver
#ifndef NRFX_PWM_ENABLED
#define NRFX_PWM_ENABLED 1
// &amp;lt;q&amp;gt; NRFX_PWM0_ENABLED  - Enable PWM0 instance
#ifndef NRFX_PWM0_ENABLED
#define NRFX_PWM0_ENABLED 1
// &amp;lt;q&amp;gt; NRFX_PWM1_ENABLED  - Enable PWM1 instance
#ifndef NRFX_PWM1_ENABLED
#define NRFX_PWM1_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_PWM2_ENABLED  - Enable PWM2 instance
#ifndef NRFX_PWM2_ENABLED
#define NRFX_PWM2_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_PWM3_ENABLED  - Enable PWM3 instance
#ifndef NRFX_PWM3_ENABLED
#define NRFX_PWM3_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_PWM_DEFAULT_CONFIG_OUT0_PIN - Out0 pin  &amp;lt;0-31&amp;gt; 
#ifndef NRFX_PWM_DEFAULT_CONFIG_OUT0_PIN
#define NRFX_PWM_DEFAULT_CONFIG_OUT0_PIN 31
// &amp;lt;o&amp;gt; NRFX_PWM_DEFAULT_CONFIG_OUT1_PIN - Out1 pin  &amp;lt;0-31&amp;gt; 
#ifndef NRFX_PWM_DEFAULT_CONFIG_OUT1_PIN
#define NRFX_PWM_DEFAULT_CONFIG_OUT1_PIN 31
// &amp;lt;o&amp;gt; NRFX_PWM_DEFAULT_CONFIG_OUT2_PIN - Out2 pin  &amp;lt;0-31&amp;gt; 
#ifndef NRFX_PWM_DEFAULT_CONFIG_OUT2_PIN
#define NRFX_PWM_DEFAULT_CONFIG_OUT2_PIN 31
// &amp;lt;o&amp;gt; NRFX_PWM_DEFAULT_CONFIG_OUT3_PIN - Out3 pin  &amp;lt;0-31&amp;gt; 
#ifndef NRFX_PWM_DEFAULT_CONFIG_OUT3_PIN
#define NRFX_PWM_DEFAULT_CONFIG_OUT3_PIN 31
// &amp;lt;o&amp;gt; NRFX_PWM_DEFAULT_CONFIG_BASE_CLOCK  - Base clock
#ifndef NRFX_PWM_DEFAULT_CONFIG_BASE_CLOCK
#define NRFX_PWM_DEFAULT_CONFIG_BASE_CLOCK 4
// &amp;lt;o&amp;gt; NRFX_PWM_DEFAULT_CONFIG_COUNT_MODE  - Count mode
// &amp;lt;0=&amp;gt; Up 
// &amp;lt;1=&amp;gt; Up and Down 
#ifndef NRFX_PWM_DEFAULT_CONFIG_COUNT_MODE
#define NRFX_PWM_DEFAULT_CONFIG_COUNT_MODE 0
// &amp;lt;o&amp;gt; NRFX_PWM_DEFAULT_CONFIG_TOP_VALUE - Top value 
#ifndef NRFX_PWM_DEFAULT_CONFIG_TOP_VALUE
#define NRFX_PWM_DEFAULT_CONFIG_TOP_VALUE 1000
// &amp;lt;o&amp;gt; NRFX_PWM_DEFAULT_CONFIG_LOAD_MODE  - Load mode
// &amp;lt;0=&amp;gt; Common 
// &amp;lt;1=&amp;gt; Grouped 
// &amp;lt;2=&amp;gt; Individual 
// &amp;lt;3=&amp;gt; Waveform 
#ifndef NRFX_PWM_DEFAULT_CONFIG_LOAD_MODE
#define NRFX_PWM_DEFAULT_CONFIG_LOAD_MODE 0
// &amp;lt;o&amp;gt; NRFX_PWM_DEFAULT_CONFIG_STEP_MODE  - Step mode
// &amp;lt;0=&amp;gt; Auto 
// &amp;lt;1=&amp;gt; Triggered 
#ifndef NRFX_PWM_DEFAULT_CONFIG_STEP_MODE
#define NRFX_PWM_DEFAULT_CONFIG_STEP_MODE 0
// &amp;lt;o&amp;gt; NRFX_PWM_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef NRFX_PWM_DEFAULT_CONFIG_IRQ_PRIORITY
#define NRFX_PWM_DEFAULT_CONFIG_IRQ_PRIORITY 6
// &amp;lt;e&amp;gt; NRFX_PWM_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_PWM_CONFIG_LOG_ENABLED
#define NRFX_PWM_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_PWM_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_PWM_CONFIG_LOG_LEVEL
#define NRFX_PWM_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_PWM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_PWM_CONFIG_INFO_COLOR
#define NRFX_PWM_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_PWM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_PWM_CONFIG_DEBUG_COLOR
#define NRFX_PWM_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRFX_SPIM_ENABLED - nrfx_spim - SPIM peripheral driver
#ifndef NRFX_SPIM_ENABLED
#define NRFX_SPIM_ENABLED 1
// &amp;lt;q&amp;gt; NRFX_SPIM0_ENABLED  - Enable SPIM0 instance
#ifndef NRFX_SPIM0_ENABLED
#define NRFX_SPIM0_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_SPIM1_ENABLED  - Enable SPIM1 instance
#ifndef NRFX_SPIM1_ENABLED
#define NRFX_SPIM1_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_SPIM2_ENABLED  - Enable SPIM2 instance
#ifndef NRFX_SPIM2_ENABLED
#define NRFX_SPIM2_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_SPIM3_ENABLED  - Enable SPIM3 instance
#ifndef NRFX_SPIM3_ENABLED
#define NRFX_SPIM3_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_SPIM_EXTENDED_ENABLED  - Enable extended SPIM features
#ifndef NRFX_SPIM_EXTENDED_ENABLED
#define NRFX_SPIM_EXTENDED_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_SPIM_MISO_PULL_CFG  - MISO pin pull configuration.
// &amp;lt;0=&amp;gt; NRF_GPIO_PIN_NOPULL 
// &amp;lt;1=&amp;gt; NRF_GPIO_PIN_PULLDOWN 
// &amp;lt;3=&amp;gt; NRF_GPIO_PIN_PULLUP 
#ifndef NRFX_SPIM_MISO_PULL_CFG
#define NRFX_SPIM_MISO_PULL_CFG 1
// &amp;lt;o&amp;gt; NRFX_SPIM_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef NRFX_SPIM_DEFAULT_CONFIG_IRQ_PRIORITY
#define NRFX_SPIM_DEFAULT_CONFIG_IRQ_PRIORITY 6
// &amp;lt;e&amp;gt; NRFX_SPIM_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_SPIM_CONFIG_LOG_ENABLED
#define NRFX_SPIM_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_SPIM_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_SPIM_CONFIG_LOG_LEVEL
#define NRFX_SPIM_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_SPIM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_SPIM_CONFIG_INFO_COLOR
#define NRFX_SPIM_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_SPIM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_SPIM_CONFIG_DEBUG_COLOR
#define NRFX_SPIM_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRFX_SPI_ENABLED - nrfx_spi - SPI peripheral driver
#ifndef NRFX_SPI_ENABLED
#define NRFX_SPI_ENABLED 1
// &amp;lt;q&amp;gt; NRFX_SPI0_ENABLED  - Enable SPI0 instance
#ifndef NRFX_SPI0_ENABLED
#define NRFX_SPI0_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_SPI1_ENABLED  - Enable SPI1 instance
#ifndef NRFX_SPI1_ENABLED
#define NRFX_SPI1_ENABLED 0
// &amp;lt;q&amp;gt; NRFX_SPI2_ENABLED  - Enable SPI2 instance
#ifndef NRFX_SPI2_ENABLED
#define NRFX_SPI2_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_SPI_MISO_PULL_CFG  - MISO pin pull configuration.
