## Environment
- Reflector: nRF54L15 DK
- Firmware: pristine NCS v3.3.1 `ras_reflector` sample
- Board target: `nrf54l15dk/nrf54l15/cpuapp`
- Extra configuration: `android_ranging.conf`
- Initiator: Samsung Galaxy S26+ (`SM-S947U`, device `m2q`)
- Android: 17 / API 37
- nRF Toolbox: 4.4.0 (`versionCode=26080501`)
- The phone was kept at least 0.5 m away when pairing and starting ranging.
## Pristine build command
```text
west build -p always \
-b nrf54l15dk/nrf54l15/cpuapp \
-d C:\ncs\v3.3.1\build_ras_reflector_android_nrf54l15dk_official \
C:\ncs\v3.3.1\nrf\samples\bluetooth\channel_sounding\ras_reflector \
-- -DEXTRA_CONF_FILE=android_ranging.conf
Relevant values verified in the final `zephyr/.config`:
```text
CONFIG_BT_BONDABLE=y
CONFIG_BT_SETTINGS=y
CONFIG_SETTINGS=y
CONFIG_NVS=y
CONFIG_BT_RAS_MAX_ANTENNA_PATHS=2
CONFIG_BT_CTLR_SDC_CS_MAX_ANTENNA_PATHS=2
CONFIG_BT_CTLR_SDC_CS_NUM_ANTENNAS=1
CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
CONFIG_BT_CTLR_SDC_CS_EVENT_LEN_DEFAULT=5000
Controller information printed by the DK:
```text
SoftDevice Controller build revision:
fc 51 7a e9 58 2c 6f fb
6d 35 9f 17 3e 08 c8 c1
7b e9 5b 95
Firmware: Standard Bluetooth controller Version 252.31313 Build 1865177321
HCI: version 6.3 (0x11) revision 0x301f, manufacturer 0x0059
LMP: version 6.3 (0x11) subver 0x301f
## Reproduction
1. Flash the pristine v3.3.1 build above.
2. Clear the bond on both the phone and DK, then pair again using nRF Toolbox.
3. Select Channel Sounding and start ranging with Frequency set to Infrequent.
4. Keep the phone more than 0.5 m from the DK.
## Result
The ACL connection, RAS discovery, CS capability exchange, CS config creation, and CS security all succeed. `LE CS Set Procedure Parameters` also succeeds. The following `LE CS Procedure Enable` fails with `INVALID_LMP_OR_LL_PARAMETERS (0x1E)`.
Android reports the expected remote capability values:
```text
remote_num_antennas_supported: 1
max_antenna_paths_supported: 2
The effective procedure parameters are:
```text
connection interval: 24 units (30 ms)
tone_antenna_config_selection: 1
preferred_peer_antenna: 1
PHY: LE 1M
max_procedure_duration: 1600
min_procedure_interval: 1000
max_procedure_interval: 5000
max_procedure_count: 0
min_sub_event_len: 1250
max_sub_event_len: 2000000
Config creation completes with:
```text
mode: 2 (PBR)
mode_0_steps: 2
channel selection: Algorithm #3b
ch3c_jump: 2
T_IP1: 145 us
T_IP2: 145 us
T_FCS: 150 us
T_PM: 10 us
channel map: 0x1FFFFFFFFFFFFC7FFFFC
The failure event contains no selected schedule:
```text
LeCsProcedureEnableComplete {
status = INVALID_LMP_OR_LL_PARAMETERS(0x1e),
state = DISABLED,
tone_antenna_config_selection = 0,
selected_tx_power = 0,
subevent_len = 0,
subevents_per_event = 0,
subevent_interval = 0,
event_interval = 0,
procedure_interval = 0,
procedure_count = 0,
max_procedure_len = 0
The DK UART log stops after `CS security enabled`; no ranging result is generated.
## Additional isolation tests
The following changes were tested one at a time and produced the same `0x1E` result:
- `max_procedure_count`: `0` -> `1`
- Frequency: Infrequent and Normal
- `CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT`: `7500 us` -> `5000 us`
- Procedure ranges `1000-5000 ms` and `500-1000 ms`
The same phone running nRF Toolbox can discover and connect to another Galaxy S26+ advertising through our internal Android test app, complete Channel Sounding, and produce distance results. Separately, both nRF Toolbox and our internal Android initiator app fail against the nRF54L15 DK at the same HCI stage.
We also tested an NCS v3.4.0 SDC build (HCI revision `0x3039`, SDC build revision `c8da3098...`) and observed the same `0x1E` result.
## Questions
1. Is there a known Channel Sounding interoperability issue between the Samsung Android 17 Bluetooth controller and the nRF54L15 SoftDevice Controller at `LE CS Procedure Enable`?
2. Does the all-zero `LE CS Procedure Enable Complete` payload indicate that the local Samsung controller rejected the procedure before schedule negotiation, or can this status/payload also represent rejection by the remote SDC?
3. Is there any SDC trace or vendor-specific diagnostic command that can identify which LL parameter caused `0x1E`?
4. Are `1 antenna / 2 antenna paths` and effective `tone_antenna_config_selection=1` the expected combination for the nRF54L15 DK in this Android use case?
5. Is there a newer SDC library or pending fix that should be tested for this Samsung interoperability case?
## Related DevZone discussions
- Channel sounding android nRFtools, only works when frequency set to infrequent.
- devzone.nordicsemi.com/.../cs-procedures-never-start-after-cs-security-enable-channel_sounding_ras_reflector-stuck-on-nrf54l15dk-with-android-17-pixel-10-nrf-toolbox-v4-3-2
- Channel Sounding Not Working with nRF Toolbox App and nRF54L15-DK
Due to our corporate security policy, I cannot upload attachment files to this public ticket. I have included the relevant configuration and sanitized log excerpts directly in the description. I can provide additional specific values or excerpts upon request.
