I created software and flashed successfully to the nRF54L15-DK. It is to toggle an LED on and off on P2.09.
I selected nrf54L15dk/nrf54l15/cpuapp for board target under build configuration in VS Code. The LED blinks on and off. Good.
I then connected a custom board with an nRF54L10 to the nRF54L15-DK via P19 connector SWD lines. The software again is the same, toggling an LED on and off, but on P0.00. It is flashed successfully to the nRF54L10.
P19 Signal nRF54L10 custom board
1 SWD0_VTG 3.0 V VDD
2 SWD0_SWDIO SWDIO
3 SWD0_SELECT GND
4 SWD0_SWDCLK SWDCLK
5 GND GND
6 SWD0_SW0 Leave unconnected
7–9 NC Leave unconnected
10 SWD0_RESET nRESET
I selected nrf54L15dk/nrf54l10/cpuapp for board target under build configuration in VS Code.
I have checked:
- SWD wiring is correct.
- The custom nRF54L10 is powered at VDD = 3V.
- NRESET is high (3V) i.e. nRF54L10 is not in reset mode.
- Flash contains a valid application.
- The CPU is running.
- Programmed the custom board, not the DK.
I use nRF Connect SDK and toolchain 3.4.1 LTS
Why the LED does not blink on P0.00?
