nRF54L15 (NCS 3.2): Excessive current consumption on UART30 when CONFIG_LOG_MODE_IMMEDIATE=n
nrf54L15 ncs upgraded from 3.0 to 3.2
CONFIG_SERIAL=y
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_LOG=y
CONFIG_LOG_BACKEND_UART=y
&uart30 {
status = "okay";
zephyr,pm-device-runtime-auto;
&uart30_default {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 0)>;
group2 {
psels = <NRF_PSEL(UART_RX, 0, 1)>;
bias-pull-up; };
&uart30_sleep {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 0)>,
low-power-enable;
The minimum power consumption is 155uA. When changed to CONFIG_LOG_MODE_IMMEDIATE=y, the power consumption can reach 4uA. When CONFIG_LOG_MODE_IMMEDIATE=n, the power consumption is normally 4uA in NCS3.0. Starting with NCS3.2, the serial port seems to be unable to enter low power mode.
  • It is not that I no longer need the UART; rather, I would like it to function as it did prior to SDK 3.0—outputting logs via the serial port whenever there is log activity, and subsequently entering a low-power mode once the log output is complete.
    I have gone through an old case which ((+) Interrupt-driven UART doesn't work with PM_DEVICE_RUNTIME - Nordic Q&A - Nordic DevZone - Nordic DevZone)shows when CONFIG_PM_DEVICE_RUNTIME is set , it may break some drivers after changing NCS version changed. I am not quite sure that could be the issue for  keeping peripheral constantly enabled by UART driver/ logging backend.
    So setting CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=n can make it assure that it's not enabled in the application.
    Also you want to keep the serial terminal. You can try the following configs
    # This is for Logging
    CONFIG_LOG=y
    CONFIG_LOG_MODE_DEFERRED=y
    # System power management
    CONFIG_PM=y
    CONFIG_POWEROFF=y
    # Device PM; this is the major part where you need to unset the SHIM config
    CONFIG_PM_DEVICE=y
    CONFIG_UART_ASYNC_API=y
    # for serial output
    CONFIG_SERIAL=y
    CONFIG_CONSOLE=n
    CONFIG_UART_CONSOLE=n
    You can omit adding the UART device suspend code I said before.
    Can you try this and measure the current and let us know?
    Thanks.
    BR
    Kazi