#ifndef NRFX_SPI_MISO_PULL_CFG
#define NRFX_SPI_MISO_PULL_CFG 1
// &amp;lt;o&amp;gt; NRFX_SPI_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef NRFX_SPI_DEFAULT_CONFIG_IRQ_PRIORITY
#define NRFX_SPI_DEFAULT_CONFIG_IRQ_PRIORITY 6
// &amp;lt;e&amp;gt; NRFX_SPI_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_SPI_CONFIG_LOG_ENABLED
#define NRFX_SPI_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_SPI_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_SPI_CONFIG_LOG_LEVEL
#define NRFX_SPI_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_SPI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_SPI_CONFIG_INFO_COLOR
#define NRFX_SPI_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_SPI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_SPI_CONFIG_DEBUG_COLOR
#define NRFX_SPI_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRFX_UARTE_ENABLED - nrfx_uarte - UARTE peripheral driver
#ifndef NRFX_UARTE_ENABLED
#define NRFX_UARTE_ENABLED 1
// &amp;lt;o&amp;gt; NRFX_UARTE0_ENABLED - Enable UARTE0 instance 
#ifndef NRFX_UARTE0_ENABLED
#define NRFX_UARTE0_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_UARTE1_ENABLED - Enable UARTE1 instance 
#ifndef NRFX_UARTE1_ENABLED
#define NRFX_UARTE1_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_UARTE_DEFAULT_CONFIG_HWFC  - Hardware Flow Control
// &amp;lt;1=&amp;gt; Enabled 
#ifndef NRFX_UARTE_DEFAULT_CONFIG_HWFC
#define NRFX_UARTE_DEFAULT_CONFIG_HWFC 0
// &amp;lt;o&amp;gt; NRFX_UARTE_DEFAULT_CONFIG_PARITY  - Parity
// &amp;lt;0=&amp;gt; Excluded 
// &amp;lt;14=&amp;gt; Included 
#ifndef NRFX_UARTE_DEFAULT_CONFIG_PARITY
#define NRFX_UARTE_DEFAULT_CONFIG_PARITY 0
// &amp;lt;o&amp;gt; NRFX_UARTE_DEFAULT_CONFIG_BAUDRATE  - Default Baudrate
// &amp;lt;323584=&amp;gt; 1200 baud 
// &amp;lt;643072=&amp;gt; 2400 baud 
// &amp;lt;1290240=&amp;gt; 4800 baud 
// &amp;lt;2576384=&amp;gt; 9600 baud 
// &amp;lt;3862528=&amp;gt; 14400 baud 
// &amp;lt;5152768=&amp;gt; 19200 baud 
// &amp;lt;7716864=&amp;gt; 28800 baud 
// &amp;lt;8388608=&amp;gt; 31250 baud 
// &amp;lt;10289152=&amp;gt; 38400 baud 
// &amp;lt;15007744=&amp;gt; 56000 baud 
// &amp;lt;15400960=&amp;gt; 57600 baud 
// &amp;lt;20615168=&amp;gt; 76800 baud 
// &amp;lt;30801920=&amp;gt; 115200 baud 
// &amp;lt;61865984=&amp;gt; 230400 baud 
// &amp;lt;67108864=&amp;gt; 250000 baud 
// &amp;lt;121634816=&amp;gt; 460800 baud 
// &amp;lt;251658240=&amp;gt; 921600 baud 
// &amp;lt;268435456=&amp;gt; 1000000 baud 
#ifndef NRFX_UARTE_DEFAULT_CONFIG_BAUDRATE
#define NRFX_UARTE_DEFAULT_CONFIG_BAUDRATE 30801920
// &amp;lt;o&amp;gt; NRFX_UARTE_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef NRFX_UARTE_DEFAULT_CONFIG_IRQ_PRIORITY
#define NRFX_UARTE_DEFAULT_CONFIG_IRQ_PRIORITY 6
// &amp;lt;e&amp;gt; NRFX_UARTE_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_UARTE_CONFIG_LOG_ENABLED
#define NRFX_UARTE_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_UARTE_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_UARTE_CONFIG_LOG_LEVEL
#define NRFX_UARTE_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_UARTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_UARTE_CONFIG_INFO_COLOR
#define NRFX_UARTE_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_UARTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_UARTE_CONFIG_DEBUG_COLOR
#define NRFX_UARTE_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRFX_UART_ENABLED - nrfx_uart - UART peripheral driver
#ifndef NRFX_UART_ENABLED
#define NRFX_UART_ENABLED 1
// &amp;lt;o&amp;gt; NRFX_UART0_ENABLED - Enable UART0 instance 
#ifndef NRFX_UART0_ENABLED
#define NRFX_UART0_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_UART_DEFAULT_CONFIG_HWFC  - Hardware Flow Control
#ifndef NRFX_UART_DEFAULT_CONFIG_HWFC
#define NRFX_UART_DEFAULT_CONFIG_HWFC 0
// &amp;lt;o&amp;gt; NRFX_UART_DEFAULT_CONFIG_PARITY  - Parity
#ifndef NRFX_UART_DEFAULT_CONFIG_PARITY
#define NRFX_UART_DEFAULT_CONFIG_PARITY 0
// &amp;lt;o&amp;gt; NRFX_UART_DEFAULT_CONFIG_BAUDRATE  - Default Baudrate
// &amp;lt;3866624=&amp;gt; 14400 baud 
// &amp;lt;7729152=&amp;gt; 28800 baud 
// &amp;lt;10309632=&amp;gt; 38400 baud 
// &amp;lt;15462400=&amp;gt; 57600 baud 
// &amp;lt;30924800=&amp;gt; 115200 baud 
// &amp;lt;61845504=&amp;gt; 230400 baud 
// &amp;lt;123695104=&amp;gt; 460800 baud 
// &amp;lt;247386112=&amp;gt; 921600 baud 
#ifndef NRFX_UART_DEFAULT_CONFIG_BAUDRATE
#define NRFX_UART_DEFAULT_CONFIG_BAUDRATE 30924800
// &amp;lt;o&amp;gt; NRFX_UART_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef NRFX_UART_DEFAULT_CONFIG_IRQ_PRIORITY
#define NRFX_UART_DEFAULT_CONFIG_IRQ_PRIORITY 6
// &amp;lt;e&amp;gt; NRFX_UART_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_UART_CONFIG_LOG_ENABLED
#define NRFX_UART_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_UART_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_UART_CONFIG_LOG_LEVEL
#define NRFX_UART_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_UART_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_UART_CONFIG_INFO_COLOR
#define NRFX_UART_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_UART_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_UART_CONFIG_DEBUG_COLOR
#define NRFX_UART_CONFIG_DEBUG_COLOR 0
// &amp;lt;q&amp;gt; PPI_ENABLED  - nrf_drv_ppi - PPI peripheral driver - legacy layer
#ifndef PPI_ENABLED
#define PPI_ENABLED 1
// &amp;lt;e&amp;gt; SPI_ENABLED - nrf_drv_spi - SPI/SPIM peripheral driver - legacy layer
#ifndef SPI_ENABLED
#define SPI_ENABLED 1
// &amp;lt;o&amp;gt; SPI_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef SPI_DEFAULT_CONFIG_IRQ_PRIORITY
#define SPI_DEFAULT_CONFIG_IRQ_PRIORITY 6
// &amp;lt;o&amp;gt; NRF_SPI_DRV_MISO_PULLUP_CFG  - MISO PIN pull-up configuration.
