<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>What command is being used to for &amp;quot;Read&amp;quot; button in nrf Programmer?</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/107733/what-command-is-being-used-to-for-read-button-in-nrf-programmer</link><description>Hi, We are building our customized PCB with other peripherals on it. We figured that if we replug the power supply, then some of the peripherals will stop working. However, if we trigger the &amp;quot;Read&amp;quot; button in nrf Programmer, the peripherals are all working</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 26 Jan 2024 07:25:45 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/107733/what-command-is-being-used-to-for-read-button-in-nrf-programmer" /><item><title>RE: What command is being used to for "Read" button in nrf Programmer?</title><link>https://devzone.nordicsemi.com/thread/466145?ContentTypeID=1</link><pubDate>Fri, 26 Jan 2024 07:25:45 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:f4c20e5c-cfcc-473d-a67b-274cf1657979</guid><dc:creator>Jared</dc:creator><description>&lt;p&gt;&lt;em&gt;&lt;/em&gt;&lt;/p&gt;
[quote user="kc9999"]The failing peripheral is AD5940 and after we manually trigger the reset pin on nrf52382, it works fine.&amp;nbsp;[/quote]
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;I see, so it&amp;#39;s not the nRF52 itself but something external that is not in the correct state after the power cycle.&amp;nbsp;&lt;/p&gt;
[quote user="kc9999"]&lt;p&gt;Is there a function inside nrf5 SDK works as reset pin?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;So that I can reset nrf52382 every time we reboot and wont be stuck in infinite loop&lt;/p&gt;[/quote]
&lt;p&gt;If you&amp;#39;re using the Softdevice then you can use&amp;nbsp;&lt;a href="https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.s132.api.v7.3.0/group___n_r_f___n_v_i_c___f_u_n_c_t_i_o_n_s.html#gad767473c9cfb8cf11c66f048e0d9eb5c"&gt;&lt;span&gt;sd_nvic_SystemReset&lt;/span&gt;&lt;/a&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;regards&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Jared&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: What command is being used to for "Read" button in nrf Programmer?</title><link>https://devzone.nordicsemi.com/thread/466123?ContentTypeID=1</link><pubDate>Thu, 25 Jan 2024 23:26:40 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:3a1c1209-8775-4022-8815-42b648826b39</guid><dc:creator>kc9999</dc:creator><description>&lt;p&gt;The failing peripheral is AD5940 and after we manually trigger the reset pin on nrf52382, it works fine.&amp;nbsp;&lt;br /&gt;Is there a function inside nrf5 SDK works as reset pin?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Edited: specifically, the function or bit manipulation for soft reset:&lt;br /&gt;&lt;br /&gt;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://files.slack.com/files-pri/T061U8F8HPE-F06G2EJL8HX/image.png" /&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/0020.image-_2800_2_2900_.png" /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: What command is being used to for "Read" button in nrf Programmer?</title><link>https://devzone.nordicsemi.com/thread/466026?ContentTypeID=1</link><pubDate>Thu, 25 Jan 2024 13:45:49 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:c6ee6469-f320-435b-af22-e53a43fe96ff</guid><dc:creator>Jared</dc:creator><description>&lt;p&gt;Hi there,&lt;/p&gt;
&lt;p&gt;This sounds very strange, as evident by the log in your screenshot the Read operation performs a reset in the end. Have you tried resetting your device and see if that helps? Have you routed out the reset pin on your custom board?&lt;/p&gt;
&lt;p&gt;Could you specify what peripherals that isn&amp;#39;t working after the power supply and exactly how they are failing?&lt;/p&gt;
&lt;p&gt;regards&lt;/p&gt;
&lt;p&gt;Jared&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
