<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/107734/odd-2-seconds-power-spikes-in-nrf9160-custom-board</link><description>Running the UDP sample from v2.5.1, we are seeing odd power spikes. The happen regardless of whether the modem is in PSM or not. Modem firmware is v1.3.6 and has been flashed several times. This happens in other code that uses the modem is well but is</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 02 Feb 2024 16:29:08 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/107734/odd-2-seconds-power-spikes-in-nrf9160-custom-board" /><item><title>RE: Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/thread/467418?ContentTypeID=1</link><pubDate>Fri, 02 Feb 2024 16:29:08 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:71242f39-e063-47ba-baff-506377106a6b</guid><dc:creator>NautDesigner</dc:creator><description>&lt;p&gt;It does appear this is PSM related based on the SIM.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/thread/466804?ContentTypeID=1</link><pubDate>Tue, 30 Jan 2024 15:36:07 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:42bc624a-3093-41c8-b33c-ae7d1a01b995</guid><dc:creator>Achim Kraus</dc:creator><description>&lt;p&gt;Sorry, that trace is too short, it doesn&amp;#39;t show the registration nor the sending of the message.&lt;/p&gt;
&lt;p&gt;I&amp;#39;m not sure, what you&amp;#39;re searching. If the modem gets PSM agreed on the cellular network, it will go to sleep and the power consumption will got down to a few &amp;micro;A. That&amp;#39;s my experience with a set of nRF9160 based devices.&lt;/p&gt;
&lt;p&gt;If you register for modem events, you will be notified, if the network support PSM and you will get notified, when the device gets sleeping.&lt;/p&gt;
&lt;p&gt;The modem uses usually 3 different phases, RRC Active, RRC Idle, and sleeping, see &lt;a href="https://www.gsma.com/iot/wp-content/uploads/2022/02/2022.03-GSMA-Energy-Efficiency-for-Mobile-IoT-1.pdf"&gt;GSMA - Improving Energy Efficiency for Mobile IoT, March 2022&lt;/a&gt;.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/thread/466803?ContentTypeID=1</link><pubDate>Tue, 30 Jan 2024 15:28:09 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:1ed76a38-825b-49b3-90a8-37a66d33148a</guid><dc:creator>NautDesigner</dc:creator><description>&lt;p&gt;Switching to a single provider&amp;#39;s SIM did eliminate the spikes once but we were still hovering around 1mA.&amp;nbsp;However, subsequent runs show the same behavior.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;&lt;a href="https://devzone.nordicsemi.com/cfs-file/__key/communityserver-discussions-components-files/4/ppk_2D00_20240130T152239.ppk"&gt;devzone.nordicsemi.com/.../ppk_2D00_20240130T152239.ppk&lt;/a&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;&lt;a href="https://devzone.nordicsemi.com/cfs-file/__key/communityserver-discussions-components-files/4/1106.modemtraces.bin"&gt;devzone.nordicsemi.com/.../1106.modemtraces.bin&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/thread/466726?ContentTypeID=1</link><pubDate>Tue, 30 Jan 2024 11:14:55 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:93fe88bf-7c19-4dc5-8f07-c7145e8ec025</guid><dc:creator>Achim Kraus</dc:creator><description>&lt;p&gt;Using LTE-M sometimes ends up in roaming with LTE release 13 without PSM.&lt;/p&gt;
&lt;p&gt;See &lt;a href="https://devzone.nordicsemi.com/f/nordic-q-a/105131/esm-error-code-50-type-ipv4-only-allowed-nrf91-asset-tracker"&gt;ESM Error Code 50: type ipv4 only allowed (NRF91 Asset Tracker)&lt;/a&gt;&lt;/p&gt;
&lt;p&gt;or watch &lt;a href="https://www.youtube.com/watch?v=RZ9QJLt-ZPs"&gt;IoT Creators Days, at 6:23&lt;/a&gt; for the background.&lt;/p&gt;
&lt;p&gt;Some MVNOs have contracts for LTE roaming, which works on base-stations with release 13 also for LTE-M, but it doesn&amp;#39;t provide the power-saving features as PSM. If your SIM is not emitted by the MNO, you need to ask the SIM provider about the details for using this SIM with LTE-M and that MNO/roaming.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/thread/466709?ContentTypeID=1</link><pubDate>Tue, 30 Jan 2024 10:21:21 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:46579ebe-d202-40ee-bdb2-da1ed2a5a040</guid><dc:creator>&amp;#216;yvind</dc:creator><description>&lt;p&gt;Thanks for sharing both. From the modem trace I can see that you are using a roaming SIM. Does the network you are trying to attach allow PSM for roaming SIM?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;CEREG and XMONITOR&amp;nbsp;indicates that you do not have PSM. Please verify spikes with a non roaming SIM.&lt;/p&gt;
