<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Asset tracker v2 won&amp;#39;t connect to nRF cloud</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/108003/asset-tracker-v2-won-t-connect-to-nrf-cloud</link><description>Hi!
 I want to start working with the thingy:91 I got. I want to test the asset tracker v2 application. I successfully programmed the thingy via the Cellular Monitor. I&amp;#39;m currently in Switzerland and I&amp;#39;m using a sim card from IoT Creators.
 When I power</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 09 Feb 2024 14:17:33 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/108003/asset-tracker-v2-won-t-connect-to-nrf-cloud" /><item><title>RE: Asset tracker v2 won't connect to nRF cloud</title><link>https://devzone.nordicsemi.com/thread/468242?ContentTypeID=1</link><pubDate>Fri, 09 Feb 2024 14:17:33 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:c904ece2-e862-4570-ac29-ab1116ce2a55</guid><dc:creator>Didrik Rokhaug</dc:creator><description>&lt;p&gt;Thanks.&lt;/p&gt;
&lt;p&gt;Unfortunately, it doesn&amp;#39;t look like the trace captures the issue.&lt;/p&gt;
&lt;p&gt;While I can decode it fine, and can see a lot of AT commands being sent, I can&amp;#39;t see the device connecting to a network and try to connect to nRF Cloud.&lt;/p&gt;
&lt;p&gt;Could you try to capture another trace, where the connection attempt to nRF Cloud is included?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Asset tracker v2 won't connect to nRF cloud</title><link>https://devzone.nordicsemi.com/thread/468129?ContentTypeID=1</link><pubDate>Thu, 08 Feb 2024 18:57:09 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:51586c98-a569-44dd-808a-9ecb5cd307e1</guid><dc:creator>woutervhoof</dc:creator><description>&lt;p&gt;Here is a modem trace of the program.&lt;/p&gt;
&lt;p&gt;&lt;a href="https://devzone.nordicsemi.com/cfs-file/__key/communityserver-discussions-components-files/4/trace_2D00_2024_2D00_02_2D00_04T09_2D00_46_2D00_55.685Z.mtrace"&gt;devzone.nordicsemi.com/.../trace_2D00_2024_2D00_02_2D00_04T09_2D00_46_2D00_55.685Z.mtrace&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Asset tracker v2 won't connect to nRF cloud</title><link>https://devzone.nordicsemi.com/thread/468018?ContentTypeID=1</link><pubDate>Thu, 08 Feb 2024 09:28:30 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:83447e3a-0a7a-43d8-bc43-79a5ca76fca8</guid><dc:creator>Didrik Rokhaug</dc:creator><description>&lt;p&gt;Can you take a &lt;a href="https://infocenter.nordicsemi.com/topic/ug_cellular_monitor/UG/cellular_monitor/intro.html"&gt;modem trace&lt;/a&gt; so that we can take a closer look at what is happening?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Asset tracker v2 won't connect to nRF cloud</title><link>https://devzone.nordicsemi.com/thread/467792?ContentTypeID=1</link><pubDate>Tue, 06 Feb 2024 16:55:02 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:cd5630ce-2e83-4a7f-b7a2-2710d47cad86</guid><dc:creator>woutervhoof</dc:creator><description>&lt;p&gt;I&amp;#39;m sorry, that&amp;#39;s a typo. I send&amp;nbsp;&lt;span&gt;AT+COPS=1,2,&amp;quot;22801&amp;quot;,9.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;I tried building the software with an older toolchain and it gives me the same results. However, the software built with the older toolchain replies much faster on the AT commands. I see that when observing the serial terminal&amp;nbsp;when I&amp;#39;m using the cellular monitor and refresh the dashboard. I can&amp;nbsp;only see the data changing in the dashboard when using the software built with the older toolchain.