#ifndef NRF_SPI_DRV_MISO_PULLUP_CFG
#define NRF_SPI_DRV_MISO_PULLUP_CFG 1
// &amp;lt;e&amp;gt; SPI0_ENABLED - Enable SPI0 instance
#ifndef SPI0_ENABLED
#define SPI0_ENABLED 1
// &amp;lt;q&amp;gt; SPI0_USE_EASY_DMA  - Use EasyDMA
#ifndef SPI0_USE_EASY_DMA
#define SPI0_USE_EASY_DMA 1
// &amp;lt;e&amp;gt; SPI1_ENABLED - Enable SPI1 instance
#ifndef SPI1_ENABLED
#define SPI1_ENABLED 0
// &amp;lt;q&amp;gt; SPI1_USE_EASY_DMA  - Use EasyDMA
#ifndef SPI1_USE_EASY_DMA
#define SPI1_USE_EASY_DMA 1
// &amp;lt;e&amp;gt; SPI2_ENABLED - Enable SPI2 instance
#ifndef SPI2_ENABLED
#define SPI2_ENABLED 0
// &amp;lt;q&amp;gt; SPI2_USE_EASY_DMA  - Use EasyDMA
#ifndef SPI2_USE_EASY_DMA
#define SPI2_USE_EASY_DMA 1
// &amp;lt;e&amp;gt; UART_ENABLED - nrf_drv_uart - UART/UARTE peripheral driver - legacy layer
#ifndef UART_ENABLED
#define UART_ENABLED 1
// &amp;lt;o&amp;gt; UART_DEFAULT_CONFIG_HWFC  - Hardware Flow Control
#ifndef UART_DEFAULT_CONFIG_HWFC
#define UART_DEFAULT_CONFIG_HWFC 0
// &amp;lt;o&amp;gt; UART_DEFAULT_CONFIG_PARITY  - Parity
#ifndef UART_DEFAULT_CONFIG_PARITY
#define UART_DEFAULT_CONFIG_PARITY 0
// &amp;lt;o&amp;gt; UART_DEFAULT_CONFIG_BAUDRATE  - Default Baudrate
#ifndef UART_DEFAULT_CONFIG_BAUDRATE
#define UART_DEFAULT_CONFIG_BAUDRATE 30801920
// &amp;lt;o&amp;gt; UART_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
#ifndef UART_DEFAULT_CONFIG_IRQ_PRIORITY
#define UART_DEFAULT_CONFIG_IRQ_PRIORITY 6
// &amp;lt;q&amp;gt; UART_EASY_DMA_SUPPORT  - Driver supporting EasyDMA
#ifndef UART_EASY_DMA_SUPPORT
#define UART_EASY_DMA_SUPPORT 1
// &amp;lt;q&amp;gt; UART_LEGACY_SUPPORT  - Driver supporting Legacy mode
#ifndef UART_LEGACY_SUPPORT
#define UART_LEGACY_SUPPORT 0
// &amp;lt;e&amp;gt; UART0_ENABLED - Enable UART0 instance
#ifndef UART0_ENABLED
#define UART0_ENABLED 1
// &amp;lt;q&amp;gt; UART0_CONFIG_USE_EASY_DMA  - Default setting for using EasyDMA
#ifndef UART0_CONFIG_USE_EASY_DMA
#define UART0_CONFIG_USE_EASY_DMA 1
// &amp;lt;e&amp;gt; UART1_ENABLED - Enable UART1 instance
#ifndef UART1_ENABLED
#define UART1_ENABLED 0
// &amp;lt;/h&amp;gt; 
// &amp;lt;h&amp;gt; nRF_Libraries 
// &amp;lt;q&amp;gt; APP_FIFO_ENABLED  - app_fifo - Software FIFO implementation
#ifndef APP_FIFO_ENABLED
#define APP_FIFO_ENABLED 1
// &amp;lt;e&amp;gt; APP_SDCARD_ENABLED - app_sdcard - SD/MMC card support using SPI
#ifndef APP_SDCARD_ENABLED
#define APP_SDCARD_ENABLED 1
// &amp;lt;o&amp;gt; APP_SDCARD_SPI_INSTANCE  - SPI instance used
#ifndef APP_SDCARD_SPI_INSTANCE
#define APP_SDCARD_SPI_INSTANCE 0
// &amp;lt;o&amp;gt; APP_SDCARD_FREQ_INIT  - SPI frequency
// &amp;lt;33554432=&amp;gt; 125 kHz 
// &amp;lt;67108864=&amp;gt; 250 kHz 
// &amp;lt;134217728=&amp;gt; 500 kHz 
// &amp;lt;268435456=&amp;gt; 1 MHz 
// &amp;lt;536870912=&amp;gt; 2 MHz 
// &amp;lt;1073741824=&amp;gt; 4 MHz 
// &amp;lt;2147483648=&amp;gt; 8 MHz 
#ifndef APP_SDCARD_FREQ_INIT
#define APP_SDCARD_FREQ_INIT 67108864
// &amp;lt;o&amp;gt; APP_SDCARD_FREQ_DATA  - SPI frequency
#ifndef APP_SDCARD_FREQ_DATA
#define APP_SDCARD_FREQ_DATA 1073741824
// &amp;lt;e&amp;gt; APP_UART_ENABLED - app_uart - UART driver
#ifndef APP_UART_ENABLED
#define APP_UART_ENABLED 1
// &amp;lt;o&amp;gt; APP_UART_DRIVER_INSTANCE  - UART instance used
#ifndef APP_UART_DRIVER_INSTANCE
#define APP_UART_DRIVER_INSTANCE 0
// &amp;lt;e&amp;gt; NRF_BALLOC_ENABLED - nrf_balloc - Block allocator module
#ifndef NRF_BALLOC_ENABLED
#define NRF_BALLOC_ENABLED 1
// &amp;lt;e&amp;gt; NRF_BALLOC_CONFIG_DEBUG_ENABLED - Enables debug mode in the module.
#ifndef NRF_BALLOC_CONFIG_DEBUG_ENABLED
#define NRF_BALLOC_CONFIG_DEBUG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_BALLOC_CONFIG_HEAD_GUARD_WORDS - Number of words used as head guard.  &amp;lt;0-255&amp;gt; 
#ifndef NRF_BALLOC_CONFIG_HEAD_GUARD_WORDS
#define NRF_BALLOC_CONFIG_HEAD_GUARD_WORDS 1
// &amp;lt;o&amp;gt; NRF_BALLOC_CONFIG_TAIL_GUARD_WORDS - Number of words used as tail guard.  &amp;lt;0-255&amp;gt; 
#ifndef NRF_BALLOC_CONFIG_TAIL_GUARD_WORDS
#define NRF_BALLOC_CONFIG_TAIL_GUARD_WORDS 1
// &amp;lt;q&amp;gt; NRF_BALLOC_CONFIG_BASIC_CHECKS_ENABLED  - Enables basic checks in this module.
#ifndef NRF_BALLOC_CONFIG_BASIC_CHECKS_ENABLED
#define NRF_BALLOC_CONFIG_BASIC_CHECKS_ENABLED 0
// &amp;lt;q&amp;gt; NRF_BALLOC_CONFIG_DOUBLE_FREE_CHECK_ENABLED  - Enables double memory free check in this module.
#ifndef NRF_BALLOC_CONFIG_DOUBLE_FREE_CHECK_ENABLED
#define NRF_BALLOC_CONFIG_DOUBLE_FREE_CHECK_ENABLED 0
// &amp;lt;q&amp;gt; NRF_BALLOC_CONFIG_DATA_TRASHING_CHECK_ENABLED  - Enables free memory corruption check in this module.
#ifndef NRF_BALLOC_CONFIG_DATA_TRASHING_CHECK_ENABLED
#define NRF_BALLOC_CONFIG_DATA_TRASHING_CHECK_ENABLED 0
// &amp;lt;q&amp;gt; NRF_BALLOC_CLI_CMDS  - Enable CLI commands specific to the module
#ifndef NRF_BALLOC_CLI_CMDS
#define NRF_BALLOC_CLI_CMDS 0
// &amp;lt;q&amp;gt; NRF_MEMOBJ_ENABLED  - nrf_memobj - Linked memory allocator module
#ifndef NRF_MEMOBJ_ENABLED
#define NRF_MEMOBJ_ENABLED 1
// &amp;lt;q&amp;gt; NRF_STRERROR_ENABLED  - nrf_strerror - Library for converting error code to string.
#ifndef NRF_STRERROR_ENABLED
#define NRF_STRERROR_ENABLED 1
// &amp;lt;h&amp;gt; nrf_fprintf - fprintf function.
// &amp;lt;q&amp;gt; NRF_FPRINTF_ENABLED  - Enable/disable fprintf module.
#ifndef NRF_FPRINTF_ENABLED
#define NRF_FPRINTF_ENABLED 1
// &amp;lt;q&amp;gt; NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED  - For each printed LF, function will add CR.
#ifndef NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED
#define NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 1
// &amp;lt;q&amp;gt; NRF_FPRINTF_DOUBLE_ENABLED  - Enable IEEE-754 double precision formatting.
#ifndef NRF_FPRINTF_DOUBLE_ENABLED
#define NRF_FPRINTF_DOUBLE_ENABLED 0
// &amp;lt;h&amp;gt; nRF_Log 
// &amp;lt;e&amp;gt; NRF_LOG_BACKEND_RTT_ENABLED - nrf_log_backend_rtt - Log RTT backend
#ifndef NRF_LOG_BACKEND_RTT_ENABLED
#define NRF_LOG_BACKEND_RTT_ENABLED 1
// &amp;lt;o&amp;gt; NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE - Size of buffer for partially processed strings. 
// &amp;lt;i&amp;gt; Size of the buffer is a trade-off between RAM usage and processing.
// &amp;lt;i&amp;gt; if buffer is smaller then strings will often be fragmented.
// &amp;lt;i&amp;gt; It is recommended to use size which will fit typical log and only the
// &amp;lt;i&amp;gt; longer one will be fragmented.
#ifndef NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE
#define NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE 64
// &amp;lt;o&amp;gt; NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS - Period before retrying writing to RTT 
#ifndef NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS
#define NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS 1
// &amp;lt;o&amp;gt; NRF_LOG_BACKEND_RTT_TX_RETRY_CNT - Writing to RTT retries. 
// &amp;lt;i&amp;gt; If RTT fails to accept any new data after retries
// &amp;lt;i&amp;gt; module assumes that host is not active and on next
// &amp;lt;i&amp;gt; request it will perform only one write attempt.
// &amp;lt;i&amp;gt; On successful writing, module assumes that host is active
// &amp;lt;i&amp;gt; and scheme with retry is applied again.
