<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>UART unable to run on self power, only when enter keil debug mode.</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/105771/uart-unable-to-run-on-self-power-only-when-enter-keil-debug-mode</link><description>Hi Nordic, I&amp;#39;m meeting with a strange scenario on UART problem. i was going to use UART communication through TX(Pin 6) &amp;amp; RX (Pin 8). At first, i thought it was working fine as I&amp;#39;m developing through debug mode. But when it came to only using PCBA without</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 24 Nov 2023 17:16:11 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/105771/uart-unable-to-run-on-self-power-only-when-enter-keil-debug-mode" /><item><title>RE: UART unable to run on self power, only when enter keil debug mode.</title><link>https://devzone.nordicsemi.com/thread/457388?ContentTypeID=1</link><pubDate>Fri, 24 Nov 2023 17:16:11 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:fa636cc7-b1a6-4418-99b8-ef5eaf0843c7</guid><dc:creator>Didrik Rokhaug</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;Which SDK and version are you using?&lt;/p&gt;
&lt;p&gt;If you are using the nRF Connect SDK, I recommend you go through our nRF Connect SDK Fundamentals course at our Nordic Developer Academy: &lt;a href="https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/"&gt;https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/&lt;/a&gt;&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Didrik&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: UART unable to run on self power, only when enter keil debug mode.</title><link>https://devzone.nordicsemi.com/thread/456567?ContentTypeID=1</link><pubDate>Tue, 21 Nov 2023 01:32:56 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:84ade220-1b6d-4262-90d8-b8ecec1dbc21</guid><dc:creator>zak_22621100</dc:creator><description>&lt;p&gt;Hi&amp;nbsp;&lt;a class="internal-link view-user-profile" href="https://devzone.nordicsemi.com/members/haakonsh"&gt;haakonsh&lt;/a&gt;&lt;br /&gt;&lt;br /&gt;where to enable &amp;quot;&lt;span&gt;pullup resistor on the RX pin&lt;/span&gt;&amp;quot; ?&amp;nbsp;&lt;br /&gt;&lt;br /&gt;Thank you&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: UART unable to run on self power, only when enter keil debug mode.</title><link>https://devzone.nordicsemi.com/thread/456163?ContentTypeID=1</link><pubDate>Fri, 17 Nov 2023 13:01:32 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:df5beb3d-95ee-496b-8f78-e6d8285ee591</guid><dc:creator>haakonsh</dc:creator><description>&lt;p&gt;Most likely your HFXO is not running. The UART peripheral needs a stable clock to operate, and the internal 64MHz RC oscillator becomes just stable enough when a debugger is attached.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Also, you need to enable the pullup resistor on the RX pin, if it&amp;#39;s left floating the UART peripheral will encounter errors.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
