<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>PPI Build error</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/107120/ppi-build-error</link><description>Hi, I am trying to increase the TX power of the BT840X fanstel device using the Code provided by Fanstel from the link https://static1.squarespace.com/static/561459a2e4b0b39f5cefa12e/t/650e3ed2ec00f63a711ea532/1695432404882/BT840X-p+Product+Specifications</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Mon, 15 Jan 2024 10:39:19 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/107120/ppi-build-error" /><item><title>RE: PPI Build error</title><link>https://devzone.nordicsemi.com/thread/464136?ContentTypeID=1</link><pubDate>Mon, 15 Jan 2024 10:39:19 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a4694dcd-ada5-4c0a-908a-db352808460b</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;So you are not seeing any improved range when increasing the output from the nRF RADIO from 0 dBm to +8 dBm? Could you provide the layout and schematics for your custom board here or in a private support ticket?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PPI Build error</title><link>https://devzone.nordicsemi.com/thread/463834?ContentTypeID=1</link><pubDate>Thu, 11 Jan 2024 16:28:28 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8552ae9a-852b-4716-8e9d-d0fe25b8b345</guid><dc:creator>Nishith</dc:creator><description>&lt;p&gt;Currently we are trying to communicate between our custom made device with BT840X&amp;nbsp;and a Fanstel Dongle BT840X.&amp;nbsp;We are measuring range indoors now with few walls and also lots of space available for the devices to communicate with each other.&amp;nbsp;The walls are only on&amp;nbsp;one side between&amp;nbsp;the devices and the right side is completely open.&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PPI Build error</title><link>https://devzone.nordicsemi.com/thread/463823?ContentTypeID=1</link><pubDate>Thu, 11 Jan 2024 15:45:00 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:44b973b4-0672-4dd5-a82a-0cd02577e19c</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Which device do you use to scan for the beacon? Is it another board with the same module, or are you using a different device? Is the module mounted on a custom board or a Fanstel DK? And&amp;nbsp;where are you&amp;nbsp;performing these measurements, indoors, or outdoors where you have a clear line of sight?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PPI Build error</title><link>https://devzone.nordicsemi.com/thread/463714?ContentTypeID=1</link><pubDate>Thu, 11 Jan 2024 11:00:18 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:ff8c0a6b-1031-4b55-a1f9-bfee206c3614</guid><dc:creator>Nishith</dc:creator><description>&lt;p&gt;we were able to find the point where the device stops detecting for beacons at 8dBm&amp;nbsp;at 40 meter .&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PPI Build error</title><link>https://devzone.nordicsemi.com/thread/463711?ContentTypeID=1</link><pubDate>Thu, 11 Jan 2024 10:53:50 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:503af24b-c6cf-4d3c-ab55-320a27bfe44f</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;How many meters range are you currently able to achieve, and how are you testing it?&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PPI Build error</title><link>https://devzone.nordicsemi.com/thread/463710?ContentTypeID=1</link><pubDate>Thu, 11 Jan 2024 10:50:01 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:0551d0ed-81c8-4369-a768-a2b33240eda5</guid><dc:creator>Nishith</dc:creator><description>&lt;p&gt;We are using the BT840X device... It can go upto +21dBm.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PPI Build error</title><link>https://devzone.nordicsemi.com/thread/463690?ContentTypeID=1</link><pubDate>Thu, 11 Jan 2024 09:33:40 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:328cef03-1961-4895-bcce-79b4f4e60b23</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;What range are you currently achieving, and which device are you connecting with? The max. TX output power from the nRF RADIO is 8 dBm.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PPI Build error</title><link>https://devzone.nordicsemi.com/thread/463657?ContentTypeID=1</link><pubDate>Thu, 11 Jan 2024 03:43:58 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:dd0d10fc-e64a-4ea7-a0b3-6f01d9fbdeed</guid><dc:creator>Nishith</dc:creator><description>&lt;p&gt;The&amp;nbsp;&lt;span&gt;nrfx_ppi.c was not properly added, so it was causing error. Now I can run it. But still the Device range has not been increased. Where can i set the&amp;nbsp;TX power value for it. i was using&amp;nbsp;BLE_TX_POWER as 8db before... But i cant increase the TX power again which will cause build error.&amp;nbsp;&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PPI Build error</title><link>https://devzone.nordicsemi.com/thread/462915?ContentTypeID=1</link><pubDate>Fri, 05 Jan 2024 13:51:54 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:fdfe68e9-624f-487b-8400-bc6dce5e463b</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;The linker error indicates that either the source file is missing or the preprocessor symbol has not been correctly set. Are you able to upload your project here so I can have a look?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PPI Build error</title><link>https://devzone.nordicsemi.com/thread/462911?ContentTypeID=1</link><pubDate>Fri, 05 Jan 2024 13:44:02 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:0ff4bfc5-fb2e-41a5-b0c1-2a2ffe74240a</guid><dc:creator>Nishith</dc:creator><description>&lt;p&gt;HI,&amp;nbsp;&lt;br /&gt;Yes. I have enabled PPI in sdk_config.h file.&lt;br /&gt;&lt;br /&gt;&lt;img style="max-height:203px;max-width:565px;" height="203" src="https://devzone.nordicsemi.com/resized-image/__size/1130x406/__key/communityserver-discussions-components-files/4/pastedimage1704461282040v1.png" width="565" alt=" " /&gt;&lt;br /&gt;&lt;br /&gt;&lt;br /&gt;Both the&amp;nbsp;&lt;span&gt;nrfx_ppi.c and&amp;nbsp;nrf_drv_ppi.c path has been added.&lt;br /&gt;&lt;br /&gt;In code, we use&amp;nbsp;&amp;quot;nrf_drv_ppi.h&amp;quot; and &amp;quot;nrfx_ppi.h&amp;quot; both as provided by Fanstel here.&lt;br /&gt;&lt;a id="" href="https://static1.squarespace.com/static/561459a2e4b0b39f5cefa12e/t/650e3ed2ec00f63a711ea532/1695432404882/BT840X-p+Product+Specifications.pdf"&gt;https://static1.squarespace.com/static/561459a2e4b0b39f5cefa12e/t/650e3ed2ec00f63a711ea532/1695432404882/BT840X-p+Product+Specifications.pdf&lt;/a&gt;&lt;br /&gt;&lt;br /&gt;Thank you.&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: PPI Build error</title><link>https://devzone.nordicsemi.com/thread/462805?ContentTypeID=1</link><pubDate>Fri, 05 Jan 2024 07:23:07 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:794fd24b-d5eb-4440-b571-99b9546d9f0f</guid><dc:creator>Vidar Berg</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
[quote user=""]&lt;span&gt;I have already enabled the PPI,&lt;/span&gt;&lt;br /&gt;&lt;span&gt;#define&amp;nbsp;NRFX_PPI_ENABLED 1&lt;/span&gt;&lt;br /&gt;&lt;span&gt;#define&amp;nbsp;PPI_ENABLED 1&lt;/span&gt;[/quote]
&lt;p&gt;Did you do this in your sdk_config.h header?&lt;/p&gt;
[quote user=""]&lt;span&gt;The PPI file path has already been added.&lt;/span&gt;&lt;br /&gt;[/quote]
&lt;p&gt;Have you included both the&amp;nbsp;/modules/nrfx/drivers/src/nrfx_ppi.c and the integration/nrfx/legacy/nrf_drv_ppi.c source file in your project?&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Vidar&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
