<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>nRF5340:  ipc_service_open_instance() failed</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/106366/nrf5340-ipc_service_open_instance-failed</link><description>Hi Support team,
 I tried to open the IPC on net-core, but failed:
 The configuration followed the sample &amp;#39; IPC service &amp;#39;: in prj.conf:
 a overlay for netwrok core:
 Could you help me see the failure reason, maybe I missed something. Thank you very</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Wed, 06 Dec 2023 14:07:52 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/106366/nrf5340-ipc_service_open_instance-failed" /><item><title>RE: nRF5340:  ipc_service_open_instance() failed</title><link>https://devzone.nordicsemi.com/thread/459202?ContentTypeID=1</link><pubDate>Wed, 06 Dec 2023 14:07:52 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:5bd63bb5-b1b2-406b-a804-12b3a2e710f6</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Hi&amp;nbsp;&lt;span&gt;Yanpeng Wu,&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Thank you for the update. I&amp;#39;m glad to hear that it works now.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;For more information about multi-image builds and the partition manager, please refer to the following doc links:&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;-&amp;nbsp;&lt;a id="" href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.5.0/nrf/config_and_build/multi_image.html"&gt;https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.5.0/nrf/config_and_build/multi_image.html&lt;/a&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;-&amp;nbsp;&lt;a id="" href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.5.0/nrf/scripts/partition_manager/partition_manager.html"&gt;https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.5.0/nrf/scripts/partition_manager/partition_manager.html&lt;/a&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Vidar&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF5340:  ipc_service_open_instance() failed</title><link>https://devzone.nordicsemi.com/thread/459194?ContentTypeID=1</link><pubDate>Wed, 06 Dec 2023 13:34:51 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:cce30a1c-f11f-4030-ab96-c1dfbe2f45f0</guid><dc:creator>Yanpengwu</dc:creator><description>&lt;p&gt;Hi Vidar,&lt;/p&gt;
&lt;p&gt;The problem is fixed. I used &amp;#39;sysbuild&amp;#39; in my application.&lt;/p&gt;
&lt;p&gt;The root cause is the device tree precedence. I defined the \boards\nrf5340dk_nrf5340_cpuapp.overlay first, then defined the ipc and the reserved-memory in an application overlay.&lt;br /&gt;The build system will stop when it finds a board overlay, so the application overlay was ignored in this situation.&lt;/p&gt;
&lt;p&gt;I pasted the description below:&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:213px;max-width:521px;" height="213" src="https://devzone.nordicsemi.com/resized-image/__size/1042x426/__key/communityserver-discussions-components-files/4/pastedimage1701869659673v1.png" width="521" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;After I moved the ipc and the reserved-memory definition to the board overlay, it was fixed.&lt;br /&gt;BTW, where can I find the &amp;#39;Partition Manager&amp;#39; if I use a multi-image build?&lt;/p&gt;
&lt;p&gt;Thank you very much.&lt;/p&gt;
&lt;p&gt;Best regards&lt;br /&gt;Yanpeng Wu&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF5340:  ipc_service_open_instance() failed</title><link>https://devzone.nordicsemi.com/thread/459167?ContentTypeID=1</link><pubDate>Wed, 06 Dec 2023 12:20:36 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:4622069d-d141-44db-8de0-cdf08326f27c</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;Are you able to provide a minimal version of your project for me to debug on my end? Note that the memory partitions are controlled by the Partition Manager if you are performing a multi-image build. The devictree partitions are then ignored.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Vidar&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF5340:  ipc_service_open_instance() failed</title><link>https://devzone.nordicsemi.com/thread/459032?ContentTypeID=1</link><pubDate>Tue, 05 Dec 2023 15:09:55 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:2948003f-e7ff-4478-b90a-ed9d4f302a50</guid><dc:creator>Yanpengwu</dc:creator><description>&lt;p&gt;By the way, I tried it on the nRF5340 DK.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: nRF5340:  ipc_service_open_instance() failed</title><link>https://devzone.nordicsemi.com/thread/459022?ContentTypeID=1</link><pubDate>Tue, 05 Dec 2023 14:51:18 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:5d90a833-e140-4152-b14d-f25194b92030</guid><dc:creator>Yanpengwu</dc:creator><description>&lt;p&gt;Are the error codes defined in C:\ncs\toolchains\c57af46cb7\opt\zephyr-sdk\arm-zephyr-eabi\arm-zephyr-eabi\sys-include\sys\errno.h?&lt;/p&gt;
&lt;p&gt;In this file, all error codes are positive values，&lt;br /&gt; #define ENOMEM 12 /* Not enough space */&lt;/p&gt;
&lt;p&gt;Seems this code is not the error reason.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