#ifndef NRF_LOG_BACKEND_RTT_TX_RETRY_CNT
#define NRF_LOG_BACKEND_RTT_TX_RETRY_CNT 3
// &amp;lt;e&amp;gt; NRF_LOG_BACKEND_UART_ENABLED - nrf_log_backend_uart - Log UART backend
#ifndef NRF_LOG_BACKEND_UART_ENABLED
#define NRF_LOG_BACKEND_UART_ENABLED 1
// &amp;lt;o&amp;gt; NRF_LOG_BACKEND_UART_TX_PIN - UART TX pin 
#ifndef NRF_LOG_BACKEND_UART_TX_PIN
#define NRF_LOG_BACKEND_UART_TX_PIN 6
// &amp;lt;o&amp;gt; NRF_LOG_BACKEND_UART_BAUDRATE  - Default Baudrate
#ifndef NRF_LOG_BACKEND_UART_BAUDRATE
#define NRF_LOG_BACKEND_UART_BAUDRATE 30801920
// &amp;lt;o&amp;gt; NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE - Size of buffer for partially processed strings. 
#ifndef NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE
#define NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE 64
// &amp;lt;e&amp;gt; NRF_LOG_ENABLED - nrf_log - Logger
#ifndef NRF_LOG_ENABLED
#define NRF_LOG_ENABLED 1
// &amp;lt;h&amp;gt; Log message pool - Configuration of log message pool
// &amp;lt;o&amp;gt; NRF_LOG_MSGPOOL_ELEMENT_SIZE - Size of a single element in the pool of memory objects. 
// &amp;lt;i&amp;gt; If a small value is set, then performance of logs processing
// &amp;lt;i&amp;gt; is degraded because data is fragmented. Bigger value impacts
// &amp;lt;i&amp;gt; RAM memory utilization. The size is set to fit a message with
// &amp;lt;i&amp;gt; a timestamp and up to 2 arguments in a single memory object.
#ifndef NRF_LOG_MSGPOOL_ELEMENT_SIZE
#define NRF_LOG_MSGPOOL_ELEMENT_SIZE 20
// &amp;lt;o&amp;gt; NRF_LOG_MSGPOOL_ELEMENT_COUNT - Number of elements in the pool of memory objects 
// &amp;lt;i&amp;gt; If a small value is set, then it may lead to a deadlock
// &amp;lt;i&amp;gt; in certain cases if backend has high latency and holds
// &amp;lt;i&amp;gt; multiple messages for long time. Bigger value impacts
// &amp;lt;i&amp;gt; RAM memory usage.
#ifndef NRF_LOG_MSGPOOL_ELEMENT_COUNT
#define NRF_LOG_MSGPOOL_ELEMENT_COUNT 8
// &amp;lt;q&amp;gt; NRF_LOG_ALLOW_OVERFLOW  - Configures behavior when circular buffer is full.
// &amp;lt;i&amp;gt; If set then oldest logs are overwritten. Otherwise a 
// &amp;lt;i&amp;gt; marker is injected informing about overflow.
#ifndef NRF_LOG_ALLOW_OVERFLOW
#define NRF_LOG_ALLOW_OVERFLOW 1
// &amp;lt;o&amp;gt; NRF_LOG_BUFSIZE  - Size of the buffer for storing logs (in bytes).
// &amp;lt;i&amp;gt; Must be power of 2 and multiple of 4.
// &amp;lt;i&amp;gt; If NRF_LOG_DEFERRED = 0 then buffer size can be reduced to minimum.
// &amp;lt;128=&amp;gt; 128 
// &amp;lt;256=&amp;gt; 256 
// &amp;lt;512=&amp;gt; 512 
// &amp;lt;1024=&amp;gt; 1024 
// &amp;lt;2048=&amp;gt; 2048 
// &amp;lt;4096=&amp;gt; 4096 
// &amp;lt;8192=&amp;gt; 8192 
// &amp;lt;16384=&amp;gt; 16384 
#ifndef NRF_LOG_BUFSIZE
#define NRF_LOG_BUFSIZE 1024
// &amp;lt;q&amp;gt; NRF_LOG_CLI_CMDS  - Enable CLI commands for the module.
#ifndef NRF_LOG_CLI_CMDS
#define NRF_LOG_CLI_CMDS 0
// &amp;lt;o&amp;gt; NRF_LOG_DEFAULT_LEVEL  - Default Severity level
#ifndef NRF_LOG_DEFAULT_LEVEL
#define NRF_LOG_DEFAULT_LEVEL 3
// &amp;lt;q&amp;gt; NRF_LOG_DEFERRED  - Enable deffered logger.
// &amp;lt;i&amp;gt; Log data is buffered and can be processed in idle.
#ifndef NRF_LOG_DEFERRED
#define NRF_LOG_DEFERRED 0
// &amp;lt;q&amp;gt; NRF_LOG_FILTERS_ENABLED  - Enable dynamic filtering of logs.
#ifndef NRF_LOG_FILTERS_ENABLED
#define NRF_LOG_FILTERS_ENABLED 0
// &amp;lt;q&amp;gt; NRF_LOG_NON_DEFFERED_CRITICAL_REGION_ENABLED  - Enable use of critical region for non deffered mode when flushing logs.
// &amp;lt;i&amp;gt; When enabled NRF_LOG_FLUSH is called from critical section when non deffered mode is used.
// &amp;lt;i&amp;gt; Log output will never be corrupted as access to the log backend is exclusive
// &amp;lt;i&amp;gt; but system will spend significant amount of time in critical section
#ifndef NRF_LOG_NON_DEFFERED_CRITICAL_REGION_ENABLED
#define NRF_LOG_NON_DEFFERED_CRITICAL_REGION_ENABLED 0
// &amp;lt;o&amp;gt; NRF_LOG_STR_PUSH_BUFFER_SIZE  - Size of the buffer dedicated for strings stored using @ref NRF_LOG_PUSH.
// &amp;lt;16=&amp;gt; 16 
// &amp;lt;32=&amp;gt; 32 
// &amp;lt;64=&amp;gt; 64 
#ifndef NRF_LOG_STR_PUSH_BUFFER_SIZE
#define NRF_LOG_STR_PUSH_BUFFER_SIZE 128
// &amp;lt;e&amp;gt; NRF_LOG_USES_COLORS - If enabled then ANSI escape code for colors is prefixed to every string
#ifndef NRF_LOG_USES_COLORS
#define NRF_LOG_USES_COLORS 0
// &amp;lt;o&amp;gt; NRF_LOG_COLOR_DEFAULT  - ANSI escape code prefix.
#ifndef NRF_LOG_COLOR_DEFAULT
#define NRF_LOG_COLOR_DEFAULT 0
// &amp;lt;o&amp;gt; NRF_LOG_ERROR_COLOR  - ANSI escape code prefix.
#ifndef NRF_LOG_ERROR_COLOR
#define NRF_LOG_ERROR_COLOR 2
// &amp;lt;o&amp;gt; NRF_LOG_WARNING_COLOR  - ANSI escape code prefix.
#ifndef NRF_LOG_WARNING_COLOR
#define NRF_LOG_WARNING_COLOR 4
// &amp;lt;e&amp;gt; NRF_LOG_USES_TIMESTAMP - Enable timestamping
// &amp;lt;i&amp;gt; Function for getting the timestamp is provided by the user
#ifndef NRF_LOG_USES_TIMESTAMP
#define NRF_LOG_USES_TIMESTAMP 0
// &amp;lt;o&amp;gt; NRF_LOG_TIMESTAMP_DEFAULT_FREQUENCY - Default frequency of the timestamp (in Hz) or 0 to use app_timer frequency. 
