<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Use I2S or PDM input/output with nRF5340</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/107869/use-i2s-or-pdm-input-output-with-nrf5340</link><description>Hi,
 I want to use I2S or PDM input on nRF5340 gateway and I2S or PDM output on nRF5340 haedset.
 I am using nRF5340 audio DK for my tests.
 I am curently using jack connectors for my test and I want to know where I can connect the I2S signals?
 Is</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Wed, 31 Jan 2024 10:58:18 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/107869/use-i2s-or-pdm-input-output-with-nrf5340" /><item><title>RE: Use I2S or PDM input/output with nRF5340</title><link>https://devzone.nordicsemi.com/thread/466907?ContentTypeID=1</link><pubDate>Wed, 31 Jan 2024 10:58:18 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:2fcf4bb1-2ed8-4ab5-bd97-9b0496c84969</guid><dc:creator>ovrebekk</dc:creator><description>&lt;p&gt;Hi&amp;nbsp;&lt;/p&gt;
&lt;p&gt;The main function of the codec is to handle AD and DA conversion, and if you have an I2S sound source you should be able to connect it directly to the nRF5340&amp;nbsp;without having to involve the codec at all.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Unless you want to use some other feature of the codec chip for audio processing?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Passing I2S audio through the codec is not one of the tested use cases for the Audio DK, but I will check with the developers if there is a way to enable this.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Is your external I2S device configured in master or slave mode? What is the audio settings?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Best regards&lt;br /&gt;Torbjørn&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Use I2S or PDM input/output with nRF5340</title><link>https://devzone.nordicsemi.com/thread/466791?ContentTypeID=1</link><pubDate>Tue, 30 Jan 2024 14:51:32 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:0c072a2d-a909-420d-8eb3-5992429fcbbe</guid><dc:creator>JJ_N</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;I want to use the codec on the audio DK. I have already configured the software to use the jack input (with AUDIO_SOURCE_I2S config) but I want to input an I2S signal instead of an analog one. I don&amp;#39;t know if it is possible and if yes where to connect my external I2S signals ?&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Best regards&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Use I2S or PDM input/output with nRF5340</title><link>https://devzone.nordicsemi.com/thread/466783?ContentTypeID=1</link><pubDate>Tue, 30 Jan 2024 14:35:13 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:ba93e42e-2c35-4259-9d89-dfb6b7cb8b6d</guid><dc:creator>ovrebekk</dc:creator><description>&lt;p&gt;Hi&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Are you planning to use the codec on the audio DK, or you want to connect an external codec through I2S?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;To enable I2S on the gateway side you have to use the AUDIO_SOURCE_I2S config as described &lt;a href="https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/nrf5340_audio/doc/configuration.html#selecting-the-analog-jack-input-using-i2s"&gt;here&lt;/a&gt;.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;On the headset side&amp;nbsp;using I2S output should be the default, and no additional configuration is necessary.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Regarding connecting an external codec to the external I2S pins there is some information in this case:&lt;br /&gt;&lt;a href="https://devzone.nordicsemi.com/f/nordic-q-a/93800/access-to-i2s-interface-on-nrf5340-audio-dk"&gt;Access to I2S interface on nRF5340 Audio DK&lt;/a&gt;&lt;/p&gt;
&lt;p&gt;Best regards&lt;br /&gt;Torbjørn&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
