<?xml-stylesheet type="text/xsl" href="https://devzone.nordicsemi.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Bluetooth MESH - Out of network buffers/Out of beacon buffers</title><link>https://devzone.nordicsemi.com/f/nordic-q-a/108847/bluetooth-mesh---out-of-network-buffers-out-of-beacon-buffers</link><description>We have on a few occasions experienced &amp;quot;Out of network buffers&amp;quot; and &amp;quot;Out of beacon buffers&amp;quot; errors occuring on nodes in a mesh network, but are unable to figure out what has caused these errors and are unable to reproduce the errors.
 When the error</description><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Tue, 12 Mar 2024 09:57:07 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://devzone.nordicsemi.com/f/nordic-q-a/108847/bluetooth-mesh---out-of-network-buffers-out-of-beacon-buffers" /><item><title>RE: Bluetooth MESH - Out of network buffers/Out of beacon buffers</title><link>https://devzone.nordicsemi.com/thread/473382?ContentTypeID=1</link><pubDate>Tue, 12 Mar 2024 09:57:07 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:d6761231-724e-49dc-8b5b-e228515bad40</guid><dc:creator>AHaug</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;Do you see the same behavior with the SoftDevice Controller instead of the Zephyr controller? If not, then we recommend you use our SoftDevice controller instead as it is the supported controller for NCS and the only controller we use for testing and verification.&lt;/p&gt;
&lt;p&gt;Also, in case you didn&amp;#39;t know this already, the Zephyr controller is not qualified by anyone and if you want to use the Zephyr controller in your product you will have to go through qualification of the controller on your own. The SoftDevice controller is qualified from our end.&lt;/p&gt;
&lt;p&gt;Let me know if changing the controller resolves the behavior you see.&lt;/p&gt;
&lt;p&gt;Kind regards,&lt;br /&gt;Andreas&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Bluetooth MESH - Out of network buffers/Out of beacon buffers</title><link>https://devzone.nordicsemi.com/thread/473203?ContentTypeID=1</link><pubDate>Mon, 11 Mar 2024 13:37:02 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a81ddc2c-7a03-489e-a461-73377b18d4a3</guid><dc:creator>AHaug</dc:creator><description>&lt;p&gt;Hi Henning,&lt;/p&gt;
&lt;p&gt;Thank you, I will add this info to the internal ticket and I&amp;#39;ll keep you updated with any activity&lt;/p&gt;
&lt;p&gt;Kind regards,&lt;br /&gt;Andreas&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Bluetooth MESH - Out of network buffers/Out of beacon buffers</title><link>https://devzone.nordicsemi.com/thread/473197?ContentTypeID=1</link><pubDate>Mon, 11 Mar 2024 13:32:14 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:3a84f2d6-8ff6-4b69-9c12-9bef767bc4d1</guid><dc:creator>Henning_I</dc:creator><description>&lt;p&gt;Hi,&amp;nbsp;&lt;/p&gt;
&lt;div&gt;
&lt;div&gt;&lt;span&gt;CONFIG_BT_CTLR_ADV_EXT&lt;/span&gt;&lt;span&gt;=y&lt;/span&gt;&lt;/div&gt;
&lt;/div&gt;
&lt;div&gt;
&lt;div&gt;&lt;span&gt;CONFIG_BT_EXT_ADV&lt;/span&gt;&lt;span&gt;=y&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;
&lt;div&gt;&lt;span&gt;CONFIG_BT_MESH_V1d1&lt;/span&gt;&lt;span&gt;=y&lt;/span&gt;&lt;/div&gt;
&lt;div&gt;Using zephyr controller.&lt;/div&gt;
&lt;div&gt;&lt;/div&gt;
&lt;div&gt;System A:&amp;nbsp; sdk 2.4 (error have occurred several times)&lt;/div&gt;
&lt;div&gt;The sink-node, on which the &amp;quot;Unable to allocate beacon buffer&amp;quot; occurs, subscribes to a group address&amp;nbsp; where data from the sensing nodes are published. The sink-node also occasionally publishes to another group to which the sensing nodes are subscribed. Messages are 8 bytes or less (which I assume is sent as unacked-messages).&lt;/div&gt;