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;I used toolchain version 2.5.2 and 2.4.3. Both build configurations and prj.conf are the same.&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Asset tracker v2 won't connect to nRF cloud</title><link>https://devzone.nordicsemi.com/thread/467750?ContentTypeID=1</link><pubDate>Tue, 06 Feb 2024 13:15:57 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:93a95d9a-05dd-4c35-867e-9f418ae09547</guid><dc:creator>Didrik Rokhaug</dc:creator><description>[quote user="woutervhoof"]However, if I send the &amp;#39;&lt;span&gt;AT+COPS=1,2,&amp;quot;22801&amp;quot;,9&amp;#39;&amp;#39; command now, it looks like the controller stops replying on AT commands&lt;/span&gt;[/quote]
&lt;p&gt;It looks like you have a &amp;quot; too much in that command.&lt;/p&gt;
&lt;p&gt;Are you sure the command is correctly formatted?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Asset tracker v2 won't connect to nRF cloud</title><link>https://devzone.nordicsemi.com/thread/467466?ContentTypeID=1</link><pubDate>Sat, 03 Feb 2024 22:35:22 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:888529ee-a239-4cff-990f-dcb2a316c526</guid><dc:creator>woutervhoof</dc:creator><description>&lt;p&gt;Hi Didrik,&lt;/p&gt;
&lt;p&gt;Thanks for the fast answer. As I was using the prebuilt asset tracker hex file, I needed to set up the development environment and build the software with the changes. After two days trying, I managed to get a hex file and flash it to the thingy. However, if I send the &amp;#39;&lt;span&gt;AT+COPS=1,2,&amp;quot;22801&amp;quot;,9&amp;#39;&amp;#39; command now, it looks like the controller stops replying on AT commands. It still gives the usual updates and recognizes button presses.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;+CSCON: 1&lt;br /&gt;%CESQ: 70,3,24,3&lt;br /&gt;[00:00:02.303,985] &amp;lt;inf&amp;gt; app_event_manager: DATA_EVT_CONFIG_INIT&lt;br /&gt;[00:00:02.568,847] &amp;lt;inf&amp;gt; app_event_manager: MODEM_EVT_LTE_CELL_UPDATE&lt;br /&gt;+CNEC_ESM: 26,0&lt;br /&gt;%MDMEV: SEARCH STATUS 2&lt;br /&gt;+CEREG: 2,&amp;quot;10F7&amp;quot;,&amp;quot;01089B08&amp;quot;,7,0,19&lt;br /&gt;+CSCON: 0&lt;br /&gt;&amp;gt; AT&lt;br /&gt;OK&lt;br /&gt;%CESQ: 70,3,19,2&lt;br /&gt;%CESQ: 71,3,24,3&lt;br /&gt;&amp;gt; AT&lt;br /&gt;OK&lt;br /&gt;&amp;gt; AT+CFUN?&lt;br /&gt;+CFUN: 1&lt;br /&gt;OK&lt;br /&gt;&amp;gt; AT+COPS=1,2,&amp;quot;22801&amp;quot;,9&amp;#39;&lt;br /&gt;&amp;gt; AT&lt;br /&gt;[00:00:32.209,442] &amp;lt;inf&amp;gt; app_event_manager: UI_EVT_BUTTON_DATA_READY&lt;br /&gt;[00:00:32.209,686] &amp;lt;inf&amp;gt; app_event_manager: DATA_EVT_UI_DATA_READY&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Wouter&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Asset tracker v2 won't connect to nRF cloud</title><link>https://devzone.nordicsemi.com/thread/467388?ContentTypeID=1</link><pubDate>Fri, 02 Feb 2024 13:43:38 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:e2884620-9ea8-4842-9e4d-97496d6da2bf</guid><dc:creator>Didrik Rokhaug</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;It could be that your network does not support ePCO. Could you try to enable legacy PCO support instead?&lt;/p&gt;
&lt;p&gt;You can enable legacy PCO support by setting these options in your prj.conf:&lt;/p&gt;
&lt;p&gt;CONFIG_PDN=y&lt;/p&gt;
&lt;p&gt;CONFIG_PDN_LEGACY_PCO=y&lt;/p&gt;
&lt;p&gt;If that does not work, could you take a &lt;a href="https://infocenter.nordicsemi.com/topic/ug_cellular_monitor/UG/cellular_monitor/intro.html"&gt;modem trace&lt;/a&gt;?&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Didrik&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
