<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Disconnect even though devices in range</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/106181/disconnect-even-though-devices-in-range</link><description>Hello,
 I&amp;#39;ve been working with nRF52840-DK Boards for about 3 months and I&amp;#39;m setting up a OpenThread mesh. I implemented UDP, CoAP, Commissioning etc. and everything works just fine.
 I already read something about the range of the devices here: And</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 15 Dec 2023 13:28:49 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/106181/disconnect-even-though-devices-in-range" /><item><title>RE: Disconnect even though devices in range</title><link>https://devzone.nordicsemi.com/thread/460562?ContentTypeID=1</link><pubDate>Fri, 15 Dec 2023 13:28:49 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d2064acc-d17f-4d0e-807a-df30021c2d5d</guid><dc:creator>Vincent124</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;Thanks for your answer.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Unfortunatly I am on vacation and won&amp;#39;t be working until January. I will be trying your tips as soon as possible. I&amp;#39;ll keep you updated!&lt;/p&gt;
&lt;p&gt;Regards,&lt;/p&gt;
&lt;p&gt;Vincent&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Disconnect even though devices in range</title><link>https://devzone.nordicsemi.com/thread/460484?ContentTypeID=1</link><pubDate>Fri, 15 Dec 2023 08:18:04 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b6889b81-fcab-40b0-9a82-e6c7acf2ff2f</guid><dc:creator>Sigurd Hellesvik</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;I will continue helping with this case.&lt;/p&gt;
&lt;p&gt;To check if there is something wrong with the Thread network like this, can you set up a &lt;a href="https://infocenter.nordicsemi.com/topic/ug_sniffer_802154/UG/sniffer_802154/intro_802154.html?cp=11_4"&gt;nRF Sniffer for 802.15.4&lt;/a&gt; and send a sniffer trace of the issue?&lt;/p&gt;
&lt;p&gt;Also, do you see the same for only 2 Thread devices, or is the range only shorter for many devices?&lt;/p&gt;
&lt;p&gt;Were you able to test the range in open space? What was the results?&lt;/p&gt;
[quote user="Vincent124"]In this enviroment a few months ago we tested Bluetooth range with the same boards and achieved a higher distance.[/quote]
&lt;p&gt;How much greater?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Disconnect even though devices in range</title><link>https://devzone.nordicsemi.com/thread/458497?ContentTypeID=1</link><pubDate>Fri, 01 Dec 2023 12:06:03 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:36d24de7-f708-4edd-a50d-34288eb2da69</guid><dc:creator>Vincent124</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;I think it&amp;#39;s a plaster wall. And it&amp;#39;s really not thick so it should not be a too though obstacle.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;I am testing my range with CoAP Packages: Every few seconds a device sends a Message to another device. If this Package reaches the other one, then this one sends an answer. Is the answer also successfully received, the device toggles a LED.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;But I do not see a problem with my way of testing.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;In this enviroment a few months ago we tested Bluetooth range with the same boards and achieved a higher distance. Could this be a problem with Thread then?&lt;/p&gt;
&lt;p&gt;I wasn&amp;#39;t able to test in open space yet because of the weather. But it is my plan to do so&amp;nbsp;in the near future.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Disconnect even though devices in range</title><link>https://devzone.nordicsemi.com/thread/458363?ContentTypeID=1</link><pubDate>Thu, 30 Nov 2023 15:28:46 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:99a56ede-74df-46e0-9abd-733dc40e5702</guid><dc:creator>Marte Myrvold</dc:creator><description>&lt;p&gt;Hi Vincent,&lt;/p&gt;
&lt;p&gt;If they are in the same room then 8-10 meters sounds short, especially if the devices are in line of sight. However, for devices that are in different rooms with a wall between them this could be expected range. What kind of wall is it, and do you know the material of it?&lt;/p&gt;
&lt;p&gt;Have you tested in a large open space with line of sight for comparison?&lt;/p&gt;
&lt;p&gt;Best regards,&lt;br /&gt;Marte&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