&lt;div&gt;System B: sdk 2.5 (error occurred at least once)&lt;/div&gt;
&lt;div&gt;The sensing node, on which the &amp;quot;Out of network buffers&amp;quot; occurred, sends 8 bytes unacked unicast messages.&lt;/div&gt;
&lt;div&gt;Regards,&amp;nbsp;&lt;/div&gt;
&lt;div&gt;Henning&lt;/div&gt;
&lt;/div&gt;
&lt;/div&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Bluetooth MESH - Out of network buffers/Out of beacon buffers</title><link>https://devzone.nordicsemi.com/thread/473105?ContentTypeID=1</link><pubDate>Mon, 11 Mar 2024 08:22:54 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:a4880ae1-feac-4581-96ec-116d04ceac3e</guid><dc:creator>AHaug</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;Update:&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Could you answer the following questions:&lt;/p&gt;
&lt;ul&gt;
&lt;li&gt;
&lt;p&gt;Are you using extended avertiser or legacy advertiser?&lt;/p&gt;
&lt;/li&gt;
&lt;li&gt;
&lt;p&gt;Are you using the SoftDevice controller or the Zephyr controller?&lt;/p&gt;
&lt;/li&gt;
&lt;li&gt;
&lt;p&gt;Are you running with &lt;code&gt;CONFIG_BT_MESH_V1d1=y&lt;/code&gt; or not?&lt;/p&gt;
&lt;/li&gt;
&lt;li&gt;
&lt;p&gt;Are you using acknowledged or unacknowledged messages? Unicast or group addressing?&lt;/p&gt;
&lt;/li&gt;
&lt;/ul&gt;
&lt;p&gt;Another update from the developers&lt;/p&gt;
[quote user=""]are unable to figure out what has caused these errors and are unable to reproduce the errors.[/quote]
&lt;p&gt;The developers are unable to reproduce this error. They have tested by sending more than 100k messages with the mentioned 2 second interval over the weekend. No error has occurred yet. Since neither they nor you are able to reproduce the error, it makes it a bit difficult to figure out what the problem actually is. If you have any other details or findings that you may believe is relevant to reproducing the behavior and&amp;nbsp;&lt;/p&gt;
&lt;p&gt;The observation you&amp;#39;ve made is not something the developers have seen before, so we will move the project from initial investigation to a bug report and investigation will continue from there.&lt;/p&gt;
&lt;p&gt;As mentioned, please let us know if you have any other findings or details that we can use.&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Kind regards,&lt;br /&gt;Andreas&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Bluetooth MESH - Out of network buffers/Out of beacon buffers</title><link>https://devzone.nordicsemi.com/thread/472477?ContentTypeID=1</link><pubDate>Wed, 06 Mar 2024 13:23:58 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:c05c12ee-ce50-4076-a908-a5f5cc6f2eea</guid><dc:creator>AHaug</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;We&amp;#39;ve created an internal inquiry to investigate if this is a bug. I will let you know when the developers have found anything and if you don&amp;#39;t hear back from me within a week or two, feel free to remind me&lt;/p&gt;
&lt;p&gt;Kind regards,&lt;br /&gt;Andreas&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Bluetooth MESH - Out of network buffers/Out of beacon buffers</title><link>https://devzone.nordicsemi.com/thread/471836?ContentTypeID=1</link><pubDate>Fri, 01 Mar 2024 14:37:42 GMT</pubDate><guid isPermaLink="false">137ad170-7792-4731-bb38-c0d22fbe4515:dc2726ca-4a52-4c71-abe8-42222887ea7c</guid><dc:creator>AHaug</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;I&amp;#39;ve picked up your case and will be looking into your inquiry next week. I&amp;#39;ll hopefully get back to you within Wednesday, and I&amp;#39;ll update you if I&amp;#39;m unable to do it by then&lt;/p&gt;
&lt;p&gt;Kind regards,&lt;br /&gt;Andreas&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
