<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>NRF5340 mapping different interface on QSPI pins</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/106323/nrf5340-mapping-different-interface-on-qspi-pins</link><description>Hello,
 I am currently developing a new hardware that feature NRF9160 and NRF5340. These two should communicate with each other using UART.
 Since space is very limited, I want to map the UART pins on P0.15 and P0.18. The datasheet of NRF5340 states</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 05 Dec 2023 11:35:39 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/106323/nrf5340-mapping-different-interface-on-qspi-pins" /><item><title>RE: NRF5340 mapping different interface on QSPI pins</title><link>https://devzone.nordicsemi.com/thread/458936?ContentTypeID=1</link><pubDate>Tue, 05 Dec 2023 11:35:39 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:4f0012a8-738d-499b-a9fb-3bb344252db3</guid><dc:creator>th_pu</dc:creator><description>&lt;p&gt;Thanks for confirmation!&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: NRF5340 mapping different interface on QSPI pins</title><link>https://devzone.nordicsemi.com/thread/458787?ContentTypeID=1</link><pubDate>Mon, 04 Dec 2023 15:44:38 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:1f25ad40-9fe6-4599-8a6e-e228c5e4f1c3</guid><dc:creator>PaKa</dc:creator><description>&lt;p&gt;The limitations are which pins are suitable for the QSPI, the data rate is high so will generate more noise than other series interfaces. The pins with the QSPI label are between power rails so the best decoupled pins (to dampen noise) and if you use the QSPI it&amp;#39;s highly recommended to use these pins. If you are not using QSPI then you can use them for whatever you want.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