&lt;p&gt;&lt;pre class="ui-code" data-mode="text"&gt;00:28:33.023827 L23_AT_STRING AT_STRING &amp;lt;= +CEREG: 5,&amp;quot;6F00&amp;quot;,&amp;quot;01B28602&amp;quot;,7,,,&amp;quot;11100000&amp;quot;,&amp;quot;11100000&amp;quot;
00:28:33.025475 L23_AT_STRING AT_STRING &amp;lt;= %XMONITOR: 5,&amp;quot;&amp;quot;,&amp;quot;&amp;quot;,&amp;quot;311480&amp;quot;,&amp;quot;6F00&amp;quot;,7,13,&amp;quot;01B28602&amp;quot;,184,5230,68,34,&amp;quot;&amp;quot;,&amp;quot;11100000&amp;quot;,&amp;quot;11100000&amp;quot;,&amp;quot;01001001&amp;quot;&lt;/pre&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/thread/466703?ContentTypeID=1</link><pubDate>Tue, 30 Jan 2024 10:03:14 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:8ea2e266-bdbc-47dc-aed4-16692ceebfad</guid><dc:creator>NautDesigner</dc:creator><description>&lt;p&gt;I just took this one. It should be similar to the trace.&lt;/p&gt;
&lt;p&gt;&lt;a href="https://devzone.nordicsemi.com/cfs-file/__key/communityserver-discussions-components-files/4/ppk_2D00_20240130T100158.ppk"&gt;devzone.nordicsemi.com/.../ppk_2D00_20240130T100158.ppk&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/thread/466702?ContentTypeID=1</link><pubDate>Tue, 30 Jan 2024 09:58:47 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:24637929-3160-4196-8d4c-657bc8a993dd</guid><dc:creator>&amp;#216;yvind</dc:creator><description>&lt;p&gt;Could you also please provide the .ppk file?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/thread/466694?ContentTypeID=1</link><pubDate>Tue, 30 Jan 2024 09:40:47 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:808dc7a9-6067-470b-bf9f-cb5de866f230</guid><dc:creator>NautDesigner</dc:creator><description>&lt;p&gt;Other devices are turned off. No LEDs are being used. We are measuring the whole board and submitted a separate, private ticket with schematic where they didn&amp;#39;t see any issues.&lt;/p&gt;
&lt;p&gt;&lt;a href="https://devzone.nordicsemi.com/cfs-file/__key/communityserver-discussions-components-files/4/modemtraces.bin"&gt;devzone.nordicsemi.com/.../modemtraces.bin&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/thread/466662?ContentTypeID=1</link><pubDate>Tue, 30 Jan 2024 07:24:09 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:28120c17-df74-4f01-9cd9-cee63c36c94c</guid><dc:creator>&amp;#216;yvind</dc:creator><description>&lt;p&gt;As this is a custom HW, where to you measure, on the whole board or the device alone? Do you have other devices on the board? Are you using LEDs? Can you please provide a modem trace and logging from the UDP sample (you will need to enable UDP in this case).&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Thank you.&lt;/p&gt;
&lt;p&gt;Kind regards,&lt;br /&gt;Øyvind&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/thread/466612?ContentTypeID=1</link><pubDate>Mon, 29 Jan 2024 19:22:35 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:80b5b41f-9f77-4abd-bbe3-9abdfa7b2ed5</guid><dc:creator>NautDesigner</dc:creator><description>&lt;p&gt;GPS is not being used as the board is nRF9160-SIAA. Also, after review, the spikes are every 1.28s. CEREG does return that the device is in PSM mode. This is tested with a modified UDP sample enabling PSM.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" alt=" " src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/8463.time.png" /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/thread/466004?ContentTypeID=1</link><pubDate>Thu, 25 Jan 2024 13:02:54 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:5e676920-679d-47e1-9faa-68f9ad689645</guid><dc:creator>&amp;#216;yvind</dc:creator><description>&lt;p&gt;Hello,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Yes, what &lt;a href="https://devzone.nordicsemi.com/members/achimkraus"&gt;Achim Kraus&lt;/a&gt;&amp;nbsp;points out is correct. Are you able to test with AT Client and see what&amp;nbsp;CEREG returns?&lt;/p&gt;
&lt;p&gt;Kind regards,&lt;br /&gt;Øyvind&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Odd 2 Seconds Power Spikes in nRF9160 Custom Board</title><link>https://devzone.nordicsemi.com/thread/465993?ContentTypeID=1</link><pubDate>Thu, 25 Jan 2024 12:38:12 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:50a8680f-b943-4eef-8e5c-80a45502503d</guid><dc:creator>Achim Kraus</dc:creator><description>&lt;p&gt;Every 2s or every 2.56s?&lt;/p&gt;
&lt;p&gt;For the later (2.56s) I guess, your network simply doesn&amp;#39;t support PSM, therefore it doesn&amp;#39;t make a difference, if you try to enable it or not.&lt;/p&gt;
&lt;p&gt;Do you use GPS? That also consumes energy, but in my experience, that doesn&amp;#39;t cause such 2s peaks.&lt;/p&gt;
&lt;p&gt;Are you able to apply that firmware to a nRF9106-DK? That may exclude also you hardware as source of the peaks.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