#ifndef NRF_LOG_TIMESTAMP_DEFAULT_FREQUENCY
#define NRF_LOG_TIMESTAMP_DEFAULT_FREQUENCY 0
// &amp;lt;h&amp;gt; nrf_log module configuration 
// &amp;lt;h&amp;gt; nrf_log in nRF_Core 
// &amp;lt;e&amp;gt; NRF_MPU_LIB_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_MPU_LIB_CONFIG_LOG_ENABLED
#define NRF_MPU_LIB_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_MPU_LIB_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_MPU_LIB_CONFIG_LOG_LEVEL
#define NRF_MPU_LIB_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_MPU_LIB_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_MPU_LIB_CONFIG_INFO_COLOR
#define NRF_MPU_LIB_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_MPU_LIB_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_MPU_LIB_CONFIG_DEBUG_COLOR
#define NRF_MPU_LIB_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_STACK_GUARD_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_STACK_GUARD_CONFIG_LOG_ENABLED
#define NRF_STACK_GUARD_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_STACK_GUARD_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_STACK_GUARD_CONFIG_LOG_LEVEL
#define NRF_STACK_GUARD_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_STACK_GUARD_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_STACK_GUARD_CONFIG_INFO_COLOR
#define NRF_STACK_GUARD_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_STACK_GUARD_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_STACK_GUARD_CONFIG_DEBUG_COLOR
#define NRF_STACK_GUARD_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; TASK_MANAGER_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef TASK_MANAGER_CONFIG_LOG_ENABLED
#define TASK_MANAGER_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; TASK_MANAGER_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef TASK_MANAGER_CONFIG_LOG_LEVEL
#define TASK_MANAGER_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; TASK_MANAGER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef TASK_MANAGER_CONFIG_INFO_COLOR
#define TASK_MANAGER_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; TASK_MANAGER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef TASK_MANAGER_CONFIG_DEBUG_COLOR
#define TASK_MANAGER_CONFIG_DEBUG_COLOR 0
// &amp;lt;h&amp;gt; nrf_log in nRF_Drivers 
// &amp;lt;e&amp;gt; CLOCK_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef CLOCK_CONFIG_LOG_ENABLED
#define CLOCK_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; CLOCK_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef CLOCK_CONFIG_LOG_LEVEL
#define CLOCK_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; CLOCK_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef CLOCK_CONFIG_INFO_COLOR
#define CLOCK_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; CLOCK_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef CLOCK_CONFIG_DEBUG_COLOR
#define CLOCK_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; COMP_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef COMP_CONFIG_LOG_ENABLED
#define COMP_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; COMP_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef COMP_CONFIG_LOG_LEVEL
#define COMP_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; COMP_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef COMP_CONFIG_INFO_COLOR
#define COMP_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; COMP_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef COMP_CONFIG_DEBUG_COLOR
#define COMP_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; GPIOTE_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef GPIOTE_CONFIG_LOG_ENABLED
#define GPIOTE_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; GPIOTE_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef GPIOTE_CONFIG_LOG_LEVEL
#define GPIOTE_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; GPIOTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef GPIOTE_CONFIG_INFO_COLOR
#define GPIOTE_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; GPIOTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef GPIOTE_CONFIG_DEBUG_COLOR
#define GPIOTE_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; LPCOMP_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef LPCOMP_CONFIG_LOG_ENABLED
#define LPCOMP_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; LPCOMP_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef LPCOMP_CONFIG_LOG_LEVEL
#define LPCOMP_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; LPCOMP_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef LPCOMP_CONFIG_INFO_COLOR
#define LPCOMP_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; LPCOMP_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef LPCOMP_CONFIG_DEBUG_COLOR
#define LPCOMP_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; MAX3421E_HOST_CONFIG_LOG_ENABLED - Enable logging in the module
#ifndef MAX3421E_HOST_CONFIG_LOG_ENABLED
#define MAX3421E_HOST_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; MAX3421E_HOST_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef MAX3421E_HOST_CONFIG_LOG_LEVEL
#define MAX3421E_HOST_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; MAX3421E_HOST_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef MAX3421E_HOST_CONFIG_INFO_COLOR
#define MAX3421E_HOST_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; MAX3421E_HOST_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef MAX3421E_HOST_CONFIG_DEBUG_COLOR
#define MAX3421E_HOST_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRFX_USBD_CONFIG_LOG_ENABLED - Enable logging in the module
#ifndef NRFX_USBD_CONFIG_LOG_ENABLED
#define NRFX_USBD_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRFX_USBD_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRFX_USBD_CONFIG_LOG_LEVEL
#define NRFX_USBD_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRFX_USBD_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRFX_USBD_CONFIG_INFO_COLOR
#define NRFX_USBD_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRFX_USBD_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRFX_USBD_CONFIG_DEBUG_COLOR
#define NRFX_USBD_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; PDM_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef PDM_CONFIG_LOG_ENABLED
#define PDM_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; PDM_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef PDM_CONFIG_LOG_LEVEL
#define PDM_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; PDM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef PDM_CONFIG_INFO_COLOR
#define PDM_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; PDM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef PDM_CONFIG_DEBUG_COLOR
#define PDM_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; PPI_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef PPI_CONFIG_LOG_ENABLED
#define PPI_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; PPI_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef PPI_CONFIG_LOG_LEVEL
#define PPI_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; PPI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef PPI_CONFIG_INFO_COLOR
#define PPI_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; PPI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef PPI_CONFIG_DEBUG_COLOR
#define PPI_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; PWM_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef PWM_CONFIG_LOG_ENABLED
#define PWM_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; PWM_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef PWM_CONFIG_LOG_LEVEL
#define PWM_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; PWM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef PWM_CONFIG_INFO_COLOR
#define PWM_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; PWM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef PWM_CONFIG_DEBUG_COLOR
#define PWM_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; QDEC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef QDEC_CONFIG_LOG_ENABLED
#define QDEC_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; QDEC_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef QDEC_CONFIG_LOG_LEVEL
#define QDEC_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; QDEC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef QDEC_CONFIG_INFO_COLOR
#define QDEC_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; QDEC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef QDEC_CONFIG_DEBUG_COLOR
#define QDEC_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; RNG_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef RNG_CONFIG_LOG_ENABLED
#define RNG_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; RNG_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef RNG_CONFIG_LOG_LEVEL
#define RNG_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; RNG_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef RNG_CONFIG_INFO_COLOR
#define RNG_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; RNG_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef RNG_CONFIG_DEBUG_COLOR
#define RNG_CONFIG_DEBUG_COLOR 0
// &amp;lt;q&amp;gt; RNG_CONFIG_RANDOM_NUMBER_LOG_ENABLED  - Enables logging of random numbers.
#ifndef RNG_CONFIG_RANDOM_NUMBER_LOG_ENABLED
#define RNG_CONFIG_RANDOM_NUMBER_LOG_ENABLED 0
// &amp;lt;e&amp;gt; RTC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef RTC_CONFIG_LOG_ENABLED
#define RTC_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; RTC_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef RTC_CONFIG_LOG_LEVEL
#define RTC_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; RTC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef RTC_CONFIG_INFO_COLOR
#define RTC_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; RTC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef RTC_CONFIG_DEBUG_COLOR
#define RTC_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; SAADC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef SAADC_CONFIG_LOG_ENABLED
#define SAADC_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; SAADC_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef SAADC_CONFIG_LOG_LEVEL
#define SAADC_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; SAADC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef SAADC_CONFIG_INFO_COLOR
#define SAADC_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; SAADC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef SAADC_CONFIG_DEBUG_COLOR
#define SAADC_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; SPIS_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef SPIS_CONFIG_LOG_ENABLED
#define SPIS_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; SPIS_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef SPIS_CONFIG_LOG_LEVEL
#define SPIS_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; SPIS_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef SPIS_CONFIG_INFO_COLOR
#define SPIS_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; SPIS_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef SPIS_CONFIG_DEBUG_COLOR
#define SPIS_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; SPI_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef SPI_CONFIG_LOG_ENABLED
#define SPI_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; SPI_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef SPI_CONFIG_LOG_LEVEL
#define SPI_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; SPI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef SPI_CONFIG_INFO_COLOR
#define SPI_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; SPI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef SPI_CONFIG_DEBUG_COLOR
#define SPI_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; TIMER_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef TIMER_CONFIG_LOG_ENABLED
#define TIMER_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; TIMER_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef TIMER_CONFIG_LOG_LEVEL
#define TIMER_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; TIMER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef TIMER_CONFIG_INFO_COLOR
#define TIMER_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; TIMER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef TIMER_CONFIG_DEBUG_COLOR
#define TIMER_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; TWIS_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef TWIS_CONFIG_LOG_ENABLED
#define TWIS_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; TWIS_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef TWIS_CONFIG_LOG_LEVEL
#define TWIS_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; TWIS_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef TWIS_CONFIG_INFO_COLOR
#define TWIS_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; TWIS_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef TWIS_CONFIG_DEBUG_COLOR
#define TWIS_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; TWI_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef TWI_CONFIG_LOG_ENABLED
#define TWI_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; TWI_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef TWI_CONFIG_LOG_LEVEL
#define TWI_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; TWI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef TWI_CONFIG_INFO_COLOR
#define TWI_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; TWI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef TWI_CONFIG_DEBUG_COLOR
#define TWI_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; UART_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef UART_CONFIG_LOG_ENABLED
#define UART_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; UART_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef UART_CONFIG_LOG_LEVEL
#define UART_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; UART_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef UART_CONFIG_INFO_COLOR
#define UART_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; UART_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef UART_CONFIG_DEBUG_COLOR
#define UART_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; USBD_CONFIG_LOG_ENABLED - Enable logging in the module
#ifndef USBD_CONFIG_LOG_ENABLED
#define USBD_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; USBD_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef USBD_CONFIG_LOG_LEVEL
#define USBD_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; USBD_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef USBD_CONFIG_INFO_COLOR
#define USBD_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; USBD_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef USBD_CONFIG_DEBUG_COLOR
#define USBD_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; WDT_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef WDT_CONFIG_LOG_ENABLED
#define WDT_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; WDT_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef WDT_CONFIG_LOG_LEVEL
#define WDT_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; WDT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef WDT_CONFIG_INFO_COLOR
#define WDT_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; WDT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef WDT_CONFIG_DEBUG_COLOR
#define WDT_CONFIG_DEBUG_COLOR 0
// &amp;lt;h&amp;gt; nrf_log in nRF_Libraries 
// &amp;lt;e&amp;gt; APP_BUTTON_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef APP_BUTTON_CONFIG_LOG_ENABLED
#define APP_BUTTON_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_BUTTON_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_BUTTON_CONFIG_LOG_LEVEL
#define APP_BUTTON_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_BUTTON_CONFIG_INITIAL_LOG_LEVEL  - Initial severity level if dynamic filtering is enabled.
