When I try to assign pins to the CAN120 peripheral this is not posible, in the devicetree under pins it states: "this node has no pins" which seem unfortunate for an CAN peripheral......
how do I assign pins to the CAN120 peripheral ?
You have to use the pinctrl stuff in order to assign pins in the dts overlay.
The can120 node should already have pins assigned when using the dk board - or you can use its dtsi files as an example.
