<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>UART3 Tx Pin is not working after adding DFU - OTA</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/108498/uart3-tx-pin-is-not-working-after-adding-dfu---ota</link><description>Dear support team,
 We are encountering a problem, ie, UART3 Tx pin is not working after adding DFU, We used Example, mcuboot_smp_ble_simultaneous to add DFU over BLE Simultaneously. We are using bellow mentioned peripherals in our project.
 1. UART0</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 08 Mar 2024 10:23:51 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/108498/uart3-tx-pin-is-not-working-after-adding-dfu---ota" /><item><title>RE: UART3 Tx Pin is not working after adding DFU - OTA</title><link>https://devzone.nordicsemi.com/thread/472902?ContentTypeID=1</link><pubDate>Fri, 08 Mar 2024 10:23:51 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:1ea00f5c-8108-4b94-9783-5b53ae595cbf</guid><dc:creator>Kazi Afroza Sultana</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&amp;#39;&amp;#39;That means we need to modify our original pin configuration, right?&amp;#39;&amp;#39;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;For Netcore, these Pins are used for RTS(P0.11) and CTS(P0.10) pin. So, yes. If you want to use thee for other pin you have to add overlay file for these.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&lt;/span&gt;You can look at this devacademy course&amp;nbsp;&lt;a href="https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-3-elements-of-an-nrf-connect-sdk-application/"&gt;https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-3-elements-of-an-nrf-connect-sdk-application/&lt;/a&gt;&amp;nbsp;to know more about this.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: UART3 Tx Pin is not working after adding DFU - OTA</title><link>https://devzone.nordicsemi.com/thread/470605?ContentTypeID=1</link><pubDate>Mon, 26 Feb 2024 06:24:54 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:175d13d1-9481-47bd-8df4-b2e976fb29cd</guid><dc:creator>Krishnachandran_a</dc:creator><description>&lt;p&gt;Hello Kazi,&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
[quote userid="108933" url="~/f/nordic-q-a/108498/uart3-tx-pin-is-not-working-after-adding-dfu---ota/470515"]You can try to use different pins which are not used for specific peripherals.[/quote]
&lt;p&gt;That means we need to modify our original pin configuration right?&lt;/p&gt;
&lt;p&gt;Is there any documentation regrding this issue?&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Additionally, could you kindly clarify whether the boot loader still controls these pins (P0.10, P0.11, and P0.19) even after we disable?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: UART3 Tx Pin is not working after adding DFU - OTA</title><link>https://devzone.nordicsemi.com/thread/470515?ContentTypeID=1</link><pubDate>Fri, 23 Feb 2024 17:54:20 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:913981c7-8fe9-4c04-beb4-bd651de68e65</guid><dc:creator>Kazi Afroza Sultana</dc:creator><description>&lt;p&gt;Hello Krishna,&lt;/p&gt;
&lt;p&gt;You can try to use different pins which are not used for specific peripherals.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: UART3 is not working after adding DFU</title><link>https://devzone.nordicsemi.com/thread/470141?ContentTypeID=1</link><pubDate>Thu, 22 Feb 2024 05:15:19 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:fec335b7-a881-43cd-bef4-c1b37825a867</guid><dc:creator>Krishnachandran_a</dc:creator><description>&lt;p&gt;Hello Kazi,&lt;/p&gt;
&lt;p&gt;Thanks for the update.&lt;/p&gt;
[quote userid="108933" url="~/f/nordic-q-a/108498/uart3-is-not-working-after-adding-dfu/470097"]Can you show me the error log of your application?[/quote]
&lt;p&gt;Actually, there is no particular error code, We probed that particular pins observed that that is not working.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Thanks,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Krishna&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: UART3 is not working after adding DFU</title><link>https://devzone.nordicsemi.com/thread/470097?ContentTypeID=1</link><pubDate>Wed, 21 Feb 2024 18:27:01 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:748b46c2-d708-4f7d-a21c-229d5240cdd2</guid><dc:creator>Kazi Afroza Sultana</dc:creator><description>&lt;p&gt;Hello,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;When the interface MCU receives a&amp;nbsp;&lt;a title="A control signal in RS-232 serial communications transmitted from data terminal equipment, such as a computer, to data communications equipment." href="https://infocenter.nordicsemi.com/topic/ug_nrf5340_dk/dita_common/glossary/glossary.html#dtr"&gt;&lt;dfn&gt;Data Terminal Ready (DTR)&lt;/dfn&gt;&lt;/a&gt;&amp;nbsp;signal from a terminal, it performs automatic&amp;nbsp;&lt;a title="A handshaking mechanism used to prevent an overflow of bytes in modems. It uses two dedicated pins on the RS-232 connector, Request to Send and Clear to Send." href="https://infocenter.nordicsemi.com/topic/ug_nrf5340_dk/dita_common/glossary/glossary.html#hwfc"&gt;&lt;dfn&gt;Hardware Flow Control (HWFC)&lt;/dfn&gt;&lt;/a&gt;&amp;nbsp;detection.&amp;nbsp; CTS flow control provides an indication to the host to stop sending serial data to the device. RTS flow control allows the host to signal the device to not send data in the serial transmit buffer out the UART&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;UART flow control pin is optional. But here you are using pin numbers what has already been used for other peripherals.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;img style="max-height:240px;max-width:320px;" src="https://devzone.nordicsemi.com/resized-image/__size/640x480/__key/communityserver-discussions-components-files/4/pastedimage1708536747713v1.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;This is from devite tree file of app core.&lt;/p&gt;
&lt;p&gt;You can create overlay file if you want to use same pins for&amp;nbsp;&lt;span&gt;SPI2 CS(P0.11) and MOSI(P0.09).&amp;nbsp;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Can you show me the error log of your application?&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Thanks.&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;BR&lt;br /&gt;Kazi&lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