// &amp;lt;i&amp;gt; If module generates a lot of logs, initial log level can
// &amp;lt;i&amp;gt; be decreased to prevent flooding. Severity level can be
// &amp;lt;i&amp;gt; increased on instance basis.
#ifndef APP_BUTTON_CONFIG_INITIAL_LOG_LEVEL
#define APP_BUTTON_CONFIG_INITIAL_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_BUTTON_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_BUTTON_CONFIG_INFO_COLOR
#define APP_BUTTON_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_BUTTON_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_BUTTON_CONFIG_DEBUG_COLOR
#define APP_BUTTON_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; APP_TIMER_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef APP_TIMER_CONFIG_LOG_ENABLED
#define APP_TIMER_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_TIMER_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_TIMER_CONFIG_LOG_LEVEL
#define APP_TIMER_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_TIMER_CONFIG_INITIAL_LOG_LEVEL  - Initial severity level if dynamic filtering is enabled.
#ifndef APP_TIMER_CONFIG_INITIAL_LOG_LEVEL
#define APP_TIMER_CONFIG_INITIAL_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_TIMER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_TIMER_CONFIG_INFO_COLOR
#define APP_TIMER_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_TIMER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_TIMER_CONFIG_DEBUG_COLOR
#define APP_TIMER_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; APP_USBD_CDC_ACM_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef APP_USBD_CDC_ACM_CONFIG_LOG_ENABLED
#define APP_USBD_CDC_ACM_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_USBD_CDC_ACM_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_USBD_CDC_ACM_CONFIG_LOG_LEVEL
#define APP_USBD_CDC_ACM_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_USBD_CDC_ACM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_CDC_ACM_CONFIG_INFO_COLOR
#define APP_USBD_CDC_ACM_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_USBD_CDC_ACM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_CDC_ACM_CONFIG_DEBUG_COLOR
#define APP_USBD_CDC_ACM_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; APP_USBD_CONFIG_LOG_ENABLED - Enable logging in the module.
#ifndef APP_USBD_CONFIG_LOG_ENABLED
#define APP_USBD_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_USBD_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_USBD_CONFIG_LOG_LEVEL
#define APP_USBD_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_USBD_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_CONFIG_INFO_COLOR
#define APP_USBD_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_USBD_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_CONFIG_DEBUG_COLOR
#define APP_USBD_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; APP_USBD_DUMMY_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef APP_USBD_DUMMY_CONFIG_LOG_ENABLED
#define APP_USBD_DUMMY_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_USBD_DUMMY_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_USBD_DUMMY_CONFIG_LOG_LEVEL
#define APP_USBD_DUMMY_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_USBD_DUMMY_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_DUMMY_CONFIG_INFO_COLOR
#define APP_USBD_DUMMY_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_USBD_DUMMY_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_DUMMY_CONFIG_DEBUG_COLOR
#define APP_USBD_DUMMY_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; APP_USBD_MSC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef APP_USBD_MSC_CONFIG_LOG_ENABLED
#define APP_USBD_MSC_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_USBD_MSC_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_USBD_MSC_CONFIG_LOG_LEVEL
#define APP_USBD_MSC_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_USBD_MSC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_MSC_CONFIG_INFO_COLOR
#define APP_USBD_MSC_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_USBD_MSC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_MSC_CONFIG_DEBUG_COLOR
#define APP_USBD_MSC_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_ENABLED
#define APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_LEVEL
#define APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; APP_USBD_NRF_DFU_TRIGGER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_NRF_DFU_TRIGGER_CONFIG_INFO_COLOR
#define APP_USBD_NRF_DFU_TRIGGER_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; APP_USBD_NRF_DFU_TRIGGER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef APP_USBD_NRF_DFU_TRIGGER_CONFIG_DEBUG_COLOR
#define APP_USBD_NRF_DFU_TRIGGER_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_ATFIFO_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_ATFIFO_CONFIG_LOG_ENABLED
#define NRF_ATFIFO_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_ATFIFO_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_ATFIFO_CONFIG_LOG_LEVEL
#define NRF_ATFIFO_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_ATFIFO_CONFIG_LOG_INIT_FILTER_LEVEL  - Initial severity level if dynamic filtering is enabled
#ifndef NRF_ATFIFO_CONFIG_LOG_INIT_FILTER_LEVEL
#define NRF_ATFIFO_CONFIG_LOG_INIT_FILTER_LEVEL 3
// &amp;lt;o&amp;gt; NRF_ATFIFO_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_ATFIFO_CONFIG_INFO_COLOR
#define NRF_ATFIFO_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_ATFIFO_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_ATFIFO_CONFIG_DEBUG_COLOR
#define NRF_ATFIFO_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_BALLOC_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_BALLOC_CONFIG_LOG_ENABLED
#define NRF_BALLOC_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_BALLOC_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_BALLOC_CONFIG_LOG_LEVEL
#define NRF_BALLOC_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BALLOC_CONFIG_INITIAL_LOG_LEVEL  - Initial severity level if dynamic filtering is enabled.
#ifndef NRF_BALLOC_CONFIG_INITIAL_LOG_LEVEL
#define NRF_BALLOC_CONFIG_INITIAL_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BALLOC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_BALLOC_CONFIG_INFO_COLOR
#define NRF_BALLOC_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_BALLOC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_BALLOC_CONFIG_DEBUG_COLOR
#define NRF_BALLOC_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_ENABLED
#define NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_LEVEL
#define NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_INIT_FILTER_LEVEL  - Initial severity level if dynamic filtering is enabled
#ifndef NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_INIT_FILTER_LEVEL
#define NRF_BLOCK_DEV_EMPTY_CONFIG_LOG_INIT_FILTER_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_EMPTY_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_BLOCK_DEV_EMPTY_CONFIG_INFO_COLOR
#define NRF_BLOCK_DEV_EMPTY_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_EMPTY_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_BLOCK_DEV_EMPTY_CONFIG_DEBUG_COLOR
#define NRF_BLOCK_DEV_EMPTY_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED
#define NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL
#define NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_QSPI_CONFIG_LOG_INIT_FILTER_LEVEL  - Initial severity level if dynamic filtering is enabled
#ifndef NRF_BLOCK_DEV_QSPI_CONFIG_LOG_INIT_FILTER_LEVEL
#define NRF_BLOCK_DEV_QSPI_CONFIG_LOG_INIT_FILTER_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_QSPI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_BLOCK_DEV_QSPI_CONFIG_INFO_COLOR
#define NRF_BLOCK_DEV_QSPI_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_QSPI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_BLOCK_DEV_QSPI_CONFIG_DEBUG_COLOR
#define NRF_BLOCK_DEV_QSPI_CONFIG_DEBUG_COLOR 0
// &amp;lt;/e&amp;gt;
// &amp;lt;e&amp;gt; NRF_BLOCK_DEV_RAM_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_BLOCK_DEV_RAM_CONFIG_LOG_ENABLED
#define NRF_BLOCK_DEV_RAM_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_RAM_CONFIG_LOG_LEVEL  - Default Severity level
// &amp;lt;0=&amp;gt; Off 
// &amp;lt;1=&amp;gt; Error 
// &amp;lt;2=&amp;gt; Warning 
// &amp;lt;3=&amp;gt; Info 
// &amp;lt;4=&amp;gt; Debug 
#ifndef NRF_BLOCK_DEV_RAM_CONFIG_LOG_LEVEL
#define NRF_BLOCK_DEV_RAM_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_RAM_CONFIG_LOG_INIT_FILTER_LEVEL  - Initial severity level if dynamic filtering is enabled
#ifndef NRF_BLOCK_DEV_RAM_CONFIG_LOG_INIT_FILTER_LEVEL
#define NRF_BLOCK_DEV_RAM_CONFIG_LOG_INIT_FILTER_LEVEL 3
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_RAM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// &amp;lt;0=&amp;gt; Default 
// &amp;lt;1=&amp;gt; Black 
// &amp;lt;2=&amp;gt; Red 
// &amp;lt;3=&amp;gt; Green 
// &amp;lt;4=&amp;gt; Yellow 
// &amp;lt;5=&amp;gt; Blue 
// &amp;lt;6=&amp;gt; Magenta 
// &amp;lt;7=&amp;gt; Cyan 
// &amp;lt;8=&amp;gt; White 
#ifndef NRF_BLOCK_DEV_RAM_CONFIG_INFO_COLOR
#define NRF_BLOCK_DEV_RAM_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_BLOCK_DEV_RAM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_BLOCK_DEV_RAM_CONFIG_DEBUG_COLOR
