<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Zephyr BLE Long Range AdvertExample for the nRF52833</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/106547/zephyr-ble-long-range-advertexample-for-the-nrf52833</link><description>We tested your sample as follows;
 Central Heart Rate Monitor with Coded PHY and Peripheral Heart Rate Monitor with Coded PHY
 The test showed that it was not the Coded PHY transmission at the advertising status.
 And then the transmission changed</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 02 Jan 2024 12:33:19 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/106547/zephyr-ble-long-range-advertexample-for-the-nrf52833" /><item><title>RE: Zephyr BLE Long Range AdvertExample for the nRF52833</title><link>https://devzone.nordicsemi.com/thread/462282?ContentTypeID=1</link><pubDate>Tue, 02 Jan 2024 12:33:19 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a7d5add4-4035-4b6e-a48c-f8478376d0e0</guid><dc:creator>Simonr</dc:creator><description>&lt;p&gt;Hi&lt;/p&gt;
[quote user="timyi"]The Heart Rate service is the standard connection, right?[/quote]
&lt;p&gt;I&amp;#39;m not sure I understand what you mean by this question. In the Coded PHY heart rate sample, the heart rate service is indeed the standard service for this sample and uses Coded PHY&amp;nbsp;&lt;strong&gt;after&amp;nbsp;&lt;/strong&gt;connecting.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Can you share some info on what error/failure you see when trying to connect after enabling Coded PHY advertising. You will also need to enable extended/Coded scanning on the central side of the connection for the device to be able to connect successfully. Both devices will need to support Coded PHY both before and in the connection to be able to connect over Coded PHY.&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Simon&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Zephyr BLE Long Range AdvertExample for the nRF52833</title><link>https://devzone.nordicsemi.com/thread/462043?ContentTypeID=1</link><pubDate>Fri, 29 Dec 2023 08:00:09 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a8b6e5f3-74a4-41c4-a3df-e153b816867d</guid><dc:creator>&amp;#216;yvind</dc:creator><description>&lt;p&gt;Hello,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;span dir="ltr"&gt;We are severely understaffed this week because of the Christmas holidays, and Simon will get back to you on this next week. Sorry for the inconvenience.&lt;/span&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;span dir="ltr"&gt;Kind regards,&lt;br /&gt;Øyvind&lt;/span&gt;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Zephyr BLE Long Range AdvertExample for the nRF52833</title><link>https://devzone.nordicsemi.com/thread/461670?ContentTypeID=1</link><pubDate>Tue, 26 Dec 2023 04:36:29 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:50e62750-2f37-479b-a4ea-bf9bef569ae9</guid><dc:creator>timyi</dc:creator><description>&lt;p&gt;The Heart Rate service is the standard connection, right? I thought you mean it was normal at advertising and changed the Coded PHY after it was connected.&lt;/p&gt;
&lt;p&gt;Is there anyway of configuration?&amp;nbsp; we failed the connection after the adverting was ok under the Coded PHY.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Zephyr BLE Long Range AdvertExample for the nRF52833</title><link>https://devzone.nordicsemi.com/thread/460323?ContentTypeID=1</link><pubDate>Thu, 14 Dec 2023 10:18:01 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:b77a39d8-c9de-40a3-a459-fdcfa72886ec</guid><dc:creator>Simonr</dc:creator><description>&lt;p&gt;Hi&lt;/p&gt;
&lt;p&gt;Please check out&amp;nbsp;these cases where &lt;a href="https://devzone.nordicsemi.com/f/nordic-q-a/93939/how-to-configure-primary-advertising-use-phy-1m-and-secondary-advertising-use-coded-phy-when-broadcast-on-the-coded-phy-on-ncs"&gt;what configs to set&lt;/a&gt; and &lt;a href="https://devzone.nordicsemi.com/f/nordic-q-a/79123/setting-throughput-example-for-scan-on-coded-phy-only-and-advertise-on-coded-phy-only/328302"&gt;how to use the bt_le_ext_* functions&lt;/a&gt; is described. You need to enable extended advertising with&amp;nbsp;&lt;strong&gt;CONFIG_BT_EXT_ADV&lt;/strong&gt;=y and&amp;nbsp;&lt;strong&gt;CONFIG_BT_CTLR_ADV_EXT&lt;/strong&gt;=y and you need to use the&amp;nbsp;&lt;span&gt;bt_le_&lt;/span&gt;&lt;strong&gt;ext&lt;/strong&gt;&lt;span&gt;_adv_* function instead of&amp;nbsp;bt_le_adv_start() that can only be used for legacy advertising.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Best regards,&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Simon&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Zephyr BLE Long Range AdvertExample for the nRF52833</title><link>https://devzone.nordicsemi.com/thread/460053?ContentTypeID=1</link><pubDate>Wed, 13 Dec 2023 07:31:40 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8c75b9d2-3d02-42ad-8122-91a68cc08568</guid><dc:creator>timyi</dc:creator><description>&lt;p&gt;Thank you for your reply. Let us have the configurations to the advertising set for the Coded PHY.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Zephyr BLE Long Range AdvertExample for the nRF52833</title><link>https://devzone.nordicsemi.com/thread/459954?ContentTypeID=1</link><pubDate>Tue, 12 Dec 2023 14:17:40 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:4fab4872-85f7-4355-8bb9-db3e40ebd438</guid><dc:creator>Simonr</dc:creator><description>&lt;p&gt;Hi&lt;/p&gt;
&lt;p&gt;Yes, this is the expected behavior. This sample shows how a specific service (the Heart Rate service in this instance) has Coded PHY suppport and can use long range to transmit heart rate values over the Coded PHY. It does advertise and connect over the standard 1MBPS PHY, but it is not a problem to also make it advertise over the Coded PHY with some configurations to the advertising set.&lt;/p&gt;
&lt;p&gt;Simon&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