#define NRF_BLOCK_DEV_RAM_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_CLI_BLE_UART_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_CLI_BLE_UART_CONFIG_LOG_ENABLED
#define NRF_CLI_BLE_UART_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_CLI_BLE_UART_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_CLI_BLE_UART_CONFIG_LOG_LEVEL
#define NRF_CLI_BLE_UART_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_CLI_BLE_UART_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_CLI_BLE_UART_CONFIG_INFO_COLOR
#define NRF_CLI_BLE_UART_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_CLI_BLE_UART_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_CLI_BLE_UART_CONFIG_DEBUG_COLOR
#define NRF_CLI_BLE_UART_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_CLI_LIBUARTE_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_CLI_LIBUARTE_CONFIG_LOG_ENABLED
#define NRF_CLI_LIBUARTE_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_CLI_LIBUARTE_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_CLI_LIBUARTE_CONFIG_LOG_LEVEL
#define NRF_CLI_LIBUARTE_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_CLI_LIBUARTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_CLI_LIBUARTE_CONFIG_INFO_COLOR
#define NRF_CLI_LIBUARTE_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_CLI_LIBUARTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_CLI_LIBUARTE_CONFIG_DEBUG_COLOR
#define NRF_CLI_LIBUARTE_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_CLI_UART_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_CLI_UART_CONFIG_LOG_ENABLED
#define NRF_CLI_UART_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_CLI_UART_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_CLI_UART_CONFIG_LOG_LEVEL
#define NRF_CLI_UART_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_CLI_UART_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_CLI_UART_CONFIG_INFO_COLOR
#define NRF_CLI_UART_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_CLI_UART_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_CLI_UART_CONFIG_DEBUG_COLOR
#define NRF_CLI_UART_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_LIBUARTE_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_LIBUARTE_CONFIG_LOG_ENABLED
#define NRF_LIBUARTE_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_LIBUARTE_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_LIBUARTE_CONFIG_LOG_LEVEL
#define NRF_LIBUARTE_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_LIBUARTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_LIBUARTE_CONFIG_INFO_COLOR
#define NRF_LIBUARTE_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_LIBUARTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_LIBUARTE_CONFIG_DEBUG_COLOR
#define NRF_LIBUARTE_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_MEMOBJ_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_MEMOBJ_CONFIG_LOG_ENABLED
#define NRF_MEMOBJ_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_MEMOBJ_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_MEMOBJ_CONFIG_LOG_LEVEL
#define NRF_MEMOBJ_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_MEMOBJ_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_MEMOBJ_CONFIG_INFO_COLOR
#define NRF_MEMOBJ_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_MEMOBJ_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_MEMOBJ_CONFIG_DEBUG_COLOR
#define NRF_MEMOBJ_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_PWR_MGMT_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_PWR_MGMT_CONFIG_LOG_ENABLED
#define NRF_PWR_MGMT_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_PWR_MGMT_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_PWR_MGMT_CONFIG_LOG_LEVEL
#define NRF_PWR_MGMT_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_PWR_MGMT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_PWR_MGMT_CONFIG_INFO_COLOR
#define NRF_PWR_MGMT_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_PWR_MGMT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_PWR_MGMT_CONFIG_DEBUG_COLOR
#define NRF_PWR_MGMT_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_QUEUE_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_QUEUE_CONFIG_LOG_ENABLED
#define NRF_QUEUE_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_QUEUE_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_QUEUE_CONFIG_LOG_LEVEL
#define NRF_QUEUE_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_QUEUE_CONFIG_LOG_INIT_FILTER_LEVEL  - Initial severity level if dynamic filtering is enabled
#ifndef NRF_QUEUE_CONFIG_LOG_INIT_FILTER_LEVEL
#define NRF_QUEUE_CONFIG_LOG_INIT_FILTER_LEVEL 3
// &amp;lt;o&amp;gt; NRF_QUEUE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_QUEUE_CONFIG_INFO_COLOR
#define NRF_QUEUE_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_QUEUE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_QUEUE_CONFIG_DEBUG_COLOR
#define NRF_QUEUE_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_SDH_ANT_LOG_ENABLED - Enable logging in SoftDevice handler (ANT) module.
#ifndef NRF_SDH_ANT_LOG_ENABLED
#define NRF_SDH_ANT_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_SDH_ANT_LOG_LEVEL  - Default Severity level
#ifndef NRF_SDH_ANT_LOG_LEVEL
#define NRF_SDH_ANT_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_SDH_ANT_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_ANT_INFO_COLOR
#define NRF_SDH_ANT_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_SDH_ANT_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_ANT_DEBUG_COLOR
#define NRF_SDH_ANT_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_SDH_BLE_LOG_ENABLED - Enable logging in SoftDevice handler (BLE) module.
#ifndef NRF_SDH_BLE_LOG_ENABLED
#define NRF_SDH_BLE_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_SDH_BLE_LOG_LEVEL  - Default Severity level
#ifndef NRF_SDH_BLE_LOG_LEVEL
#define NRF_SDH_BLE_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_SDH_BLE_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_BLE_INFO_COLOR
#define NRF_SDH_BLE_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_SDH_BLE_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_BLE_DEBUG_COLOR
#define NRF_SDH_BLE_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_SDH_LOG_ENABLED - Enable logging in SoftDevice handler module.
#ifndef NRF_SDH_LOG_ENABLED
#define NRF_SDH_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_SDH_LOG_LEVEL  - Default Severity level
#ifndef NRF_SDH_LOG_LEVEL
#define NRF_SDH_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_SDH_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_INFO_COLOR
#define NRF_SDH_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_SDH_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_DEBUG_COLOR
#define NRF_SDH_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_SDH_SOC_LOG_ENABLED - Enable logging in SoftDevice handler (SoC) module.
#ifndef NRF_SDH_SOC_LOG_ENABLED
#define NRF_SDH_SOC_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_SDH_SOC_LOG_LEVEL  - Default Severity level
#ifndef NRF_SDH_SOC_LOG_LEVEL
#define NRF_SDH_SOC_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_SDH_SOC_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_SOC_INFO_COLOR
#define NRF_SDH_SOC_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_SDH_SOC_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_SDH_SOC_DEBUG_COLOR
#define NRF_SDH_SOC_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_SORTLIST_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_SORTLIST_CONFIG_LOG_ENABLED
#define NRF_SORTLIST_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_SORTLIST_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_SORTLIST_CONFIG_LOG_LEVEL
#define NRF_SORTLIST_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_SORTLIST_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_SORTLIST_CONFIG_INFO_COLOR
#define NRF_SORTLIST_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_SORTLIST_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_SORTLIST_CONFIG_DEBUG_COLOR
#define NRF_SORTLIST_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; NRF_TWI_SENSOR_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRF_TWI_SENSOR_CONFIG_LOG_ENABLED
#define NRF_TWI_SENSOR_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; NRF_TWI_SENSOR_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef NRF_TWI_SENSOR_CONFIG_LOG_LEVEL
#define NRF_TWI_SENSOR_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; NRF_TWI_SENSOR_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef NRF_TWI_SENSOR_CONFIG_INFO_COLOR
#define NRF_TWI_SENSOR_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; NRF_TWI_SENSOR_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef NRF_TWI_SENSOR_CONFIG_DEBUG_COLOR
#define NRF_TWI_SENSOR_CONFIG_DEBUG_COLOR 0
// &amp;lt;e&amp;gt; PM_LOG_ENABLED - Enable logging in Peer Manager and its submodules.
#ifndef PM_LOG_ENABLED
#define PM_LOG_ENABLED 1
// &amp;lt;o&amp;gt; PM_LOG_LEVEL  - Default Severity level
#ifndef PM_LOG_LEVEL
#define PM_LOG_LEVEL 3
// &amp;lt;o&amp;gt; PM_LOG_INFO_COLOR  - ANSI escape code prefix.
#ifndef PM_LOG_INFO_COLOR
#define PM_LOG_INFO_COLOR 0
// &amp;lt;o&amp;gt; PM_LOG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef PM_LOG_DEBUG_COLOR
#define PM_LOG_DEBUG_COLOR 0
// &amp;lt;h&amp;gt; nrf_log in nRF_Serialization 
// &amp;lt;e&amp;gt; SER_HAL_TRANSPORT_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef SER_HAL_TRANSPORT_CONFIG_LOG_ENABLED
#define SER_HAL_TRANSPORT_CONFIG_LOG_ENABLED 0
// &amp;lt;o&amp;gt; SER_HAL_TRANSPORT_CONFIG_LOG_LEVEL  - Default Severity level
#ifndef SER_HAL_TRANSPORT_CONFIG_LOG_LEVEL
#define SER_HAL_TRANSPORT_CONFIG_LOG_LEVEL 3
// &amp;lt;o&amp;gt; SER_HAL_TRANSPORT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
#ifndef SER_HAL_TRANSPORT_CONFIG_INFO_COLOR
#define SER_HAL_TRANSPORT_CONFIG_INFO_COLOR 0
// &amp;lt;o&amp;gt; SER_HAL_TRANSPORT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
#ifndef SER_HAL_TRANSPORT_CONFIG_DEBUG_COLOR
#define SER_HAL_TRANSPORT_CONFIG_DEBUG_COLOR 0
// &amp;lt;q&amp;gt; NRF_LOG_STR_FORMATTER_TIMESTAMP_FORMAT_ENABLED  - nrf_log_str_formatter - Log string formatter
#ifndef NRF_LOG_STR_FORMATTER_TIMESTAMP_FORMAT_ENABLED
#define NRF_LOG_STR_FORMATTER_TIMESTAMP_FORMAT_ENABLED 1
// &amp;lt;h&amp;gt; nRF_Segger_RTT 
// &amp;lt;h&amp;gt; segger_rtt - SEGGER RTT
// &amp;lt;o&amp;gt; SEGGER_RTT_CONFIG_BUFFER_SIZE_UP - Size of upstream buffer. 
// &amp;lt;i&amp;gt; Note that either @ref NRF_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE
// &amp;lt;i&amp;gt; or this value is actually used. It depends on which one is bigger.
#ifndef SEGGER_RTT_CONFIG_BUFFER_SIZE_UP
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_UP 512
// &amp;lt;o&amp;gt; SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS - Maximum number of upstream buffers. 
#ifndef SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS
#define SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS 2
// &amp;lt;o&amp;gt; SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN - Size of downstream buffer. 
#ifndef SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN 16
// &amp;lt;o&amp;gt; SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS - Maximum number of downstream buffers. 
#ifndef SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS
#define SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS 2
// &amp;lt;o&amp;gt; SEGGER_RTT_CONFIG_DEFAULT_MODE  - RTT behavior if the buffer is full.
// &amp;lt;i&amp;gt; The following modes are supported:
// &amp;lt;i&amp;gt; - SKIP  - Do not block, output nothing.
// &amp;lt;i&amp;gt; - TRIM  - Do not block, output as much as fits.
// &amp;lt;i&amp;gt; - BLOCK - Wait until there is space in the buffer.
// &amp;lt;0=&amp;gt; SKIP 
// &amp;lt;1=&amp;gt; TRIM 
// &amp;lt;2=&amp;gt; BLOCK_IF_FIFO_FULL 
#ifndef SEGGER_RTT_CONFIG_DEFAULT_MODE
#define SEGGER_RTT_CONFIG_DEFAULT_MODE 0
// &amp;lt;&amp;lt;&amp;lt; end of configuration section &amp;gt;&amp;gt;&amp;gt;
#endif //SDK_CONFIG_H
&lt;/pre&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;pwm.c&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;#include &amp;quot;pwm.h&amp;quot;
static nrf_drv_pwm_t m_pwm0 = NRF_DRV_PWM_INSTANCE(0);
#define PWM_PIN0_0  (18)
//static nrf_drv_pwm_t m_pwm1 = NRF_DRV_PWM_INSTANCE(1);
//#define PWM_PIN1_0  (17)
static void pwm0_handler(nrf_drv_pwm_evt_type_t event_type)
    if (event_type == NRF_DRV_PWM_EVT_FINISHED)
        //nrf_gpio_pin_set(17);
        //NRF_LOG_INFO(&amp;quot;pwm0_handler&amp;quot;);
        //nrf_gpio_pin_clear(17);
static nrf_pwm_values_individual_t m_demo1_seq_values;
static nrf_pwm_sequence_t const    m_demo1_seq =
    .values.p_individual = &amp;amp;m_demo1_seq_values,
    .length              = NRF_PWM_VALUES_LENGTH(m_demo1_seq_values),
    .repeats             = 2000,
    .end_delay           = 0
static nrf_pwm_sequence_t const seq =
    .values.p_individual = seq_values,
    .length              = NRF_PWM_VALUES_LENGTH(seq_values),
    .repeats             = 0,
    .end_delay           = 0
static nrf_pwm_sequence_t const seq2 =
    .values.p_individual = seq_values2,
    .length              = NRF_PWM_VALUES_LENGTH(seq_values2),
    .repeats             = 0,
    .end_delay           = 0
void pwm_sample(void)
      nrf_drv_pwm_config_t const config0 =
          .output_pins =
              //PWM_PIN0_0 | NRF_DRV_PWM_PIN_INVERTED, // channel 0
              PWM_PIN0_0, // channel 0
              NRF_DRV_PWM_PIN_NOT_USED, // channel 1
              NRF_DRV_PWM_PIN_NOT_USED, // channel 2
              NRF_DRV_PWM_PIN_NOT_USED  // channel 3
          .irq_priority = APP_IRQ_PRIORITY_LOWEST,
          //.irq_priority = APP_IRQ_PRIORITY_HIGHEST,
          //.base_clock   = NRF_PWM_CLK_250kHz, //1cyc 4us
          //.base_clock   = NRF_PWM_CLK_125kHz, //1cyc 8us
          //.base_clock   = PWM_CLK_1MHz_BASE32, //1cyc 1us
          .base_clock   = NRF_PWM_CLK_1MHz, //1cyc 1us
          .count_mode   = NRF_PWM_MODE_UP,
          //.top_value    = 12500, //100ms period = 10Hz
          //.top_value    = 2000, //2000μs = 2ms period = 0.5kHz
          //.top_value    = 1250, //8us(=125kHz)*1250 = 1ms period = 1kHz
          //.top_value    = 500, //500μs = 0.5ms period = 2kHz
          .top_value    = 200, //20us * 50 = 1000μs = 1ms period = 1kHz
          .load_mode    = NRF_PWM_LOAD_COMMON,
          .step_mode    = NRF_PWM_STEP_AUTO
      APP_ERROR_CHECK(nrf_drv_pwm_init(&amp;amp;m_pwm0, &amp;amp;config0, pwm0_handler));
	  m_demo1_seq_values.channel_0 = 0;
	  m_demo1_seq_values.channel_1 = 0;
	  m_demo1_seq_values.channel_2 = 0;
	  m_demo1_seq_values.channel_3 = 0;
&lt;/pre&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PWM parameter settings problems.</title><link>https://devzone.nordicsemi.com/thread/454852?ContentTypeID=1</link><pubDate>Thu, 09 Nov 2023 09:05:18 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a3b63052-462e-403f-af4e-e64163f50020</guid><dc:creator>kkuma256</dc:creator><description>&lt;p&gt;I am currently creating it in the following environment.&lt;/p&gt;
&lt;p&gt;nRF5 SDK: 17.1.0&lt;br /&gt;nrfjprog version: 10.23.1 external&lt;br /&gt;JLinkARM.dll version: 7.92c&lt;/p&gt;
&lt;p&gt;Switching to nRF Connect is difficult now as many other parts have already been manufactured.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PWM parameter settings problems.</title><link>https://devzone.nordicsemi.com/thread/454847?ContentTypeID=1</link><pubDate>Thu, 09 Nov 2023 08:38:19 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:284f4055-83e2-449e-b2d1-d971d23bd8f6</guid><dc:creator>Naeem Maroof</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;I will look into this issue.&lt;/p&gt;
&lt;p&gt;Can you provide complete project code as only the config might not be enough to see the issue.&lt;/p&gt;
&lt;p&gt;Please mention which sdk verison you are using.&lt;/p&gt;
&lt;p&gt;Will like to mention that Nordic recommends the use of Latest &lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/index.html"&gt;Nordic Connect SDK (NCS)&lt;/a&gt;&amp;nbsp;for all and specifically for the new designs / projects.&lt;/p&gt;
&lt;p&gt;If you are not bound to use older SDK, I would recommend you to shift to the use of &lt;a href="https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-1-nrf-connect-sdk-introduction/topic/exercise-1-1/"&gt;NCS along with the VSCode&lt;/a&gt;.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Regards,&lt;/p&gt;
&lt;p&gt;Naeem&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
